View Full Version : PT Cruiser / PT Cruiser Convertible
  1. 01 Pt Cruiser power steering issue
  2. PT leaking coolant
  3. Instrument Cluster
  4. shifting problem
  5. losing RPM's when starting PT cruiser
  6. PT CRUISER Stalls and throws code
  7. 01 timing belt help.
  8. parts for my 2002 pt cruiser
  9. 2006 PT Cruiser A/C issues
  10. Replace 05 timing belt
  11. Key Replacements
  12. '03 PT Cruiser bolt identification
  13. Airbag light, Cruise Control, Horn not working
  14. PT and 5.7
  15. 2004 Turbo - ? on not wanting to shift to start
  16. New Wheels Question
  17. the best mileage correction tools for American cars in the world
  18. Crysler Mechanic Help, from yale 329
  19. pt cruiser has annoying squeak on left side of motor
  20. Engine Squeek
  21. PT Cruiser Turbo Power Steering hosees bursting
  22. Does the PT Cruiser have uconnect WiFi?
  23. 05 PT Cruiser Convertible Top Issue
  24. 02 pt turbo blowing smoke
  25. MORE Airbag Trouble
  26. sluggish takeoff and engine light
  27. 04 PT turbo
  28. Air Bag Light
  29. Transmission Problem?
  30. keep old car or go for '07 PT conv.?
  31. better mpg topless?
  32. 01 PT Cruiser Running Hot/Overheating
  33. Control for A/C and Heater
  34. PT Cruiser Convt. vs. Sebring Convt.
  35. Parking brake sticking?
  36. check engine light
  37. Brakes
  38. P.T. Cruiser 2004
  39. front wheel bearings
  40. Gurgling In Heater Core
  41. 2001 PT power steering failure
  42. A/C lost it's charge
  43. turbo upgrade?
  44. 2001 PT Timing Belt/chain replacement??
  45. Dome Light Dumb Question
  46. Automatic shifter hard to move
  47. Just put on the Lambo doors! Anyone have these?
  48. 02 Foglights
  49. Replace control arm bushing?
  50. Got the car Back and guess what
  51. Well It's Back to the shop. for THE 05 PT
  52. Defrost vent, top center of dash, removable??
  53. I Give up with all trust for Dealerships
  54. Listen up NOW, Im 55 and a dam careful Driver.
  55. Electrical Problem??
  56. 2005 pt turbo, Dealer Turns nasty
  57. can't Post Help
  58. Key Fob
  59. Clutch Noise
  60. bad gas or what????
  61. Show Your PT Pride!
  62. car won't start,...then try a few hours later...runs beautifully..????
  63. What happen to my Cruiser?
  64. Ejecting CD from CD playeHow do you do it?
  65. 2001 Limited Ed. Won't Start.
  66. Cursed PT Cruiser...?
  67. Headlight help
  68. ABS & Traction control turn off on highway
  69. Car Cut Off
  70. Selling My 2006 PT Cruiser
  71. pt turn key alarm will not allow start of car
  72. 2007 New PT Convertible - in town 12.5 - 15 mpg ??
  73. uses oil then stops
  74. Rear Wiper Only Works At Times
  75. dash lights
  76. Radio problem in PT Cruiser
  77. timing help
  78. '02 Cruiser front end clunk
  79. 01, fog lights
  80. Oil in Air Filter Box
  81. what tires can i fit
  82. 2004 PT Cruiser Problem
  83. No Brake lights
  84. Timing Belt Replacement
  85. Air Bag Light Problem
  86. Sterring whell shimmy
  87. 03 Cruiser has no power
  88. Bule dot tail lights
  89. engine jerking
  90. Clutch upgrade
  91. Why is there so many PT Cruisers on dealer's used lots?
  92. Would you recommend a cruiser?
  93. 2006 PT Cruiser
  94. 2003 PT Remote and Key
  95. Anyone Lower a Cruiser yet?
  96. 2007 AC quits?
  97. Starter problems for my PT cRUISER
  98. Not a neon, but I own one
  99. No Brake Lights
  100. Help. Kitten stuck in my dashboard!
  101. Steering noises...
  102. 2002 PT Power Window Switch
  103. how long will they run?
  104. Pt Engine Problem
  105. Which one?
  106. Battery Removal
  107. Seat Belt 2002 Pt Cruiser
  108. 2005 PT convertible sirius ready?
  109. irregular motor revving
  110. 2002 PT Cruiser; OBDll code P0551
  111. Can anyone tell me how to get to the spark plugs?
  112. Loaded '05 PT Cruiser Conv. 4sale in Ohio
  113. for sale
  114. Fuel Injector flow rate?
  115. Should I Buy A PT Cruiser Drop Top?
  116. Should I Buy A PT Cruiser
  117. Busted lower radiator hose.
  118. How's $420 for spark plugs and an oil change sound?
  119. Engine idiot light, rough idle
  120. service manual
  121. temp gauge failing
  122. Crap, Need Wiring Diagram Today !!
  123. Head gasket problems? and Turbos?
  124. keyless entry programing
  125. Fan Relay
  126. looking at buying a used PT cruiser. Help!?
  127. exhaust system upgrade?
  128. Does anyone ever answer your questions here anymore?
  129. Any one had problems with lock solenoid?
  130. 2 Questions: Gear shifting sound and gas mileage
  131. idot light for oil keeps coming on.
  132. 2005 pt gt sedan pcm recoded sticker
  133. Lost Brake Boost
  134. wrecked my pt cruiser
  135. Transmission fell out
  136. Hhr
  137. how much slower is the pt turbo with an auto?
  138. Srt-4 Pt?
  139. 2003 PT Turbo Questions
  140. battery corrosion problems
  141. Upper Dash Pad removal
  142. help with selecting first car
  143. PT Cruiser with manual transmission
  144. More Power, How?
  145. electrical prob 2001 PT
  146. Oil Capacity 2003 2.4 Liter?
  147. PT Turbo vs. Subaru WRX
  148. A/C Freon Discharges while at Idle???
  149. Leaking tires
  150. 01 pt tcm problem
  151. New here...
  152. Pt Big Brake Upgrade Group Buy!
  153. thinking about buying a 2005 Pt touring
  154. Survey
  155. Passenger power seat
  156. Remote start
  157. Window Tinting on Side Rear Windows
  158. 2003-Poor Mileage, Whirring Noise from Steering
  159. 2001 accident waiting to happen ( steering)
  160. timing mark
  161. 2002 PT Cruiser
  162. Miles Per Gallon
  163. PTCrusier washer bottle
  164. Mopar Oil Filters - Good or Bad?
  165. Cruiser Parts
  166. could b close
  167. Poor POOR Pt lol
  168. Can't shut engine off with the key.
  169. Performance Parts
  170. Need Information
  171. Cruiser Window Tints anf UK Police
  172. I need one rim off of a Limited 2002
  173. Lonestar Cruise
  174. cruise the falls 4
  175. PT Cruiser GT HO vs. RX-8
  176. Rear wheel bearing (disc brakes)
  177. HELP! Need heated breakaway side mirror for 2001 pt
  178. Whipple Supercharger for PT
  179. Has anyone bought the PT Cruiser Covert yet??
  180. Got to Drive a PT Cruiser Convertible
  181. rev limiter
  182. GT Photos
  183. Plug Change, What Plugs ?
  184. 600+ PT Cruiser event- Cruise the Falls 4!!
  185. help with plugs
  186. Chrysler PT Cruiser Convertible
  187. 2.4 cam timing
  188. PICS: modified PT Cruiser from Cali dealership
  189. PT Cruiser Trailer
  190. Exhausts & performance chips
  191. 03 cruiser steering
  192. gt-crusier turbo upgrade from chill factory
  193. Toys For Tots - Orange County, Ca
  194. Dream Cruiser is a nightmare
  195. Cruiser GT vs Mustang GT
  196. How 2 reprogram RDL module
  197. 1989 Chrysler Dynasty
  198. Keyless Remote programing
  199. ST III, 3rd Annual InterNational PT Cruiser Event
  200. GT Cruser
  201. costs of running a PT Cruiser
  202. The Ungodly Amount of Limited Edition PT Cruisers
  203. Shore Thing 2 Reminder - Only 3 days left
  204. PT commercial song
  205. PT commercial song
  206. PT commercial song
  207. Shore Thing 2 Registration is now OPEN!!
  208. Shore Thing 2 Registration Opening Soon!
  209. PT Cruiser event- Cruise the Falls II
  210. PT convertiable
  211. Show off your PT...!!!!
  212. Spotted . . .
  213. The Start of the PT Cruiser
  214. they need a biger engine
  215. PT Cruiser pics
  216. Aftermarket going crazy after PT Cruiser
