View Full Version : Dakota
- 1989 Dakota 4X4 hard Shifting
- Is it possible to turn a 2x4 into a 4x4?
- 96 abs & brake light, air bag light all on
- 99 dakota "clanking" sound
- Wtb
- 94 3.9 manual shift occasional backfires???
- HVAC regulator
- 97 Dakota V6 intermittent problem now permanent
- Power Steering 1999 Dodge Dakota Sport 2wd V6
- Engine Light on
- 03' dakota
- 96 dakota engine swap
- 318 rattle
- 97 Dakota Overheating
- chunks in differential :(
- Dakota has no power and runs rough
- Air conditioning problems
- Dakota TT
- 1998 Dakota SLT
- Looking at a 95 Dakota
- Driver door weld busted
- 1991 dodge dakota v8 fuel problem
- 94 Dodge Dakota V8
- 99 Dakota Overheating
- Just got a badass ride.....
- 5.2l
- 96 dakota
- looking at a 91 dakota....
- 04 quad woofer boxs
- Oxygen Sensor on 318 V-8
- Fuel Gauge Problem
- Getting into doors
- Differential gasket leak
- 98 dakota electrical problem
- Dodge air conditioning cable
- 1988 Dodge Dakota charging problems
- Mudding Preperation and After Care
- How to prime the fuel pump
- 2001 Hesitation/Stuttering
- 98 slt a/c question=
- 90 Dakota Trans Rattle
- Hot front brakes
- who likes the 4.7L
- '01 Dakota lighting problems
- Need Cap/Topper
- Best Air Intake for Dakota
- Thermastat location
- Paint Code?
- Dakota overheats at highway...
- looking at buying a used dakota 1997 or newer
- 2.2 Choke linkage
- Parking Brake Problems
- idle problems when starting engine
- 1997 Fuel Filter
- Replacing Starter
- speedometer and transfer case prob
- Error Code 43
- 2001 Dakota Speed Sensor
- 1987 2.2 Carburator diagrahm
- Carb Ajustment question
- Cab Vent Filter
- Error Code
- 1992 2x4 dakota intermittant engine prob
- It won't stay running
- Size Cap / Topper for 87 Dakota?
- 95 max tire size
- water pump
- 5-spd Shft knob
- 360 heads on 318 block??
- 2001 Dodge Dakota Transmission Wont Downshift
- gas tank
- 3 inch lift kit
- 89 dakota w/ 3.9 v6
- Flasher location? 2001 Dakota Quad cab
- MPG difference
- Homemade Air Intake
- wiring for boat trailer
- Blend Door Actuator Location 98 Dakota
- "96" dakota
- Adding power locks and remote starter...
- 3.9 backfire problems
- My little experiment
- 2004 Dakota Power Steering
- keyless entry
- Ticking Noise
- Cruise control & TCL
- Proper up-keep
- Spark Plugs
- Overheating problems...Help!!
- 11 Mpg??!!
- looking to buy
- Performance exhausts
- Cold Starting Problems
- 03 dakota master power window switch
- New 99 dakota
- Engine Swap
- 99 dakota no spark, no fuel, no bus
- brakes for dakota with v8
- 20's or 22's on a dakota
- 87 Dakota 3.9l Questions
- 2003 Dakota Service Manual
- going green
- 318 fuel system
- Speed Sensor
- 1993 Dakota Fuel Problem
- 1992 5.3 v8 trans no gears when heats up
- 1997 Dakota Drop Kit
- 98 Dakota dash light for 4 wheel drive
- Parking, tail, and dashlights... again
- Parking, Tail, and dash lights
- 92 Dakota Need Help!!!fuel Problem
- 93 dakota brakes
- Belt Questions
- Help I Need Something
- 4cyl Dokota?
- Setting Clock
- '01 4.7 V8 Exhaust leak
- 99 Dakota
- 1995 dode dakota lift kits
- 2000 dakota rear locks and windows acting up!
- motor swap
- 98 Dakota 4X4 ??
- help anyone who knows about car alarms
- 2001 Dakota tranny noise
- 1993 dakota NEEDS TRANS ebay
- Ball joints
- 01 Dak - Overdrive cuts out
- 02 Dakota Quad 4x4 - steering pulls in 4x4
- Cams and Smog Checks
- 95 Dodge Dakota
- Converting from gasoline to lp gas
- hello im new
- Forced Induction
- 93 dakota duel line leak
- look for a motor
- how difficult is white face guage kit to install?
- Brake bleeding problems need help QUICK!!
- HELP! Engine Light, 2000 Dakota V-6
- fuel tank system question
- brake troubles
- 01 dakota limited power when cold
- Problems come in three's..right?
- Lower Control arm
- timeing 3.9 magmum
- Dakota recalls
- 95' Dakota U-Joints
- 99 dakota v6 PCM failed
- timeing
- 99 Dakota Poor Heat
- 1988 dodge dakota ignition lock cylinder
- 2000 Dakota fuel gauge
- 92 dakota 4x4 light question
- Info on r/t daktoa
- 1996 2.5 engine problems
- 1994 Dakota run's like as* plz help me out 3.9 magnum plz help asap (busing sucks)
- taking off Front Bumper
- Can I get better gas mileage?
- 93 Dakota Performance
- Dakota 2000 turn signal shuts itself off
- remove door speakers and kick panel rear
- 93 Dakota Rebuilt Trans Problem
- 1988 Dakota 4-speed auto to 3-speed conversion?
- 1988 Dakota - Equipped as Shipped?
- flushing radiator
- 89 Dakota Running rough.
- 95 Dakota transfer case
- 1990 Dodge Dakota
- 99 Dakota
- '94 Dakota 4X4 Transfer Case Noises
- Instrument Panel Problems
- 93 Dakota Ignition Trouble's ??
- '97 Dakota Front Wheel Bearing
- 91-96 clear taillights on ebay
- 95 dakota transmission problems
- '01 speedometer adjustment?
- RPM Guage not working. Anyone Help!
- Cruise Control Help
- 2000 Driver's Side Heated Mirror
- crank sensor location 91 dakota
- Catalytic Converter Size 96 Dakota V6
- 96 Dakota A/C Problems
- Fan Clutch problems
- '98 Engine Swapping
- engine swap
- 17" Sst Ram Rims 4 Sale
- Locating sensor
- 1998 dakota air conditioning question
- Differentials
- 93 Dakota Turn Signals
- Just got a 92 Dakota doesn't start
- Trans Filter Change
- 2000 Dakota 4x4 with GOODIES...OBO!
- Fuel Filter
- 98 dakota r/t sale $5400.
- looking at buying '98 Dakota 80,000 miles
- 1998 magnum for sale ???
- magnum r/t question-
- FS: 92 Dakota V8 NYC
- 2001 Dakota code P0420
- shifting problems
- Dash warning lights
- Dakota will not start
- 94 Dakota doesn't start
- How much should I sell my 97 3.9L sport ext cab for?
- RPM jumping
- 1991 318 engine
- Engine swap
- How to stop thieves from popping your door lock!!!
- 1988 dakota help
- rattling sound
- 98 Dakota Trouble starting in the morning
- Flip the heater switch and NO air comes out
- 97 dakota brakes
- Dakota R/T...A/C fan speed only 1 & 2. What do I need to replace?
- Help, horn not working in my 93 dakota
- 95 dakota oil leak
- Out of gas with 5 gal in the tank? 95 Dakota V8
- fuel gage
- 97 V6 Rough Idle and Questions
- 1988 dodge dakota
- Intermittent Charging Problem
- 1998 v8 stalling
- idle rpm
- hi i am new have 93 dakota
- 92 Dakota dies and wont start for 5-25 minutes. PLEASE HELP!!
- 2001 dakota 4wd not working
- 93 Dakota No heat
- 93 Dakota door handle
- Steering Column Over Drive Switch
- 99 dodge dakota power loss between 50-60 mph?
- head lights
- EGR Trouble code, 95 Dakota V8
- Fuel system cleaning
- V6 to V8 Conversion
- Not Idling
- How much noise do balljoints make when they need to be replaced?
- coolant leak
- 2006 Dodge Dakota Sport 4.7 Ho Shocks
- 97 Dodge Dakota heat problem
- fuel tank ball thingy
- 1997 Engine Rattle
- 01 Dakota trany probs
- 2001 Dodge Fog Lamps
- Stalling due to Fuel Starvation?
- 91 Kota Jet chip
- Tires/Wheels for 02 Dakota 4X4
- 1993 Dakota - won't start
- 1999 Dakota Heater will not get hot
