Our Community is 705,000 Strong. Join Us.
View Full Version : 3
  1. 08 Coolant temp sensor P0117
  2. annoying taillights are too bright
  3. Mechanic - Boston North Shore
  4. No Temperature Gauge
  5. Manual Transmission Fluid
  6. 09 Mazda 3 starts in neutral, but not park
  7. Condensation on Dashboard above A.C.
  8. brake noise
  9. mazda 3 skyactive (opinions)
  10. Mazda 3 oil change leading to problems...
  11. pcv valve
  12. premacy clutch problem scraping sound
  13. Brake squealing
  14. Timing belt
  15. vent air flow
  16. transmission adjustment
  17. 05 Hub Assembly
  18. Anyone know of a good repair manual?
  19. Humming noise from rear (stops with brake)
  20. radio help
  21. Need advice, messed up my new (to me) car
  22. Blocked EGR valve
  23. Oil Drain Pan Replacement
  24. Mazda3 won't start in neutral
  25. Cigarette Lighter Issue
  26. Mazda 3 Alarm Sensitivity
  27. Mazda 3 Won't shift!
  28. Friend has a Transmission problem
  29. I have a STRANGE problem, don't know where to place it...
  30. 99 Protege Electrical Problem
  31. Air intake
  32. Mazda3 power door lock problems
  33. Mazda3 alignment specs?
  34. 2004 3GT/2.3 engine Big Knocking
  35. Tire/wheel Noise from the front wheels 2005 Mazda 3 s
  36. Is this a good price on a 08 Mazda 3i Sport?
  37. 2008 Mazda3 Sport power steering trouble
  38. ABS Failure Mazda 3
  39. DTC codes
  40. Center console panel with cig lighter is loose
  41. Automatic Lock Issues
  42. 3 Vs. 6
  43. Mazda 3 warranty and 'recommended services'
  44. Mazda 3i won't start, clutch stuck!
  45. Plastic Covering under carriage under Engine
  46. Grinding noise in mazda 3 when turning.
  47. Headlight and horn won't shutoff
  48. Problems with new brakes wearing unevenly
  49. Mazda 3 parts
  50. cv axles and thermostat
  51. noul model
  52. Radio Auxilary input
  53. Reflector
  54. '06 Mazda 3 Oil change
  55. 2004 Mazda3 temp display
  56. 05 Mazda 3 Rough Idle And Lagging
  57. Automatic Transsmision
  58. How long to Clutches last on these things?
  59. Question about brakes...
  60. Brand new Mazda 3 wont start.. Help!
  61. Good Buy or not
  62. I really like my M3
  63. Accessing Fuel Computer in 08' Mazda3
  64. where is the oil filter located
  65. Funny sounding start...
  66. Does the 3 have ETS?
  67. BOSE - Sub Woofer Warning
  68. Wanting a Mazda 3i 2005 - Insurance?
  69. Mazda 3 pics
  70. Sunroof f'd up...
  71. NY/NJ/CT Mazda3's
  72. A lot of trouble!!!
  73. cracked oil housing-
  74. Brake/ABS light
  75. Air Bag/front seatbelt warning light
  76. oil question
  77. 2009 next mazda 3 (J68C)
  78. turboing a mazda 3.....
  79. 05 poping out of third
  80. i-sport vs. s-sport
  81. Brand new M3 - odd noise
  82. Dvd/ Navigation
  83. Hilarious Mazda3 video :)
  84. Trailer hitch on a 07' Mazda3 3.2 wagon?
  85. Mazda National Day – Orlando, Fl – Jul/28/2007
  86. specs and comparrison
  87. Cold air water damage?
  88. 2006 VS 2007 Mazda3...Question
  89. Clear Bra...need info!
  90. Got ticket, went to court and.........
  91. 17" Exel TZ-10 with Toyo proxes for sale
  92. Thinking about a 3.
  93. 2005 Mazda 3s ignition- keyless entry doesn't work
  94. anyone else own a speed 3?
  95. Swapping Transmissions
  96. Manual transmission
  97. Intake System
  98. FS: MJH Mazda 3s SEMA vehicle $15k out the door
  99. High RPM's
  100. I want A/C in my 2004 Mazda 3
  101. Friend is contemlating a 3
  102. fuel filter
  103. Crashed & Injured
  104. Interior
  105. damnit board wax
  106. Mazda3 A/C
  107. milage how much do you have on you 3
  108. Tell me what you think???
  109. *FS Mazda 3
  110. fs: Mazdaspeed Elite Projects Mazda 3
  111. Updated: Anyone looking to buy a Mazda 3
  112. Anyone looking to buy a Mazda 3S?
  113. Anyone looking to buy a Mazda 3S?
  114. FS: Several Items - Eibach, Injen, Hoen, Ultimate Pedals, OEM Mazda
  115. Millenia Ignition Problem
  116. intermittent starting problem
  117. Stolen...
  118. Replacing Rear Brake Pads
  119. Angel Eyes - Predator Chromium
  120. Mazda 3 HB performance parts
  121. Best place in Northern VA for tint
  122. deaad pedal
  123. Audio upgrade
  124. Adjusting the headlamp
  125. Mazda3 vs. Audi A3
  126. Exterior Temperature...Celsius/Farenheit
  127. which is the best sounding
  128. cold air intake
  129. M3 any good?
  130. turbos?
  131. does anyone know ...
  132. what do you use...
  133. Trouble starting
  134. speaker placement
  135. How do you like your Mazda 3?
  136. Light Swap Help Please Read!!!!
  137. FS 2004 Mazda3 S sedan
  138. Mazda 3 Deck
  139. Factory Stereo
  140. electrical
  141. Mazda parts
  142. wheels and tires
  143. 05 mazda 3 s fog lights
  144. Long Day
  145. Stock speakers Suck
  146. After Market parts
  147. Changing oil on the Mazda 3
  148. How much does the 3 hatchback usually go for?
  149. How big of rims can I put on my Mazda 3?
  150. whildriving slipped into neutral and back into drive and the car jerked? is it ok?
  151. mazda 3
  152. Just Bought a Mazda 3 - XM/Sirius Radio Question
  153. race
  154. mazda 3, great looking car.
  155. Mazda3 SP23
