View Full Version : Durango
- Error code 1491
- 2003 Durango Door Locks / Keyless Entry
- Changing a Waterpump on 99 Durango
- 98 Durango 5.2 uneven front braking
- 98 Durango 5.2 feels like misfire at idle
- Let's Start a HEATING PROBLEM RELALL
- 99 durango - starting problem
- turn signals flash
- 04durangofoglamps
- 99 D glove box lock
- Blown Engine
- Hissing noise from power steering pump
- Vent problem??
- Extended warranty for 02 Durrango
- Question for a 2001 dodge Durango rear wiper
- Engine controller
- New Here....
- coolant
- Should I Remove the catalytic converter?
- Rear Leaf Spring bushings Install
- heater vent smells acrid
- Replace Cruise Control Switch; '98 Durango
- Temperature problem, 2000, 4.7L
- Replacement Driving/Fog Lights
- Starting problem & parts on floor....
- Radiator Fan Relay
- Trade-in value Blues
- Price question....
- costs for lifting?
- Keyless Entry Died
- Codes P0121 and P0203
- 99 Durango Starting Prob In Cold Weather
- 1998 Durango problem
- 1999 Dodge Durango Front End Humming!!
- 24" ON DURANGO
- another coat of clear-coat?
- 1998 Dodge Durango Rear End Humming!!
- Check Motor lamp is Lit
- Durango spare stolen; advice on replacement & lock
- Dodge Ram Srt Convertion Kit
- 1999 Durango Tranny Problem?
- oil change
- Stock CD player for 99 durango
- Heater core
- door locks
- Weird tire wear
- Ashtray light bulb?
- Aftermarket Heated Seat Panels
- reverse humming
- 2001 Durango engine service light
- 98 Durango Stalling
- Clutch Fan vs. Electric Fan
- 98 D preventive maint.
- Replacing Ball Joints
- A Little RANT about Dodge - and other
- Oil Use 01 vs 99 tsb - please help?
- turn signals
- 2001 5.9 using oil ???? - what's acceptable?
- 98 SLT 4x4 Slipping Trans When Cold
- 2001 Durango 5.9
- Water on floorboard
- door speakers
- Loud humming/roar in rear end at hwy speeds
- Is a solid axle swap for a 2000 Durango possible?
- Bjoint recall
- Power windows
- '99 5.2 D w/ #5 & #6 Misfire! HELP!!!
- 2005 Durango Water taken into Hemi Engine
- 1999 durango 5.2 cranks over fine wont start
- 99 d radio harness ?
- Heater Problems
- Fuel Pump Failure
- Help diagnose Humming noise problem
- 2000 Durango - Transfer case leak
- 2001 durango engine light P0051
- 99d 75mph vibration
- 99 durango need help
- 99 durango overhead console
- Security light flashes
- leaking transmission
- Rear Control PLEASE HELP
- Durango start issue
- 2002 Dodge Durango Clicks on Acceleration
- AWD 4WD to 2WD
- Winter Chains
- tranny
- looking for side nameplate for a 2000 dodge durango
- 2000 durango code p0320/ frustrated
- 98 durango shift indicator
- 2000 durango power locks
- Air Conditioning problems w/2002 Durango
- what's with the brakes?
- 2000 4.7 cold Trans
- '98 Durango headlight problems
- starter removal 99 4x4
- 2000 Durango transmission
- meaning of Obd codes 0720 and 1368
- Code P0551, anyone else get this?
- resistor pack
- 01 durango PS leak
- help electrical problems
- 2000 durango power lock blowing fuse
- Moving stuff from one 2002 durango to another
- 2000 Durango Floor Heat
- About to Buy 2002 Durango
- 88 Durango with problems shifting to gear
- Headliner
- Wind noise
- 99 4x4 5.9L Rear Differential
- creaking noise front end
- engine oil type?
- Lifter noise
- 99 Durango stalled, now it won't start!
- PLEASE HELP-99 Durango TPS and Rear Rubbing Noise
- 98 Durango turns off as soon as I accelerte or reverse
- GPS 02' Durango
- Disk or Drum
- Dodge Durango SXT Gauge upgrade How To
- 2001 Durango - Headlights blink
- check engine light, code P1687
- moisture
- Front Body Mount Bolts
- help my radiator petcock is dripping.
- Intake gasket R&R how do I disconnect my fuel line
- no bus; check engine
- Help with 00 Durango Rear Brakes
- FS: 98 durango SLT plus w/ 87k miles
- Durango Error Codes
- Bad intake gasket, If I fix it will I get better MPG
- Transmission ?
- overheating
- Check Engine Light
- Check Engine light, ABS light, brake light
- 99 Durango - rubbing brakes
- ABS & Brake Light (Beating a Dead Horse)
- Ut-oh. Cold weather, there goes the idle
- Error code 1491
- acting crazy
- Replacing Thermostat on Durango
- Recallls
- 02' Durango SLT
- Door latches
- 2001 Durango Fuel Smell? After Starting?
- Engine Light and P0700 Code
- 2000 Durango/No speedometer, chk engine light, ABS light
- Creaking Noise
- 2005 Durango w/Hemi
- 2005 Durango Factory Remote Start
- 02 durango power Outage help!!!
- Durango PCM source that's cheaper.
- Super Charger
- code 320
- Need help- Dealership is stumped
- 99 Durango 5.9
- Wanting to buy Durango
- Keypad entry?
- Missing when idling???
- Rear Wheel Well Liner Removal?
- Durango stalls - It's in th UK and I'm in Qatar
- mp3 PLAYER
- Side Window Seal Replacement???
- ni turn signals
- ABS and Brake light stays on
- oil going bye bye
- Flashers and blinkers not working, replace flasher box?
- Front Blower Motor Not Working?????
- 20" rims and tires 4x4
- 2001 Durango R/T Power Outlet Problems
- Durango is loud and I think the engine is blown
- Help!! Rear Brakes Locking Up!
- Can I fix this P0601 code?
- What is P 0601?
- Drivers seat rocking
- 2001 Durango A/C works only on rear
- What battery for key fob?
- 2000 D acting up (again)
- New to this forum??
- Problem With Durango Vents
- Speed sensor
- 99 Durango power window problem
- overheating
- Durango A/C Question
- 4.7 Idle Air Control Valve or Throttle position sensor
- Installing Trailer Brake Under Dash Need Help!
- Popping Noise while making turns.
- 2000 slt A/C not working properly, blows warm air
- Overheating
- Power door locks problems
- Durango power locks problem
- help?? engine shut downs
- harmonic balancer removal?
- RE: 2003 D Computer reset?
- EVAP Problem
- A/C condenser removal?
- How to remove center console?
- a/c problems
- vibration while towing durango
- AIT relocation... in question
- 04 key and remote
- Replacement Speakers
- 2000 Durango - Error 1491
- 2000 durango
- Error code 1388
- 2003 Durango Overheat problem
- dome light flashes with emer. flashers
- specs
- 99 radiator fan problem, engine kill
- 03 5.8 Plenum air fitting Q
- What's the problem?
- Motor RPM's high shifting 1st/2nd/3rd
- Desperate Help for my 2001 Durango
- Blower resister on 98?
- 98 Gauges jump around with key ont of ignition
- Thinking about buying a '99
- Crazy Gas Gauge
- Where to mount trans. oil cooler
- Transmission cooler
- Durango Broken into, need new steering column? Help me please!
- 5.2 to 5.9 engine swap? anyone done it yet?
- Need Keyless Entry (HELP?)
- Thermostat
- 2001 Durango Cruise Control
- engine code help
- '98 stalls in a hard turn
- purge solenoid valve
- Wrong trans fluid??
- 1999 Engine Light
- 2002 Durango SLT Acceleration Problem
- stupid durango want start
- service 4wd light
- 1999 Durango 5.9L stalling issue
- power windows on 1998
- 2003 Durango transmission service
- trouble code po720
- dome lights
- AC Compressor kicking on and off?
- Water pump torque sequence and specs for 98
- check engine light on
- Love My Durango
- interior light fuse keeps blowing
- 4.7 gas mileage
- A/C about to go out?
- abs and brake light on after speaker upgrade, please help
- How to tell if recall work has been done.
- ball joint problem ????
- need advice
- Gauges Randomly Go Out, Warning Lights On
- power plug
