View Full Version : Intrepid
- Tranny Cooler lines
- Transmission problems
- ALT / PS belt change
- Help! 96 ES dies when shift into gear.
- Take a look at my website
- Help - Ignition lock jam
- Questions on modifications to my 1997 Intrepid
- 3.3L Intrepid Engine Interchangable?
- 01 with a knocking noise
- Fuel pump?
- 2004 intrepid starter makes grinding noise during start
- troble code p 0551
- Blinker trouble
- all kinds of parts for sale for 99 Intrepid
- code 11
- Ignition problem?
- Error code P0172
- 2001 Intrepid R/T Wiper Switch?
- No speedometer
- Infinity System
- Vibration Passenger Front (96 Intrepid)
- Door locks -- 1996 Intrepid
- Stereo 1996 Intrepid
- 97 intrepid - Blower resistor replacement ( How/Where)?
- Where is Camshaft Position Sensor in 04 Intrepid SXT?
- Timing chain tensioner changed now will not start.
- replacing egr valve on 3.5 97' Intrepid
- looking for 04 Intrepid Body Kit
- 99 Intrepid hiccups/stalls when tank full
- 94 Intrepid probs
- dodgeintrepid.net
- wiring diagram
- 99 trunk release schematic
- Code 72 (Cat Conv Failure) on 1997 Intrepid 3.5L
- glazed over headlights, 99
- 97 3.5 Intrepid code 21 & 17 -??
- Won't Start
- 96 Intrepid electronics
- How to replace the blower motor on 93
- fuel filter on a 98 Dodge Intrepid
- Trouble codes for all Intrepids 1993-2004
- 94 Intrepid strange transmission....
- crooked intrepid
- 1996 Dodge Intrepid blown start/run fuse under hood
- whiper problems
- Prevention and Solution Questions for 99' 2.7l INTREPID
- how do i take off air cleaner??
- Headlight bulb replacement
- 1997 Dodge Intrepid - Where is the EGR valve located?
- 2000 Intrepid - 2.7 L - Running Cold
- Class Action Suit against Chrysler
- missfire detected in cylinder six on a 3.5L
- replace infinity amplifier
- 2004 Intrepid Stall and Check Engine Light
- 2001 Intrepid R/T stalls when slowing down
- Headlights
- Spark plug wires
- i need code help
- 2000 Intrepid engine stalls when turning right!
- Intrepid 2.7 to 3.2 swap
- oil light won't go out
- 02 Intrepid ES heating system sucks!
- 02 Intrepid ES Auto tranny woes
- 2000 Dodge Intrepid , Help
- Power Loss on Acceleration and check engine light!
- Intrepid electrical problem
- brakes
- Dash Lights
- check engine light
- 1997 intrepid will not spark or trun over
- Suspension question
- how do i install new turn signal flashers in a 1993 dodge intrepid?
- Does anyone know about the radio antena?
- Short Circuit
- trunk stuck
- Infinity Amplifier location
- 1994 Intrepid Radiator fans wont come on
- HELP!!! CLAMP & CRANK SENSOR
- 99 Intrepid - Convert Kilometers to MPH
- 99 Dodge Intrepid in wreck
- 2.7 owners
- '98 Intrepid has intermittent start problem
- possible bad fuel pump
- On the freeway going 0mph
- car battery??
- 95' 3.5L Interferance engine?
- having problems
- I have a 98 intrepid and interior blower wont stop
- 97 Intrepid Cold Start Problems Help!!
- map light bulb???
- Brake Lights on 2000 Intrepid
- Intrepid will not go into gear until warm
- what's your idle speed???
- cold tranny
- my bad tranny
- Can't get 1999 Intrepid out of park!
- Does anyone know how to program the keyless entery for a 94-95 dodge intrepid?
- The truth about oil
- 1998 Intrepid won't start
- electrical diagram someone???
- '96 trep 3.5L T-Belt
- windows wont defrost
- Tranny
- 2.7 dodge intrepid class action lawsuit
- 99 Dodge Intrepid 2.7 misses at idle
- radio removal/installation
- Starting Problems
- oil pressure light
- Infinity-right side good,left side bad ???
- Intrepid won't start $#@*&%&!
- Leaking
- Too much torque?
- My Intrepid Problem
- Engine stall when slowing down
- 2002 Intrepid
- 02 Intrepid needs new tranny.
- low fuel, air bag, gear indicator ligth coming on, no reazon
- intrepid 97 3.5 ltr
- 1997 Intrepid Blower not working, blown fuse
- 1997 intrepid radiator --- does it have a drain
- 93 Intrepid wont run????
- Parking Brake Indicator Light Problem
- 96 Intrepid Won't Start
- 1998 CV Joint replacement problem???
- Standing up against Dodges Intrepids
- need performance?
- need new rotors 2002 intrepid
- nos?
- won't start
- dodge stoped intrepid
- 2.7 conversion to a 3.2
- mod for dodge help me
- Starting Problems
- Shrunken window seals
- Transmission Problems
- need head for '95
- 1998 Dodge Intrepid smokes...
- 2.7L Engine Issues - Transmission too
- noise when pressing x
- Intermittent shuddering while driving
- tranny out in 96' intrepid
- New with a few questions...
- Haze on inside of windshield
- convincing it to start,or trying to
- Electrical Problem in 95
- 1993 Intrepid powers out
- CA: Looking for a 99-00 Intrepid, $50.
- Dealer turned off my auto door locks
- '94 Intrepid won't start
- 2000 intrepid Chirps
- How reliable are the mid-late 90's Intrepids?
- i hear a clicking while driving
- 1993 Intrepid Trans / Computer Trouble
- Intrepid problems
- intrepid performance
- 1994 Intrepid for sale! 77000 miles! $400
- '99 Dodge Intrepid - Speed Senor(s)
- transmission problem
- Reset to Engine Computer?
- 2000 Intrepid initial problems - please help
- A/C Problems, 99 Intrepid
- 99 Intrepid Idle Speed
- Engine Control Fuse Short
- Change of 1996 Intrepid battery
- oxygen sensor
- 95 Intrepid 3.5L died - won't restart
- Front Brake pad replacement
- Intrepid 3.3L // no power at fuel pump
- replacing battery cable on 97 intrepid
- 1999 Dodge Intrepid 2.7 Engine Diagram
- '95 Intrepid ES 3.3L Fans run continously
- 1999 intrepid overheats - replaced everything so far.
- Engine shutdown
- 2 of 6 coils are bad
- 2000 Intrepid starting problems?
- 1996 Dodge Intrepid brake problems
- someone with a 99 intrepid, please help
- 2.7l
- Smoking intrepid. Tips?
- 97 keeps blowing park light fuses
- help changing the battery on 1997 intrepid?
- locked myself out..
- intermittent door lock problem
- no start
- 2.7 1999 intrepid "BLOWED ENGINE AND ANYTHING MESSED UP THREAD"
- hard to shift into gear
- Intrepid Rear Noise at higher speeds
- Mold in ventilation system
- intrepid tranny pros
- My 1997 Dodge is over heating
- keyless remote for 1998 intrepid es
- Installing 3rd party Remote Start
- Spark Plugs
- Shouldn't this be warranty work?
- Programming keyless entry remote for a 2002 Intrepid SE
- Please Help! My '95 Dodge Intrepid Is Overheating
- '01 R/T has mushy brakes
- AC causing engine to overheat?
- Will a 2002 Dakota radio/cd player fit my 2001 Intrepid?
- Undercarriage Clicking
- air conditioning problem
- 1997 turn signal issue
- Left Wheel Hub on 94 Intrepid
- Rack Bushings How-To
- Squeal from front passenger wheel (possibly brakes)
- Stereo Volume
- Auto Climate Control = POS???
- 2000 Intrepid 2.7 swap to 3.2?
- Relay for my transmission
- How To Change The Battery On 2000 Intrepid
- keyless remote entry programming
- What is Dodge going to replace the Intrepid with?
- EGR Valve
- 96 trepid brakes
- electric trunk release ?
- Low Pressure Light Comming On???????
- got a knock in the front end when turning
- 94 intrepid fans problem
- Taking out stock Stereo
- What Next!?!?!?
- Unknown Engine Shutdown Problem - Help!
- 2001 Dodge Intrepid gas filter????
- how hard to change the steering rack on a 93 interpid
- Do you know of any good magazines for backyard mechanics?
- ignition cylinder - 96 Dodge Intrepid
- For Sale 1997 Dodge Intrepid
- anybody experiencing problems with no oil pressure at idle - new rebuilt engine?
- 98 Intrepid Starter Problems?
- If only I knew what was wrong...
- 94 Dodge Intrepid steering locks when air conditioner on
- Installing new cd player. need help
- limp mode cause and effect
- Keyless entry option ?????
- Chrysler Infinity Amp wiring diagram
- How to find out if my fuel pump has stopped working.
- Scratched up door plastic
- Can a 3.3 replace 3.5 engine?????
- running hot?? help!!!!! 97 dodge intrepid 3.5L
- Looking for a Chrysler/Dodge CD player
- '94 Eagle Vision Tsi - BIG PROBLEMS!
- putting a 318 into one , is it a good idea?
- HELP windshield wipers posessed!!!!!!!!!
- 95 Intrepid Radiator Fan woes!!!!!
- 89 Spirit with questionable issue
- 1999 Dodge Intrepid WONT START NOTHING
- rev limiters
- keyless remote 96 Eagle Vision
- how to get the most out of 2.7 litter
- easiest and best way to fix scratches and small rust spots
- rear speakers sound bad? why?
