View Full Version : TrailBlazer/Trailblazer EXT
Pages : 1 2 3 4 [5] 6 7 8
  1. Change Oil Soon Light
  2. better way to hang the spare?
  3. Is this a good price for a high mileage 2003 Trailblazer LT?
  4. Purchasing a Used TB
  5. Accuracy of "Oil life left"?
  6. Customizing Interior
  7. The truth about gasoline
  8. Listening to the radio...
  9. Removing the Torque limiter on a Trailblazer.
  10. Which grade of gas do you use?
  11. pulsing fan
  12. Hi, I'm new to these forums.
  13. Wind Noise 2004 Trailblazer
  14. Built motor/turbocharged Trailblazer project
  15. sensor under the top radiator mount
  16. Projector headlights
  17. "OC" in rear view mirror instead of temp
  18. Remote FOB Sync/Reprogram - 02 Trailblazer
  19. Navigation Disk
  20. 05 V8 mods
  21. Amber Rack Lamps
  22. Trany fluid leak
  23. 02 electrical help PLEASE !!
  24. Squeak
  25. New TrailBlazer
  26. o2 sensor removal
  27. Ford F150 wheels on TBs?
  28. Some info on trans usage in sno and ice
  29. strange clicking noise
  30. Steering wheel emblem
  31. blower motor
  32. security light
  33. 2004 fuel filter change when?
  34. Seat loose
  35. yellow turn signals
  36. Fuel Gauge Not Working
  37. Cruise control Quits
  38. 2005 shocks
  39. service 4 w d light
  40. tires
  41. Which gears to use?
  42. keyless remote programming
  43. creaking front end
  44. Heated seats
  45. 02' TB - Can I adjust the Wipers? And a rattling noise from roof rack...
  46. Molded Wood Dash Kit for Sale
  47. Start of a problem with Transmission, Transfer Case or Rear end
  48. Camshaft Timing Sensor
  49. Odd Grinding Noise from rear wheels when in AWD
  50. Radio
  51. 2005 Fuel Filter
  52. Looking for crate 4.2 I6
  53. Transmision shifting hard on a 2004 TB
  54. Vibration in Trailblazer
  55. accident damage question
  56. rear window out of track
  57. sway bar links
  58. Navi and XM
  59. Gear Ratio
  60. Vertical scratches on windows
  61. Weight Capacity
  62. Wood grain dash F/S for a 02 Trailblazer
  63. Key pad and some electrical issues
  64. aftermarket muffler question!
  65. knocking left side dash?
  66. Shift knob loose
  67. 2002 Trail Blazer Wheel Noise
  68. Transfer case problems
  69. HVAC problem - Help
  70. Computer Updates
  71. Clicking sound when touching brakes?
  72. Test port dosent work
  73. Loud engine noise when accelerating - 2003 model
  74. TB have a prob with 4x4?
  75. Smelly vents on 03 TrailBlazer
  76. Hooray! 2002 TB is gone.
  77. Head Lamps and Tail lights
  78. my new mods
  79. Two problems, AC and Putting in Drive
  80. Speedomador Problems
  81. diesel vs gas filler
  82. New member need help Trailblazer keeps cutting out
  83. Hi, new member w/t ? about running boards
  84. spare tire??need help
  85. spare tire??
  86. Ignition Switch Replacement Question?
  87. 2005 Trailblazer Slipped Out of Park and Into Reverse
  88. Searching for Custom Grill for 05
  89. Horn Problem Trailblazer
  90. brake/turn signal
  91. Remove wax from trim
  92. Calling All Chevy Lovers
  93. A/C Fan Intermittent
  94. wireing
  95. New member here...
  96. Locking gas cap availability?
  97. Best Bulbs for TB
  98. Window switch question
  99. Ltz Tires
  100. 2002 transmission is broken again.
  101. Keyless entry programming problems
  102. Installed "Earthing" or Grounding wire kit to your TB?
  103. Rear Brakes? Hard to replace?
  104. 05 TB EXT LS V8 oil change
  105. fan clutch?
  106. Chrome intakes (cold air)
  107. fill up your ride now
  108. new Trailblazer owner ""HELP"" ?!?!?!
  109. outside temp. control giong crazy???
  110. locks and lights
  111. Need to change steering fluid??!
  112. New TB Owner Here!
  113. 03 TB Gas Mileage
  114. 2002 TB no start problems
  115. Speakers.
  116. 6 CD Changer
  117. Removing body trim
  118. installing a new deck into my '04 trailblazer
  119. Chip for better gas mileage
  120. mp3
  121. 4wd shift from stopped position
  122. North Face floormats/trunkmat
  123. 22" Dvinci Havoc XL Wheels Question
  124. New trailblazer 391hp AWD
  125. Trailer brake controller....?
  126. flap on filler neck
  127. Stainless Steel Mud Guards
  128. Fan Clutch: How to Change It
  129. AC + overheating
  130. Glowing red exhaust
  131. HATEFUL, EVIL, Daytime Running Lights DRL
  132. correcting typo
  133. Shifting out of Park...
  134. AC Thermostat External Temp
  135. 2.4l I 6
  136. Remove emblems/badges
  137. 2003 tb ext parking brake adjustment
  138. black smoke in trailblzer ext 2005
  139. Replacement emblems
  140. Chrome/Stainless Steel Center Grill
  141. oil sending unit(?) leaking
  142. 4x4 removal
  143. Generic spare keys?
  144. 03 Trailblazer Rear Axle Oil Change
  145. 02 Chevy trailblazer fan clutch?
  146. loss of MPG? on a 2005?
  147. 4-wheel drive indicator light
  148. rear wiper inop
  149. 2005 Trailblazer - acceleration / hesitation
  150. bypass hole in airbox...purpose?
  151. 2002 TB Fueltank prob
  152. accessories
  153. Keyless entry programming
  154. Rear window wiper
  155. Direct replacement fog lamps? LQQking for something better/brighter.
  156. Underdrive Pulley's for the V8?
  157. Lots of rattles from under carriage?
  158. Fourms and Pages
  159. Fan Clutch Fan Clutch Fan Clutch
  160. Creative Ideas for TB listing
  161. 2002 Trailblazer recalls
  162. Clicking sound, front of engine, when cold
  163. Increasing Ground Clearance
  164. Wireing question
  165. Cold air intake
  166. 2005 Trailblazer LS w/ Bose and 6 disc.....thought it can play MP3's
  167. is this legal?
  168. Buying trailblazer
  169. '02 wet passenger floorboard
  170. Fog light installation on LS Trailblazer
  171. Parking Lights - Fuse?
  172. Reverse lights illuminate on keyless entry
  173. Question about rims?
  174. Noob with a few questions
  175. First post...Bad vibes please help
  176. 22" Wheels+Tires for sale
  177. Radio Navigation set data base
  178. No mudflaps on Trailblazer w/ running boards?
  179. Installing mudflaps on 2004 Trailblazer?
  180. Fog light installation
  181. Gas Tank size
  182. Resale Values diving into the pooper...
  183. Noise when accelerating -any speed ('04 Tb)
  184. How do I remove the sun visors for headliner removal
  185. Windshield Wipers Jump
  186. Remote entry on key?
  187. Another intermittent problem
  188. Service Bulletin # PIP3164A
  189. Aftermarket Muffler
  190. 2003 EXT 4WD Suspension Improvements ???
  191. rattle noise from rear
  192. DVD with sunroof
  193. Fan control
  194. Hotchkis Anti Roll Bars
  195. Electrical Nightmare
  196. 10% Ethanol?
  197. LT EXT w/ Bose - Adding Kicker - Please Help
  198. Turn Signals
  199. Droopy headliner
  200. Switched power needed at the top of the windshield.
  201. WTF was Chevy thinking? Control arm in the way of bigger tires
  202. Back window button stuck on 2003 Trailblazer
  203. Dash Kits
  204. I4.2L vs. I4.2L
  205. Bumper cover repair
  206. Who makes replacement shocks (besides Bilstein)?
  207. Fog light voltage/Underbody neon mod...
  208. 2003 Trailblazer Radio Knobs
  209. Turn signals blink twice, then shut off...HELP...
  210. Locked Out
  211. remote #1 and #2
  212. 2002 TrailBlazer GPS navigation
  213. Outside Turn Signal Mirrors help.
  214. 2002 TB Rust Problem
  215. Where can I find a replacement carpet (not mats)?
  216. installing strobes/siren into a vehicle
  217. Squealing Noise
  218. What is your average miles / kilometers per tank?
  219. horrible gas mileage normal?
  220. Mirror Extensions for Towing
  221. Trailblazer body lift? Suspension lift?
  222. After Market Amp With Factory Radio
  223. '02 fan clutch
  224. Brake Pedal dropping when depressed.
  225. Change Engine Oil Light (2004 TBlazer)
  226. 2005 vs. 2002 4.2L
  227. Door locks
  228. 02 TB fan clutch replacement
  229. Power to the ignition coils....
  230. How are they cylinders numbered?
  231. Need Help From Majestic Red Metallic Trailblazer Owners
  232. Trailblazer Angel Eyes Projector Lights
  233. Question about purchasing a new TrailBlazer
  234. Check engine light after Cold air intake installation
  235. Headlight Housings
  236. Starts and almost stalls
  237. What can i do with these
  238. 265/75r16 on stock wheels
  239. Rough acceleration on my Trailblazer I6
  240. Dropping the Headliner
  241. How do you remove the headrest..
  242. Black Rims
  243. Turbonator
  244. Replacement of the steering wheel buttons
  245. Throttle Body Spacer Question (Mr. Northface help)
  246. Suspension Spacer project done
  247. Driver's side power window problem
  248. Looking to Buy: LS/LT Running Boards
  249. install Airaid PowerAid problem
  250. Roof Rack Clearance Lights install?
