View Full Version : TrailBlazer/Trailblazer EXT
Pages : [1] 2 3 4 5 6 7 8
  1. 2003 Trailblazer hard to steer to right
  2. Transfer Case Control Module / Install
  3. beefing up rear springs for towing, too much sway
  4. 04 TB LS tire question
  5. heated seat back/driver side quit
  6. Chevrolet TrailBlazer?
  7. change oil light wont go off
  8. 05 trailblazer won't start
  9. A/C problem
  10. AC wont work on setting 5
  11. Loud Noise!!
  12. 03 TB not starting, bunch done already
  13. Fan clutch again
  14. Still running even with key out of ignition?
  15. 08 TB Rear Seat Wont Fold Down
  16. occasional various issues
  17. 02 LTZ tach needle jumping
  18. 03 TB LTZ steering wheel controls
  19. check engine light and fuel guage issues.
  20. 04 TB LS Blinker issue
  21. Stalling/Sluggish Acceleration..P0134/P0130
  22. Clutch fan
  23. Remote keyless entry
  24. 2004 Trailblazer Hesitating
  25. loud roaring in right front tire.
  26. Problem with 02 ABS brakes
  27. Access to spark plugs Tblazer 03 V6
  28. stabiltrak active on dry asphalt 2006 Trail B.
  29. P0305 Cylinder 5 Misfire
  30. rear a/c problem
  31. Burning oil smell from trailblazer rear
  32. A/C Issues
  33. Driver side window master switch problems
  34. 03 Rear Power Windows not working
  35. problem with the temperature of the engine
  36. instrument cluster lights...
  37. Fan clutch left unplugged...help!
  38. Strange A/C problem
  39. Thermostat Question
  40. Radiator cause water pump failure? Please help
  41. 05 Trailblazer idles rough and stalls
  42. 04 Chevy Trailblazer - cost to replace front passenger side door
  43. Any Trailblazer SS owners out there? I have a question
  44. oil pressure
  45. O5 rear hatch lock
  46. brake lights
  47. oil pressure and brake light
  48. What happened to the vin stickers on body panels?
  49. Adding a navigation system to a 07-08 Trailblazer
  50. 2002 TB Low Oil PSI at Idle
  51. 2002 tralblazer sercurity light on and wont start
  52. Rear Speakers
  53. Power Steering issue?
  54. Trailblazer Rough Idle
  55. towing capacity
  56. trailblazer 2003
  57. trailblazer lt ext 2005, engine light
  58. Errattic idle
  59. 02 Drivers side power seat wont go forward
  60. tire wear
  61. LED lightbulb replacements
  62. 2000 Trailblazer Ticking Sound
  63. 255-65-17 tires?
  64. Trailblazer aftermarket tail lights anyone?
  65. Universal Joints
  66. 2005 trailblazer starting issues
  67. Battery light comes on
  68. gas smell/starting
  69. How do you change th license plate bulbs on a 2002 trailblazer
  70. Squeaking Noise At Front Of Engine
  71. Trailblazer vibration/hum
  72. Need rear spoiler/3rd brake light for EXT
  73. Low Oil Pressure
  74. P0449 code...
  75. 2002 hid install help
  76. Transmission Fluid recommendation?
  77. Fuse/Wiring help
  78. 2008 TB Liftglass won't open
  79. Power Steering Hose Bursted!
  80. knocking sound from engine
  81. Trailer lights not working
  82. CV joints
  83. 03 trailblazer brakelight problem
  84. How to clean your throttle body
  85. 05 Trailblazer Radio problem.
  86. 2002 Trailblazer front axle locks 4wd
  87. Excessive power draw
  88. secondary air intake malfunction
  89. Engine whining and pinging sound DTC P0327
  90. Help
  91. Cabin HVAC (ACC) filter
  92. Can i rekey a chevy tb 03
  93. 02trailblazer/dtcp0014-p0105
  94. 2004 Chevy Trailblazer
  95. red flags
  96. 2004 Trailblazer Blown Transmission
  97. Car dead overnight
  98. A little fog light help?
  99. Anyone runing 245/75R/16 tires in their TB?
  100. Trailblazer starts and dies have codes!
  101. P1120
  102. 02 Trailblazer crank but no start!?
  103. 2003 Trailblazer, when i get to 30mph the engine stays revved up
  104. clicking /thumping sound in back right rear ????help
  105. Temp. gauge not working properly
  106. Climate control temperature issue on TB05 EXT
  107. water pump question
  108. '05 TB wheels locking up in 4HI
  109. The CHEVY 03+ NAVIGATION RADIO Screen damaged
  110. 2002 Trailblazer Cranks but won't start
  111. 07 Trailblazer Traction control
  112. LOST Key FOB What now..
  113. Engine- swap will a 05 work in an 06?
  114. timing belt information
  115. wont start with key, remote only
  116. Upgrading the rear view mirror '08 TB
  117. code p0410
  118. 03 front differential right side oil pan axle lube
  119. changing blower motor
  120. Trailblazer squeals after front diff. replaced
  121. RPM gauge goes dead
  122. 2004 TB CD Stuck in Player
  123. chevy trailblazer 02
  124. Fuse between battery and starter
  125. Trailblazer "SS" rear lower bumper valance
  126. 2003 TB gauge problems
  127. 4 wheel wont engage light blinking
  128. 07 TB lift glass doesn't lock
  129. '04 trailblazer p0410, secondary air pump
  130. Loud Clicking Noise When Rear A/C is on
  131. Heater and instrument panel
  132. 2004 Trailblazer low beam headlights out
  133. Front end Whirring over 40 mph
  134. Annoying thumping noise when driving over pot holes
  135. Rear View Mirror TB 04
  136. Mirror settings
  137. Vibration/Humming
  138. Somethin' leaking...
  139. P0741 P0894 trans fault any help?
  140. Shattered Rear Window
  141. heat stuck on.....
  142. what is the typical temp readings in 2005?
  143. instant fuel readings - help is needed
  144. **Got into an accident, need advice!!!***
  145. Cup Holder Inserts???
  146. Fan Clutch
  147. Need axle lube advice for 03 TB
  148. No electrical power then suddenly its ok
  149. '03 Trailblazer Eletrical Issues
  150. 2002 Trailblazer Lt with vibration/shudder problem
  151. Trailblazer EXT 04 - AC is not working
  152. Transmission issue...
  153. Squeaky Chassis
  154. what do I see under the oil cup?
  155. Idle drop-off and shutting off at stop
  156. what should i look 4 before i buy 2005?
  157. Motor won’t start, sporadic gauge movement, locked transmission- PLEASE HELP
  158. 4wd on 02 tb
  159. Inside fan Part number???
  160. idle problem when fan turned to defrost
  161. Passenger Headlight Lowbeam
  162. Exhaust Rattle
  163. Random jerks while driving
  164. AC not working
  165. Computer Issue
  166. Trans wobble
  167. dead battery
  168. wont shut off
  169. 2003 Reduced Power Light / check engine problem
  170. 2002 Trailblazer Keeps Stalling
  171. battery recommendation?
  172. 03 trailblazer how do i remove valve cover?
  173. help with something?
  174. Engine compartment cleaning?
  175. spark plugs
  176. IGN/ACC wire / where and which?
  177. Interior Fan Malfunction - HELP
  178. 04 Trailbazer engine swap...now defrost/vent/floor selector knob doesn't work.
  179. scratches and scuffs
  180. Compass issue
  181. Trailer wire connection problem
  182. Stupid question?
  183. what tire?
  184. battery drain ??
  185. Changed spark plugs and now it stalls?
  186. Fuel pump and line repair...Keep your receipts
  187. inside fan stopped to work
  188. 02 Trailblazer AC
  189. 04 Trailblazer - AC takes forever to get cool
  190. 2004 Trailblazer EXT I6 Engine Swap...Dead #4 Cylinder!
  191. 2002 Trailblazer is at NHTSA testing facility
  192. Catalytic converter or Exhaust manifold
  193. Where are the grease fittings on a 2004 tb?
  194. 02 TB Alternator Removal
  195. 04 Trailblazer stalls at red lights
  196. Sparkplugs
  197. off-road rims and tires, anyone?
  198. Power seats won't move forward/backward but other functions work
  199. Shifting Gears......'clank'..!!
  200. Rattling doors on bumps
  201. 2005 Trailblazer Ext Brake Controler Hookup
  202. SES light and trembling/vibration on 02 TB
  203. Key Fob Question
  204. Loss Of Power Cuts Off When Stopped
  205. 2205 Trailblazer Brake Controler Wiring
  206. 2003 Trailblazer EXT Clicking problems
  207. 2003 Trailblazer EXT
  208. What is the proper oil?
  209. 2002 TB EXT / Envoy XL Faults?
  210. 2002 Trailblazer A/C won't blow thru vents.
  211. MAP Sensor
  212. Shorted Fuse Block Terminals
  213. 2003 TB tranny lines
  214. My Trailblazer cherps and clunks, HELP
  215. tb line converter
  216. 2003 trouble code
  217. Could it be my AC/heater blower motor?
  218. Anyone had any luck with power programmers??
  219. tachometer
  220. Can't find fuel filter
  221. 05 TB stalling and hesitating....
  222. '05 TB stalling.. someone please help me!!!
  223. Grinding noise in driver's side wheel????!!!
  224. front rotors bad after 10000 miles
  225. '03 Trailblazer with K & N filter
  226. Interior rear view mirror/broken mount
  227. 2002 Trailblazer Electrical Problem Shuts OFF
  228. gauge cluster
  229. Batteries gone wild
  230. P0410 code 05 ls
  231. 2002 Brake pedal/ Taillight issue
  232. main pulley
  233. pcm reflash ???
  234. 2002 trailblazer radio problem
  235. Po455 & P1680 codes
  236. worse idol and hesitation after tune up
  237. coil pack
  238. Climate Control Problem
  239. 04 Trailblazer Ext codes & un-diagnosed problems
  240. Rear tail light assembly
  241. air intake
  242. locking gas cap
  243. Squealing noise in reverse
  244. whining between 2600 to 2900
  245. big tune-up...first time...please help!
  246. Trans cooler on '03 TB
  247. 2002 Trailblazer LS ABS light problem
  248. wrong temperature reading
  249. sqealing window
  250. Vertical glass scratches in all 4 doors
