View Full Version : Dakota
Pages : 1 2 3 4 5 [6]
  1. Neons almost done
  2. Topper for sale!!
  3. 92 Aerostar trans/ no reverse
  4. Hydrostatic drive
  5. 96 dakota for sale
  6. 89 Dakota quits running
  7. heater blower motor
  8. '95 dakota noise
  9. lift kits?????
  10. factory radio wiring dia. '99 dakota
  11. Need a new engine for Dodge Dakota 99
  12. Swaping 5.2 for newer 3.9 Mag or other in 91 Dakota
  13. What is correct tire size on 92 Dakota ?
  14. Actuator for sale
  15. Electrical Short
  16. Not starting
  17. WTB/ straight undented BED for my 92' Dakota
  18. Transmission problem
  19. lift kits
  20. tonneau cover
  21. A/c expansion valve
  22. lifting my dakota
  23. dakota timing chain noise
  24. 1994 5.2
  25. Flickering Headlights
  26. programing keyless entry to my 03 dakota
  27. Radio Help
  28. 4x4 4hi doesnt work and 4low grinds in?...
  29. 99 Dakota tranny slips from2nd to 3rd
  30. 3.9 Mag Distributor drive bushing
  31. 92 dakota code 42 auto shutdown circuit
  32. No Fire
  33. 93 dakota problem
  34. fuel tank
  35. Gas Mileage
  36. Trouble code
  37. Questions about the 98 Dakota
  38. No power to truck at all!!! Please help
  39. Weird shifting i need help
  40. Dakota V8 Governor
  41. Engine Needed
  42. Update On 98 Dakota.......
  43. vigorous boiling - water lost thro overflow
  44. Gas Tank Size in 99 Dakota R/T?
  45. 2001 Quad-Cab Power Lock Problems
  46. 98 dakota.....
  47. 89 Dakota
  48. 89 High Idle Problems
  49. Caliper Bolt Star or Torx What size?
  50. Strange Alarm-like sound when stereo power is on
  51. ABS & Brake lights are on
  52. Wanting to upgrade to stock 4x4 Suspension
  53. Flowmaster or Gibson
  54. 91 sometimes starting...HELP
  55. 00 should i buy?
  56. 91 dakota pick up
  57. Ignition Recommendations???
  58. power but wont start
  59. 1996 Dakota troubles
  60. ticking sound
  61. 1999 Fog Lights
  62. 4 Cylinder Dakota?
  63. i need stereo help
  64. Thinking of buying one, opinions?
  65. My Fog lights are staying on
  66. Tires
  67. back pressure
  68. 2.5L Upgrades?
  69. Dakota Fuel Problem
  70. Dodge dakota CRUISE
  71. 2001 Dakota remote receiver
  72. 2001 V6 Dakota not starting
  73. Dakota Engine Revs unexpectedly
  74. Coolant Smell
  75. where to buy cheap parts???
  76. need advice and or help!
  77. 1988 V6 idle problem
  78. dodge dakota
  79. 95 dakota no power help please
  80. Overflow Tank Leaking
  81. 93 dakots just wont start
  82. What do you think? I want your opinion...
  83. sticking throttle/ high rpm
  84. door locks/ auto. windows
  85. transmission slip/ odometer clicking
  86. 98 dakota 3.9 liter rocker arms
  87. no oil pressure on 2002 dakota
  88. Removing a water pump an a 94 318
  89. FYI about my old 90 DAKOTA
  90. speed and abs sensors
  91. Heater control.
  92. abs sensor
  93. 2000 dakota, how to adjust bands in transmittion?
  94. 1993 Dakota Cowl
  95. Oil Pump Replacement 99 Dakota
  96. headers for my 93
  97. '93 Dakota - Lo oil press @ idle
  98. 1993 Dakota Questions
  99. fs 97 dakota r/t clone
  100. Crankshaft position sensor???
  101. 1992 cruise control repair
  102. Programing Remote Keyless Entry 97 Dakota
  103. OIL SLUDGE in MOST DODGES
  104. Help w/ Auto Door Locks!!!
  105. 5-speed Conversion
  106. 97 Dakota with funny noise
  107. Need help fixin' a 95 dodge
  108. MTX Custom Speaker Enclosure for Dakota?
  109. Removing oil pan to change oil pump??????
  110. Door handles not functioning
  111. v8 swap????????
  112. how do i take a tank off to change fuel tank
  113. 2000 dakota quad 4x4 replacing fuel pump
  114. mark III parts
  115. Engine Ideas
  116. heater core removal on 95 dakota
  117. no spark at coil
  118. dakota odometer
  119. Bug Sheild 4 Sale
  120. factory alum.wheel center cap.
  121. 1990 2.5 Dakota will not start
  122. 2000 Dakota fan blade question
  123. Performance Suggestions
  124. Where can I find
  125. Seat Belt stuck in Latch
  126. 2000 Dodge Dakota
  127. Banks Sidewinder
  128. 93 Dakota 3.9 running prob
  129. Northeast Dakota Sites?
  130. Rebuilt or slightly used transmission.
  131. ac/heater blower fan regulator?
  132. Removing the starter
  133. Viper Seats For Sale! (look if you're willing to spend $$$$)
  134. 98 Dakota cooling system
  135. Next-Gen 4.7 or 3.7/3.9?
  136. 94 Dakota wierd vibe
  137. traction issues with r/t
  138. good deal or bad r/t
  139. Wiring Troubles
  140. Looking for bad points
  141. Difference between 03 and 04
  142. Looking for a set of Dakota Sport Wheels
  143. dakota ?probs?
  144. is this a good deal?
  145. Anti-lock breaks
  146. Stock 360 V8 intake manifold for sale
  147. '91 5.2 stumbles
  148. routing diagram for drive belt
  149. 1993 Dodge Dakota Trouble
  150. Just bought me a 2002 Club Cab
  151. Motor Madness 10/18/03
  152. 02 5.9L R/T AutoTrans trouble
  153. Carseat in extended cab?
  154. just bought a R/T can i get some opinion from longer owners
  155. 4.7L...Are the 2000-2003's all the same??
  156. 1988 Dakota differential parts
  157. Stalling
  158. stupid question. Where is my fuel pump?
  159. 1999 Dakota 4x4 crew cab V8
  160. Battery or Alternator?
  161. 1988 Dakota rear end
  162. Dakota decals
  163. 92-96 engine swap
  164. 3.9L V6 - Cracked Heads
  165. Cracked Cylinder Heads
  166. 2002 Dakota 5.9L dyno Plots
  167. Dash Panels
  168. Used Dakota
  169. intakes, exhaust, and lifts
  170. Straight Pipes
  171. 01 dodge dakota problem
  172. supercharger / ignition / boost retard etc.
  173. high idle after spark plug/cable/distributor cap change
  174. billet grill
  175. Rough Idle
  176. need advice
  177. turbo r/t
  178. 1989 Dakota Sport convertible for sale
  179. Gas Mileage
  180. Spark Plug Failures?
  181. shaking around 40kmh??? 89 Dakota Sport 4wd
  182. Need some mods advice
  183. Buying a 97 Dakota 4x4 xtended cab
  184. No Power!!!!!???
  185. Just bought a new 2002 Quadcab
  186. 99 Dakota Sport Rattle
  187. 2001 Keyless Entry
  188. transmission problems?
  189. Gas tank leaking
  190. for sale
  191. Any good sites?
  192. Code 34
  193. '95 dakota v-6 3.9
  194. engine miss
  195. corrosion keeps Dakota from starting
  196. 4.7L Headers
  197. Dodge Dakota- Need to bulid a hood extension latch due to new installed grills
  198. question about convertor
  199. Dakota Wreck Pictures!
  200. 3.9 and 5.2 reliablity? and other q's
  201. Need a seat for a 93 Dakota
  202. 3.9L headers
  203. 92 V6 Dakota Maintenance Headaches
  204. 1993 Dodge Dakota Problems
  205. Sub-Enclosure
  206. Dodge Dakota Quad Cab offers the best of both worlds
  207. Blue Lights
  208. 1999
  209. 1999 Dodge Dakota R/t V8 Sport
  210. nice custom Durango/Dakota 97 and up rims/tires
  211. New style
