View Full Version : Dakota
- 00 4.7 quad, power steering loses power at low rpm
- 1993 v6 2wd won't start
- '92 Dakota stuttering at highway speeds
- Duel Exhast
- dakota upgrades?
- O2 P0141 & P0161 faults
- 2000 4.7 Dakota Stalls/Stumbles
- Dakota Sport engine miss when weather is cold
- 2000 Dakota Slipping 1st gear
- Fuel Probs
- 04 Radio wiring
- Water Leaking
- Dakota stalling after 15 min
- 97 Dakota 3.9 engine begin to stall
- '98 dakota rearend swap? Help
- 93 3.9 LE blower moter fuse or...?
- brakes?
- 98 hard shift into OD.
- 95 Dodge Dakota
- 1999 dodge dakoto sounds like a disel when idling
- 1999 dakota will not start
- '93 Heater Core
- 1989 Dakota V6 No Oil Pressure
- 1992 dodge dakota transmission
- how to clear engine codes
- 99 dakota intermittent 4-wheel drive
- leaky injectors on tbi
- 97 Dakota electrical problem
- Dads Dakota
- AC Bypass
- Dodge Dakota Starting Problems
- Oh no the tranny
- 92 Dakata with poor breaks
- 94 dakota 3.9 v-6
- FS:Dakota 97-04 Car Cover ClubCab
- 2002 RC Front Spoiler ?
- 99 Dakota turn signal relay problem...
- 2002 window crank
- uh oh
- gotta luv lsd
- dodge dakota 97 water pump
- 1999 Dodge Dakota
- stereo removal
- No P/S to P/S
- 02 dakota, headlight out, a/c prob
- 1999 Dakota Sport
- Wiper motor
- thinking of buying
- 93 dakota 2.5L problems
- 2.2 for a 2.6 out of a minivan
- 92 Dakota, Runs rough when cold
- hard to start in morning
- Dakota Overheating V6
- Starter motor on '89...............
- Hard to Start
- Dakota Sport with a 5.9L engine? Why?
- cd player
- 99 Dakota 3.9 surging problem?
- Dodge Dakota wont start
- 87 Dakota quits running
- Exhaust "humming"
- 95 Dodge Dakota Won't start, Help!!!
- 94 Dakota electrical problem
- terrible brakes
- 4x4 doesn't respond
- Dakota Transmission squeel
- fuel guage malfunction
- 94 Dakota 3.9 Fuel problem
- 1999 3.9L Engine noise/Braking ?
- engine ticking , whining noise 2003 dodge dakota
- stampede
- timing belt diagram
- performance chip
- trouble code
- '92 Dakota won't start
- 96 3.9L Fuel Pump Problem
- 93 Dakota shakes!!! HELP
- 1994 dakota exaust manifold
- Steering problems
- auto shutdown relay
- I am in serious need of help
- how much can the dakota tow?
- Dodge Dakota 2003 4.7l v-8 - Where can I get an ECU upgrade?
- important question
- dodge dakota won't start
- 94 dodge
- Truck Tool Boxes
- 94ish model dakota
- Fuel Pressure Regulator for a 98 Dakota V6
- dodge daykota
- broken doors
- 3.9 rattle
- 2000 Dakota Bolt Problem
- 1989 dodge dakota heater/ a/c
- New Tires
- 94 dakota 2.5l truck doesnt start
- 01 quad cab - mysteriously quits at stop sign
- Ok, new to this forum
- no heat in 97 dakota
- 2001 Dakota Stuck In Low 4x4
- Help! Stranded broke college kid tryin to get home for Xmas '94.... oil problem.
- Service manuals
- 2000 Dakota won't start
- Power locks...location of actuators..Help
- ABS failure?
- 2001 heater core question
- First Dodge, looking for info 2002 stx
- Speaker Removal
- Dakota 200 wont start
- Damn you dakota bolt pattern...
- how much???
- Shaved tailgate and custom bumper
- how much?
- Ssrt?
- 5.2Lv8 Dodge dakota stalling in drive
- Thinking of buying
- 4 Hi Hesitates
- Lighting Problem
- Interior Lights
- Dakota + Ivan = Trouble
- Instrument panel backlight intermittent
- Dakota 3.9L...Looking for help
- 87 dakota bench to buckets????????????
- 98 Dakota idling problem solved - for now
- 2002 Dakota Blower Motor trouble
- Headlights go out...
- 92 dakota not starting
- 96 dakota tranny woes
- engine swap for 95 ?
- buzzing auto door locks
- 98 Dakota won't start
- 98 Codes
- '99 Dakota V6 Coolant/Heating Problems
- Changing spark plugs?????
- Heavily considering an 01/02 Dakota
- 2002 Dakota 2 questions
- HEEEEELLLPPP 93 Dakota 3.9 Magnum Can`t start it
- Battery slowly losing charge.....................
- Spark Knock - '94 Dakota
- Starter motor problem?..........
- 89 no start
- engine stalls when warm
- 2001 Dakota Central Timer Problem
- lookin for an R/T
- Transmission problem
- 2001 Dakota dropped dead
- Lights
- dakota no fuel
- dakota wont start need help asap please!!!!
- did dodge make a 4x4 5.9l dakota 97-04?
- exhaust
- 22" rims
- 91 Dakota
- i got a 90 dodge dakota i think i have trans problem
- 93 dakota problem
- fuel smell out of exhaust
- Tranny
- 1997 Dakota Possible Tranny problem?
- 1990 3.9L Motor Swap
- Differental fluid
- 2001 dakota comp help
- ac/heater control
- hard starting when cold
- power door locks
- ABS Control Mod: need help from the experts...
- turn signals
- Explain Sport +??
- 97 Dakota Wont start
- 93 5.2 computer ?
- '93 Dodge Dakota, 5.2 Magnum, Hard to start when hot.
- replaceing clutch
- looking for performance parts
- Any advice for getting to the factory deck
- 03 dakota cuts out at 95 mph
- 03 dakota with air bag light on
- Brake Rotors
- Idling Problems with 89 Dakota
- voltage regulator in 1989 3.9 V-6
- surging
- Keyless entry remotes
- 93' Dakota V6 Please Help
- 99 Dakota starts hard when it rains
- Grab this deal
- Can I use these tires on my 2002 Dakota?
- No or very little heat
- max speed for 02
- Coolant leaking from passenger compartment on '04 Dakota
- Rattle at 2000 RPM
- 2000 Dodge Dakota loses power and skips
- Driver Side Power Window Repair
- 2000 dakota abs light
- 93 dakota fan fell off!
- My Dodge dakota Review (2002 4.7 4x4 Club cab sport Plus)
- 5.2 Ignition timming
- Oil Change
- ground effects?
- '98 Dakota leaks in rain
- 93 Dakota V6 Running Hot
- Where can i get Valve covers for a 94 3.9L?
- 93 dakota 3.9 magnum wont start
- 99 dodge dakota 4x4 problem
- Engine Replacement
- 93 Dakota suddenly loud. Help!
- 95 4 cyl dakota flips out once a week, dunno
- My 92' Dakota dosen't get spark??? HELP!!!!!
- Magnaflow Exhaust is looking for a So Cal 2004 Dakota RC/SB for Prototyping
- Stalling hot - is mechanic right? Swap ECM?
- Dakota in Canada
- Spark Knock
- 93 dakota wont start
- Engine Pinging after backfire
- 95 3.9 wont start
- Rough Idel
- Leaking tranny fluid
- cabin air drops out when eccelerating whats the fix?
- Drivetrain noise
- Please Help!, Flashing Headlights
- what is a dakota?!
- 00' Dakota: Whats the best Air Intake?
- 95 Dakota A/C & cooling problem
- Dash Kit
- transmission line removal
- mysterious charging problem!!
- What to look for in buying a used R/T? and where can he go to talk to owners?
- peice of snap ring? found in transmission pan
- No Spark 94 2wd Dakota 3.9
- 2000 Dakota overheating
- Dakota Differential Need answer ASAP
- Cutting out
- looking for some chrome wheels for my 98 dakota
- '04 quad cab 4x4
- Oil Warning Light
- Manual to power seat upgrade
- over heating problem please help
- What do you think of this 01 sport
- blower motor not working
- sub box
- 93 5.2L OEM fuel lines or plastic connector to fuel rail
- 91 dakota fule pump relay
- 93 Dodge Dakota Electrical Short
- 93 Dodge Dakota 3.9 A/C problems
- Decisions, decisions!!!
- AC Bypass
- 92 Dakota won't start
- fuel gauge in a 93 dakota 4x4
- Neons almost done
- Topper for sale!!
- 92 Aerostar trans/ no reverse
