Our Community is 662,000 Strong. Join Us.
View Full Version : Achieva
Pages : [1] 2
  1. '96 Oldsmobile Achieva
  2. Loc on radio
  3. 97 oldsmobile achieva sl overheated and now it wont start please help!!!!!!!!!
  4. 98 Achieva no heat
  5. Engine Rebuild
  6. power door locks 96 olds achieva
  7. 1996 Oldsmobile Achieva Turbo and Supercharger?
  8. 92 Olds makes and ittermitting spark @ the balancer
  9. 1994 Olds Achieva, 3.1 S Leaking coolant
  10. Trouble identifying my 2.3 L Quad Four motor
  11. Achieva having acceleration issues
  12. Loud tapping from engine
  13. 1998 Oldsmobile Achieva--TRANSMISSION WON'T SHIFT...
  14. Cold affecting speedometer
  15. 3.4 Over Heating
  16. 1995 olds achieva engine swap help.
  17. 1998 ACHIEVA Heater Core
  18. Tubbing and Narrowing...
  19. My 1996 Olds Achieva 3.1L V6
  20. diagnostic harness
  21. TCC Solenoid 94 olds achieva
  22. Looking for a Front Upper Strut Tower Bars
  23. 97 Achieva How to remove original ball joint
  24. what happens next
  25. 1994 Achieva Starter Wiring Diagram
  26. How to replace 94 Achieva QUAD 4 Engine
  27. 1992 achieva fan issues
  28. Car runs fine, but speedo is WAY wrong.
  29. 98 A/C pressure cycling switch
  30. 96 Achieva Code P0440 / Occasional Flickering Engine Light
  31. 1996 Olds Achieva Engine cuts out
  32. No start, has spark, has fuel, only when warm? anyone?
  33. 96 achieva starts then stalls
  34. '97 Achieva Won't Start NEED HELP BAD
  35. p0341 message
  36. Won't lock into gear
  37. 95 olds achiva S
  38. 97 Achieva Lift Points?
  39. 95 3.1 temp problems
  40. Bumper cover
  41. Retained Power Accessory (RAP) stays on
  42. Cold weather stalls and no starts with my 96
  43. Brake caliper bolt holes stripped
  44. 97 Olds Achieva 3.1
  45. flickering/pulsating lights- Achieva
  46. antifreeze smell when adjusting cab temp - 97 Achieva
  47. egr flow insufficient-Achieva
  48. heater core replacement
  49. '93 Achieva Check Oil Light
  50. Engines for 1995 Achieve
  51. Key won't come out
  52. 97 Achieva Cruise Control not working
  53. 95 3.1L Service Engine Soon
  54. Higher rpm than normal
  55. 96 Achieva Body Kit
  56. 97 achieva-- listen to my problem...
  57. Firewall
  58. 96 Achieva dash lights come on-then no start
  59. 96 achieva Clunking...Control Arm Bushing?
  60. 96 achieva clunks Control Arm bushing?
  61. acheiva poors gas out of the tail pipe
  62. Windows !!!!
  63. air conditioning
  64. 95 Achieva distributor cap ... not required?
  65. I replaced a Quad four motor on my Achieva 93
  66. Achive 95 lights
  67. Howto: Program Achieva remotes
  68. coolant capacity
  69. achieva wont start
  70. Oldsmobile Achieva 1997 - Thermostat housing
  71. 95 2.3quad achieva, valve cover problems
  72. 95 Achieva Intermittant stalling-
  73. 96 Achieva Tire Pressure?
  74. car scared the crap out of me
  75. 96' Achieva SC 2.4L Drive cycles?
  76. '94 blower fan issue
  77. 96 Achieva Front Hub/Bearing Replacement
  78. 1995 Achieva S tune up
  79. 1995 Achieva S door locks
  80. 96 Achieva - IPC dark / stalls immediately
  81. hope its not a head gasket
  82. fuel problems I think
  83. 96' Achieva SC 2.4L
  84. '92 Achieva -- Starting problems and runs rough
  85. how to find a ICP????
  86. 92 Achieva 3.3 Swap
  87. 1996 Achieva, tail light and instrument panel lighting issue
  88. "98 Olds Acheiva
  89. Running rough - 94 Achieva
  90. no defrost
  91. '96 Sc 2.4l
  92. 94 Achieva rough idle and shaking (PLEASE HELP)
  93. 1998 Oldsmobile Achieva stalling help.
  94. 96 electronic issues
  95. Does a 95 Acheiva 2.3 transmission fit a 96 2.4 model?
  96. 97 Achieva Brake Issue
  97. Need to know...
  98. Cools at high RPMs only, I don't get it!-95 Achieva
  99. 2.4, tried what I know....please help!!!
  100. 95 olds acheiva 2.3L won't start
  101. 96' Owner Need help
  102. 93 3.3 achieva s hesitates when press pedal
  103. 1996 achieva thrft bypass
  104. woman needs help 96 achieva
  105. Changing Engine Problem
  106. 96 Acheiva- Runs to rich, stalling
  107. 96 Achieva SC 3.1L - Where is the A/C fill valve?
  108. stumbles on hills
  109. stumble on hills
  110. Intermittent electrical short??? Or worse??
  111. Weird sound...hard to describe
  112. Changing Motor '95 3.1L SFI V6 [M]
  113. 97 achieva 3.1L, PCV valve making noise
  114. 97 achieva 3.1L, ETS not letting me brake properly
  115. 97 Achieva mystery
  116. 1995 Olds Achieva Transmission swap.
  117. 94 Turn over won't start...
  118. Ebtcm ???
  119. 1994 Olds Achieva acceleration hesitation
  120. 94 Oldsmobile Achiva dash and tails not working
  121. ABS and ETS issue
  122. Will my car make it?
  123. 93 Achieva 3300 - No Reverse -
  124. Intermittent starting '96 Achieva SC 3.1
  125. 98 3.1 misses
  126. 96 Achieva 3.1 runs poorly
  127. Weird Idle Problem!!!
  128. 97 achieva 2.4 dohc cranks but no start
  129. anyone ever had a failed IPC after having it repaired by southern electronics?
  130. 97 SL Air Filter Housing
  131. 97 Achieva overheating issue.
  132. Grinding noise in 1st gear
  133. '94 tranny drip leads to thermostat prob.
  134. 96 twin cam starts sometimes
  135. wheel bearings-95 Olds achieva
  136. Removing 3rd Brake light housing on 96
  137. Bad transmission?
  138. Cooling problem
  139. 96 Olds Achieva 2.4 150k Starts Runs 30 secs then dies Give it gas dies
  140. No hot air, overheats when driving in traffic ('93 V6)
  141. 95 Achieva 2.3 Lifter chatter
  142. Can't keep coolant in it-Achieva
  143. 98 achieva trans problem?? U tell me.
  144. Hidden Horn
  145. 95 Achieva S stalls when put in reverse from park
  146. problem starting please help!!!!
  147. ran 97 olds out of gas
  148. Car won't start, got fuel and fire
  149. 96 TC Airbag Light
  150. Low Coolant Light-97 Olds Achieva
  151. interior carpet wet before driven
  152. please help with ets sensor
  153. Rear Dash Cover on 1998 Olds Achieva
  154. 97 OLDS ACHIEVA fan
  155. glowing orange catalytic converter
  156. 98 achieva trany ?
  157. hello need some advice
  158. achieva suspension drop?
  159. 96 Achieva p0442/p0300
  160. 96 achieve think passlock is messed up
  161. changing heater core on 95 Achieva S
  162. 95 3.1L Service Engine Soon (or check engine)
  163. Overheating only when I turn on the heater in Achieva 94 2.3L
  164. when car started runs like it is not running on all 4 cylinders
  165. 94 achieva S where is the thermostat
  166. starts then dies p0300 and p0440- achevia
  167. Interchangeability of inner door panels (1994 Achieva SC)
  168. '93 Achieva hard start in high humidity
  169. 95 ols Achieva runs rough
  170. 97 Olds Achieva
  171. 96 Achieva shuts off while driving & no start
  172. 96 Transmission
  173. Fuel leaking into intake manifold
  174. 96...transmission trouble?
  175. 96 TC Front end
  176. 93 Achieva "body control module"?
  177. 96 achieva...horrible noise
  178. looking for preformance parts
  179. can a bad CPS onthe 3.1L cause no start similar to passlock security failure ?
  180. tire rim size?
  181. passlock I new ignition lock relearn
  182. IPC rebuild/exchange
  183. Firing Order 96 Olds. Acheiva SL 3.1
  184. 94 Achieva engine fan continues to run.
  185. 96 Achieva...check engine light
  186. 1994 Olds Achieva acceleration hesitation
  187. flashing high beam indicator (98)
  188. 3.1L Woes...
  189. 2.4 tc misfiring
  190. Cam Position Sensor/96 Acheiva 3.1
  191. rebuilt 2.3L oil issue
  192. 1997 Olds Achieva power window quit
  193. 96 Achieva fan problem, sensors good
  194. 93 olds Achieva just turns off after running fine!!
  195. 93 Achieva thermostat
  196. 1998 Olds Acheiva - No ignition, wont start
  197. idiot lights - mostly on - ABS / ETS OFF / LOW TRAC
  198. 93 Achieva
  199. 97 Olds Achieva starts but shuts down after 2 seconds
  200. Help! Heater Core Mystery!!!!
  201. a quick question about paint codes for the achieva
  202. Check engine lite
  203. 92 SC questions
  204. how to replace crankshaft sensor.
  205. 1992 olds achieva 3.3 white smoke from exhoust
  206. 95 Achieva drops during backing up and braking
  207. 98 Olds Achieva burns fuses when AC turned on
  208. Starting problem-1995 Achieva
  209. need help changing heater core
  210. water pump housing in 1995 achieva
  211. 1996 Achieva Starts for a second than it shuts off
  212. Quad Drivers Module Question
  213. 93 Olds Achieva Not Getting Spark
  214. New and Old Members Please Read
  215. 96 Achieva 3.1L - Where is the A/C Low Pressure valve?
  216. 1997 Fuse Block
  217. ??? High Pitched Squealing Noise ???
  218. Car intermittently will not start
  219. No Ignition on my 1996 Achieva
  220. Hi..great forum! Engine Tech Swap question...
  221. 92 achevia cooling fan don't work
  222. 96 Achieva don't start
  223. Please Help ..intermittent Trans Problem
  224. 92 achevia 3300 v6 hard starting idle shakey
  225. 94 achieva timing SOHC Quad 4
  226. Achieva starting hard after warm
  227. 92 fan problem
  228. 97 achieva power windows problem
  229. Fusable link???
  230. can i bolt in 3.4 or 3.8 in my 95
  231. service engine soon =warning
  232. need new turn signal stalk=
  233. White smoke under load
  234. 96 Achieva shifts roughs and..
  235. head light malfunction
  236. 1995 Achieva Power Window Control Module
  237. 97 olds passlock
  238. 97 olds achieva 2.4
  239. 96 Achieva Trans Problem
  240. Idle problem
  241. Wierd noise
  242. turn signals wont work
  243. 94 Quad 4
  244. 92, Ach, Full Throttle Low Speed...shaky idle...Transmission???
  245. MAF sensor
  246. 94' Achieva with dead engine.
  247. Oil Presure High
  248. 96 Achieva 2.4L wont start after replacing several parts
  249. 92 achieva quad 4
  250. interior lights and warning sounds
