View Full Version : Dakota
Pages : 1 [2] 3 4 5 6
  1. Upper ball joints
  2. fuse block description
  3. 93 3.9 regulator
  4. 2.5L dakota idle problems Please Help
  5. 2000 Dakota Thermostat
  6. 2nd Gen Dakota air hat
  7. Changing Oil
  8. Ignition timing for '97 3.9L
  9. 2000 Dakota / Remote Start
  10. '90 dakota injector not firing
  11. 3.9 to a 5.2
  12. dakota with no spark
  13. front end popping noise, AC quits when accelerating
  14. Dakota Driveline Whine
  15. v6 govenor
  16. 93 V8 318, can't get power to anything
  17. how to check starter/engine ground
  18. Hard shift/Cooler Weather
  19. '04 Dak: Replacement of instrument cluster light bulb
  20. 1996 Dakota V8 4WD won't start
  21. Rear tire slant
  22. rear diff 2000 dakota
  23. Clutch adjustment on '04 4x4 4.7L
  24. 3.9 magnum parts
  25. 2003 4.7L 4 wheel drive Tranny problem
  26. Aftermarket Headlights for 94
  27. 2001 Dakota Problems
  28. Oxygen sensers on 1996 dakota
  29. 1999 Dodge Dakota
  30. WANTED 88 dakota
  31. intake manifolds
  32. 1998 dakota heater resistor pack location??
  33. Weird transmission behavior: Should I buy this truck?
  34. 2003 Dodge Dakota 4x4 4.7 liter engine
  35. '90 Dakota sputters after sitting
  36. Radio Out
  37. truck quits running
  38. 91` dakota V8 charging problems
  39. NO Brake Lights
  40. 2001 dakota truck
  41. 1987 dakota oil pressure
  42. Data logger
  43. Belt Diagram
  44. 1994 dodge dakota motor swap...help
  45. Adding horsepower
  46. tranny troubles
  47. dakoto motor swap (bad issues)
  48. 91 to 95 motor swap
  49. Dakota Losing Power
  50. 318 engine
  51. 91 Dakota no lights
  52. Dodge 2001 pickup truck coding
  53. Dodge 2001 pickup truck with need's a translation for this coding
  54. 89 dakota wont crank
  55. 4 or 5 quarts of oil?
  56. 4 Or 5 Quarts of Oil?
  57. Blinking 4 lo light
  58. 1989 Dakota dash,park light, fuel and speedo gauge
  59. wining noise slight when making right turn what is it tire noise or something more
  60. Anti spin differential
  61. Tonneau Cover
  62. Knocking issues 91 5.2
  63. 2001 Dodge Quadcab stuck in drive
  64. Tonneau Troubles
  65. Dealer recommended services
  66. 91 dakota, drivers rear abs valve?
  67. Custom exhaust system...throwing check engine light
  68. chattering brakes
  69. 1998 Dakota, override shutdown problem
  70. AC and other problems
  71. 1995 Dakota 4x4 318 no spark at coil
  72. 3.7L 2WD Quad Cab Gas Mileage
  73. HO 4.7L or NOT?
  74. 97 dakota water pump
  75. 2003 Dakota, P1604
  76. 99 dakota....
  77. 01 dakota trany prob?
  78. Overheating
  79. Overheating Problems
  80. what kind of transmission do i have????
  81. 1998 Dodge Dakota SLT thoughts?
  82. 1999 dakota r/t running bad
  83. 90 Dakota starting problem
  84. quest for firmer shifts
  85. 92 dakota fuses
  86. 2004 Crankshaft Sensor
  87. 91' 318 with fluctuationg idle and hesitation.
  88. Transmission Overdrive / Lockup Wiring
  89. Changed cams to HO and now P0016
  90. U-Joint trouble
  91. Need More ooomph
  92. 95 dakota 3.9 auto
  93. 92 dakota
  94. 3.9 V6 Backfire/power Loss
  95. 90 Dakota Headliner
  96. 92 wiper in low speed not working nor is off spot right
  97. 99 Dakota 2.5L light tapping noise from eng
  98. 91 Dakota Cowl panel removal
  99. 93 dakota "knocking" sound?
  100. problems starting a 93 v6 auto
  101. 03 Dakota with cat converter problems.....
  102. 93 4 cyl dies restarts cold
  103. Wipers don't work?
  104. teapot sound behind dash
  105. Mysterious CEL -- 2001 Quad Cab 4X4 4.7L
  106. 1993 dodge dakota 318 hesitation probms
  107. 1988 Dodge Dakota 2.2 timing information.
  108. 1995 Dakota Radiator Fan
  109. 91 dodge dokota..knockin sound
  110. 93 dakota 5.2L tranny shifts at high rpms
  111. 87 Dakota problems.
  112. Dakota R/T SPECS 0-60 1/4M????
  113. interchange 1995 dodge dakota
  114. Leaking water
  115. Dome light and light around key ignition
  116. A few questions about a friend's '97 3.9L Dakota
  117. 1997 extended cab - Towing - Opinions please
  118. Complete Stereo Revamp
  119. stumped! 92 3.9 stalling and backfiring
  120. Bucket Seats in 91
  121. 1991 dodge dakota wiring and fuel tank
  122. 360 into V6 dakota???
  123. Crankshaft bolt
  124. all this input is really great,
  125. removing the AC condenser bracket 99 dakota
  126. ign. sys. fuzlink blowing '93 dakota 3.9
  127. 02 spedometer spiked and locked
  128. Hey, new guy here, Dakota front end whine, 4 wd...?
  129. bypass hose leaking
  130. water leak near thermostate housing??
  131. 99 Dakota V6-V8 Engine Swap Project
  132. how do u get the rear seal out
  133. 2000 Dodge Dakota platinum plugs
  134. Thinking of buying a dodge dakota need advice
  135. help no spark
  136. 87 Dakota fuel guage
  137. 2001 dakota 4.7
  138. Falling apart on me...
  139. 2005 Dakota Quad Cab Advice Needed
  140. 1993 Dodge Dakota Gas Mileage
  141. 2002 dakota no spark
  142. '98 Dakota tranny problem
  143. Dakota 93 lights problem
  144. Dakota 93 lights problem
  145. Dakota 93 lights problem
  146. 1999 Dakota 318 5.2L AUTO "stalling" problem
  147. 88 dakota 4WD broken steering column
  148. 05 Dakota Stalls
  149. 89 Dakota vacuum diagram?
  150. engine noise
  151. 92 Dodge Dakota Backfiring problem
  152. 92 Dodge Dakota Backfiring problem
  153. 1997 Dodge Dakota SLT V6 Magnum 4x4 Automatic-NO OIL PRESSURE
  154. would this work?
  155. 2002 5.9L Dakota Cat-Backs
  156. '01 4.7 with water sludge in oil
  157. 2000 trans?
  158. No Spark 92 3.9 DAKOTA
  159. 94 dakota broken speedometer
  160. For Sale
  161. '89 Dakota heater blower quit working....
  162. Engine Clunking and Oil Pressure 99 dakota
  163. Truck gets hot ,water comes out......
  164. '01 Dakota 4wd Not Working!
  165. hand cranked window open and it broke
  166. 2000 dodge dakota help 4X4 help
  167. 98 dakota rear end noise - ring and pinion?
  168. Transmission swap I HAVE QUESTIONS HELP!
  169. 2002 Dakota remote starter
  170. 2004 Dakota - High pitched whistling in cab when cold
  171. Check guages light when taking turns
  172. 97 Dakota 3.9L transmission slipping
  173. Difficulty shifting to 3rd
  174. No shifting into OD
  175. Brush Guard for an 88` dakota
  176. 1994 Dakota Will not start
  177. 2000 dakota trans problem
  178. Electrical Gremlin
  179. 87 Gas tank sending unit ??????
  180. 94 dodge dakota coolant leak
  181. 91 3.9 Stalling problem
  182. 95 Dakota wont lock
  183. 91 5.2 will not start
  184. help truck wont start
  185. '92 V6 no fuel pressure
  186. updgrading bumper from 99.....
  187. 2000 Dakota 3.9 cold idle issues
  188. how low can i go?
  189. Need 99 / 2000 4.7 Engine
  190. front grille replaced
  191. strange problem with 02' dakota
  192. Radiator fan staying on
  193. seats
  194. 2001 Evap
  195. Intermittent whistling sound
  196. tranny troubles
  197. 1990 Dakota No start...
  198. Odd noise from front end/engine...
  199. question about tail pipe
  200. 45RFE interchangeability
  201. Whinning Noise
  202. 00 Dakota have to hold gas pedal to floor to start.
  203. Setting timing dakota 3.9 1992
  204. 1992 Doge Dakota Gauges
  205. snapped bolt
  206. Radiator V6 & 4cyl the same?
  207. v6 to v8 engine swap?
  208. 90 Dakota driver seat belt
  209. Possible tampons in the gas tank.
  210. tools needed
  211. 1996 dakota asd fuse keeps blowing
  212. Air Pump Question
  213. Dodge PCM replacement
  214. crankshaft oil seal leak
  215. rear wheel shudder
  216. Speaker size for Dakota??
  217. fuel pump
  218. no spark when its cold
  219. 2000 Dakota power plug (in dash)
  220. 1989 Dakota Ignition Switch Problems
  221. 93 dodge dakota makes clunking noise when in reverse
  222. Just bought a 95 Dodge Dakota.. Check it out
  223. K&N intake for 93 v6
  224. intermitant miss/elect. or fuel?
  225. Rear end or tranny
  226. 93 dakoda elec. problems
  227. 98 Dodge Dakota
  228. 2005 window crank
  229. Oil pump
  230. 93 Dodge Dakota Steering
  231. I Need A Little More Clearance
  232. Bad PCM?
  233. transmission swap,will it work?
  234. New Ride!!!
  235. 93 dakota radio/cd wiring...
  236. 98 Dakota Oil Pressure
  237. Please Reply!
  238. Please Reply!
  239. 99 dakota cv axel replacement
  240. 01 dodge dakota,cruise control diagnose
  241. 02 Dakota Quab Cab 4X4 - 4X4 problem!
  242. 02 Dakota Quad Cab 4x4 - brake noise!
  243. 1989 Dakota 4X4 hard Shifting
  244. Is it possible to turn a 2x4 into a 4x4?
  245. 96 abs & brake light, air bag light all on
  246. 99 dakota "clanking" sound
  247. Wtb
  248. 94 3.9 manual shift occasional backfires???
  249. HVAC regulator
  250. 97 Dakota V6 intermittent problem now permanent
