View Full Version : Sebring / Sebring Coupe / Convertible
Pages : [1] 2 3 4
  1. Lugnut broke off inside rim
  2. 1996 Sebring JX Convertible/ engine schematics
  3. 2006 Sebring: Brake light comes on when turning right
  4. Strange shift problems
  5. 95 Chrysler Sebring disconnected and reconnected chassis ground with the battery att.
  6. I have a problem...Answers anyone????
  7. Changing lighter socket
  8. 99 Sebring Battery Issue!!!!
  9. Coolant Question..
  10. Front Brakes
  11. 99 coupe rims fit 03 sedan?
  12. 2006 electricial problem
  13. 2002 sebrind 2/7 coolant problem
  14. Question! Any more damage?
  15. '03 Sebring Wear?
  16. 99 sebring overheating
  17. Center Console Lid Compatibility
  18. PO601 CODE does it need a PCM/ecm
  19. Electrical?
  20. Brake Vibration
  21. 2.5l v6 dohc?
  22. 96 sebring conv.air vent controlls
  23. Sebring engine Question 2.7?
  24. passenger side axle help
  25. Here's a strange one.
  26. 02 Sebring Conv. questions
  27. 97 Sebring convertible left rear seatbelt assembly removal
  28. 04 Sebring Oil Pressure Light
  29. 98 Sebring LXi A/C always on
  30. 2000 sebring highbeam headlamp
  31. need right rear seatbelt assy for 97 convertible
  32. 96 sebring - timing chain
  33. 99 sebring fixed
  34. 99 sebring conv. nightmare
  35. Read all posts on blower motor here is a new one for ya,
  36. 99 Sebring Convertible 2.5L Coolant Problem
  37. 1997 Sebring Convert. dashboard temp/directional sensor.
  38. Loud Rattling, any ideas?
  39. Coolant leak
  40. 2001 starter fuse keeps blowing
  41. 96 Sebring Conv. no spark/no start
  42. 1995 sebring coupe 2.5l v6 overheating
  43. 01 Trans? Help!
  44. Door Check Strap
  45. sebring oil leak
  46. 02 sebring front wheel squeaks on right turns and bumps
  47. 1996 Sebring Conv 2.5l engine compatability
  48. 98 sebring lxi runs like #$%^&
  49. 2003 sebring parts
  50. 2.5L V-6 interference engine or not?
  51. HELP - 96 Sebring Died
  52. What needs to come off to remove cluster on 1997?
  53. convt boot 2004 sebring
  54. 2006 Sebring - Window Lock button not working
  55. suspension upgrade
  56. 01' Headlights
  57. 02 sebring lx sedan brake problems
  58. 2004 Sebring - Clunking Transmission
  59. Desperately Need Advice...1997 Sebring LX, timing belt broke!
  60. 04 sebring runs fine, jumps when trying to accelerate
  61. Battery Location
  62. 174 OBD2 code
  63. 2001 Sebring LXI a.c. vent problem
  64. Interion electrical problems
  65. 96 jxi speakers
  66. 2002 Sebring transmission trouble
  67. brake problem on 96 sebring
  68. Convertible water leak need help
  69. 2004 Chrysler Sebring Convertible
  70. wheel spacer question
  71. timeing belt on a 2.5l how bad is it to do?
  72. keyless remote sebring conv 2000
  73. 1999 Sebring dash and parking lights not working
  74. 2000 Sebring Speed Sensor
  75. Windshield washer fluid Spray thingy doesn't work!
  76. 2004 sebring dashboard diagram
  77. 97 sebring v6 humming noise heard when driving
  78. Question about alternator and wheel bearing
  79. 98 Sebring Heater blowing cool/cold air
  80. 2005 Sebring touring, how good are they?
  81. 98 Sebring Convertible 2.5 V6 -Cam pulley bolts - right or left hand thread??????????
  82. compatibility of 1998 engine VS 1996 Sebring
  83. 01 Sebring LXI heater problem...
  84. Chrysler Sebring LXI 2002 coupe, question about motor
  85. 1997 Sebring Convertible electrical
  86. Convertible Boot!
  87. 95 sebring lx 2.5 v6 start problem
  88. 2003 Sebring 2.4 X no start problem
  89. 2004 Sebring Battery
  90. Help! Car won't go into gear
  91. need help brake pedal issues
  92. 2000 Sebring front bumper removal
  93. 98 Sebring LXi starting problem
  94. 2003 Sebring LXi takes 2 seconds to shift to drive
  95. 99 Cnvtbl - left passenger window problem..pls help
  96. AC pipe (gas pipe) freezing up
  97. 30 amp fuse keeps blowing
  98. 2005 Sebring conv.-check engine light & code 0129
  99. Oil light/tranny bucking
  100. wont start
  101. Sunroof
  102. heater prb 2004 sebring
  103. 05 Sebring engine miss
  104. 1998 Sebring Coupe - wanting to mod out - suggestions?
  105. 1996 Sebring in limp mode - what to try now?
  106. 1998 LXi Cylinoid clicking, wont go into gear
  107. 1998 chrsyler sebring lxi for sale
  108. 98 sebring lx convertable motor prob!
  109. 98 sebring lx conveertable motor prob!
  110. Head Gasket
  111. serbing overheating
  112. Need help with battery....
  113. How do you make a 2.7 v6 last?
  114. no start need help plz
  115. 95 sebring timing belt snapped
  116. A vibration on a 2001 sebring convertible limited edition
  117. 96-98 Seatbelt Control Timer Module
  118. Proportion Valve Leak
  119. Fuel Filler Neck Discontinued for ALL Sebrings
  120. '95 Sebring coolant leak
  121. water under seat
  122. oil leak
  123. Parts Needed for a 2004 Sebring Limited
  124. 2002 LX problem with AC when idle
  125. 2002 LX need help with keypad/horn
  126. idler pulley bolt
  127. dash light fuse?
  128. 96 Sebring Convertible how to program keyless transmitter
  129. 01 sebring a/c issue
  130. Can I use a 2005 2.7L in a 2001 ????
  131. Replacement Top
  132. 1996 Sebring LX - need to get in/under dash
  133. radiator fan is not coming on...
  134. 97 Sebring PCM
  135. 2004 Sebring Limited won't start!!!
  136. 2001 Chrysler Sebring Jxi Convertible - Only $2999
  137. Programming a 2000 Chrysler Sebring Fob
  138. Rims
  139. Radiator Drain?
  140. 98 sebring convert battery problems
  141. 2000 sebring engine flush
  142. Bolt Pattern Mishap
  143. Problem with power to radio, maplights, keyless entry ??
  144. 1998 cirrus 2.5L code 1495
  145. 2000 Sebring Convertible Power Windows
  146. 1998 Sebring sedan
  147. 2001 Sebring Convertible Clock Spring
  148. 97 sebring transmission noise
  149. 98 sebring lxi, tranny?
  150. blower motor resistor
  151. HELP! 2003 Sebring problems
  152. 97 vs 98 : Convertible vs. Coupe Engine Swap
  153. 2005 Sebring wheel rubbing problem
  154. 1996 stalling and idling rough
  155. Emblems for Sebring JXI
  156. Electrical Problems
  157. 03 Sebring, 2.7 water pump
  158. Squeaking noise when steering in the cold
  159. Programed 04 Chrysler Sebring Convetebol Remote Keyless Entry Key Fob
  160. 2001 sebring sedan lxi 2.7 engine swap!!! HELP!!!!
  161. 2002 Sedan headlights on........heat off
  162. How do I check 2002 Sebring blower motor
  163. Water Pump replacement
  164. Computer??
  165. Convertible engine in a coupe??
  166. strange leak
  167. removing alarm system
  168. 97 LXI Convertible power pass lock not working!
  169. rear window coming unglued
  170. Sebring headrest removal
  171. swap a 2001 2.7l to a 2004 2.7l NGC
  172. lowering my sebring
  173. Installing a new convertible top
  174. 1999 sebring coupe 2.5 hesitation
  175. 2006 Chrysler sebring
  176. oil light 1999 Sebring
  177. 2001 Sebring Drivers Side Mirror Replacment
  178. 2002 sebring convertible keyless entry
  179. Engine cuts out at 3000rpm....
  180. 2.7 cranks but doesnt have spark need help
  181. does anyone have a chrysler 2.7 car i need help
  182. 2000 Sebring Heater Hose
  183. 95 Sebring wont start
  184. Lug Locks?
  185. Requesting Tips on Replacing EGR Valve in 97 Sebring LXI Coup
  186. blower
  187. 2004 sebring limited coupe spark plugs
  188. 97 sebring throttle HOT! Fire melts
  189. RPM Problems....Ahhhhhh!!!!
  190. 97 Sebring cranks over but wont start
  191. Replacing the Thermostat.
  192. tranny trouble
  193. belt replacement
  194. '97 2.5-liter runs ruff cold, smooth warm. Need help, suggestions
  195. Sebring Transmission or sensors?
  196. Rear View Mirror
  197. No Power Steering 97 sebring..
  198. 99 lxi convertible - radiator, etc replacement
  199. 2001 chrysler sebring convertible, steering wheel hard to turn in cold weather
  200. New Timing Belt...
  201. 1997 chysler seabring convertable top doesnt go down or up
  202. 98 Sebring ABS problem
  203. 98 sebring coupe keyless remote
  204. sebring convertible
  205. 01 Horn Issue
  206. 98 weatherstrip
  207. Parts for JXI convertible
  208. Whining
  209. 96 Sebring Conv hard start, rough idle
  210. Can't get heat through the defroster vent
  211. Wheel hub help?
  212. Key won't turn in ignition
  213. Aftermarket amp install
  214. front end rattling
  215. factory alarm
  216. what remote?
  217. 1997 Chrysler Coupe Wipers
  218. 1998 Serbring LxI to buy or not
  219. Sebring Coupe + Chrysler 300M wheels compatibility
  220. 2000 Sebring Limited Ignition
  221. 99 Sebring JXI Convertable
  222. 96 Sebring 2.5l / humming noise while turning left
  223. 97 Sebring 2.5L coolant leak.
  224. Serpentine belt
  225. Top of rear strut Loose
  226. Speedometer acting funny.
  227. Car starts shaking at certain speed?
  228. Ralph Sr
  229. 1996 chrysler sebring
  230. considering purchase
  231. 2000 JXi problems
  232. 2003 sebrin glxi
  233. carpartswholesale.com ripped me off....beware
  234. 2000 JXi fuel filter
  235. Water in engine of 1997 sebring convertible
  236. 2001 sebring drivers window wont go up
  237. 1999 Sebring Wont Start
  238. a/c drain tube
  239. 97 Jx Serpentine Belt Diagram(not Under The Hood)
  240. 1995 Sebring Front bumper
  241. 1996 Sebring JXI Conv Overheating
  242. Game: Name that noise
  243. 98 Sebring (Stratus) Convertible stereo/cd problem
  244. Offset and bolt pattern.
  245. convertible top motor
  246. 1999 2.5L convertible tune-up
  247. egr
  248. 04 Sebring Conv. Side Mirror Casing Cracked
  249. '96 Sebring Water Buildup, Only rear speakers play.
  250. 2002 Sebring Water housing leak
