Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chrysler
> Sebring | Sebring Coupe | Convertible
View Full Version :
Pages :
1
2
3
4
5
Yeah, I messed up
2005 2.4L DOHC 02 sensor location?
2003 Dash disassembly
sebring 2.7 overheats
Having Trouble Accelerating Uphill
Fog Lights on a 98 JXi
Photoshop users?
2005 Sebring TSI will not blow HVAC out floor vent
Please help 2000 Sebring running rough
i need guidance
2000 Sebring 2.4L Radiator Drain Petcock Replacement
timing belt for a 2.5 liter v6 seabring
97 2.5 liter power steering bracket removal
fuse blown, no spark
P0172 p0175 v6 2.7
Is it necessary to remove battery before connecting something to the radio?
What is it?
1998 Sebring Lxi Cargo roof bars
wont crank
2003 Sebring LX horn issues
Code P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
02 Sebring Limited Steering and Lights
2003 Sebring LX 2.4 check engine light
Fuel pump issues
digital mileage & rpm reader comes on and off - any one know why??
What is wrong??
98 Chrysler Sebring Convertible missfire
sebring Convertible Window only goes 3/4 ways up, Help
02 sebring no speedo,tach,or gauges
'97 Sebring Conv. Starts then dies
Wheel alignment
96 Sebring Lxi cranks but wont start
96 sebring convet 2.4 dohc
96-2000 Sebring Conv RECALLS
Chrysler sebring 05 overheating
911!!!chrysler sebring P0300 code and valve sound!!!
2002 Sebring Convertable Smells of gasoline when Idle
2001 front bumper cover removal
OEM tire size
Tpms
Dinged Door, Need Touch Up Paint
96 sebring con, has top sound like a diesel engine
rear rotor
2004 sebring stalling problem
97 Sebring 2.5L V6 intermittent miss
sebring 2.7 p0340 mystery
Idle control air valve
1999 sebring wont start
95 sebring 2.5
check engine light bulb burned out
Sebring '04 LXi, Check Engine is flashing, atfer a dead battery
95 sebring trans problems
04 Chrysler Sebring won't move!!
2000 chrysler sebring conv. service engine light on
Blower motor or blower motor resistor?
spark plugs
98 Sebring stalls and misfires
How to replace the upper strut mount on my 1997 convertible?
96 JXI runs rough
2000 Sebring LXI remote start operating instructions?
99 jxi Sebring convertible
2002 Chrysler Sebring Dash Lights
A/C drain
Rotten smell coming from AC
97 sebring cov. remote program
2001 sebring convertible air bag light problem
96 Sebring timing belt problem
2001 lxi 3.0 v6 ac prob
Blower Motor Resistor Replacement
2002 Sebring LXi P0705
No spark, No fuel
2001 sebring convertable hum under hood
95 sebring ruff ride
2001 chrysler sebring lxi radio flashing/noise coming from column????
99 Sebring Conv. electrical issues
98 Sebring JX-door bell/locks/interior lights flashing
04 thermostat Housing leaking
Car Shaking
1999 Sebring Conv. right side mirror doesnt move
How to Get DTC's for 1998 Sebring Convertible?
2004 sebring conv v6 cluster light issue
crankshaft pully 97 2.5L
97 Sebring power top button
1997 Sebring Convertable EGR or Distributor
98 Convertible Cluster Issue
2002 Sebring lx, 2.7 cooling problems
2004 Sebring LXi, 2.7, passenger window goes down only...?
engine exchanges
03 v6 O2 sensor bank 1 sensor 2?
Speedo WAY off....
1997 Sebring Serpentine/Idler Pully
97 JX downshift for no reason
07 Sebring Horn
98 Sebring Convertible, Transmission Noise, GOING NUTS!!!!
Misfire-multiple cylinders
2005 Sebring-Centre Shift Console
1997 Sebring wont stay running
07 sebring brake issue
2003 sebring gauge cluster stopped working
jerks when stopping
Sebring Body kits
Programing Keyless Remote for 2006 Sebring Convertible
Jumpy speedometer needle
Car wont start
soleniod pack
Whats the diffrence in motors from coupe to convertible??
heater blower hestiates
Ignition Gremlins
98 coupe hard to start when cold
A bunch of questions
Oil in all 4 spark plug wells
2007 sebring headlights... how to turn off?
2001 2.7 Sebring 177k Money Sucker
Lugnut broke off inside rim
1996 Sebring JX Convertible/ engine schematics
2006 Sebring: Brake light comes on when turning right
Strange shift problems
95 Chrysler Sebring disconnected and reconnected chassis ground with the battery att.
I have a problem...Answers anyone????
Changing lighter socket
99 Sebring Battery Issue!!!!
Coolant Question..
Front Brakes
99 coupe rims fit 03 sedan?
2006 electricial problem
2002 sebrind 2/7 coolant problem
Question! Any more damage?
'03 Sebring Wear?
99 sebring overheating
Center Console Lid Compatibility
PO601 CODE does it need a PCM/ecm
Electrical?
Brake Vibration
2.5l v6 dohc?
96 sebring conv.air vent controlls
Sebring engine Question 2.7?
passenger side axle help
Here's a strange one.
02 Sebring Conv. questions
97 Sebring convertible left rear seatbelt assembly removal
04 Sebring Oil Pressure Light
98 Sebring LXi A/C always on
2000 sebring highbeam headlamp
need right rear seatbelt assy for 97 convertible
96 sebring - timing chain
99 sebring fixed
99 sebring conv. nightmare
Read all posts on blower motor here is a new one for ya,
99 Sebring Convertible 2.5L Coolant Problem
1997 Sebring Convert. dashboard temp/directional sensor.
Loud Rattling, any ideas?
Coolant leak
2001 starter fuse keeps blowing
96 Sebring Conv. no spark/no start
1995 sebring coupe 2.5l v6 overheating
01 Trans? Help!
Door Check Strap
sebring oil leak
02 sebring front wheel squeaks on right turns and bumps
1996 Sebring Conv 2.5l engine compatability
98 sebring lxi runs like #$%^&
2003 sebring parts
2.5L V-6 interference engine or not?
HELP - 96 Sebring Died
What needs to come off to remove cluster on 1997?
convt boot 2004 sebring
2006 Sebring - Window Lock button not working
suspension upgrade
01' Headlights
02 sebring lx sedan brake problems
2004 Sebring - Clunking Transmission
Desperately Need Advice...1997 Sebring LX, timing belt broke!
04 sebring runs fine, jumps when trying to accelerate
Battery Location
174 OBD2 code
2001 Sebring LXI a.c. vent problem
Interion electrical problems
96 jxi speakers
2002 Sebring transmission trouble
brake problem on 96 sebring
Convertible water leak need help
2004 Chrysler Sebring Convertible
wheel spacer question
timeing belt on a 2.5l how bad is it to do?
keyless remote sebring conv 2000
1999 Sebring dash and parking lights not working
2000 Sebring Speed Sensor
Windshield washer fluid Spray thingy doesn't work!
2004 sebring dashboard diagram
97 sebring v6 humming noise heard when driving
Question about alternator and wheel bearing
98 Sebring Heater blowing cool/cold air
2005 Sebring touring, how good are they?
98 Sebring Convertible 2.5 V6 -Cam pulley bolts - right or left hand thread??????????
compatibility of 1998 engine VS 1996 Sebring
01 Sebring LXI heater problem...
Chrysler Sebring LXI 2002 coupe, question about motor
1997 Sebring Convertible electrical
Convertible Boot!
95 sebring lx 2.5 v6 start problem
2003 Sebring 2.4 X no start problem
2004 Sebring Battery
Help! Car won't go into gear
need help brake pedal issues
2000 Sebring front bumper removal
98 Sebring LXi starting problem
2003 Sebring LXi takes 2 seconds to shift to drive
99 Cnvtbl - left passenger window problem..pls help
AC pipe (gas pipe) freezing up
30 amp fuse keeps blowing
2005 Sebring conv.-check engine light & code 0129
Oil light/tranny bucking
wont start
Sunroof
heater prb 2004 sebring
05 Sebring engine miss
1998 Sebring Coupe - wanting to mod out - suggestions?
1996 Sebring in limp mode - what to try now?
1998 LXi Cylinoid clicking, wont go into gear
1998 chrsyler sebring lxi for sale
98 sebring lx convertable motor prob!
98 sebring lx conveertable motor prob!
Head Gasket
serbing overheating
Need help with battery....
How do you make a 2.7 v6 last?
no start need help plz
95 sebring timing belt snapped
A vibration on a 2001 sebring convertible limited edition
96-98 Seatbelt Control Timer Module
Proportion Valve Leak
Fuel Filler Neck Discontinued for ALL Sebrings
'95 Sebring coolant leak
water under seat
oil leak
Parts Needed for a 2004 Sebring Limited
2002 LX problem with AC when idle
2002 LX need help with keypad/horn
idler pulley bolt
dash light fuse?
96 Sebring Convertible how to program keyless transmitter
01 sebring a/c issue
Can I use a 2005 2.7L in a 2001 ????
Replacement Top
1996 Sebring LX - need to get in/under dash
radiator fan is not coming on...
97 Sebring PCM
Automotive Network, Inc., Copyright ©2012
