View Full Version : Intrepid
Pages : 1 2 [3] 4 5 6
  1. 95 intrepid very hard to steer
  2. Correct air pressure
  3. Problems with 99 Intrepid *shocker I know* please help
  4. Need help-2003 Intrepid Valve Body Replacement
  5. Spark Plugs
  6. so does anyone agree with me?
  7. rattling noise on my 95 intrepid 3.3L?
  8. 1997 Dodge Intrepid Trouble Code 122155 or 22155?
  9. 2001 Intrepid, 2.7
  10. 01 with vibration at 60 mph
  11. 2 Wtf's
  12. An ABS problem with my 1997 Intrepit ES
  13. I think I messed it up
  14. Interference Engine?
  15. Step on brakes, trunk unlocks. '99 Intrepid
  16. Tranny problem/hard shifting
  17. Help, Intrepid quit working!
  18. Engine stalls after replacement
  19. 2000 Dodge Intrepid 2.7
  20. tranny
  21. oil question
  22. 94 Intrepid brake lights and more
  23. Help! Codes 1684, and 0455
  24. Help! Codes 1684, and 0455
  25. Help! Codes 1684, and 0455
  26. Can't shift out of Brake.
  27. HELP Transmission
  28. Warning light cluster going nutz!
  29. 1997 3.5 dodge intrepid
  30. HELP!!! We have NO Idea what to even call it!
  31. Problems after remote programing
  32. pcm #`s
  33. smells like cow manure
  34. 1996 Intrepid light unit
  35. 94 Intrepid sporadically stalls
  36. driving me crazy
  37. Where are my speed sensors located?!?
  38. '01 engine swap...no start.
  39. O2 Sensor / Catalytic Converter
  40. Only 2 days till Christmas
  41. Engine Light
  42. changing engines in an intrepid
  43. Electrical problem oil light on but nothing on dash
  44. Overheating due to passanger side fan?
  45. 99 Intrepid fans won't come on
  46. How to set timing on 2.7L
  47. Coolant leak, no idea where.
  48. blowing engine control fuse
  49. still problems?
  50. Dodge Intrepid, water in oil
  51. A question I forgot to ask
  52. 1996 Intrepid Surging
  53. Dodge Intrepid Switched Engine Promblems
  54. 1996 intrepid stereo repair
  55. Engine ticking.
  56. installing after market stereo
  57. High/low speed fans
  58. A Question?
  59. 2001 intrepid rear seat removal
  60. Right side headlamp
  61. 2000 witrh 2.7 engine stalls and won't restart
  62. I need help.........
  63. no one seems to know answer
  64. 1999 Defroster Fan Noise
  65. alarm system
  66. 98 intrepid hesitates
  67. 97 intrepid 3.5l start and stall
  68. A Interesting Problem...
  69. Water pump? 97 Intrepid 3.5
  70. Blinker Problem
  71. 95 intrepid squealing after new plugs & wires!
  72. alarm ??
  73. 99 intrepid alarm system
  74. 2000 dodge intrepid egr valve
  75. Replacing Driver Side Mirror?
  76. 1997 Intrepid Auto door locks
  77. Dodge Intrepid Guages Dont Work
  78. 93 Intrepid ES stalling problem
  79. Trouble codes....
  80. Front End Clunk
  81. 2000 Dodge Intrepid Idles low and stalls...
  82. Engine Swap?
  83. solenoid pack
  84. Need help in aligning the timing chain in the Inteprid 2.7 engine
  85. Priced Paint Job
  86. Breaks?
  87. 99 Oil Leak
  88. 2000 dodge intrepid heater and air conditioner problem.
  89. 94 Intrepid Acceleration Noise
  90. 2004 Dodge Intrepid Engine Light & Oil Light
  91. 1999 2.7L w/Broken Timing Chain
  92. 94 3.5 tcm
  93. 2001 Intrepid SE auto door locks
  94. it starts with a bad miss and wont keep running
  95. odd idle problem
  96. transmission
  97. 95 3.5 tranny problem, Suggestions needed
  98. Need new brake pads... any suggestions?
  99. 98 Intrepid intermittent problem with headlights
  100. 94 intrepid
  101. My winshield wiper light won't turn off someone help please
  102. 2001 Rear Turn Signal Bulb
  103. 2001 Intrepid - Transmission slow to engage when cold
  104. how do i remove speed governor on 94 Intrepid
  105. 97 3.5 dodge intrepid
  106. red fluid leaking?
  107. Wheel Cover Noise, 2002 Dodge Intriped
  108. 1996 Intrepid Won't turn off..?? HELP??!
  109. swap a 2.7 engine in 2001 intrepid whith 2.7 2004 seabring
  110. green transmission fluid
  111. Down shifting problem
  112. Just a follow-up
  113. Remove Rear Door Panel on 2000 Intrepid
  114. 2.7 noise...
  115. 3.2 wont start when warm
  116. Parting Out 95' Intrepid
  117. Deisel sounding motor
  118. Just bought a 95 dodge intrepid..QUESTIONS!! Help
  119. Do intrepids fall apart at higher miles?
  120. starter replacement problems
  121. 94 intrepid electrical problem
  122. head lights and fog lights dont work but all others do how can I fix this?
  123. Parts age
  124. Intrepid dies
  125. oil light flickering when at running temp
  126. temp gauge
  127. 95 Intrepid electrical probs
  128. timing belt, cam sensor, transmission fuck what is it now!!!!!!!
  129. 95 Intrepid limp in update, more questions
  130. strut replacement
  131. 99 Intrepid ignition problems
  132. Strange RPM problems...
  133. 98 intrepid won't start
  134. Flush or not to Flush?
  135. 94 Intrepid lights on
  136. 95 intrepid chronic intermittent lip in
  137. 1999 oil light
  138. Intrepid Transmission Interchangability
  139. Air conditioning recharge
  140. Just a quick question intrepid not starting.............Please help!!!!!!!!!!!!!!!
  141. 96 trans stuck in second gear
  142. Idle Air Control Sensor and Stalling
  143. 94 tranny
  144. front end trouble
  145. Air filter box tube?
  146. bcm computer
  147. 99 starter and radio
  148. new to Dodge
  149. 95 intrepid won't start cold
  150. clunking noise
  151. 97 Intrepid Parking Brake Adjustment.
  152. Heater Help!!!
  153. 95 intrepid electrical
  154. 99 Intrepid Starting Issues....
  155. intrepid 1999 3.5 engine/1997 3.5 swap
  156. Transmission
  157. 98 Intrepid
  158. no heat
  159. Can I change a rear wheel bearing on 96 Intrepid?
  160. Weird problem keeping my car in gear
  161. 04 Dodge Intrepid
  162. keyless remote
  163. autoshift cable
  164. 1994 Dodge Intrepid dash lights
  165. Child Car Seat suggestions or after market LATCH system kit
  166. 2001 intrepid coolant
  167. '00 Intrepid trunk release problem
  168. I solved the great WTF problem...
  169. 1995 Dodge Concprde
  170. Headlight foglight switch combo?
  171. 1993 Dodge Intrepid Keyless entry
  172. 95 Intrepid ES Stalling Problem, Please Assist
  173. 96 3.3 High Idle
  174. 94 Intrepid
  175. Heat
  176. 96 3.5 Intrepid wont stay running
  177. 1998 Intrepid ES No start
  178. 2.7 timing chain
  179. Starting problem with an added twist
  180. 1998 Dodge Intrepid Starting Problem
  181. Got a GOOD WTF problem here!
  182. 2000 Intrepid error code
  183. 2000 Intrepid 2.7
  184. 2000 Intrepid 2.7 timing chain
  185. Cool weather Thump?
  186. 2001 Intrepid SE
  187. custom fit cd changer
  188. Horn replacement
  189. sudden idle surge
  190. 97 intrepid steering issue
  191. Using oil detergents in 2001 Intrepid?
  192. 94 intrepid blowing fuses again.
  193. 2004 intrepid oil light
  194. Steering
  195. (ABS) (Trac cont) Dash lights on
  196. my dodge
  197. Interior lights won't go off 2001 intrepid
  198. Replace rear blinker in 99 Intrepid
  199. 98 Intrepid 2.7 exhaust smoke from exhaust , not only when being started in the morn.
  200. First Intrepid
  201. Wow!!! I really hate my Dodge
  202. Shifting Problem
  203. 1995 Dodge Intrepid oil pump?
  204. 3.5 L Water Pump
  205. 95 tranny/torque converter
  206. Exhaust
  207. rebuild 2.7
  208. engine diagram for 99 2.7intrepid
  209. loss of compression... oil light on... white smoke
  210. serious problem
  211. radio buzz caused by lights
  212. Power Steering Switch
  213. fuel line routing diagram
  214. 99 Intrepid consuming oil
  215. gas gauge problem
  216. 95 intrepid transmission
  217. 1998 Dodge Intrepid HVAC Blower not working
  218. Drive axle removal
  219. '00 Intrepid trunk release problem
  220. stallin car
  221. `96 Intrepid Tranny Problems
  222. Limp Mode Code #21 Intrepid 95
  223. Check Engine light (Eagle Vision 95)
  224. Where is the CPS
  225. replying
  226. 99 intrepid
  227. starting problems 93 dodge intrepid
  228. '94 Intrepid with accelleration problems
  229. Tune up 4 Eagle Vision Intrepid 3.5, 24Valve
  230. 99 intrepid broken window lift
  231. windshield wiper arms
  232. 1996 Intrepid Overheating
  233. Po605 Code???!!
  234. 2002 Intrepid trunk light
  235. 2000 intrepid for sale
  236. 94 Intrepid Tranny Problem
  237. Transmission
  238. 2002 intrepid tranny
  239. 94 Intrepid won't turn over
  240. Help, Weird Sound
  241. Replace 1999 Intrepid Door Locks
  242. 1994 Dodge Intrepid Blows Radiators
  243. 1997 Cruise Control Problems
  244. 95 tranny problems
  245. 2004 Ingine Light and Engine Dying
  246. 96 Headlight replacement
  247. 1999 Dodge Intrepid Antifreeze?
  248. 93 intrepid blower not working
  249. 94 intrepid power goes down
  250. 2003 Intrepid overhead light problem
