View Full Version : Dakota
Pages : 1 2 [3] 4 5 6
  1. 96 dakota engine swap
  2. 318 rattle
  3. 97 Dakota Overheating
  4. chunks in differential :(
  5. Dakota has no power and runs rough
  6. Air conditioning problems
  7. Dakota TT
  8. 1998 Dakota SLT
  9. Looking at a 95 Dakota
  10. Driver door weld busted
  11. 1991 dodge dakota v8 fuel problem
  12. 94 Dodge Dakota V8
  13. 99 Dakota Overheating
  14. Just got a badass ride.....
  15. 5.2l
  16. 96 dakota
  17. looking at a 91 dakota....
  18. 04 quad woofer boxs
  19. Oxygen Sensor on 318 V-8
  20. Fuel Gauge Problem
  21. Getting into doors
  22. Differential gasket leak
  23. 98 dakota electrical problem
  24. Dodge air conditioning cable
  25. 1988 Dodge Dakota charging problems
  26. Mudding Preperation and After Care
  27. How to prime the fuel pump
  28. 2001 Hesitation/Stuttering
  29. 98 slt a/c question=
  30. 90 Dakota Trans Rattle
  31. Hot front brakes
  32. who likes the 4.7L
  33. '01 Dakota lighting problems
  34. Need Cap/Topper
  35. Best Air Intake for Dakota
  36. Thermastat location
  37. Paint Code?
  38. Dakota overheats at highway...
  39. looking at buying a used dakota 1997 or newer
  40. 2.2 Choke linkage
  41. Parking Brake Problems
  42. idle problems when starting engine
  43. 1997 Fuel Filter
  44. Replacing Starter
  45. speedometer and transfer case prob
  46. Error Code 43
  47. 2001 Dakota Speed Sensor
  48. 1987 2.2 Carburator diagrahm
  49. Carb Ajustment question
  50. Cab Vent Filter
  51. Error Code
  52. 1992 2x4 dakota intermittant engine prob
  53. It won't stay running
  54. Size Cap / Topper for 87 Dakota?
  55. 95 max tire size
  56. water pump
  57. 5-spd Shft knob
  58. 360 heads on 318 block??
  59. 2001 Dodge Dakota Transmission Wont Downshift
  60. gas tank
  61. 3 inch lift kit
  62. 89 dakota w/ 3.9 v6
  63. Flasher location? 2001 Dakota Quad cab
  64. MPG difference
  65. Homemade Air Intake
  66. wiring for boat trailer
  67. Blend Door Actuator Location 98 Dakota
  68. "96" dakota
  69. Adding power locks and remote starter...
  70. 3.9 backfire problems
  71. My little experiment
  72. 2004 Dakota Power Steering
  73. keyless entry
  74. Ticking Noise
  75. Cruise control & TCL
  76. Proper up-keep
  77. Spark Plugs
  78. Overheating problems...Help!!
  79. 11 Mpg??!!
  80. looking to buy
  81. Performance exhausts
  82. Cold Starting Problems
  83. 03 dakota master power window switch
  84. New 99 dakota
  85. Engine Swap
  86. 99 dakota no spark, no fuel, no bus
  87. brakes for dakota with v8
  88. 20's or 22's on a dakota
  89. 87 Dakota 3.9l Questions
  90. 2003 Dakota Service Manual
  91. going green
  92. 318 fuel system
  93. Speed Sensor
  94. 1993 Dakota Fuel Problem
  95. 1992 5.3 v8 trans no gears when heats up
  96. 1997 Dakota Drop Kit
  97. 98 Dakota dash light for 4 wheel drive
  98. Parking, tail, and dashlights... again
  99. Parking, Tail, and dash lights
  100. 92 Dakota Need Help!!!fuel Problem
  101. 93 dakota brakes
  102. Belt Questions
  103. Help I Need Something
  104. 4cyl Dokota?
  105. Setting Clock
  106. '01 4.7 V8 Exhaust leak
  107. 99 Dakota
  108. 1995 dode dakota lift kits
  109. 1995 dode dakota lift kits
  110. 2000 dakota rear locks and windows acting up!
  111. motor swap
  112. 98 Dakota 4X4 ??
  113. help anyone who knows about car alarms
  114. 2001 Dakota tranny noise
  115. 1993 dakota NEEDS TRANS ebay
  116. Ball joints
  117. 01 Dak - Overdrive cuts out
  118. 02 Dakota Quad 4x4 - steering pulls in 4x4
  119. Cams and Smog Checks
  120. 95 Dodge Dakota
  121. Converting from gasoline to lp gas
  122. hello im new
  123. Forced Induction
  124. 93 dakota duel line leak
  125. look for a motor
  126. how difficult is white face guage kit to install?
  127. Brake bleeding problems need help QUICK!!
  128. HELP! Engine Light, 2000 Dakota V-6
  129. fuel tank system question
  130. brake troubles
  131. 01 dakota limited power when cold
  132. Problems come in three's..right?
  133. Lower Control arm
  134. timeing 3.9 magmum
  135. Dakota recalls
  136. 95' Dakota U-Joints
  137. 99 dakota v6 PCM failed
  138. timeing
  139. 99 Dakota Poor Heat
  140. 1988 dodge dakota ignition lock cylinder
  141. 2000 Dakota fuel gauge
  142. 2000 Dakota fuel gauge
  143. 92 dakota 4x4 light question
  144. Info on r/t daktoa
  145. 1996 2.5 engine problems
  146. 1994 Dakota run's like as* plz help me out 3.9 magnum plz help asap (busing sucks)
  147. taking off Front Bumper
  148. Can I get better gas mileage?
  149. 93 Dakota Performance
  150. Dakota 2000 turn signal shuts itself off
  151. remove door speakers and kick panel rear
  152. 93 Dakota Rebuilt Trans Problem
  153. 1988 Dakota 4-speed auto to 3-speed conversion?
  154. 1988 Dakota - Equipped as Shipped?
  155. flushing radiator
  156. 89 Dakota Running rough.
  157. 95 Dakota transfer case
  158. 1990 Dodge Dakota
  159. 99 Dakota
  160. '94 Dakota 4X4 Transfer Case Noises
  161. Instrument Panel Problems
  162. 93 Dakota Ignition Trouble's ??
  163. '97 Dakota Front Wheel Bearing
  164. 91-96 clear taillights on ebay
  165. 95 dakota transmission problems
  166. '01 speedometer adjustment?
  167. RPM Guage not working. Anyone Help!
  168. Cruise Control Help
  169. 2000 Driver's Side Heated Mirror
  170. crank sensor location 91 dakota
  171. Catalytic Converter Size 96 Dakota V6
  172. 96 Dakota A/C Problems
  173. Fan Clutch problems
  174. '98 Engine Swapping
  175. engine swap
  176. 17" Sst Ram Rims 4 Sale
  177. Locating sensor
  178. 1998 dakota air conditioning question
  179. Differentials
  180. 93 Dakota Turn Signals
  181. Just got a 92 Dakota doesn't start
  182. Trans Filter Change
  183. 2000 Dakota 4x4 with GOODIES...OBO!
  184. Fuel Filter
  185. 98 dakota r/t sale $5400.
  186. looking at buying '98 Dakota 80,000 miles
  187. 1998 magnum for sale ???
  188. magnum r/t question-
  189. FS: 92 Dakota V8 NYC
  190. 2001 Dakota code P0420
  191. shifting problems
  192. Dash warning lights
  193. Dakota will not start
  194. 94 Dakota doesn't start
  195. How much should I sell my 97 3.9L sport ext cab for?
  196. RPM jumping
  197. 1991 318 engine
  198. Engine swap
  199. How to stop thieves from popping your door lock!!!
  200. 1988 dakota help
  201. rattling sound
  202. 98 Dakota Trouble starting in the morning
  203. Flip the heater switch and NO air comes out
  204. 97 dakota brakes
  205. Dakota R/T...A/C fan speed only 1 & 2. What do I need to replace?
  206. Help, horn not working in my 93 dakota
  207. 95 dakota oil leak
  208. Out of gas with 5 gal in the tank? 95 Dakota V8
  209. fuel gage
  210. 97 V6 Rough Idle and Questions
  211. 1988 dodge dakota
  212. Intermittent Charging Problem
  213. 1998 v8 stalling
  214. idle rpm
  215. hi i am new have 93 dakota
  216. 92 Dakota dies and wont start for 5-25 minutes. PLEASE HELP!!
  217. 2001 dakota 4wd not working
  218. 93 Dakota No heat
  219. 93 Dakota door handle
  220. Steering Column Over Drive Switch
  221. 99 dodge dakota power loss between 50-60 mph?
  222. head lights
  223. EGR Trouble code, 95 Dakota V8
  224. Fuel system cleaning
  225. V6 to V8 Conversion
  226. Not Idling
  227. How much noise do balljoints make when they need to be replaced?
  228. coolant leak
  229. 2006 Dodge Dakota Sport 4.7 Ho Shocks
  230. 97 Dodge Dakota heat problem
  231. fuel tank ball thingy
  232. 1997 Engine Rattle
  233. 01 Dakota trany probs
  234. 2001 Dodge Fog Lamps
  235. Stalling due to Fuel Starvation?
  236. 91 Kota Jet chip
  237. Tires/Wheels for 02 Dakota 4X4
  238. 1993 Dakota - won't start
  239. 1999 Dakota Heater will not get hot
  240. Cylinder No.7 Misfire
  241. 2001 dakota engine/tranny replacement anyone???
  242. 97 dakota 5.2 starts, idles fine,but...
  243. Code 36 1992 Dakota stalls then restarts
  244. 3.9 computer
  245. Tranny Problem (?)
  246. what will i need to swap 3.9 for 5.2
  247. few questions
  248. 95 blower motor switch
  249. 2002 dakota code p0306
  250. Does fully synthetic plus a little Lucas oil stabilizer work well in the 3.9L?
