View Full Version : Sebring / Sebring Coupe / Convertible
Pages : 1 2 [3] 4
  1. 98 seabring convertible top goes down but wont go up!!
  2. 1999 sebring crank sensor
  3. '00 Sebring Dash Gauge Light Problems
  4. something weird spark plug poping out?
  5. 98 JXI Convertible - Rear Tail Lights
  6. power windoe
  7. LXi battery
  8. engine surge - 2004 sebring touring - V6
  9. LXi Amp
  10. a/c problems
  11. Questions on semi-stick
  12. 03 LX spits & sputers
  13. Door makes clicking sound when opened
  14. fog lights
  15. Sebring LXi Pipe Size
  16. 1996 sebring jxi
  17. Anyone buy injectors from rockauto.com??
  18. Taillight
  19. catback exaust
  20. LXi Intake
  21. starts then dies
  22. 2001 Sebring LXi
  23. Water Damage
  24. A/C, Heater Blower Works only on High
  25. Need some advice.
  26. fog lamp and headlight brights problem
  27. Starting problem and rough running
  28. Sebring - Power Source/Cigar Lighter quit working
  29. Stock Speakers in a 2001 Sebring Sedan
  30. Radiator drain plug location.
  31. radiator drain plug location
  32. alternator replacement?
  33. Maintenance Advice
  34. Poor gas mileage, engine dies, rough idle, 98 JXI
  35. Radio Lights flashing after jump start
  36. 93 lebaron tranny problem
  37. 2001 sebring conv. - removing center consol
  38. 1997 sebring
  39. Watch out for rip off mechanics
  40. Help! 99 sebring convert. door /electrical problem!
  41. Help Installing A System in a 01 LXI
  42. Harsh downshift
  43. Boot for sale
  44. sebring with no power
  45. A few questions, need help
  46. 99 Sebring runs rough
  47. All lights flickering
  48. 2000 Sebring with a power steering noise
  49. 2000 Jxi- No Spark
  50. Struts
  51. Sebring Radio Problem
  52. Random Alarms___
  53. running out of gas??
  54. New Member To This Site
  55. Gas Mileage?
  56. Help with my 2001 sebring lxi please
  57. Sebring jxi 97 Idling
  58. 97 Sebring
  59. 2001 LXI Battery replacement and "squeak from front wheel"
  60. 20 Inch Wheels On A 2002 Lxi Sebring
  61. water pump replacement
  62. Fan Switch won't move air to front panels 96 (def & floor ok)
  63. What else can go wrong with my sebring?!?
  64. no heat- Electrical
  65. Help!!
  66. Water pump & timing belt
  67. vanity mirror light
  68. New carpet & Upholstery
  69. Auto Dimming mirror needed
  70. turn signal stuck
  71. 2002 Sebring Heater
  72. my sebring mod list
  73. Is this possible?
  74. Serpentine Belt
  75. 98 sebring lxi parting out
  76. Shocks or Struts on 97 coupe
  77. Seat heaters
  78. '98 sebring emergency brake
  79. cruise control speed, is it accurate?
  80. Engine removal 2000 2.7l
  81. High Idling
  82. Heater only on high, after restitor change
  83. dash lights won't work on 98 jxi limited
  84. 1998 Chrysler Sebring Overheating
  85. Is $550 to much?
  86. Speaker Removal
  87. MORE transmission trouble
  88. Keyless Entry Problem
  89. '98 convertable leaking water into the cabin
  90. Can't remove Plug Coil!!
  91. 2001 Convertible (top)
  92. 2001 sebring battery dicharging
  93. Need Exhaust Tips
  94. radio compatible
  95. 97 Sebring JXi Fuel Gauge Problem
  96. Data Link Connector Numbering
  97. new owner
  98. Starter Removal
  99. smoking sebring
  100. Problems starting
  101. 2002 Sebring Programing key
  102. 98 Sebring Conv. stalls at low speed
  103. 95 Sebring
  104. 1998 sebring has no spark, it wont start
  105. engine fuses blowing
  106. 98 Sebring JXI Remote & Radio
  107. Post Tune-Up Problems - ALL Advice Appreciated
  108. How to diagnose radiator fan issues
  109. 98 Sebring Convert RF hum
  110. 98 Sebring Conv - oil level
  111. 2001 sebring conv.2.7 engine needs a boost
  112. Installing Airbags
  113. 97 Sebring Blower Switch only works on high
  114. please help me with brake light
  115. 99 sebring # 8 fuse blows
  116. Chrysler letter
  117. electrical issues
  118. RPM drops to zero while driving
  119. 99 Sebring LXi Coupe
  120. Engine Problem
  121. Electrical Short Possiby???
  122. 98 Sebring Interior
  123. remove the governer on trotle fro more speed
  124. Factory 17 inch alloys for sale
  125. 05 sebring signiture
  126. Door locks
  127. 96 Sebring Won't Restart After An Hour
  128. Keyless entry?
  129. looking way to unlock trottle lock
  130. Code 301
  131. "98 Sebring convertible problem
  132. Help with replacing front bumper for Sebring convertible
  133. Electrical Problem
  134. Turn the key, then nothing.
  135. Convertible Top
  136. Transmission Shift Noise
  137. Help! Oil pressure HIGH????
  138. PROGRAMMING INSTRUCTIONS for 04 Sebring
  139. 1998 chrysler sebring conv. battery issues
  140. Water in Rocker Panel
  141. fuel pump problem
  142. Spoiler Needed
  143. Fuse problem? Wierd electrical
  144. Antifreeze leak
  145. wiring schematics
  146. o2 sensor on 98 sebring convt
  147. After new battery put in it starts but wouldn't idle at low rpm
  148. what is the problem with starting
  149. 1995 Sebring LXi "FOR SALE"
  150. Tranny not shifting
  151. squeaking in front end area
  152. Chrysler Sebring Blower
  153. Fuel guage all messed up!!!!!!
  154. 1996 sebring tranny problem
  155. blower switch does not work at all!
  156. idling on rev high
  157. Most bizarre thing
  158. Several more problems with 96 Sebring
  159. loud roaring at higher speeds
  160. gas tank for 01 sebring lxi
  161. 1996 Sebring Convertible Headlight Bulb
  162. Spark Plug Change & Timing Belt
  163. A30 Fuse issue
  164. Owners Manual Info
  165. Chrysler Sebring Transmission problems
  166. Advice? Looking at '05 to buy.
  167. blower works on 1,2,3; not High
  168. 2001 Chryler Sebring won't start
  169. 97 problem with power steering/AC/battery
  170. water dripping from underneath pass floor board
  171. Lack of power
  172. Seat belt problem
  173. 95 Sebring SRS light won't go out
  174. missing at 55 mph - 99 Sebring
  175. idiling problem - 99 Sebring
  176. Timing Problem?
  177. Low Fuel Level Warning Light
  178. key programming...
  179. ignition wires
  180. Power top hydraulic line replacement
  181. Does anybody have a 1995-2000 sebring convt?
  182. 01 Sebring Convertible Side Skirts
  183. It's the motor mounts, right?
  184. 96 JXA cooling fan won't start HELP
  185. Horn Problem... Unbelievable!
  186. Help with flushing the radiator
  187. 97 Sebring JXi: Loosing all electrical and getting "Ccd" Error Message
  188. Sebring overheating
  189. 98 Conv JXI Oil Pressure Switch Leaking
  190. common problems in Sebrings?
  191. top will not go up.
  192. Anti Freeze Leak 2.5 V6 1997 Sebring
  193. Cruse Control Problem
  194. one bad rim need to buy replacement
  195. wanted and looking for keyless entry program for sebring 2001
  196. No Start Situation
  197. Car For Sale!!!
  198. 2001 Sebring Power Mirrors
  199. 2001 sebring keyless entry programing
  200. Electircal Problem? Dash Radio Flicker
  201. Convertable Performance Mods
  202. 99 sebring key wont turn!!
  203. Daytiem Runnign Lights
  204. Tranny problem
  205. '97 Squealing Brakes
  206. Difference In Sebring JXI and JX?
  207. oil coming out of exhaust
  208. 98 cnvt front end thumping sound
  209. convertible tuneup,is it easy?
  210. Air bag light keeps coming on?????
  211. 98 JXI 6-CD changer adapter
  212. Location of OBDII port
  213. changing air filter
  214. Warning about jacking up Sebrings!!
  215. Transmission Overheating
  216. where to buy accessories?
  217. 95 lebaron oil pump change?help
  218. 98 Sebring Lxi speaker sizes
  219. Good Tires????
  220. Sebring owners
  221. Timing Belt
  222. 98 Sebring Conv. Top Motor
  223. missfire and backfire
  224. Rusting Shock Tower
  225. Keyless Entry Remote Programming For A 97 Jxi
  226. Does it worth?
  227. Won't Start
  228. 1997 sebring jxi
  229. Engine braking during cruise control
  230. Rims
  231. programming keyless entry
  232. LXI w/Infinity Sound System
  233. 97 JXI starts when engine cold but not when engine hot
  234. location of the fuel filter on a 95 sebring
  235. turbo thoughts? help!
  236. transmission hesitation
  237. 1999 Sebring Convertible JXI
  238. 1999 Sebring Convertible JXI
  239. Eng. Noise
  240. Manual avail on 01?
  241. 200 Sebring Low Idle
  242. 98 LXI tweeters
  243. 1998 sebring won't pass smog
  244. Ignition lights went out & won't start
  245. digital odometer goes blank
  246. Sebring starting problem
  247. 2001 v6 starter location
  248. aftermarket stereo help
  249. overdrive vs drive
  250. 98 sebring conv. 2.5 misfires runs rich
