View Full Version : Dakota
- 2005 Dakota 4 Wheel Drive ????
- 93 Dakota Frame Rails
- 1994 Dodge Dakota
- Question on spark plugs
- 92 dakota 2.5L won't start when cold
- Seat Belt Replacement
- cutting out/backfiring/shutting down
- 02 Dakota Door Lock Noise
- Dakota Seat Belt Buckle
- Transmission options for 1988 Dakota
- dakota no spark/fuel. FIXED
- 2001 QC 4X4 snap sound when braking
- 1991 Dakota 2.5 bucking and jerking
- dakota fuel
- 99 dakota wiring
- 1997 GC blower on defrost only
- Exhaust question
- 96 dakota electrical problems
- Wheel Nuts
- stalling out
- Cable in Dakota 2001
- 93 will only start in Neutral
- 88 Dodge Dakota: No Start or Solenoid Click
- 03 4.7 Quad Cab Comfortable Pulling Weight
- spark plugs 2000 4.7
- 95 dakota extended cab - leaking on drivers side when rains
- 02 dakota
- smell antifreeze - NOT heater core
- starter clicks nothing happens
- Rattling Noise..
- 1995 Dodge Dakota
- 2003 4.7L Quad Cab Dakota stalling
- Just bought a 06 quad cab 3.7
- '93 3.9L intermittent cut out under load.
- 2000 Dakota misses after warming up
- 1994 dodge dakota
- 1991 Dodge Dakota wont start!!
- 1994 dakota- oil pressure light flickers and gauge flutters when idling
- My truck won't turn right!
- 2002 Dakota V-6 vibration
- Two issues- front and rear ends
- 95 dakota no spark
- check gages light
- 02 Sensor
- EVAP system problem - kind of long winded
- guages
- switch from auto to manual
- 91 Dodge Dakota - No Spark
- 1999 dakato steering box
- 89 dakota
- 1990 4X4 3.6 troubles hard to start and it dies but will restart with in 5 to 10 mins
- 01 radio and gear indicator problems
- P0720 - speed sensor code
- 1992 Air Conditioner Problem
- check condenser fan for overtheating concern
- Dodge dakota stumbles
- 92 dakota 5.2
- 03 Dakota blinking dome lt and door lock issues
- 02 Dakota shaking and power loss
- 2003 Dakota P0456 code
- 94 Dodge Dakota Seat Replacement
- 05 Dakota brakes
- P1716 Transmission Problem while Accelerating when Hot
- Dakota Fuel problems
- 1987 Dodge Dakota 3.9L V6 Rear end tag number HELP!
- 93 dakota
- 2001 Automatic Transmission
- 2001 dakota truck
- 03 Dakota thermostat problem
- truck won't turn over after shaking while driving.
- 02 dakota we brake problem
- 1997 Dakota 3.9 "NO CHECK ENGINE LIGHT"Moniters "Not Ready"
- 1996 dodge dakota transmission
- subwoofer box for a 2002 dakota
- 91 Dakota Door Problem
- Climate control works on High only
- 94 Dodge Dakota Speedometer Not Working
- popping the 5amp fuse in the power distribution center
- dakota with small emission leak code
- 93 Dakota won't start after tranny swap.
- 98 Dodge Dakota Oil pressure
- 92 Dakota 5.2 just dies
- 92 Dakota problem when in gear
- 1987 dodge dakota running rough
- 02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6
- alternater not charging
- Overheating after filling with gas
- 2008 quad cab tonneau cover
- 2002 Dakota L-headlight L-doorlock
- 94 dakota trans problem
- 97 dakota starts, but kills itself
- Numerous Throttle Position Sensors
- headlight taillight and interior light stopped working
- 1997 Dodge Dakota Trans problems
- Front end noise
- 1990 Dakota Resonates at 70 mph
- No Power!!! Normal?
- Power steering pump replacement causes seemingly unrelated issue
- maintenance light on
- 04 Dakota Will Not Start
- 94 Dakota idle question!!!!!!!!!
- cant get out of park
- Having trouble with tranny build
- 93 5.2 wount run smooth
- 94 Dakota Tensioner Question
- 1994 Dakota Headlight Assembly Removal
- Random Overheating 03 Dakota
- Little heat in my 94 Dakota
- 2001 - QuadCab Air Bag Light
- 90 Dakota P/up Trailer Harness
- Three Dakota questions from a new owner
- No 3rd Gear (2000 automatic)
- '97 Dakota Speedometer wont work
- 94 dakota 5.2 starting isues
- mirror pigtail wiring diagram needed for bench-testing heating element
- 4 wheel drive, doesnt shift back, sticks
- Warranty extension '96-'99 Please read
- stiff spots in steering 02 Dak Quad 4x4
- System too Lean
- 97 Dakota Fog Lights
- 04 dakota P0204 error
- Power Window Motor Replacement
- water pump replacement
- '03 Dakota 2wd random loud pop under truck
- '98 Dakota wheel bearings and ball joints
- 1995 3.9 liter won't start. Finally fixed!!
- Winter Tires and Rims
- 93 Dakota Blower not working
- fuel gauge problem
- Should I buy a Dakota?
- Belt slipping off.
- 1988 3.9L Not Starting
- 1994 Dakota blows white smoke
- 99 Dakota won't link to scanner
- Fuel Pressure - 95 sport 4cyl
- 97 Dakota spongy pedal and brake light
- random multiple cylinder misfire
- headlight problem...please help
- 1995 dodge dakota 318 V-8
- Timing Belt Question - 95 Dakota Sport
- 5 speeds...
- 1995 4cyl Dakot Sport Pls Help
- 93 Dakota Oil Pressure
- 1993 dodge dakota transmission
- 1998 clunking noise pls help
- fuse size for a 93
- Transmission RE-Programming
- transfer case engagement question
- No headlights
- Tranny od problems
- Annoying Sound
- Upper Console Swap
- dakota fog light replacement
- 1987 dakota starter removal v6
- 2006 dakota
- 1997 Dakota right cab corner
- Check Engine Light P0783
- relays
- Random idle issue. Replaced Iacv.
- 02 Dakota Oil pressure!
- 93 Dakota has no spark, but I do!!
- Sludge
- 97 dakota stalling after warm up
- 97 dakota backfiring
- No Spark No Fuel Pressure
- 92 Dakota won't go over 75mph
- fan hitting the fan shroud
- '04 power lose when engine warms up.
- 99 Dakota 3.9 stutters and putters, HELP, please!!
- Busted Brake Line, Near Engine
- ABS Warning light
- steering problem on 88 dakota
- 1993 5.2 Dakota dying
- tranny oil cooler add on
- 93 dakota overheating?
- clunking from rear
- AC Air Conditioner clutch
- 01 quad cab power windows
- 89 dakota making noise from undercarriage
- 96 Dakota 3.9L STILL SHUTTERING
- What to look for (Used 1993 V6 Ext.)
- 1996 Dakota Sport 3.9L V6 Manual Transmission
- Sparkplug removal stuck plug
- Manual Transmission lube capacity???
- 96 3.9l oil pump change?
- Dakota Spark plugs
- 92 Dakota Sensor Identification
- '93 3.9L Dies When Cold
- oil pressure drop
- Broken wheel studs
- 01 Dakota For sale
- Is there a filter in the dash area??
- need help with trouble codes
- Gas Mileage Drop
- 2003 Dakota repeated resistor failure
- Electrical Hell...
- engine swap 1st gen
- Dakota engine specs
- '02 Dakota 3.9L cold starting problem
- larger wheels on 04 QC 4x4 Dakota
- Considering...03 QC SLT 4.9 4x4 5Spd
- Firing Help Plz Help
- 97 Dakoa Rear Speaker Help
- 01 Dakota tail light problem
- Ram brakes on a Dakota??
- 03 Dakota not shifting
- 1999 dodge rt dakota
- bent valve
- 2001 4.7l P/S pump useful info
- 97 Dakota Stereo & Speaker Installation
- Good Dakotas?
- Replacing spark plugs
- 01 dakota power window
- 00 Dakota OD wont shut off. WHY???
- 04 dakota Quad Cab - Rearend Clunk when Shifting
- 1991 dakota tranny slipping/reverse only
- 06 Dakota front end clunking noise
- Dakota 2.5L with bad cylinder?
- tranny problems with 92 4x4
- Body lift kit for 96 2WD...
- really need insite...i'm stumped....
- what tranny is in a 02 dak
- 99 dakota trans slip
- comprestion test
- 93 body 02 drive train
- 87' Dakota Charging Probs
- 01' dakota - breaks and problems
- 95 dakota power issues
- 01 Dakota Oil Pressure
- Shift Light
- 91 Dakota Problems.
- Parting out entire 97 dak. check this out
- 1999 Dakota
- 91 Dakota Headlight problem
- 1994 Dakota 318 V8 Runs like crap
- location of crank sensor on 1990 dakota?
- 1990 dakota 3.9L wont start(need help asap)
- Tachometer
- Too fast idle
- Weird Electrical Problems
- Cherry Bomb Glass Pack on 97 Dakota
- 97 Dakota Speaker Size
- Performance chip
- 1991 dakots starting problems HELP
- Tire Pressure
- false multiple cylinder misfire
- 90' Dakota Starting Problem
- question about tires for 96 dodge dakota
- tranny p1762
