Our Community is 705,000 Strong. Join Us.
View Full Version : TrailBlazer | Trailblazer EXT
Pages : 1 2 [3] 4 5 6 7 8 9
  1. 05 fuel lever sensor bad
  2. Trailblazer Bumper
  3. '03 using oil
  4. 02 Trailblazer wiper problem
  5. Tire load index rating
  6. Installing a new radio in a 04 trail blazer
  7. mpg question on older trailbazer
  8. Door control panel
  9. 4wd prob on 04 TB
  10. Instrument Panel Cluster - Spedometer
  11. Replacement tail light
  12. Tail lights not turning off
  13. mirror temperature reading
  14. bulb plug melting
  15. Waterpump
  16. Tick Noise that just wont go away!!!
  17. questions for tune up, '04tb, 4.2L, 106K mi
  18. seat covers, who makes what?
  19. Snow plow for 2003 trailblazer
  20. Brake controller
  21. Super Charger
  22. 2002 Seat Belt Light and Chime
  23. 2002 TrailBlazer TPS-Electrical Issue ??
  24. noise in steering wheel
  25. Keypads
  26. Bose Radio Removal Question?
  27. Shorted Somthing Clicking Noise from Engine Block
  28. 2005 Trailblazer Remote Start/Keypad Information
  29. 2005 TRailblazer thermostat replacement
  30. Electrical ?'s
  31. 2003 Airconditioner belt replacement
  32. Tune Up!
  33. 02 trailblazer too many issues to list
  34. 2002 Trailblazer - trouble starting engine
  35. 02 TB fan speed
  36. SEL on then off, is there a problem?
  37. License Plate Lights
  38. Heater issues on 02 TB
  39. 2004 TB Check Engine Soon Light -- How to Turn it Off
  40. Tick noise
  41. Idle vibration at low speed
  42. 120 Km Per Hour In 4lo!
  43. A.I.R. Pump
  44. Keyless entry question
  45. Instrument Panel Bulb out
  46. Compass in mirror not accurate
  47. Off Road Package
  48. 2004 trailblazer fuel trouble
  49. Heated Seat doent work
  50. Whining Noise When Starting.... Pump?
  51. 2005 Trailblazer Luggage Rack Question
  52. front end squeaking
  53. Quick Remote Starter Question
  54. Help with immobilizer.
  55. PO128 code
  56. 02 Suspension and Steering Problems
  57. AC noisy?
  58. Looking for Stock Taillights for an 2002
  59. Fuel Gauge 2007 Trailblazer
  60. camshaft sensor
  61. Changing Spark Plugs ??
  62. heated seats
  63. 2002 TrailBlazer
  64. Whining Noise
  65. A different noise
  66. help on a basic tune up
  67. 2002 Trailblazer Park Brake Adjustment
  68. Whirling noise
  69. passenger and rear blow cold all the time
  70. Finally got my act together!!
  71. wiring question
  72. '04 Fan/Fan Clutch
  73. Remote Start 2004/ locks
  74. Coolant smell in 2003 Trailblazer
  75. Turns over like it has a dead battery......
  76. Steering wheel buttons
  77. Service Onstar message
  78. 04 Brake Lights
  79. How do you replace left rear pasngr window motor
  80. Is this a good truck?
  81. 2004 Trailblazer EXT trailering harness
  82. frontend bushing noise? 2002 tb
  83. Seat issues in 02 TB...
  84. visor question
  85. whining noise
  86. One more Question!!
  87. 2002 trailblazer ls...i need help
  88. Driver Side Seat Broke! Parts available???
  89. Power Loss and hesitation
  90. Speedometer Getting Stuck
  91. Whining Noise When First Started
  92. onstar led turn red next to blue button
  93. driver side door handle lock pushed in from break in
  94. How do You get code???
  95. intermittent electrical problem
  96. Service Engine Soon - I have the code
  97. Master window switch
  98. Help!! 02 Trailblazer making thuding noise underneath
  99. Trailblazer rolls in Park??
  100. It Happened Again
  101. A/C compressor replacement
  102. Trailblazer Tail Lights
  103. Emergency Brake not holding
  104. 04 gets hot
  105. Nav Unit Transfer - 2004 Escalade to 2005 TB
  106. any ideas
  107. ***IS it possible???/ Smart??****
  108. ticking noise coming from engine...also never ending service light
  109. Weird noise coming from the dashboard.
  110. 04 + Reapir Manual
  111. At speeds of 45+ car jumps, causing RPM's to increase
  112. A smell like ketcup, after driving car for short distance
  113. In Cabin Air Filter
  114. rear hatch keeps clicking trying to lock
  115. Low Oil Pressure
  116. Electrical problem
  117. 04 trialblazer(po 172)CODE
  118. Rough idle
  119. '06 Trailblazer ignition problems
  120. Fuel Gauge Wrong?
  121. 03 TB Headlights not working
  122. 04 TB remote entry ?
  123. How many miles?
  124. Direct wire radar detector
  125. Hesitation
  126. PCM Random Access Memory (RAM) Error?
  127. Bought an 04 Trailblazer EXT
  128. fan clutch probs.
  129. ac problem
  130. excessive headlight burnout
  131. clicking when turn engine off
  132. Service 4WD light and 4WD question
  133. Trailblazer EXT Keyless Entry
  134. ODBII connection on 03 trailblazer
  135. Transfer Case DTC codes
  136. fan clutch reprogram
  137. Converter question
  138. 4WD switch question
  139. Trailblazer AC issue
  140. some help
  141. A challenge to TB experts - Engine Heat
  142. Inermittent Blower Operation
  143. need advice
  144. Keyless entry remote
  145. 02 rough idle
  146. Trailblazer oil issues
  147. 2002 Trailblazer recall question.
  148. Brake Controller wiring
  149. Tire pressure
  150. 2K3 TB - rear AC blows intermittent
  151. Camshaft and crankshaft position sensor
  152. $1200 Evaporative Core...Excessive???
  153. battery keeps dying
  154. car issues
  155. removing the side view mirror glass only
  156. where are they located?
  157. P10304 Cylinder 4 misfire
  158. AC Kills Motor
  159. Disk Error on 6 Disk Changer
  160. Lost instrument cluser, no tach and no speed...
  161. location for a switch
  162. 06 trailblazer window control problems
  163. A/C Blows HOT HOT air from pass. side.
  164. Tailgate won't lock
  165. P0410 code - 2005 Trailblazer
  166. 05 Trailblazer - Replacement Airbags
  167. 2005 Trailblazer clock
  168. Trailblazer catylitic converter failure
  169. 03 Blown fuse
  170. I cant remove my key from the ignition!!!
  171. fog lights
  172. 2005 trailblazer with trailer package - need to install brake controller
  173. Accelerator Pedal Position Sensor
  174. Drive Train Service
  175. dash removal on 03 trailblazer
  176. Fan clutch and long trips
  177. 02 trailblazer revving really high at times
  178. TB MAP Sensor & TB Clean
  179. Need to take out the factory CD player
  180. 2003 TB ignition switch
  181. Porcelain broke
  182. 99 Trailblazer fob prob
  183. Bad smell on my A/C vents
  184. 03 ext gas tank recall
  185. Help Me From Saudi Arabia
  186. 2002 Trailblazer Info
  187. New TB
  188. Spark Plugs in 2002 TB
  189. Clicking Noise, Rear Fuse Box
  190. 2005 Trailblazer Differencial aligment
  191. Instrument/Dash lights went out....help
  192. Replacing HVAC Mode Door Actuator
  193. Standard 04 TB radio/cd player frozen!
  194. looking at a 2002 Trailblazer
  195. Change Oil Light
  196. 2005 Chevy trailblazer Diff!
  197. Intermitent cranking problem
  198. CDs stuck in Bose 6-Disc Changer!?!
  199. Acetone in diesel
  200. any hepl for this problem?
  201. Struts/Shocks
  202. Speedometer Not Working
  203. two things
  204. Need new steering wheel
  205. 04 Rough Idle in Drive
  206. 2005 Trailblazer rear axle replacement.
  207. New problem after water pump
  208. 2002 TB engine dies when turning on AC
  209. 04 Trailblazer aftermarket headlight, grille, and bumper cover question.
  210. 2003 Trailblazer - a/c air conditioning intermittent
  211. secondary air injection pump (SAI)
  212. secondary air injection pump (SAI)
  213. secondary air injection pump (SAI)
  214. Help with wiring!
  215. 04 trailblazer seat wiring help?
  216. driver window stuck
  217. High RPM's after start
  218. 2004 Trailblazer - DTC P0016
  219. BCM HELP or WIRING
  220. seafoam
  221. Diff capacity
  222. Special lug nuts?
  223. CB Radio Installation
  224. misfire
  225. Ambient sensor-A/C 02 TB
  226. Anti Syphon Device
  227. make all lights burn at same time?
  228. 2002 Trailblazer running rough
  229. From a 1997 GMC Jimmy to a 2005 Chevy Trailblazer
  230. Headlight flasher ( wig wags )
  231. TB fan clutch
  232. used Trailblazer...
  233. dbramle3
  234. Airbag warning light
  235. service brake system (wont start?)help
  236. NO sound out of rear speakers
  237. 4l60e
  238. Not to change the subject, but...
  239. Question about the factory stereo
  240. belt noise
  241. Trailblazer Remote Or Antanna Lead
  242. Trailblazer stereo problems
  243. Low beam HIDs, high beam DRLs ?
  244. 2005 Rear Disc Brake Replacement Question please
  245. blower motor resistors
  246. 4WD Problem
  247. Rear window opener
  248. Steering wheel buttons
  249. wheel bearings
  250. gear ratios
