Our Community is 662,000 Strong. Join Us.
View Full Version : PT Cruiser | PT Cruiser Convertible
Pages : [1] 2
  1. check engine code P340
  2. Drivers side window and convertable top
  3. Can you put tire chains on a PT Cruiser?
  4. 03 PT Popping Noises
  5. PO340 Error Code
  6. Steering column ground
  7. 03 pt cruiser shut down while driving
  8. Occassional rough idle?
  9. '01 PT Cruiser, Thermostat Knob won't turn past certain point...
  10. 07pt runs rough sometimes
  11. 2003 PT Cruiser Timing Belt Tip ...
  12. headlight issue 2006 pt cruiser
  13. Front end problem
  14. Bad 01 cruiser engine. Will 98 stratus 2.4 fit?
  15. Well, I bought a 2009 Dodge Nitro???
  16. '02 PT Cruiser Manual trans- won't go into gear
  17. Paid Consumer Research Study - Car Owners
  18. PT Cruiser Electric Fan problem
  19. 06 Cruiser changing trans fluid question
  20. Having trouble with windows/cd player
  21. Blown Motor
  22. I am still an Canadian/American
  23. I am still an Canadian/American
  24. PT 02 Airbag system reset
  25. Crysler Canada came through, and yes a Dodge again
  26. camshaft position sensor
  27. 06 PT Cruiser stop lights going out
  28. 06 Airbag light warning for 5 minutes
  29. Radiator Fan out?
  30. PT Cruiser - unusual odor
  31. PT Cruiser Lug Nut
  32. oil sender leak
  33. LA Body Shop & Bumper Cover "Wrinkle"
  34. Power Steering Pump Diagram & Relief Valve
  35. Chryslers Silent recall
  36. kool-vue muffler?
  37. what's wrong with my PT?!
  38. Well, It happened again. Number seven power steering burst
  39. Right Front Wheel Spin
  40. Engine light and P2096 code on 2002 PT Cruiser
  41. Battery Problems
  42. 01 Pt Cruiser power steering issue
  43. PT leaking coolant
  44. Instrument Cluster
  45. shifting problem
  46. losing RPM's when starting PT cruiser
  47. PT CRUISER Stalls and throws code
  48. 01 timing belt help.
  49. parts for my 2002 pt cruiser
  50. 2006 PT Cruiser A/C issues
  51. Replace 05 timing belt
  52. Key Replacements
  53. '03 PT Cruiser bolt identification
  54. Airbag light, Cruise Control, Horn not working
  55. PT and 5.7
  56. 2004 Turbo - ? on not wanting to shift to start
  57. New Wheels Question
  58. the best mileage correction tools for American cars in the world
  59. Crysler Mechanic Help, from yale 329
  60. pt cruiser has annoying squeak on left side of motor
  61. Engine Squeek
  62. PT Cruiser Turbo Power Steering hosees bursting
  63. Does the PT Cruiser have uconnect WiFi?
  64. 05 PT Cruiser Convertible Top Issue
  65. 02 pt turbo blowing smoke
  66. MORE Airbag Trouble
  67. sluggish takeoff and engine light
  68. 04 PT turbo
  69. Air Bag Light
  70. Transmission Problem?
  71. keep old car or go for '07 PT conv.?
  72. better mpg topless?
  73. 01 PT Cruiser Running Hot/Overheating
  74. Control for A/C and Heater
  75. PT Cruiser Convt. vs. Sebring Convt.
  76. Parking brake sticking?
  77. check engine light
  78. Brakes
  79. P.T. Cruiser 2004
  80. front wheel bearings
  81. Gurgling In Heater Core
  82. 2001 PT power steering failure
  83. A/C lost it's charge
  84. turbo upgrade?
  85. 2001 PT Timing Belt/chain replacement??
  86. Dome Light Dumb Question
  87. Automatic shifter hard to move
  88. Just put on the Lambo doors! Anyone have these?
  89. 02 Foglights
  90. Replace control arm bushing?
  91. Got the car Back and guess what
  92. Well It's Back to the shop. for THE 05 PT
  93. Defrost vent, top center of dash, removable??
  94. I Give up with all trust for Dealerships
  95. Listen up NOW, Im 55 and a dam careful Driver.
  96. Electrical Problem??
  97. 2005 pt turbo, Dealer Turns nasty
  98. can't Post Help
  99. Key Fob
  100. Clutch Noise
  101. bad gas or what????
  102. Show Your PT Pride!
  103. car won't start,...then try a few hours later...runs beautifully..????
  104. What happen to my Cruiser?
  105. Ejecting CD from CD playeHow do you do it?
  106. 2001 Limited Ed. Won't Start.
  107. Cursed PT Cruiser...?
  108. Headlight help
  109. ABS & Traction control turn off on highway
  110. Car Cut Off
  111. Selling My 2006 PT Cruiser
  112. pt turn key alarm will not allow start of car
  113. 2007 New PT Convertible - in town 12.5 - 15 mpg ??
  114. uses oil then stops
  115. Rear Wiper Only Works At Times
  116. dash lights
  117. Radio problem in PT Cruiser
  118. timing help
  119. '02 Cruiser front end clunk
  120. 01, fog lights
  121. Oil in Air Filter Box
  122. what tires can i fit
  123. 2004 PT Cruiser Problem
  124. No Brake lights
  125. Timing Belt Replacement
  126. Air Bag Light Problem
  127. Sterring whell shimmy
  128. 03 Cruiser has no power
  129. Bule dot tail lights
  130. engine jerking
  131. Clutch upgrade
  132. Why is there so many PT Cruisers on dealer's used lots?
  133. Would you recommend a cruiser?
  134. 2006 PT Cruiser
  135. 2003 PT Remote and Key
  136. Anyone Lower a Cruiser yet?
  137. 2007 AC quits?
  138. Starter problems for my PT cRUISER
  139. Not a neon, but I own one
  140. No Brake Lights
  141. Help. Kitten stuck in my dashboard!
  142. Steering noises...
  143. 2002 PT Power Window Switch
  144. how long will they run?
  145. Pt Engine Problem
  146. Which one?
  147. Battery Removal
  148. Seat Belt 2002 Pt Cruiser
  149. 2005 PT convertible sirius ready?
  150. irregular motor revving
  151. 2002 PT Cruiser; OBDll code P0551
  152. Can anyone tell me how to get to the spark plugs?
  153. Loaded '05 PT Cruiser Conv. 4sale in Ohio
  154. for sale
  155. Fuel Injector flow rate?
  156. Should I Buy A PT Cruiser Drop Top?
  157. Should I Buy A PT Cruiser
  158. Busted lower radiator hose.
  159. How's $420 for spark plugs and an oil change sound?
  160. Engine idiot light, rough idle
  161. service manual
  162. temp gauge failing
  163. Crap, Need Wiring Diagram Today !!
  164. Head gasket problems? and Turbos?
  165. keyless entry programing
  166. Fan Relay
  167. looking at buying a used PT cruiser. Help!?
  168. exhaust system upgrade?
  169. Does anyone ever answer your questions here anymore?
  170. Any one had problems with lock solenoid?
  171. 2 Questions: Gear shifting sound and gas mileage
  172. idot light for oil keeps coming on.
  173. 2005 pt gt sedan pcm recoded sticker
  174. Lost Brake Boost
  175. wrecked my pt cruiser
  176. Transmission fell out
  177. Hhr
  178. how much slower is the pt turbo with an auto?
  179. Srt-4 Pt?
  180. 2003 PT Turbo Questions
  181. battery corrosion problems
  182. Upper Dash Pad removal
  183. help with selecting first car
  184. PT Cruiser with manual transmission
  185. More Power, How?
  186. electrical prob 2001 PT
  187. Oil Capacity 2003 2.4 Liter?
  188. PT Turbo vs. Subaru WRX
  189. A/C Freon Discharges while at Idle???
  190. Leaking tires
  191. 01 pt tcm problem
  192. New here...
  193. Pt Big Brake Upgrade Group Buy!
  194. thinking about buying a 2005 Pt touring
  195. Survey
  196. Passenger power seat
  197. Remote start
  198. Window Tinting on Side Rear Windows
  199. 2003-Poor Mileage, Whirring Noise from Steering
  200. 2001 accident waiting to happen ( steering)
  201. timing mark
  202. 2002 PT Cruiser
  203. Miles Per Gallon
  204. PTCrusier washer bottle
  205. Mopar Oil Filters - Good or Bad?
  206. Cruiser Parts
  207. could b close
  208. Poor POOR Pt lol
  209. Can't shut engine off with the key.
  210. Performance Parts
  211. Need Information
  212. Cruiser Window Tints anf UK Police
  213. I need one rim off of a Limited 2002
  214. Lonestar Cruise
  215. cruise the falls 4
  216. PT Cruiser GT HO vs. RX-8
  217. Rear wheel bearing (disc brakes)
  218. HELP! Need heated breakaway side mirror for 2001 pt
  219. Whipple Supercharger for PT
  220. Has anyone bought the PT Cruiser Covert yet??
  221. Got to Drive a PT Cruiser Convertible
  222. rev limiter
  223. GT Photos
  224. Plug Change, What Plugs ?
  225. 600+ PT Cruiser event- Cruise the Falls 4!!
  226. help with plugs
  227. Chrysler PT Cruiser Convertible
  228. 2.4 cam timing
  229. PICS: modified PT Cruiser from Cali dealership
  230. PT Cruiser Trailer
  231. Exhausts & performance chips
  232. 03 cruiser steering
  233. gt-crusier turbo upgrade from chill factory
  234. Toys For Tots - Orange County, Ca
  235. Dream Cruiser is a nightmare
  236. Cruiser GT vs Mustang GT
  237. How 2 reprogram RDL module
  238. 1989 Chrysler Dynasty
  239. Keyless Remote programing
  240. ST III, 3rd Annual InterNational PT Cruiser Event
  241. GT Cruser
  242. costs of running a PT Cruiser
  243. The Ungodly Amount of Limited Edition PT Cruisers
  244. Shore Thing 2 Reminder - Only 3 days left
  245. PT commercial song
  246. PT commercial song
  247. PT commercial song
  248. Shore Thing 2 Registration is now OPEN!!
  249. Shore Thing 2 Registration Opening Soon!
  250. PT Cruiser event- Cruise the Falls II
