Our Community is 662,000 Strong. Join Us.
View Full Version : TrailBlazer | Trailblazer EXT
Pages : [1] 2 3 4 5 6 7 8 9
  1. AC not cold when idling-but otherwise cold
  2. Squeeking from front driveshaft
  3. can't gas into my trailblazer ___HELP
  4. 2005 Trailblazer "low collant temp" Light
  5. downshifting problem
  6. 03 trailblazer trans swap interchange from 02 blazer??
  7. thumping from passenger-side rear
  8. 2002 engine swap
  9. Windshield Washer Reservoir - 2008 TB
  10. Proper Gap?
  11. Passenger side low beam went out.
  12. Selling Trailblazer
  13. Type of Transmission filter needed
  14. Fan clutch replacement
  15. 2002 TB barake problem
  16. '03 TB sway bar linkage
  17. High RPM
  18. 05 Trailblazer whining sound
  19. trailblazer will not turn off
  20. from 2011 chevy cruze ls to chevy trailblazer ext 9:43:41 AM, crazy?
  21. Power steering hard to turn left only
  22. High RPM's
  23. 03 trailblazer LS 4.2 butterfly in throttle body does not close allway
  24. electrical short?
  25. Need help with 03 TB/LT/EXT Front axle/diff
  26. Replacing the rack & pinion 2002 TB
  27. New to the Trailblazer
  28. accessory power outlet fuse?
  29. tailgate. Interior trim panel Removal
  30. Power steering or rack and pinion?
  31. trailblazer no sound from rear door speakers
  32. 2006 Trailblazer doesn't blow on speed 5
  33. 2003 Trailblazer EXT
  34. 2008 TB radiator drain
  35. 2006 TrailBlazer
  36. Battery?
  37. Front axle nut
  38. 2004 trailblazer dual climate control issues
  39. please help me ..dealers can't solve this problems..Any solutions you know ?
  40. 2002 TB 63k, loses accel, sluggish, RPMs die
  41. brake job?
  42. Low Beam Lights
  43. Rebuild 4L65E DIY
  44. 03 trailblazer holds back at takeoff
  45. Light problems on 03 trailblazer
  46. '03 tb fuse for battery
  47. 02 TrailBlazer tail light issue
  48. A/C problem
  49. 04 Trailblazer,no start
  50. 05 Coolant temp low code?
  51. Any way to clean inside of headlight lens?
  52. 03 trailblazer with 0442 DTC
  53. 03 trailblazer,noise when you accelerate
  54. 06 Trailblazer with bad front differential
  55. air won't blow through upper vents
  56. '03 Trailblazer No Reverse cold
  57. Spare Tire Removal
  58. dash lights/ignition switch? '02 TB
  59. odd engine vibration
  60. Misfire...
  61. little vibration in steering, pad and accelarator
  62. 06 Trailblazer--blower will not shut off
  63. slow drivers window, doesn't seal at speed
  64. 05 Only ANG Fuel Consump and not Actual
  65. Possible tranmission issue?
  66. 03 trail blazer when put in 4wd it goes back toauto4wd
  67. Whining noise
  68. Speedometer and tach goofey
  69. 2008 Trailblazer StabiliTrak System...
  70. 08 trailblazer brakes sticking
  71. 02 trailblazer rear heat problem..blowing cold air
  72. parts illustration for front differential right side
  73. Cruise Control
  74. temp not steady
  75. Funny noise from top of the engine
  76. Installing Gabriel Hijackers onto TB/Envoy
  77. performance issue
  78. mmm what next??
  79. New Battery and car will not idle when a/c is on
  80. 02 trail blazer missfire/no cruise???HELP!
  81. 04 trailblazer ping noise when starting to accelerate
  82. Lock of the Trunk activates sometimes
  83. Misfire Again
  84. 2005 chevy trailblazer fan clutch
  85. 2003 Trailblazer blower motor resistor
  86. spare tire hoist
  87. Trailblazer lost acceleration?
  88. What is overall Length & width of a TB -EXT?
  89. 2002 Trail Blazer, no power
  90. Brake controler wiring
  91. no power trail blazer
  92. loud wining sound after fuel filter replacement
  93. 05 trailblazer air pump issue
  94. Ac issue.. weird behavior.
  95. AC question
  96. 04 TB Ext rear air control question
  97. Trail EXT - Problem with Fuel Level Indication
  98. 2002 Trailblazer rattling in top half of motor
  99. shaking bad
  100. 02 TB - pin hole leak in transmission cooler line
  101. Wrong battery issues?
  102. 04 ext water in tail light
  103. 02 TB sparkm plug replacement question
  104. ABS Sensor
  105. pulsating lights
  106. New Issue...interesting?
  107. 2002 TB fan clutch DIY
  108. Help with fan clutch
  109. 02 TB tranny has no 2nd or rev
  110. 2002 trailblazer sluggish, woosh noise
  111. A/c problems
  112. Where to begin.....
  113. ac question again
  114. additional transmission cooler 2004 Trailblazer
  115. Trailblazer roof rack clearance lights
  116. faint noise coming from where you put your oil in
  117. LED brake light fits in trailer hitch
  118. New Charging Issue
  119. Radio now oicks ups engine
  120. hum in front end
  121. vibration/shake 2009 trailbazer
  122. What brand of struts did you buy?
  123. 03 trailblazer front strut replacement
  124. 03 Trailblazer LTZ won't start good battery
  125. Quick help - which is Cylinder 1?
  126. The most dangerous vehicle....
  127. No signal PCM diagnostic port
  128. 03 trailblazer wiring diagram needed
  129. '04 Trailblazer Ext air conditioning problem
  130. gauge light 04 TB
  131. oil pressure low/ bogs out/ stalls
  132. RKE liftgate control module
  133. Fuel gage or level sender
  134. Xenon bulbs & adapters
  135. rpm issues
  136. transmission removal
  137. 2002 Trailblazer windshield wiper problem
  138. o4 TB dash light
  139. power steering
  140. Radiator petcock on 2003 Trailblazer
  141. Okay for larger tires?
  142. + 200 hp!
  143. Heater starts blowing cold air on passenger side?
  144. lights and dash flickering
  145. power / performance programmers
  146. questions about doors
  147. PO105 map sensor circuit
  148. Trailblazer Wet Passenger Floorboard Fix
  149. Weird vibration 02 tb
  150. 99 cd changer wire harness diagram.
  151. how to replace a low beam head light
  152. Programming my key fob
  153. TrailBlazer tailgate
  154. idle issues 03 northface tb
  155. speedo went nuts
  156. 2002 TB Oil gauge acting up
  157. Fan Relay Switch???
  158. 2 Questions 2003 NF Edition Trailblazer
  159. Growling noise on my front end
  160. 02 Trailblazer cranks, but doesn't start
  161. TrailBlazer Key Stuck. short term fix
  162. replacing front struts
  163. Aluminum Wheel failure at 45K miles
  164. Oil Pressure Guage Fluctuation
  165. Engine running rough while idling
  166. 4wd light blinks when i select 4wd or 4wd lo or hi and a4wd
  167. 02-chevy trailblazer- tranny/fuel issue
  168. 2004 TB fan/heater/AC
  169. Aftermarket front bumber
  170. that lil ornage light
  171. Transmission puzzle
  172. scratches on rear window
  173. t/b is history???
  174. '03 Envoy/TB can't remove key when battery dies
  175. Trailblazer locks door while keys in ignition!
  176. Help
  177. Auto start wants to start without me!
  178. 2003 TB passenger side window, mirror and locks stuck
  179. Windshield recall
  180. 02 Trailblazer rough idle and check engine light
  181. 2005 Trailblazer Speedometer Inaccurate/Inoperative! Help Please!
  182. 03 Bucking while in 4wd.
  183. Charging issue
  184. door switch lights
  185. 4WD whining noise
  186. P0410 Secondary Air Injection System
  187. Key less entry not working rear liftgatenot open
  188. 4wd on dry pavement
  189. wheel bearing replacement
  190. 05 ascender
  191. Bad burnt electrical smell from heater
  192. Nothing but 2wd
  193. Noise from hitch under trailer
  194. 2003 Trailblazer hard to steer to right
  195. Transfer Case Control Module / Install
  196. beefing up rear springs for towing, too much sway
  197. 04 TB LS tire question
  198. heated seat back/driver side quit
  199. Chevrolet TrailBlazer?
  200. change oil light wont go off
  201. 05 trailblazer won't start
  202. A/C problem
  203. AC wont work on setting 5
  204. Loud Noise!!
  205. 03 TB not starting, bunch done already
  206. Fan clutch again
  207. Still running even with key out of ignition?
  208. 08 TB Rear Seat Wont Fold Down
  209. occasional various issues
  210. 02 LTZ tach needle jumping
  211. 03 TB LTZ steering wheel controls
  212. check engine light and fuel guage issues.
  213. 04 TB LS Blinker issue
  214. Stalling/Sluggish Acceleration..P0134/P0130
  215. Clutch fan
  216. Remote keyless entry
  217. 2004 Trailblazer Hesitating
  218. loud roaring in right front tire.
  219. Problem with 02 ABS brakes
  220. Access to spark plugs Tblazer 03 V6
  221. stabiltrak active on dry asphalt 2006 Trail B.
  222. P0305 Cylinder 5 Misfire
  223. rear a/c problem
  224. Burning oil smell from trailblazer rear
  225. A/C Issues
  226. Driver side window master switch problems
  227. 03 Rear Power Windows not working
  228. problem with the temperature of the engine
  229. instrument cluster lights...
  230. Fan clutch left unplugged...help!
  231. Strange A/C problem
  232. Thermostat Question
  233. Radiator cause water pump failure? Please help
  234. 05 Trailblazer idles rough and stalls
  235. 04 Chevy Trailblazer - cost to replace front passenger side door
  236. Any Trailblazer SS owners out there? I have a question
  237. oil pressure
  238. O5 rear hatch lock
  239. brake lights
  240. oil pressure and brake light
  241. What happened to the vin stickers on body panels?
  242. Adding a navigation system to a 07-08 Trailblazer
  243. 2002 TB Low Oil PSI at Idle
  244. 2002 tralblazer sercurity light on and wont start
  245. Rear Speakers
  246. Power Steering issue?
  247. Trailblazer Rough Idle
  248. towing capacity
  249. trailblazer 2003
  250. trailblazer lt ext 2005, engine light
