Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chrysler
> Sebring / Sebring Coupe / Convertible |
View Full Version :
Web
AF
Pages :
1
2
3
4
2000 Sebring JXI Backseat removal
dark transmission fluid
Sebring loud squeling noise
"01 Sebring Sedan with blown engine - HELP
Need this answered...
2001 Sebring Conv - Radio lights blinking
Need Help With OBDII CODE READER
What does a EGR Valve do
partingout 95 sebring & 96 cirrus
1998 jxi won't start when fuel < 1/4 tank
Sebring cooling fan/ Please help
LXI stereo
torque converter
Need info on 01 Sebring
What are the best brand of tire to run on my 02
Remote Keyless Entry - RC failing
Smoke coming from heater vents
should i buy this??
1999 Sebring Tranny Troubles
Thinking about buying a sebring
97 sebring stalling and misfiring
Exhaust ?
kill switch
electrical issues radio/door locks/fan dial
radio wiring diagram
Map Sensor
'96 convertible 2.5L dohc timing belt install
Starting problem
dash board lights flickering
AC mode panel problem
Sebring power steering problem??? HELP!
Blow interior lights (96 sebring lxi)
Top not working and mirros out
2001 Sebring Sedan Water Leak
95 Sebring Transmission replacement
help???
wifes car wont start 1997 sebring
Electrical glitch
Electrical glitch
WTB Sebring
Brake Light Flicker
Steering Wheel / Ignition Lock
Location of the car battery for a 99 Chrysler Sebring convertible??
What Works The Fan??????????
97 sebring coupe 3600$ is it worth?
Radio differences
radiator fan has stopped 4 days and then works again?
Adding an inline converter
Keyless Entry Remote Programming Instructions 00 Sebring ??
Sebring convertible rear window unglued
99 Sebring Convertible jx
help!!! having a electrical problem!!
2001 sebring cup holder/ashtray light
01 sebring heat cuts in and out
1999 Sebring Fuel Filter Location?
99 Sebring Convt stuck on Defrost
1999 chrysler sebring keyless entry reprograming
01 factory alloy rim
ingition key not working
sebring 01 was overheating now wont start
Stalling problem
wire colors
Sebring Tire Pressure
01 Sebring Intermittent Start/Fuse blowing
heater control not working
Chrysler Crosswagon 'Signature Series'
Door mechanics (messed up)
ignition fuse
1996 sebring jxi will not start
sebring 4 sale
swapping stealth motor into sebring?
Stattin / idoling problem
New car - wierd sound..
HELP: New Amp STILL NOT WORKING
No start 96 sebring lxi
Sebring Radio reset
97 sebring 4-sale
temperature gauge on the 2004 Sebring Convertible
No electricity after replacing EGR Valve on 2000 Sebring
97 Lxi speakers
Wipers Stay On Intermittent in Off Position
Fan motor only works on high still after resistor block change
looking for peformance parts and info on motor mods. 97 bring
fuel gauge flipping
98 Sebring Convertible
2001 Sebring 4dr engine knocking
replacing convertible ragtop
battery light still on
not charging
2000 JX Conv Keyless entry question
overheating sebring v6/96
Blower Motor Resistor Replacement (with pics)
Remote Program
Radio CD/ Power Window
97 Chrysler Sebring convertible remote programming
2001 LX Sebring Convertible
Handbrake light comes on when I accel.....
engine stalls + oil light on
think it might be starter related
96 Seabring Not Running
Sebring factory radio and 4 6"by9" speakers for sale
remote programming for 2000 Sebring convertible
Power Door Locks
motor mounts
Oil Pressure Indication Light
'98 Sebring Convertible Key
washer pump quit on 2001
A/c Problem On 1997 Sebring Conv.
under dash cd player
replacing tail light howto
1999 Sebring CONVT - verticle recliner lever doesn't work
ac controls
2001 Sebring Front Right Whine
Exhaust for '99 2.5L Sebring?
plugs & wires on a 2000 sebring convt
idling problem
1995 sebring diagnostic codes
HOw to make my Sebring a Lil Faster
Buying used '97 Sebring ...
What system is in this thing?
How do you get your inside door panels off? 97 sebring coupe lxi
Transmission locked - can't start-1997
Blown Head Gasket
defrost controls
Convertable Tops
99 Jxi Suspension/chassis rattle
2002 Sebring Conv. Electrical Problem
97 lxi steering wheel shakes when going fast..
95 Sebring Electrical Pest
96 Sebring Tachometer problems
99 Sebring LXI Timing belt???
Really Strange Lighting Problem
Exhaust For 99 Sebring?
1998 LXI Transmission
2003 sebring torque converter can it cause whining
2003 Sebring Oil Sludge?
99 Sebring Wont Start!! PLEASE HELP!!!
Door locks not working
Speedometer reads 0 transmission wont shift out of first
2000 Sebring JXI Convertible Keyless Remote
What type of Remote?
Subwoofer options on a ~'97 Sebring Vert?
factory radio problem
2004 chrysler sebring remote programming
Intermittent tachometer and odometer
Considering 97 Sebring JX - Questions
dash lights
Wiring Diagram
Cirrus tire pressure
Tail Lights
97, 197000
Gas Pedal Tension Adjustment ...
Water in the rocker panels
96 sebring conv for sale southern california
engine swap
2000 Convert Windshield Washer Relay
Oil Light Flicker
Keyless remote
problem with radio after battery dies
98 Sebring Convertible...water in the rockers?
1998 sebring ? location of conv top motor
96 Sebring Rt Rear Tail Light Assembly
Trouble with my 98 sebring convertible
wanted- gray leather driver's seat 97 jxi
rear window convertible 04 sebring
Remote programming for 99-01 Sebring Convertible?
97 lxi tranny
How do you program remotes to a 00 Sebring LXi Coupe?
Infinity Factory Sound System
Keyless Entry
sebring JXI No air out of vents
1996 sebring convertible tail light
98 seb conv jxi ignition fuse problem
Odd question about size of Sebring
Another Fan switch problem (maybe the same)
white gauges lighting Sebrnig Conv2000
99 Sebring JXi Coupe Remote Starter
1995 Sebring 2.5 engine quits running.
Seat Belt (Convertible)
Chrysler 2.7L Engine Problems
Ignition key stuck AFTER visiting mechanic.
Power Door Lock Question..........
Needing A Stupid Answer For A Stupid Question....
stock radio removal
Autostart - no heat?
For Sale: Sebring Custom Trunk Mounted Subwoofer Boxes
crysler sebring
2001 Sebring rear jack points
High beams
1996 Sebring JXI Convertible
Fan switch control problem.
sebring cold air intake
Cruise control not working, 2.5 automatic
my car dies while i am driving. then i stop and start it and it starts right back up.
dome lights dont work when opening doors
96 Sebring Convertible Body Kits
Sebring Keyless Remote Programing
01 Sebring replace headlight bulbs
99 Sebring Check Engine Light
96 JXi Bogging out
99 SEBRING LXI <~Makes wierd sound when shifting!
96 Sebring Wiper Blades
Door Handle Broke Off
Cross Member & Extended Warranty??
98 Starting Problems
HVAC dash lights not working
Custom Car Audio System for sale
Some JXi questions
96 SeBring Fuel Pump Location
96 Sebring starting probs
1998 Keyless Remote Programming Instructions
Need help on tuning and souping up my engine!!!!!!!!
Brakes
1998 Chrysler Sebring JXi Conv Reliability?
Water
96 Convertible 2.5L hesitation
HP question
Electrical System Discharge 1996 conv
Body Kits
98 sebring
Euro taillights?
seabring jxi broke
Indiglo Guages????
Remote programming
gas
1998 JXI engine performance
What's yours?
Seat Covers
2002 Sebring Convertible
Sebring Convertibles
Web
AF
