Our Community is 662,000 Strong. Join Us.
View Full Version : Cobalt
Pages : [1] 2
  1. Wiring problem
  2. Brake Bleeding
  3. 2005 Cobalt 2.2 Ecotech hesitates when hot
  4. Wanted: Stock 2006 Chevrolet Cobalt SS Parts
  5. New Cobalt owner, general questions
  6. cobalt Reliability
  7. yet another cobalt steering rattle...
  8. power locks
  9. cobalt 2007 LT loud, rhythmic noise
  10. Factory radio fully lit up...
  11. 05 missfire at low rpm
  12. 2008 Chevy Cobalt Cruise Control
  13. Loud noise!!
  14. 06 ss s/c fuel recommendations
  15. Tie Rods
  16. 07 Cobalt hard starting after getting fuel
  17. Clunking Sound From Wheel Well
  18. Cobalt misses in the rain
  19. My 2006 Cobalt shut's down while driving
  20. When to have brakes checked/replaced?
  21. Accident... Totaled??
  22. Key stuck in ignition 2005 Cobalt LT
  23. Broken Timing Chain
  24. Spotted Yellow Cobalt Ls (Rollins Road In Round Lake)
  25. Loud Roaring Noise
  26. knocking while driving!
  27. Unforunate Snow Accident, PLEASE HELP.
  28. upgrading to power locks and install keyless entry / remote start
  29. Power locks don't work from Driver side panel
  30. install center console arm rest
  31. Free Parts 2007 Cobalt LT-1
  32. HELP Cobalt Will not start
  33. '05 - Simultaneous malfunctions (p.s. DIC, speedo, t/c, no shift)
  34. Spotted: Black Cobalt SS (Route 60 In Vernon Hills)
  35. Rotor warping problems
  36. Cobalt LS Turbo
  37. Autometer C2 Wideband Air/Fuel Ratio Gauge
  38. Antenna is loose
  39. More Horse power
  40. 2008 chevy cobalt
  41. 2009 Cobalt LT Mod Questions
  42. 06 LS doesnt feel as powerful as should be?
  43. Build
  44. Check Engine Light: P0411
  45. Armrest question
  46. need a little help
  47. 2006 Cobalt 2.2 ecotec engine replacement procedure needed
  48. Looking for a new key!
  49. 2006 Front Rotor Change
  50. key stuck in ignition
  51. P0131 Error code
  52. Hahn Racecraft Stage V
  53. Factory Remote Start - add on
  54. Key for Locking Wheel Nut
  55. Car Antenna 2007 Cobalt
  56. Cobalt Power Steering Recall
  57. locked in traction control
  58. 2005 Clicking noise when braking
  59. engine miss SS
  60. 06 Cobalt Stalling
  61. cobalt bad noise at 3000 rpm
  62. P0411 Secondary AIR injection problem
  63. 2009 Chevy Cobalt hub cover caps.
  64. Cobalt LT headlight wiring
  65. 2005 cobalt - what is an easy way to remove the plastic housing of the oil filter?
  66. 2.6" Pulley
  67. Option B
  68. Gm Dual Pass Endplate
  69. Zzperformance Or Over The Top Performance Cold Air Intake
  70. Question about cobalt LT 08
  71. ZZP Performance Midlength Header & Downpipe
  72. AEM Uego Wideband Air / Fuel Ratio Gauge
  73. Crate Engine Depot / Rockenbach Chevrolet Meet
  74. ZZP Performance S3 Heat Exchanger
  75. 2006 Chevrolet Cobalt SS Supercharged 2.0L Ecotec
  76. 08 Cobalt Wiring Question
  77. 05 Balt bogging down.No power.
  78. FS: ABSOLUTELY LIKE NEW Black Leather HEATED front and rear seats for Chevy Cobalt SS
  79. 06 Cobalt: Theft Deterrent
  80. chevy colbalt-07
  81. Weird Problem with BRAND NEW 2009 Cobalt HELP
  82. EVAP I/M Readiness Test
  83. winter allmost here i need tires
  84. Transmission Problem
  85. 2007 Cobalt, new lower control arm bushings..
  86. Anyone know anything about ignition switches?
  87. Spindle nut torque spec?
  88. Steering wheel turns to the right(about 30degrees) when brake is pressed...
  89. 2007 Cobalt LS - Excessive Road Noise
  90. rear window defroster connection came loose
  91. Intake/Exhaust
  92. 07 Chevy Cobalt lights
  93. How to install '07 Cobalt Head Unit
  94. '05' Cobalt Power Steering
  95. Car Lock
  96. 2005 Cobalt license tage light bulb?
  97. Kumo tires?
  98. 2006 Cobalt losing coolant and running rough
  99. Need horse power...help... Cobalt ls 2.2l ecotec
  100. 05 Cobalt fuel problem
  101. total exhaust
  102. Recommended door speaker replacements
  103. Front suspension rattle, control arm bushings.
  104. Question about my intercooler
  105. no cool fans relay 2007 ls
  106. '07 Cobalt Bad engine misfire
  107. 2007 ls no rear running lights
  108. Want to Buy an '06/07 Cobalt - Any Reliability Issues I should be know about?
  109. Alarm Disconnect
  110. '07 head rests
  111. Cobalt ECM puzzle! Can u help me crack the puzzle?
  112. Door locks
  113. Alarm when unlocking with key
  114. Smaller Subwoofer box for the Cobalt?
  115. Greetings from NJ...question on steering wheel swap
  116. Hard Start after getting gas
  117. Cobalt shuts off while driving.
  118. Tinting and headlights, powerlocks and neon lights...OH MY!
  119. Cobalt problems (BCM?)
  120. A few changes
  121. Transmission Fluid?
  122. Speedometer and Transmission Problems On An 08 Cobalt
  123. Warning Messages
  124. 06' Cobalt Injectors do not fire.. Everything else is go! Any ideas? Thanx 4 ur help!
  125. Help with Cobalt!
  126. Need to upgrade performance
  127. remote start problems
  128. 06 cobalt aftermarket gauges
  129. Water in oil
  130. 05 Cobalt; Defrost and Floor Settings Do Not Work
  131. Ignition Key Problem
  132. Pioneer Sound System Upgrades
  133. oil changes
  134. new to the site
  135. Ghost in the machine
  136. Engine Ticking PLEASE HELP!!
  137. No sound from speakers
  138. Bad gas mileage
  139. 08 Cobalt BCM Question?
  140. 05 Cobalt LS...is possessed....door locks work and dont work
  141. ss s/c?
  142. Block heater
  143. iPod playback
  144. Fs: All Cobalt Parts From A 2006 2.2l Ls 4 Door
  145. Click in front passenger wheel?
  146. 05 Cobalt shifter doesn't unlock
  147. cobalt cd "check disk
  148. How to remove 07 Cobalt door panels?
  149. Touch brake and car died
  150. Dumb question from a Cobalt newbie
  151. Please Help
  152. Shaking and vibrating Steering wheel and rattle in dash.
  153. Hey all, just bought a 08 Cobalt LT
  154. buy or not 2006 LTZ
  155. cobalt air intake
  156. Cable Type Lock Conversion
  157. replacing RH side manual mirror on 2DR
  158. Spark Plugs
  159. '05 Cobalt~ Stereo reads "lock"
  160. 2.0l clutch
  161. Installing JVC head unit problem
  162. Buying a Cobalt?
  163. Need pink dash kit...
  164. More MPG
  165. 2005 Chevrolet Cobalt 2.2L Ecotec
  166. 2005 SS Maintenance Advice
  167. Oil changes, new Colbalt
  168. Steering wheel volume button not working
  169. Power Programmer!!!!!!!!!!
  170. 2006, 2.2, When accellerating quickly the motor shutters, (like starving for fuel)
  171. Wanted: Install Greddy Full Auto Turbo Timer
  172. Front Seat Belts
  173. Seat Belt Dinger
  174. loss of oil
  175. Cobalt SS body kit
  176. Won't Start All The Time!!
  177. service airbag light
  178. Looking to buy performance parts..
  179. 05 chevy cobalt not starting ,read power steering
  180. 2007 Cobalt Remote Start Issues
  181. bucking like its out of gas
  182. 2006 Cobalt LS Level 2
  183. Just bought 2008 Chevy Cobalt
  184. 07 engine temp? Normal or Not normal
  185. Just did my second oil change
  186. Cobalt SS Resonator
  187. Speed Governor
  188. Headlight covers
  189. Disable Seat Belt Alarm - How?
  190. Install comand start 2007 Cobalt
  191. oil clearing code
  192. 2007 2LT coupe question
  193. 2005 Cobalt
  194. good mods?
  195. ??? About the cobolt SS
  196. Keyless entry entender
  197. After market muffler mpg?
  198. 07 Focus ZX3 vs 07 Cobalt???
  199. For Sale Chevy Cobalt Black Tail Lights
  200. 06 LT Radiator Issues:(
  201. Turbo Cobalt SS coming late 2008.
  202. cobalt ss shift knob
  203. Major RPM flutter 2007 2.2L 4T45E
  204. new rims
  205. cobalt: K.I.A.
  206. Location of the Intake Ait Teperature Sensor on '06 2.4L Cobalt
  207. Body Kit
  208. Help With Purchase??
  209. Cobalt Satisfaction
  210. Removing the Standard gear knob
  211. 2007 Chevy Cobalt LS stereo System
  212. Problem with audio
  213. Cobalt CD Player Problems
  214. Cobalt SS Shift knob
  215. 101.000 miles on the cobalt.
  216. Cobalt Code Scan
  217. Acceleration
  218. Air circulation.
  219. looking into buying a cobalt
  220. Cruise Control
  221. performance parts
  222. New Cobalt owner here with a couple questions..
  223. just bought a new 2007 LS coupe
  224. Cobalt 2006: Govern/Limiter?
  225. Shift Points
  226. Oil filter comparison. 2007 Ecotec 2.2L.
  227. SS/SC springs on LS coupe
  228. How about the quality of this car?
  229. need wiring diagram for stock headlights
  230. quick question
  231. Cobalt SS/SC Gone in 2008
  232. Ls 2.2 Intake
  233. PCV valve?
  234. Checking ATF level, adding/draining ATF..
  235. Ecotec oil filter..
  236. $40 ignition key for 2007's??
  237. DC Sports or Borla?!?!
  238. Colbalt's actual MPG-What will it get
  239. Cars you have raced with the cobalt ss sc
  240. Cobalt SS supercharge or the dodge srt.. which has the most upgrading potential
  241. Question about mufflers/catbacks
  242. Where should I go to buy a used 06 cobalt supercharge??
  243. cobalt ss supercharge vs. impala Ls
  244. Can I be stupid for 5 seconds?
  245. New cobalt ss\sc owner...questions.
  246. Cobalt Ss/sc Stage Kits?
  247. Cobalt Fog Light Bulb Replacement
  248. CobaltCoupe.net is now up and running!
  249. wanna take the cobalt ss motor an put it in a 4 wheel drive truck is it possible
  250. new member with 2005 ss supercharged
