View Full Version : Dakota
Pages : 1 2 3 [4] 5 6
  1. 95 blower motor switch
  2. 2002 dakota code p0306
  3. Does fully synthetic plus a little Lucas oil stabilizer work well in the 3.9L?
  4. Looking at buting a 97 3.9L V6 with 300,000kms
  5. Help!!!
  6. mopar pcm
  7. Engine Light
  8. dakota windows
  9. 97 Dakota overheating
  10. coolant loss/no heat
  11. 2004 Dakota 4.7L
  12. replace heater core 93 dakota
  13. Busted output speed sensor
  14. nitrous on 02 4.7
  15. 98 Dakota Electrical Schematic
  16. 00 v6 3.9 will not start
  17. 92 Dakota Lift Kit
  18. Backwards fuel filter ?
  19. nitrous kit on 318 ('96 bodystyle)
  20. 95 4x4 won't shift
  21. electrical/brake problems
  22. 1999 Dakota No Start.. Baffling!
  23. dakota wont start
  24. Automatic light
  25. 2001 dakota headlights
  26. Fuel filter
  27. Interior ac/heater vents
  28. bushings in lower control arm(1998 4x4 v8)
  29. 318 install
  30. 2006 Dakota R/T
  31. Replacing Coolant
  32. 97 Dakota wont start
  33. repair to computer ECM
  34. 95 dakota 3.9 no spark
  35. Dropping out of overdrive ?
  36. 1993 Dakota Blower motor wiring
  37. I want More Power!!!
  38. New DAKOTA questions
  39. 01 Dakota Code Problems
  40. Tire Sizes
  41. dakota needs gas pedal
  42. headlights not working 93 dakota
  43. 95 dakota no spark
  44. strips
  45. Need help finding transmission
  46. 99 Dakota - stalling problems
  47. 2001 Dakota SLT Club Cab
  48. Starting problems
  49. Rear Main seal
  50. Its not xmas yet, but I have lights on!
  51. check this out
  52. mil icon
  53. 4CYL. boost
  54. air bag/heater fan
  55. RPM Surge
  56. BBK 1723 70mm TB
  57. HELP Can't remember how to change headlights 88 dakota
  58. "Updating" 3.9 V-6
  59. front suspension knock on 98 dakota 4x4
  60. 93 Dakota Woes
  61. 2002 Questions
  62. Not starting 97 Dakota Sport, 5.2l (318)
  63. '89 dakota bogging down
  64. 01 dakota headlights
  65. dakota brakes
  66. problem with brake lights
  67. Pull to the right.
  68. 400 horse 318 build
  69. can't figure out overheating
  70. Bypassing A/C pully. Will I still have heat?
  71. When to use overdrive in my Dakota Sport?
  72. AC problems
  73. 1989 Dakota Surges Code 55
  74. 01 Dakota 4x4 squeaks in 4wd
  75. 4.7L TB, Intake Manifold, and Cams
  76. parking brake
  77. dakota takes off w/o me
  78. When I hit the accelerator the truck barely moves
  79. Speedometer not working
  80. 92 Dakota windshield wipers come on and engine stalls
  81. 92 Dakota stalls and has trouble restarting
  82. Netural Safty switch location
  83. Performance exhaust
  84. 95 Dakota No Brake Lights
  85. 2000 Dakota SLT cold start...dies
  86. Performance air intake
  87. factory amp?
  88. Air-Vent selector not working right. (Vacumm Issue?) Help!
  89. Best exhaust for my Dakota
  90. 1995 dakota no spark at coil no fuel 3.9
  91. 97 3.9L Dakota keeps blowing relays?
  92. 1995 ABS & Brake light on
  93. Performance chip
  94. high idle
  95. AMI billet fuel door/nozzle snag?
  96. Lookin to purchase A Dakota
  97. 92 Dakota Maintenance light reset?
  98. CAD slow to engage, '89 4x4
  99. wanting to buy Uhaul type box to fit on dodge dakota
  100. 87 Dakota engine issue
  101. 90 dodge dakota failed emmissions.high nox
  102. '90 Dakota AT won't pull when engine's warm
  103. Neutral safety switch
  104. Tire noise?........
  105. '90 Dak Won't Start when Engine is Warm
  106. '89 High idle when warmed up........
  107. 1993 dakota ignition question
  108. 1992 dodge dakota 4x4 v6 5 speed ?'s
  109. 96 Dakota, small engine, need the 1st. part of the air intake.
  110. 96 Dakota, 2.2L Fuel Injected, no codes no spark, etc.
  111. 90 dodge 3.9 no power at coil
  112. Dakota 6cyl 4x4 battery drained but charged
  113. AC only blows out defrost vents
  114. 2001 Dakota Blower Motor
  115. 2003 Dogde dakoda sport p0456 fault code
  116. 20" rims and tires 4x4
  117. Dodge Dakota P0455
  118. 2001 Dakota 3.9 hesitation and missfire
  119. '98 Dakota Air Conditioning
  120. 95 dakota overdrive
  121. soft brakes
  122. 1997 dakota 2 wheel drive ????
  123. 91 Dakota no spark
  124. Running lights wont shut off
  125. '89 won't start when hot..............
  126. P0505
  127. blown engine
  128. transmission swap?
  129. 87 dakota vapour lock
  130. starter problems
  131. Torque converter/Throttle position sensor
  132. Camshaft position sensor on 00' Dakota
  133. 99' 5.2 v8 wants to overheat
  134. 2000 Dakota wont start.. filter problems?
  135. A/C Problems - '00 Sport
  136. Brake trouble
  137. Just in the morning
  138. Don't know where thermostat is located
  139. missing vacuum hose?
  140. 2002 R/t 5.9
  141. 3.9L Backfiring problem
  142. 1999 Dakota
  143. '89 now working great with "new" ECM but............
  144. Dakota V-6 improvements
  145. v8 swap for my 98 dakota
  146. rear seats
  147. 96-Dakota-Not Getting Spark
  148. 93 dakota radiator problems
  149. a\c compressor jump start
  150. 86 supra wiring diagram
  151. Temp Rising on 00 4.7 Dakota Help!
  152. 89 Starting Problems
  153. 91-96 dakota lift kits
  154. Which gear oil for 03 Dakota V6 4wd 5sp
  155. Dakota Questions
  156. Dakota mileage
  157. carbs
  158. Dakota ???
  159. Radiator ???
  160. 96 Dakota driver door replacement ?
  161. Any 05 Dakota Owners Having Luck Finding Mods?
  162. My New 3mos Old `05 Dakota CC.
  163. Carbon fiber cold air intake
  164. air bags to increase load/ride height?
  165. 93 Dakota intermitent restart problem
  166. need throttle cable for v8
  167. electrical 1999
  168. Hub Assembly Needed!!
  169. Knocking in Front Suspension/RPM Surge
  170. 97 Dakota Heater Core Replacement NEED HELP!!!
  171. Sratring problem bad relay
  172. Brake/Suspension Issues
  173. speed correction
  174. What Motor Oil Should I Use?
  175. Can i fit a 440 in my 1992 Dakota
  176. fuel injectors not working
  177. Power steering oil
  178. Timing chain?
  179. 93 Dakota Heater Fan
  180. Power Outlet Problem '00 3.9L SLT 2Dr
  181. Please .... location of voltage regulator.......
  182. I put in another computer.................
  183. Brake Lights not working
  184. Stalling 1995 Dakota
  185. 2001 dakota electrical problem
  186. Electrical Problem on Dakota 1994
  187. hot after 20 miles or so
  188. Dakota Inner axle shaft seal replacement
  189. 1994 Dodge dakota rebuild
  190. 2000 dakota SLT
  191. No Headlights/Dome light
  192. Motor mount kits?
  193. dakota box swap
  194. Want to sawp my NEW dakota v6.... info on compatible engines...
  195. 97 died now wont start
  196. 92 Dakota.signals Wont Blink-flasher Ok.
  197. just a quick motor question
  198. Squeak in front; Rubbing sound in back
  199. 96 dakota running problem
  200. 1989 V-6 Dakota Won't Start
  201. 04 Dakota Steering noise
  202. Gen 1 engine swaps
  203. Need 2005 Dakota Topper
  204. 2001 dodge dakota air conditon fan contol
  205. Tail gate handle assembly
  206. 1995 Dakota questions
  207. PO 442A Evap Cntr small leek dedected
  208. Help with fuel pump problem
  209. Computer bad?..............
  210. Dakota engine
  211. Reverse tranny skip Dakota SLT 5.9
  212. 97 Dakota dies when first started
  213. 99 dakota blinkers quit
  214. weird problem with warm start and wipers on a 90
  215. 1997 keyless entry troubles
  216. 04 Dakota overdrive problem
  217. raced a ram.....dead even
  218. Vibrations at higher speeds.
  219. Hemi, is it for real?
  220. Key less Entry
  221. inside door handle on 98 Dakota
  222. 94 dakota wheel swap
  223. lift kits
  224. 04 dakota quad/4.7v8 gas
  225. electric fan question on 4.7
  226. Radiator not pulling from reserve tank
  227. Dakota as a daily driver?
  228. My new 05 Dodge Dakota v8 4.8l Limited Edition Special
  229. 2000 Dakota Radiator drain plug location?
  230. What is the best Cat-Back Exhaust for an 01' Ext. Cab 4x4 4.7
  231. 93 Dakota problem
  232. where is the oil sending unit on my 3.9 ??
  233. Will headers hurt anything?
  234. More efficient fan clutch 01'Dakota 4.7
  235. Dodge Dakota '94 Cranks but won't Start
  236. 93 dodge
  237. Coolant leak
  238. oil pressure..or.. no oil pressure
  239. Where is the fuse for the dash Power Outlet? 01' Dakota
  240. Front axel seals
  241. 1992 Hazard Light Malfunction
  242. 1999 RT heater leak
  243. 2000 dakota Dash problems
  244. 2000 Interior Illumination
  245. 89' will not go faster then 70mph plz help!
  246. '88 4 speed tranny problems.
  247. 2001 Dodge Dakota Sport PROBLEM
  248. steering tierod adjustment sleeve
  249. UPGRADES performance,interior, eterior
  250. anti lock breaks light
