Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chrysler
> Sebring / Sebring Coupe / Convertible |
View Full Version :
Web
AF
Pages :
1
2
3
4
2001 lxi p605 internal controm module error and p700
**please Help** Speedo Is Way Off
2001 sebring convertible headrest removal
ac/heater climate control / floor vent only
Dashboard peeling on 03 Sebring Coupe
02 Sebring Sedan electrical issues
help, 2001 sedan ground wire location
Dash board vents
2003 sebring a/c+heater problem help please
1997 convertable with starting/power problems
2001 LXi Sedan
Cost of replacing starter on 97 sebring conv?
Emergency Brake Light Problem
2001 Conv. Troubleshooting blown Fuse #5
01 sebring 2.7 engine removal
1996 sebring a/c problem
Sebring LXI dash board
03 Sebring LXI Mods
2003 chrysler sebring
battery wen dead
Engine removal 2002 sebring convertible
1996 sebring LXi service manual
96 Sebring stalling and hesitating problem finally fixed.
03 Sebring Oil light flicker
1997 Sebring Convertible Parts Car
2000 JXi Convertible Brakes
2001 Chrysler Sebring Ac Question
White Smoke
96 Sebring NO start NO spark
1998 sebring conv. rad. fan burning up inside.
tranny problems
2000 Sebring Convertible valve tick
chysler sebring 2002
Fuel Lines 96 Sebring JX Conv
seat belt guide
Used car questions?
2002 sebring Lxi
Spark plug location 1998 sebring convert
2002 sebring thermostat
Replacing Factory amp
96 Sebring Conv. won't start, will jump
Wind noise & water leak - 2 Ft windows of Sebring
Problem with Passenger side rear power window
97 sebring conv wont start
2002 sebring LXI Coupe - Shift Solenoid B???
'97 Convertible: 2.5L timing belt change
'97 Conv - Trunk won't open (jammed?)
Sebring won't start. Not the battery. Where's the Starter!?
Loss of Power
96 sebring lxi problems
1998 Sebring Convertible Part needed
99 Sebring won't start
2000 Sebring won't start
Sebring electrical problem intermitant no radio or wipres
Pulling the engine
98 sebring convertible dash vent wont open
Help!!! Thermostat Housing Leaking
2002 Sebring Sedan Battery Questions
EGR Circuit Malfunction-1998 Sebring
1999 Sebring conv. fuel pump?????
02 Sebring BIG problems? Don't know if its transmission.
1995 Chrysler Sebring Horn Alarm
Did you try to repair thermostat housing on 2.7 engine? 01 Sebring
more hp
2007 Sebring trunk latch
1997 Sebring coupe transmission problem, help pls !!!
Sebring Dash Lights
Chrysler 1998 SebringTransmission down shift
2000 sebring no bus ccd
2002 sebring lx noise from back
Driving problem
Replacement of Crank Sensor in a 1999 Chrysler Sebring JXi Convertible
2006 Sebring Touring sedan
Headlight Replacement
BIG help help please
another 1998 lxi conv. not starting!
removal of door panel
Spark Plug Popping Out
2000 Chrysler Sebring fan switch help
Mpg
1996 Sebring Convertible Has A Mind Of It's Own!!
brake light
1998 sebring jxi convertible cold weather p/s noise
underbody shields?
i need serious help with this
2001 Conv - RPMs All Over The Place - Engine Revving
99 Sebring JXI brake light problem
speedo is way off and tranny problems
Keyless remote
97 sebring convertable top wont open / close
digital odometer turned off and rpm isnt working either
2001 Lxi Coupe Transmission noise when cold
I need a little expertise here....
2001 Sebring LXI Opinion Needed
Glove compartment
1998 Chrysler Sebring LXi Coupe stalls makes weird noise in park or at low speed.
1998 Chrysler Sebring LXi Coupe stalls at low speed.
Problems with Remote Starter Installation
I Ran Thru A Huge Puddle And Now My Car Wont Start
Removing a thermostat
New Transmission Problem not already listed
Heater AC and Lights Problems
Creaking noise coming from front tire wheel, help!!!
2000 chrysler sebring jxi convertible
97 Sebring Dash Lights
Spongy brakes
Antifreeze flowing when cold
2003- Transmission & radiator leaks FYI!
Should I buy this Chrysler Sebring lxi?
HELP ASAP! 2000 Sebring
97 Sebring convertible seat belts lock up
timing question
where is it
2001 sebring front grill remove
oil change
oil seal
2001 sebring lx front grill removal
oil leak
manuel trans sebring
1999 Sebring LXI engine noise when cold
Radio Question
very slow acceleration to 0 to 200 rpm
Interior lights stay on
2004 4 Door Sebring Keyless Remote, How to Program?
How Much..?
Stupid question: where is the power amplifier? (1996 JXi)
2001 vibration 45mph+ when on accelaration
1999 Sebring door lock wiring diagram
2004 sebring Headlight Adjustments
Convertible top adjustment
97 sebring!looking to cstm..
2001 coupe to 2003 coupe conversion, possible?
question about the dashboard
Head Gaskets?
Can't find info on 1995 sebring transmission
96 LXI Problems
1996 sebring conv. remote fob
Dual Exhaust Question
Transmission Fluid
Sebring JXI 1997
2002 Chrysler Sebring Brake Light on Corners
99 sebring convertible clicking sound
96' Sebring Coupe 2.5L Front Brakes
99 sebring conv. door sensor issue
01' LXI Conv. AC Compressor-DIY???
2002 Chrysler Sebring Sedan LX 2.7 v6 Noise?
Help 2001 Sebring stalls
help
Siren Noise 2004 Chriysler Sebring LX
04 sebring LX
HELP!! 96 Sebring JXi Convert will crank but not start
99 Conv-Blower Motor Resistor Keeps Blowing Out
99 Sebring Convertible - Won't start. Key problem, or part of the antitheft system?
96 Sebring Coupe Transmission Problem
2002 Sebring Coupe Remote
Is there a mod to perform to allow the fogs on an 02 to light without headlights?
Sebring Key Starts Intrepid
2002 Sebring Convertible CD player
1996 Sebring Program Door Lock Remote
Heat core replacement.
Convertible rim offset JX
Problem with AC (Sebring JXI 97)
97 Sebring Conv Cooling Fan
Torque manaagement disable? Ill affects?
1996 2.7L Spark plug change time? PLug brand?
Dash removal
2001 Sebring LXI Power Window Problems
02 LX shifting issue
Engine Codes
p1698 code 2001LXI
Recalls
Stalling at 65mph!!
Small Oxygen leak? New Gas Cap?
Blown door panel speakers
Headlight question
Looking for advice on aftermarket performace for Sebring
Cold Air Intake Systems
Air condition Problems
Help Me Install My Alarm
Chrysler Sebring Facelift
Sebring Convertible Radio
2000 jxi conv
96 sebring convertable
04 Sebring question
Painting issue...
2000 Sebring Jx No spark
2000 JX Conv-Blower Motor Resistor
I need to remove
97 Sebring Stuck rear window
Please Help me
1996 sebring convertible right rear turn signal does not flash
front pop or bagning wen turning full in reverse
2000 Fuel Filter?
96 Sebring hesitating and stalling intermittently
Coolant Bleed Valve
What's the deal?
Window Leak
grinding noise cold
replace rear glass in 2000 sebring convertible?
97 sebring Lxi radio reset
2001 lx sebring
Who has the link for the "how to" on replacing plugs and wires
Air Bag Light
Programing the Garage Door on the visor
Factory Amp or Stereo Problem?
deck light message where milage is
Battery indicator light
98 LX Coupe DRIVER POWER SEAT
How reliable are Sebrings?
1997 sebring JXI not starting
200 watt amp and a 10" subwoofer
oil light
need location of a sensor
CV joints bad???
99 Sebring convertible...15" to 16" wheels
DTC codes
180 degree thermostat
Radiator drain plug removal 2000 JXI 2.5
1997 Sebring Conv Fuel Problem
rear defroster
05 sebring performance
97 sebring Lxi, whats the biggest rim you can use
01 specs
oil and grease spay leaks front wheels
Replacing plugs, wires, and what else?
Extended Warranty for a used Sebring
97 sebring LXI, tops out at 4000 rpm, should it top out higher?
Trying to get more off the line,,97 sebring Lxi
Air circulator insert
Mystery Noise!
Defroster wire broke off
2000 Sebring engine tick
dropped q-tip down injector port
car noise
2002 Sebring blower motor
keyless transmitter
Sebring Chrome Wheel problems
there is a High squeling noise when i reach speed of 35 and 65
How to Remove Sebring interior part
Where the heck does p0161 mean
05 GTC Boot Cover
96 Sebring convertible rear window
Cleaning the top
2001 Chrysler Sebring "clunk" noise near my feet
audio system
transmisson problems
Sebring-locked steering column-can't start!
1998 seabring
Web
AF
