View Full Version : Intrepid
- 95 dodge intrepid, overheating, not starting, leaking...please read
- 2000 Dodge Intrepid ES Trans
- 1993 intrepid shifting problem
- runs then dies... wont start
- Jerky Movements
- Water Pump
- 94 intrepid cruise controls cuts out occasionally
- 97 Intrepid - cranking but not starting - please help!
- 2001 intrepid anti theft
- 2001 Intrepid "P0455" Evap Systems Leak
- Loud Squealing noise
- Traction off and ABS light will not go off
- 94 intrepid has A BUNCH OF PROBLEMS need help!!!!
- '96 Intrpepid 3.3L V6 Issues
- 2000 2.7 quitting while backing up
- engine code P0030
- problems with 96 intrepid...can anybody help?
- 1995 Transmission Woes. Not Limp Mode
- No heat in cabin for first 15 mins.
- OverHeating
- tranny solenoid in 02 interpid wierd
- 97 intrepid climate control problem
- location of solenoid on 2002 interpid
- 2002 tranny issue hellllpppppppppp!!!
- Transmission prob need Help?????
- 98 Dodge Intrepid Rack & Pinion
- 2000 Intrepid 2.7 Leaky injectors?
- Blown Engine in '99
- Need advice on 02 emission problem
- Need advice on what to do next. Video clip inside.
- 96 intreped stalling
- Intrepid 99 overheating with A\C
- Wet carpets when AC on.
- 2001 Dodge Intrepid A/C & Rad/fan problem
- 1996 Dodge Intrepid ES
- 99 ac problem
- keyless remotes wont work
- 1999 Big Engine Swap
- oxygen sensor
- 99 Intrepid-New Engine/No start!!!
- Left/Right bank running lean due to over rich correction factor?
- 96 intrepid problems
- opinion on replacing 2.7 engine
- Almost got in a wreck. Went in ditch and wheel sitting at angle now HELP!
- 1994 Headlight Issues
- 96 Intrepid Issues (Poss. PCM?)
- 94 Climate control problem
- Dodge Intrepid won't start sometimes!
- 2002 Intrepid Speedometer, 7k mileage
- control arms / sway bar
- No engine power
- oil sludge
- intrepid tranny problem
- synthetic oil
- most common problems
- This site ROCKS
- transmission problems
- dodge intrepid
- 1995 Electrical Problems
- 99 intrepid one fan runing one not
- cam pos. sensor
- Intrepid wiring harness
- What are these codes:Po406, Po601? How do I fix them
- A/c And Window Just Quit On Me Today
- intrepid wont shift in third weird looooook
- 96 Intrepid - Tie rod ends
- 99 tranny problem
- 95 Intrepid -Plumes of Gassy Steam!
- 2002 3.5 Police Intrepid question
- does the fans on 95 intrepid run together?
- 93 Intrepid Intermittent Starting Problem
- 2002 Intrepid idling to low
- 99' intrepid A/c issue
- Dodge Intrepid 1999 2.7L AC Recharge
- 1997 Dodge Intrepid 3.3L won't start!! Help please!!!!!!!
- 02 3.5 thermostat question
- rear struts
- Auto Door locks
- Manual Climate control to Auto on 01 Intrepid
- Sudden shift from 4th to 2nd
- 2002 Dodge Problems
- 99 Pesky 1391 Code
- electrical problems
- 1997 Intrepid keeps dieing
- exhaust
- 2002 2.7 P0340
- heater problem
- 2001 3.2 ES Transmission Issue
- 1996 Intrepid does not start
- Help!! p0123 now p0122 99 intrepid
- ABS light
- 2001 R/T - Low idle problem
- Water mixed with Oil Leaking
- Cams won't line up on 95 Intrepid 3.5
- 97 intrepid,2.7 rebuild advise
- 2004 Dodge Intrepid Tranny/Reverse/Motor Mounts
- Are 95 and 96 parts/body parts compatible?
- trouble codes
- 2000 Intrepid 2.7L problem
- pos 3.5 ohc
- Electrical Issues... because I am a moron.
- 96 Intrepid too rich(both banks)
- no luck. hapless. overheating
- 2.7 noise
- 95 intrepid trans locked up
- 2001 Intrepid ES air bag question
- Stripped screw removal
- oil leak
- Front Brake/rotor replacement on '01
- proper spark plug gap for '95 Intrepid 3.3L
- location oil sending unit 2001 intrepid 2.7 l
- - Starter or Solenoid ?
- 95 intrepid- tranny
- '98 emergency lights
- Overheating Catalytic!!
- 2002 Intrepid, tranny, senors gear shift.. so confused
- Rebuilding engine.
- 94 dodge intrepid strange issues
- need help please read inside
- 97 intrepid
- '94 Intrepid Trans Slips/stops Buzzing Noise
- 95 Intrepid trac off and abs lights keep coming on
- 97 code help
- '97 Intrepid gauges turn off intermittently
- Possibly Clockspring
- Doge 97 intrepid reverse lights
- 96 3.5 radiator fans staying on
- 95 Intrepid 3.3L jerks when accelerating
- intrepid/concorde water pump
- Timing belt '98?
- no a/c
- 1995 Intrepid pouring oil
- dash lights
- 96 intrepid engine tap
- 95 intrepid
- 94 Intrepid, no heat
- 2002 Intrepid 3.5 overheat
- not shifting out of park
- Belt Pulley Clicking Sound
- OEM Mopar Aftermarket Parts
- 2002 Intrepid code P0440
- Knock Knock... 2001 3.2L Questions
- 97 3.5 vibrates (shakes) when shifting
- 97 cranks but doesn't start
- 2002 Intrepid Transmission Problems
- HELP!!CAr dosen't start, Raw fuel smell, Puff out of cyl 4!!WTF&^%
- Heater not working properly. 1999 Intrepid
- 99 intrepid help needed
- 02 Intrepid water in floorboard
- thermostat help!
- Extended cranking time 96 dodge intrepid
- 96 Intrepid Front Struts for sale.
- 2002 Intrepid Se Trans question?
- Losing Coolant
- Speedometer Broken
- 96 3.5 Overheating
- 2004 intrepid
- Fan again HELP!!
- So long Trep.......'sniff', 'sniff'....
- need help with fuel pressure
- 94 Intrepid lost it's marbles
- 99' Intrepid oil pressure problem after engine rebuild
- 99 Intrepid Warning Light Blink on and off
- Dodge Intrepid Thermostat help
- 1995 Dodge Intrepid High-pitched Hum
- 96 Intrepid Driver Door Panel
- No Fan....PCM?
- No start 2.7L ...Help!
- No start 2.7L
- 1993 Tie-rod end
- 1993 Tie-rod end
- Intrepid dilapidation
- 2.7 Engine Problems...
- 2000 intrepid, No speedometer, only 2nd gear and reverse
- 2000 Intrepid Heater Smell
- '99 Intrepid ... Burned on $2K rebuilt trans 'cuz speed sensor failed??
- 1999 2.7 coils
- Air bag, ABS Light, Dash Doesn't Work - PCM?
- 2000 intrepid won't move.
- 1996 or 1997 repair/service manual
- Engine knock
- Need Help relacing ignition swtich...
- 94 Intrepid-No guages, runninglights, and limp mode
- 95 Intrepid Wont Start,Cold Weather Killed It
- Signal light stops working at random
- "97 Intrepid gauges drop to 0
- Transmission Locked Up
- 1999 water pump/timing gear question
- 1996 Dodge intrepid 3.3L misfire codes
- 99 intrep brake lights short 911! - 911!
- Code Reader for 1994 Intrepid
- 1994 Dodge Intrepid tail light
- 1999 Intrepid Tranny Swap...I NEED ADVISE!!! PLEASE HELP!
- 1996 Intrepid Tanny
- Just thinking.....Any safe oil additives??
- 98 Intrepid ES, CD Player Fit
- Brake Lights
- 1999 Dodge Intrepid 2.7 water pump
- Heated Catalyst Efficiency Below Threshold
- blend door actuator?
- Engine Swap
- Engine Swap
- Engine Swap
- 96 Intrepid/ leaking gas
- How to turn on Fog Lights
- 1999 Intrepid Electrical Problem
- 94 intrepid keeps stalling
- wont shift out of 2nd
- Dodge 2002 Intrepid problems
- 1993 Intrepid 3.5l not starting..Please Help
- 96 3.5L Fans not running
- Looking at a 2001 Intrepid
- 1999 Evaporator Change
- '97 dodge intrepid lock/unlock switch question
- How to pick intrepid Lock? I lock My keys In
- Wiper Woes on 96 ES
- HELP !!! 1997 Intrepid / car alarm and battery problem
- Need tips on removing alternator from 1999 Intrepid
- 96 Intrepid
- 93 Intrepid No Spark
- Limp mode??
- ABS Problems
- 94 intrepid 3.3 overheating
- 95 Intrepid no reverse??
- 96 intrepid woes
- Coolant leak/ no heat
- error code 12 54 43
- p0700/p1776 Help please
- 98 Intrepid Non-Start
- 2003 Intrepid clock
- What does an input sensor do? Anyone know and have advise?????
- Tranny Help Please!!!!!!!!1
- Code 12 for a 95 intrepid
- 1997 Headlight issues
- 1999 Intrepid lost reverse after a trip to the shop!
- 96 Intrepid woes
- 1995 Intrepid Starting Problems
- 2.7l Thought they were lying
- Two Keys Start My Intrepid
- Intrepid Oil Pump - Help!!!
- 99 Intrepid Help
- Tranny Help plz!
- 2000 Intrepid Tranmission Problem
- ANYONE KNOW WHICH IS THE 3rd CYLINDER ON THE 2.7 I GOT A MISFIRE CODE FOR 3RD CYLIN
- brakes
- Need advice on a 1999 Intrepid
- Front Crank seal on a 3.5
