View Full Version : Intrepid
- 1999 Dodge Intrepid Antifreeze?
- 93 intrepid blower not working
- 94 intrepid power goes down
- 2003 Intrepid overhead light problem
- 95 intrepid cooling fans
- 95 Intrepid won't start
- 1997 Transmission 3rd and 4th gear going...
- 2000 Intrepid Dash Removal
- CV Joints on 2000 Intrepid
- Electric window relay???
- 1999 Transmission taking a coffee break?
- dodge 1994 intrepid transmission problems
- no gauges are working
- 1995 Intrepid ES Heater Control won't turn on
- 99 Dodge Intrepid
- '99 intrepid fuel delivery issue
- Tranny Problems
- 2000 dodge intrepid
- 2002 Dodge Intrepid Overheating Only with Air On
- 1995 Intrepid- Code 32
- headlight replacement
- over heating 1996 Dodge Intripid
- 94 Won't Start, Ign. Fuse Keeps blowing
- Part # for 98 Intrepid keyless entry remote?
- Air Conditioning HELP
- Special tool for A/C condenser?
- Gas Pedal Vibration
- Need Help With 94 Intrepid Please!!!!!!!
- front vibration over 55 only when accelerating
- 2000 intrepid fuel gauge indicator
- 96 Intrepid Back Up Light Problem
- A/C compressors for intrep
- AMP problem
- 96 3.3L Slight stutter?
- Oil Coming Out Of Oxygen Sensor
- intake manifold gasket
- 2002 intrepid wont start after 20-30 mile drive.
- gonvoer on a 97 3.5 dodge intrepide
- '94 Concorde Won't shift out of low
- 94 Dodge Intrepid not idling
- 02 Intrepid NO A/C
- 97 with some probs
- Check Engine Light
- 99, intrepid heater problems
- 94 A/C not working...
- Speed sensor location
- 94 intrepid 3.3L stals from stop only when hot!!
- Air Bag "Door"
- Blinker Problems
- Engine knock
- Oil Presure Light Flicker at idle
- 96 jumper cables backwards. whats broken?
- 97 intrepid w/ some type of electrical problem
- dent in bumber
- 200,000 on 2.7?
- Replacing manual AC with ATC
- 97 Intrepid: Electrical Problems
- Engine hesitation while at a stop
- 1996 3.3L Starting Problem
- programming keyless entry remote for a 2001 intrepid
- Have Trans Problem
- Timing belt bent valves on my 95 Eagle Talon
- Engine noise in my 95 Dodge Intrepid 3.3L
- car wont start
- 2004 Intrepid Driver window falling off track
- Door Speakers
- A poll for Intrepid owners. Like or dislike
- 95 Intrepid stereo
- rear end conversion on dodge intrepid
- please help
- code
- Need advice on 2001 with 2.7
- 94 dodge intrepid tranmission problem i think
- 93 transmission problems
- blinker lights
- 96 intrepid blower only directs to windshield
- intreped for sale, but it has a broken tranny, how much $$$
- engine code help needed
- 2000 Low Idle
- 97 Intrepid wont start
- 2.7 engine stalling / rough idle
- 99 cooling fan problem
- A/C Compressor electrical
- Replacement stereo
- 97 Dodge intrepid tranmission
- how to remove airfilter housing on 99 intrepid
- Hot Intrepid
- Metal To Metal
- Changing a '98 intrepid starter
- Intrepid 2.7 conversion to 3.5.....HELP
- Cooling fans
- Overheating at highway speeds
- 94 Intrepid Transmission Problem
- Lucas Transmission fix for 95
- Engine noise
- Battery light engine dieing.
- starting problem 1995 intrepid
- 1998 Intrepid Transmission Question
- 2003 dodge intrepid stereo wiring problems?
- belts
- 1999 Plymouth Voyageur
- washer fluid light
- Car is DYING need help asap
- 98 Intrepid - Stereo/CD - No Volumn
- Oil light flashes on 2001 Intrepid
- Top Speed On 95 Dodge Intrepid?????
- door locks and window motors
- hood release cable
- auto idiot (me) needs help re starting/electrical
- Wondering
- 1999 Dodge Intrepid (2.7L) A/C problem
- Changing 2.7 to 3.2
- keyless 1996
- 96 intrepid dies sometimes and will not start
- Never Know when its gona Die
- 2001 Dodge Intrepid ES, good deal?
- Starting Problems '99
- Car Cuts Off And Engine Light Is On
- 96' Dodge Intrepid Check Engine Light
- 99 Intrepid Won't Start
- 97 intrepid stalls PLEASE HELP!!!!!!!!
- Transmission Noises
- Cruise Control Not Setting
- Airbag Sensor in 95 Intrepid?
- trunk lock
- 94 Intrepid starting problem
- 2002 Intrepid Side Mirror Switch Help
- 97 Intrepid 3.5 L Stalls Intermittently
- Cooling Question
- abnormaly high idle in park!!!!!!
- A/C not cold
- 2000 intrepid want start
- 2000 Dodge intrepind engine ?
- 2002 Intrepid A/C Blows cold on drivers side only
- Power windows on 96 Intrepid
- 94 Intrepid
- Exhaust Leak?
- 96' Intrepid "ELECTRICAL"
- There should be a recall on 2.7 engine
- break & air bag lights stay on
- Help! problem with check engine light trasmission codes
- 2002 Intrepid electrical (blower and overhead lamps)
- Knocking noise when hitting breaks
- PCV Valve in 2001 3.5L Intrepid
- 2001 Intrepid
- 2003 dodge keyless entry
- Engine surges
- 3.5 stalls when stopping
- Intrepid Suspension problem....i think...
- adding keyless entry
- Interchangability of Speedometer (i.e., Custer) Assemblies for 2000 Intrepids
- 1997 Steering wheel catches fire
- Possible solution to make Chrysler fix 2.7 engines
- Overheating Problems?
- 3rd to 4th gear slippin'
- 2004 Intrepid ES - General Opinion
- 2001 Keyless Entry
- question about shifting gear
- intermittent starting problem
- fuel pressure
- Intrepid 95 cruise control not working
- Inner Tierod Bushings
- Air Bag light -- '96
- 2000 Intrepid - Blue Smoke, Oil Light
- Hood struts don't work
- Crashed My Intrepid Have Questions
- How to remove front bumper Intrepid 95
- Repairing Magnetic Pick up
- 2004 dash lights
- Wanted Intrepid w/blown motor
- 96 intrepid
- How difficult to replace timing chain -2.7?
- check engine light
- 1998 Dodge Intrepid 3.2L Engine Problems
- 2000 Int wont start, running out of options...
- Intermittent electrical problems
- How Do You Repair A Dashpanel With A Blown Airbag
- 2000 Intrepid - Dash Panel - Main Wiring Harness - P04759892AB
- A Silly Question: Break Fluid
- need help buying
- Won't start, flickering lights
- My dodge intrepid 99
- Help
- 1995 Intrepid fans runs all the time. Anyone help?
- 1997 keyless remote
- What is the procedure to read / clear the Check Engine light on 96?
- 1997 intrepid inquiry
- 99 intrepid engine switch 2.7 to 3.2
- 95 intrepid ES trans problems
- 00 Intrepid knocking
- BCM trouble
- Turn Signals
- Intrepid stalls on highway
- 96 Engine Surges
- question about tires
- Voltage problems
- Blower Motor always on.
- Trouble Code Help
- Engine Trouble
- Screaming 02 Trep
- Help Sick trep
- Remote Radio Switch '01
- Whistle/squeal with throttle when cold
- electric -blowing fuses.
- '96, R. Front thumps bad on bumps.
- What will fix this?
- 96 tranny acts funny cold
- Is This Normal???
- Battery, Alternator or starter?
- headlight replacement in a '93 Dodge Intrepid
- Need help replacing passenger mirrors
- 02 ES heat and A/C air STINKS!!!!!!!!!!!!!!
- Body Control Module Switch
- Have 1994 Intrepid for parts complete.
- Reverse problem on '93 Intrepid
- 95 dodge intrepid is stalling
- Informative Material
- oil light coming on 2001
- "LIMP MODE" 93 intrepid
- 94 Intrepid - Air bag light, A/C, and more
- need a 3.2L engine
- 99 Intrepid Oil Pressure Problem Need Help
- 98 intrepid starting problem
- '93 control arm won't budge
- Door Locks for a 94 are they hard to change
- 2002 3.5L Stalling Problem
- 93 screwy trany
- 99 Intrepid keyless entry control box
- 42LE Transmission
- Flasher Replacement
- 93 Noisy Doors
- 99 Intrepid TDC for Timing Chain Replacement
- 2000 intrepid dying
- headliner
- communication erros
- Intrepid Belt and Hose Change
- 96 Intrepid computer problems
- Super Nice '02 Intrepid R/T for sale
- Flickering dash lights
- waterpump on 99 intrepid
- changing a stereo for a 97
- 94 intrepid hard down shifting
- Intrepid 2000 engine light just came on
- stereo removal 2000 Intrepid
- '97 Intrepid transmission problem
- 99 intrepid Timing Chain Problem
- 1999 Intrepid Heater a/c fan resistor location
- Here we go again. Error codes 1694 and 1391
- How to check fuel pressure
