View Full Version : S-10
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. 1995 s-10 wont start
  2. S-10 no start
  3. 1987 2.5L, 4speed manual, considering engine swap, trying to figure out best route.
  4. 1987 S10 Needs help!! Engine? Possible Trans issues
  5. wiring problems
  6. exhaust ?s
  7. Cap Swap
  8. 96 s10 no reverse
  9. 4WD will not turn on
  10. 95 s10 v8 shifter linkage and various ?'s
  11. Caliper replacement - Leaking
  12. 2000 S10 Blazer 4.3 burns up coils
  13. 91 Blazer Blows Smoke
  14. S10 oil pressure unit?????
  15. 96 s10 problem
  16. 1993 S10 Bumper mounts
  17. 1996 S-10 Turn signals?
  18. 95 s10 runs rough after rain shower/moist mornings
  19. Timing problem S-10 ???
  20. P0452
  21. 220 tbi running really rich
  22. loss of power at high altitude?
  23. 97 S-10 2.2 5spd White Smoke!
  24. stalling after replacing fuel pump
  25. Ford 9" and S10 question
  26. 1991 4.3 engine missing, low on power
  27. Bought an '85 S10
  28. Transmission interchangable
  29. 93 Grill on 84 S-10
  30. zr2 4wd quesiton
  31. any gm tecs on here?
  32. 03zr2 transfer case poping in 4x4
  33. S10 Rodeo
  34. 1990 4.3 starts then dies
  35. trans vaccume lines--and more, 85 s-10
  36. 2002 s10 p1860 code?
  37. 2001 Blazer 4.3 into a 1996 s-10 problem
  38. 2003 S-10 Radiator thread problems
  39. Open the bleeder
  40. Clutch fan replaced, so why?
  41. Oil level
  42. Reverse lights not working
  43. engine swap
  44. 2 Wheel Drive to 4 Wheel Drive
  45. Intermittent loss of electrical when trying to start
  46. turn signal swicth 93 s10 blazer
  47. 2000 s-10 steering shaft
  48. Pour coolant in, coolant gushes out(2.5)
  49. s/10 2.2 engine cross refernce
  50. a/c only blows under dash..
  51. 92 S10 have coolant leak
  52. Ball Joint
  53. 4.3 vortec ?
  54. Oxygen Sensor
  55. 98 S-10 2.2 no start
  56. Cleaning Engine
  57. 2001 s10 ac and heater fan
  58. 1999 s10 guessing fuel problem
  59. ac blower fan switch
  60. 87 s-10 4speed..loss of power when shifting into 1st gear
  61. 92 S-10 lifters
  62. Fuel Line for 2.8 engine
  63. headlights flicker
  64. Parking Brake
  65. 1995 chevy S10 2.2 engine
  66. Drive Shaft Lube Fitting
  67. Tempeture Gauge in 83 S-10 2.8
  68. wheel rubs a arm
  69. 83 Chevy S-10 2.8 Check Engine Light
  70. 4X4 BLZR - what is the thing under battery tray?
  71. Battery neg to Engine?
  72. How do you prevent Vapor Lock
  73. 2002 S-10 Aux. Power outlets
  74. 95 S-10 complete electrical failure(engine too)
  75. Ext. Cab Rear Driveshaft U-joints
  76. 2 Barrel Carb 83 S-10 2.8
  77. 1998 s-10 a/c help
  78. 2000 S-10 4.3L V6 AC Replacement Questions
  79. firing problem
  80. 1991 s-10 4.3 2wd
  81. 1999 S10 front brake caliper removal
  82. 1983 Chevy S-10 4x4 2.8 V6
  83. can anyone help?
  84. Alternator wire(s)
  85. 2.2 Head
  86. will not start!
  87. 2.8 to 4.3 swap
  88. Fuel pressure problem on a 2001
  89. Too many kilometers?
  90. Tips on installing manual transmission
  91. AIR Check Valves-- SES Light Back On
  92. 1994 s-10 4.3 5 speed 4x4 SWB
  93. Code 42 & 44
  94. 98 S-10 Rough Idle
  95. "00" s10 tranny P1870 code
  96. Frame Options
  97. 95 2.2 runs rough when engine is cold
  98. 87 S-10 won't start
  99. 4-Door ZR2 Pickup?
  100. Plastic Fuel Tank?
  101. 1995 S-10 4.3 won't start
  102. rearend swap
  103. 99 zr2, no sound from any aftermarket radio help
  104. Windsheild Washer Nozzle Replacements...
  105. The usual P0101 and P0410
  106. 2.8 Injectors
  107. low oil pressure after engine change? but oil pressure was 60 when pulled!
  108. ABS won't shut off 2003 S-10
  109. 1990 S10 2WD 4.3L Not getting fuel.
  110. S10 1996 won't crank intermittet problem
  111. ac problem
  112. 94 S-10 with no reverse in transmission
  113. S10 hard starting problems
  114. Dash lights,Tail lights
  115. Air filter
  116. Liquid sound after I start my truck
  117. engine swap, 98-99, smog pump hoses on headers??
  118. 97 s-10 no spark
  119. No Headlights
  120. Head gasket sealers
  121. 02 S10 wont start...................
  122. 2000 s10 extreme vibrations
  123. Need offroad roof rack
  124. For better results...
  125. 97 S-10 4wd won't work.
  126. tranny swap or engine swap
  127. 96 S-10 wiring harness in a 94 Model S-10
  128. 2000 S-10, ABS and Brake light issue - have codes, need advice!!!
  129. 86 S10 blazer noises
  130. Ecotec Swap?
  131. 4.3 Vortec
  132. ECMB fuse WTF
  133. 2001 s-10 service engine light flashing
  134. needing help diagnosing
  135. No heat
  136. Code 37 Problem
  137. 1997 s-10 wont start
  138. 2002 Third Door Handle
  139. 4L60 won't shift out of 1st
  140. 1991 s10 4.3 tranny problems?
  141. 4.3 vortec convertion
  142. 1993 conversion
  143. Intake modifaction on a 2.8 TBI
  144. Rebuilt nv3500, grinds going to 2nd gear
  145. Engine swap.. general questions
  146. Able to fit 31x10.5" tires on 92 S10 Blazer?
  147. THIRD Door weatherstrip or gasket????? HELP!!!!!
  148. mt2500 can you help
  149. What do you guys think.
  150. 93 2.8 to a 94 2.2 auto?
  151. 2001 S-10 Extreme crankshaft noise 4.3 Vortec
  152. Transmission Hard shift into 2nd Gear
  153. 1992 Chevy s10 load of problems , please advise...
  154. s10 loss of power hesitation codes po404 po452
  155. 88 s10 check engine light inoperative
  156. problem with my 2000 s10
  157. views on the fastest s-10 produced
  158. 95 s10 transmission problems
  159. 01 s-10 only starts with starter fluid
  160. 97 sonoma lowered help!!
  161. 97 Blazer Shift Shaft Oil Seal Replacement
  162. dash lights on a 1999 s-10 ext cab
  163. Will a 383 stroker run on a stock 90 c1500 computer
  164. need new tranny
  165. alternator
  166. Corroded Brake Line
  167. 1991 sonoma/s10 4.3 tbi running rich nightmare
  168. S-10 Radiator trans and oil lines
  169. Vin Code
  170. Annoying Surge
  171. Help plumbing a fuel cell!
  172. 96 4x4 Engine Removal
  173. Door lock relay 1987 s-10 chevy Blazer
  174. Front brakes locked up
  175. Fuel Troubles on my 1987 S10
  176. need opinions here
  177. 02 license plate light housing fell out
  178. check this out
  179. Knock sensor location on 88 s10 blazer
  180. ignition switch
  181. Auto to Manual?
  182. Swapping out the carb
  183. A/C vacuum lines
  184. Which Thermostat Temp?
  185. Fresh Air Vent Vacuum Actuator
  186. s-10 loses electrical power driving
  187. 94 S10 fuel pump relay/glovebox/what the hell???
  188. Need to Advance Timing on 95 S10 with 2.2
  189. Power window electrical issue
  190. Tranny question
  191. value S-10 with new motor
  192. 4.3 motors
  193. 1998 S-10 X-cab Truck and Oil pressure?
  194. shift cable adjustment
  195. 95 2.2L fast idle problem - idle air control?
  196. Power Break Booster install, help!??!
  197. Cause of transfer case failure.
  198. 700r4 tranny?
  199. Plug Wires
  200. Engine Difference 2000 4.3 and 96 4.3
  201. 96 S10 Blazer P0440 Code
  202. No Fuel or Spark!?!?!?
  203. Smog Pump?
  204. 30 AMP HVAC fuse keeps blowing
  205. hard shiftin?
  206. Self-Diagnostic Jump ALDL Connector
  207. A/C 98 s10 pickup
  208. To DexCool or not to DexCool? That's the question.
  209. Rear turn signal question
  210. Fuel line has air mixed with gas
  211. 99 S10 problems on cold start
  212. Better MPG
  213. Would different rear end help gas mileage?
  214. 1998 S-10 TRUCK A/C Where is it?
  215. knocking sound from rear and vibration
  216. Flatbed Coversion
  217. 1991 S10 Spark Knocking
  218. 1998 S-10 ABS Sensors location???
  219. 4x4 shifting to 4 hi issue
  220. carb problem
  221. hei vs. coil pack
  222. Having problems with steering column on my 87. Any help?
  223. how do you remove interior panels?
  224. S-10 engine specs
  225. Steering/Suspension Part
  226. rear window defroster tabs
  227. S-10 just blow air out of dash vents
  228. stalling
  229. type of transmission
  230. Fog Lights
  231. Windshield wiper problems!!!...
  232. 95 S10 surging at low speed/part throttle
  233. rear end info
  234. 2000 Xtended cab seats
  235. 97 hombre 2.2 #3 cyl fills with gas
  236. sittin cockeyed
  237. S-10 intermittent starting problems
  238. Catalytic Converter
  239. No Power mirrors or horn???
  240. hiss noise from ignition key switch or behind dash ?
  241. need help installing
  242. Key less Remote
  243. Spare Tire Hoist
  244. 3rd door handle-Broke again-Can you say cheap?
  245. 95 s10 problem
  246. Multiple misfires 99 2.2
  247. Removing plastic from gauges-How??
  248. fuel injector issue
  249. Will they fit?
  250. 1987 S-10 4X4 Auto. 2.8L V6, Timing? Power?
