Our Community is 705,000 Strong. Join Us.
Chevrolet
> TrailBlazer | Trailblazer EXT
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
tires
Which gears to use?
keyless remote programming
creaking front end
Heated seats
02' TB - Can I adjust the Wipers? And a rattling noise from roof rack...
Molded Wood Dash Kit for Sale
Start of a problem with Transmission, Transfer Case or Rear end
Camshaft Timing Sensor
Odd Grinding Noise from rear wheels when in AWD
Radio
2005 Fuel Filter
Looking for crate 4.2 I6
Transmision shifting hard on a 2004 TB
Vibration in Trailblazer
accident damage question
rear window out of track
sway bar links
Navi and XM
Gear Ratio
Vertical scratches on windows
Weight Capacity
Wood grain dash F/S for a 02 Trailblazer
Key pad and some electrical issues
aftermarket muffler question!
knocking left side dash?
Shift knob loose
2002 Trail Blazer Wheel Noise
Transfer case problems
HVAC problem - Help
Computer Updates
Clicking sound when touching brakes?
Test port dosent work
Loud engine noise when accelerating - 2003 model
TB have a prob with 4x4?
Smelly vents on 03 TrailBlazer
Hooray! 2002 TB is gone.
Head Lamps and Tail lights
my new mods
Two problems, AC and Putting in Drive
Speedomador Problems
diesel vs gas filler
New member need help Trailblazer keeps cutting out
Hi, new member w/t ? about running boards
spare tire??need help
spare tire??
Ignition Switch Replacement Question?
2005 Trailblazer Slipped Out of Park and Into Reverse
Searching for Custom Grill for 05
Horn Problem Trailblazer
brake/turn signal
Remove wax from trim
Calling All Chevy Lovers
A/C Fan Intermittent
wireing
New member here...
Locking gas cap availability?
Best Bulbs for TB
Window switch question
Ltz Tires
2002 transmission is broken again.
Keyless entry programming problems
Installed "Earthing" or Grounding wire kit to your TB?
Rear Brakes? Hard to replace?
05 TB EXT LS V8 oil change
fan clutch?
Chrome intakes (cold air)
fill up your ride now
new Trailblazer owner ""HELP"" ?!?!?!
outside temp. control giong crazy???
locks and lights
Need to change steering fluid??!
New TB Owner Here!
03 TB Gas Mileage
2002 TB no start problems
Speakers.
6 CD Changer
Removing body trim
installing a new deck into my '04 trailblazer
Chip for better gas mileage
mp3
4wd shift from stopped position
North Face floormats/trunkmat
22" Dvinci Havoc XL Wheels Question
New trailblazer 391hp AWD
Trailer brake controller....?
flap on filler neck
Stainless Steel Mud Guards
Fan Clutch: How to Change It
AC + overheating
Glowing red exhaust
HATEFUL, EVIL, Daytime Running Lights DRL
correcting typo
Shifting out of Park...
AC Thermostat External Temp
2.4l I 6
Remove emblems/badges
2003 tb ext parking brake adjustment
black smoke in trailblzer ext 2005
Replacement emblems
Chrome/Stainless Steel Center Grill
oil sending unit(?) leaking
4x4 removal
Generic spare keys?
03 Trailblazer Rear Axle Oil Change
02 Chevy trailblazer fan clutch?
loss of MPG? on a 2005?
4-wheel drive indicator light
rear wiper inop
2005 Trailblazer - acceleration / hesitation
bypass hole in airbox...purpose?
2002 TB Fueltank prob
accessories
Rear window wiper
Direct replacement fog lamps? LQQking for something better/brighter.
Underdrive Pulley's for the V8?
Lots of rattles from under carriage?
Fourms and Pages
Fan Clutch Fan Clutch Fan Clutch
Creative Ideas for TB listing
2002 Trailblazer recalls
Clicking sound, front of engine, when cold
Increasing Ground Clearance
Wireing question
Cold air intake
2005 Trailblazer LS w/ Bose and 6 disc.....thought it can play MP3's
is this legal?
Buying trailblazer
'02 wet passenger floorboard
Fog light installation on LS Trailblazer
Parking Lights - Fuse?
Reverse lights illuminate on keyless entry
Question about rims?
Noob with a few questions
First post...Bad vibes please help
22" Wheels+Tires for sale
Radio Navigation set data base
No mudflaps on Trailblazer w/ running boards?
Installing mudflaps on 2004 Trailblazer?
Gas Tank size
Resale Values diving into the pooper...
Noise when accelerating -any speed ('04 Tb)
How do I remove the sun visors for headliner removal
Windshield Wipers Jump
Remote entry on key?
Another intermittent problem
Service Bulletin # PIP3164A
Aftermarket Muffler
2003 EXT 4WD Suspension Improvements ???
rattle noise from rear
DVD with sunroof
Fan control
Hotchkis Anti Roll Bars
Electrical Nightmare
10% Ethanol?
LT EXT w/ Bose - Adding Kicker - Please Help
Turn Signals
Droopy headliner
Switched power needed at the top of the windshield.
WTF was Chevy thinking? Control arm in the way of bigger tires
Back window button stuck on 2003 Trailblazer
Dash Kits
I4.2L vs. I4.2L
Bumper cover repair
Who makes replacement shocks (besides Bilstein)?
Fog light voltage/Underbody neon mod...
2003 Trailblazer Radio Knobs
Turn signals blink twice, then shut off...HELP...
Locked Out
remote #1 and #2
2002 TrailBlazer GPS navigation
Outside Turn Signal Mirrors help.
2002 TB Rust Problem
Where can I find a replacement carpet (not mats)?
installing strobes/siren into a vehicle
Squealing Noise
What is your average miles / kilometers per tank?
horrible gas mileage normal?
Mirror Extensions for Towing
Trailblazer body lift? Suspension lift?
After Market Amp With Factory Radio
'02 fan clutch
Brake Pedal dropping when depressed.
Change Engine Oil Light (2004 TBlazer)
2005 vs. 2002 4.2L
Door locks
02 TB fan clutch replacement
Power to the ignition coils....
How are they cylinders numbered?
Need Help From Majestic Red Metallic Trailblazer Owners
Trailblazer Angel Eyes Projector Lights
Question about purchasing a new TrailBlazer
Check engine light after Cold air intake installation
Headlight Housings
Starts and almost stalls
What can i do with these
265/75r16 on stock wheels
Rough acceleration on my Trailblazer I6
Dropping the Headliner
How do you remove the headrest..
Black Rims
Turbonator
Replacement of the steering wheel buttons
Throttle Body Spacer Question (Mr. Northface help)
Suspension Spacer project done
Driver's side power window problem
Looking to Buy: LS/LT Running Boards
install Airaid PowerAid problem
Roof Rack Clearance Lights install?
2004 antenna replacement ? Need help Please
any other Trailblazer forums, also, V8 Swap question
factory radio wiring schematics
axle right rear
valve seals
Selling Custom Sound System
Upgrade system
Lift kit and rims and tires
P0495
For the few who didn't see it.
AC and MPG
External air temperature sensor location
Ticking Noise
Driver Info Center
GM Recalling 300,000 Trucks, SUVs
backup system
Sound system question
Backlight on wheel buttons
trailer light fuses
Will My EXT Tow a Car Trailer?
noise question HELP! please
DIC calibration
fog lights
Vent Visors/Bug Deflector - Extended Trailblazer
Shock Absorbers
Intermittent Audio system
leaking terminal on battery
Turn Signal Mirror install complete!
Tap from behind?
Jet Torque Converter and TransPerformance Kit?
Vibration in Gas Pedal
Airaid Throttle Body Spacer
Ticking Noise from the fan clutch
Scratches on windows
P0300 Misfire cyclinder 4
Power Mirrors Don't Recall Well
Lift Kit
Fuel Economy & Tire Pressure
Just Joined...Rear Tailgate Shock Issue
Automotive Network, Inc., Copyright ©2013
