Our Community is 705,000 Strong. Join Us.
Chevrolet
> TrailBlazer | Trailblazer EXT
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
Driver side window master switch problems
03 Rear Power Windows not working
problem with the temperature of the engine
instrument cluster lights...
Fan clutch left unplugged...help!
Strange A/C problem
Thermostat Question
Radiator cause water pump failure? Please help
05 Trailblazer idles rough and stalls
04 Chevy Trailblazer - cost to replace front passenger side door
Any Trailblazer SS owners out there? I have a question
oil pressure
O5 rear hatch lock
brake lights
oil pressure and brake light
What happened to the vin stickers on body panels?
Adding a navigation system to a 07-08 Trailblazer
2002 TB Low Oil PSI at Idle
2002 tralblazer sercurity light on and wont start
Rear Speakers
Power Steering issue?
Trailblazer Rough Idle
towing capacity
trailblazer 2003
trailblazer lt ext 2005, engine light
Errattic idle
02 Drivers side power seat wont go forward
tire wear
LED lightbulb replacements
2000 Trailblazer Ticking Sound
255-65-17 tires?
Trailblazer aftermarket tail lights anyone?
Universal Joints
2005 trailblazer starting issues
Battery light comes on
gas smell/starting
How do you change th license plate bulbs on a 2002 trailblazer
Squeaking Noise At Front Of Engine
Trailblazer vibration/hum
Need rear spoiler/3rd brake light for EXT
Low Oil Pressure
P0449 code...
2002 hid install help
Transmission Fluid recommendation?
Fuse/Wiring help
2008 TB Liftglass won't open
Power Steering Hose Bursted!
knocking sound from engine
Trailer lights not working
CV joints
03 trailblazer brakelight problem
How to clean your throttle body
05 Trailblazer Radio problem.
2002 Trailblazer front axle locks 4wd
Excessive power draw
secondary air intake malfunction
Engine whining and pinging sound DTC P0327
Help
Cabin HVAC (ACC) filter
Can i rekey a chevy tb 03
02trailblazer/dtcp0014-p0105
2004 Chevy Trailblazer
red flags
2004 Trailblazer Blown Transmission
Car dead overnight
A little fog light help?
Anyone runing 245/75R/16 tires in their TB?
Trailblazer starts and dies have codes!
P1120
02 Trailblazer crank but no start!?
2003 Trailblazer, when i get to 30mph the engine stays revved up
clicking /thumping sound in back right rear ????help
Temp. gauge not working properly
Climate control temperature issue on TB05 EXT
water pump question
'05 TB wheels locking up in 4HI
The CHEVY 03+ NAVIGATION RADIO Screen damaged
2002 Trailblazer Cranks but won't start
07 Trailblazer Traction control
LOST Key FOB What now..
Engine- swap will a 05 work in an 06?
timing belt information
wont start with key, remote only
Upgrading the rear view mirror '08 TB
code p0410
03 front differential right side oil pan axle lube
changing blower motor
Trailblazer squeals after front diff. replaced
RPM gauge goes dead
2004 TB CD Stuck in Player
chevy trailblazer 02
Fuse between battery and starter
Trailblazer "SS" rear lower bumper valance
2003 TB gauge problems
4 wheel wont engage light blinking
07 TB lift glass doesn't lock
'04 trailblazer p0410, secondary air pump
Loud Clicking Noise When Rear A/C is on
Heater and instrument panel
2004 Trailblazer low beam headlights out
Front end Whirring over 40 mph
Annoying thumping noise when driving over pot holes
Rear View Mirror TB 04
Mirror settings
Vibration/Humming
Somethin' leaking...
P0741 P0894 trans fault any help?
Shattered Rear Window
heat stuck on.....
what is the typical temp readings in 2005?
instant fuel readings - help is needed
**Got into an accident, need advice!!!***
Cup Holder Inserts???
Fan Clutch
Need axle lube advice for 03 TB
No electrical power then suddenly its ok
'03 Trailblazer Eletrical Issues
2002 Trailblazer Lt with vibration/shudder problem
Trailblazer EXT 04 - AC is not working
Transmission issue...
Squeaky Chassis
what do I see under the oil cup?
Idle drop-off and shutting off at stop
what should i look 4 before i buy 2005?
Motor won’t start, sporadic gauge movement, locked transmission- PLEASE HELP
4wd on 02 tb
Inside fan Part number???
idle problem when fan turned to defrost
Passenger Headlight Lowbeam
Exhaust Rattle
Random jerks while driving
AC not working
Computer Issue
Trans wobble
dead battery
wont shut off
2003 Reduced Power Light / check engine problem
2002 Trailblazer Keeps Stalling
battery recommendation?
03 trailblazer how do i remove valve cover?
help with something?
Engine compartment cleaning?
spark plugs
IGN/ACC wire / where and which?
Interior Fan Malfunction - HELP
04 Trailbazer engine swap...now defrost/vent/floor selector knob doesn't work.
scratches and scuffs
Compass issue
Trailer wire connection problem
Stupid question?
what tire?
battery drain ??
Changed spark plugs and now it stalls?
Fuel pump and line repair...Keep your receipts
inside fan stopped to work
02 Trailblazer AC
04 Trailblazer - AC takes forever to get cool
2004 Trailblazer EXT I6 Engine Swap...Dead #4 Cylinder!
2002 Trailblazer is at NHTSA testing facility
Catalytic converter or Exhaust manifold
Where are the grease fittings on a 2004 tb?
02 TB Alternator Removal
04 Trailblazer stalls at red lights
Sparkplugs
off-road rims and tires, anyone?
Power seats won't move forward/backward but other functions work
Shifting Gears......'clank'..!!
Rattling doors on bumps
2005 Trailblazer Ext Brake Controler Hookup
SES light and trembling/vibration on 02 TB
Key Fob Question
Loss Of Power Cuts Off When Stopped
2205 Trailblazer Brake Controler Wiring
2003 Trailblazer EXT Clicking problems
What is the proper oil?
2002 TB EXT / Envoy XL Faults?
2002 Trailblazer A/C won't blow thru vents.
MAP Sensor
Shorted Fuse Block Terminals
2003 TB tranny lines
My Trailblazer cherps and clunks, HELP
tb line converter
2003 trouble code
Could it be my AC/heater blower motor?
Anyone had any luck with power programmers??
tachometer
Can't find fuel filter
05 TB stalling and hesitating....
'05 TB stalling.. someone please help me!!!
Grinding noise in driver's side wheel????!!!
front rotors bad after 10000 miles
'03 Trailblazer with K & N filter
Interior rear view mirror/broken mount
2002 Trailblazer Electrical Problem Shuts OFF
gauge cluster
Batteries gone wild
P0410 code 05 ls
2002 Brake pedal/ Taillight issue
main pulley
pcm reflash ???
2002 trailblazer radio problem
Po455 & P1680 codes
worse idol and hesitation after tune up
coil pack
Climate Control Problem
04 Trailblazer Ext codes & un-diagnosed problems
Rear tail light assembly
air intake
locking gas cap
Squealing noise in reverse
whining between 2600 to 2900
big tune-up...first time...please help!
Trans cooler on '03 TB
2002 Trailblazer LS ABS light problem
wrong temperature reading
sqealing window
Vertical glass scratches in all 4 doors
Does anybody know what this box is?
Headlamps? 04TB
Chev. Blazer
04 TB, how big is the gas tank?
noises... driving me crazy
Just Curious - Whats Your Gas Mileage?
power window switch
2nd time a charm, replace ign switch
2002 TB oil pressure gauge dropping to 0 then back to 40
What are your opinions on oil?
4WD Problem
batter not charging message
Changing spark plugs for the first time
Mis-Fire on 2005 TB
Backlight on dash out
2004 Radio Lights
shower included, just add rain
Does my 2002 Trailblazer OEM radio have an Aux port? Where?
Help!!!!!!!!! Trailblazer Ss Gear Shift
Front side marker bulb relacement
04 TB - hopefully will get some answers!
05 TB Cruise Control Issues....
rear end oil
02 trailblazer instrument cluster lights
Need help replacing Camshaft sensor
2002 LS Seatbelt Question
Lights coming on instrument panel
2002 vertical and horizontal headlight alignment
Red flashing light
05 fuel lever sensor bad
Trailblazer Bumper
'03 using oil
Automotive Network, Inc., Copyright ©2013
