View Full Version : S-10
- Best tires for s-10
- Cassette Wire
- 1996 S-10 Charging/Cranking Problem
- 2000 4x4 S-10 std cab body lift kit
- tbi injector problem
- Clutch Problems - 93 4.3L TBI
- digital dashboard-93 s-10 blazer
- Bedliner
- 1.6 Ratio Rockers on a 4.3
- Remote and RCA wire install?
- Idle problems
- electrical problem's interrior please help
- Used $.75 inch wheels for sale with tires
- Transmission slips occasionally
- 98 S-10 Break lights don't work
- Noid vs. Test Lights
- 1983 s-10 electrical woes
- 85 S-10 Racecar questions
- Chevy s10 2.2l...hp gains
- Cold start problem
- The 283?
- 89 s10 tec 4 running real rich need help
- Will a '01 Camaro Monsoon radio fit in a '95 S-10?
- katrina damage
- Adding Power Locks and Windows
- How much air should I put in my tires?
- Need axel
- fuel pump trouble
- Oil Pan Removal
- Paint gets chipped up on gravel roads
- Is the turbonator actually worth buying?
- For Sale: LT1 long block, complete or parts, dirt cheap
- fan clutch stuck?
- Any explainations for this quirk?
- Powerdyne Power Plate Users BEWARE!
- A 1989 4.3 Mess
- hudraulic clutch line
- Is There a certain vaccume line that controls the vents in your blazer?
- truck
- fuel problem!
- 89 S-10 Blazer w/ Digital Instrument Cluster
- Erratic Idling 93 Tahoe 2.8l
- Fuel Gauge
- swapping from a 2.8L to a 4.3L
- 95 S Fiberglass Front End
- Running Hot and losing oil
- 98+ Zr2 S-10
- Truck picture thread
- engine swap
- '96 S10 Blower Motor Relay? (ABS light connection?)
- Clutch Quick Connect
- 1987 blazer power door locks help!
- Dash light flicker when I open door
- 94Blazer 4.3 Fuses
- 89 s10 blazer 4.3 cuts off when stopping at a light
- Idler and pitman arm
- Crate Motor Sources
- 1989 S - Blazer Starter Alignment
- It's finally painted!
- Heater core leaking...ouch
- A/C Compressor will not turn on
- How to put 670 hp in your S-10
- Wiring Diagram 96 Chevy S-10
- 99 water pump shot!
- ? about zq8 swaybars will they work
- intermittent washer and wipers on 97 s-10
- 1988 2.5 Oil Pan Gasket
- truck turns over no crank
- DRL or auto headlights?
- Pos or Neg ?!
- battery cable burn !
- 1988 door assembly
- s-10 engine swap
- steering wiring harness for 1986 s10
- Need help with AC
- What is the timing?
- 97 blazer not starting
- servicing heater core instructions!
- How Hard on Gas?
- help
- reprogram keyless remote
- freeze plug problem...
- 94 s10 Blazer won't turn over
- gas prices cartoon
- 1995 Blazer rear end interchange info needed
- 3INCH lowering kit
- Bolt pattern numbers?
- performance will this help!!!!!
- different types of drivers... what are you?
- s10 wont start again
- Turnsignal/hazard
- runs rich untill warmed-up
- side moter mounts
- Thermostat???
- Rke (remote Keyless Entry) Instructions Needeed.
- Vortec 4.3 Idle
- Rough running and missing power
- 1991 S10 electrical problems
- 1991 Chev s-10 2wd pickup 4.3L stalling at lights
- 1998 s10 p/u front control arm bushing replacement help.
- fuel gauge not working.
- HELP with a 91 S10 Blazer trany
- Trannie
- 1995 S10 Hazard Switch?
- Fuses
- 1995 Blazer s-10 auto transmission trouble
- 1997 s10 blazer speedo not working
- plug wires 98 hombre
- Truck Not Running Right? Hard On Fuel And Sluggish Power? Try These First.....
- 1974 mustang
- 1992 s10 4x4 4.3 engine
- 2" Body Lift Problems
- where are these relay switches?
- start then not......start then not...........
- 2001 4.3L hard starter
- 89 4.3l ecm color codes
- gas tank replacement
- need help finding part name/number
- 2.5 surges
- Gauge issues after running low on fuel
- high idle sometimes
- $3.00/gal
- 87 s10 WILL NOT START
- 4.3 vortec W oil in upper plenum
- How many have these common 1st gen problems?
- 4 Wheel drive shifter knob/handle replacement
- Fs/ft:97 S10 Ext. Cab-bagged-bodydropped
- 1998 Chevy S-10 4cyl Standard; Check Engine Soon
- Looking for a tired old Chevy S10
- hard to start after K&N installed
- 4wd s10, auto or manual?
- need help...i riped out a wiring harnest truck wont run-tail lights dont work
- idle problem
- Brake Pads WTF?
- v6 s10 fuel pump failures
- 4-speed v-8 engine swap
- Changing 2000 S10 alternator
- 95 chevy s10 2.2l mods
- 95 chevy s10 2.2l
- dry-rotted tires
- 94 s10 timming
- passenger airbag control
- 95 Chevy s-10 starter troubles
- Help!!! Zr2 Dual Exhaust
- 00 s10 rear axle
- Sticky Clutch
- s10 tailgate cables
- 1985 s10 2.8
- O2 sensor question 1987
- Front Speakers
- key messed
- 4.3 torgue spec head bolts
- 1991 s-10 wont start kinda runs backfires
- How to r/r ball joints
- 1994 S10 Tailgate Handle Broke
- Blazer interior lights
- Pcv Valve
- high oil pressure
- Cant figure it out
- 94 S10 4.3L 2wd starter replacement
- 95 S-10 4.3 vortec surge
- ac blower relay fuse
- installing (all) ball joints/replacing bad ones
- 87, s10, 4 wheel drive.
- Complete and utter loss of power while on the highway
- Cold Startup problems
- poor acceleration
- load ability of the xtreme
- light bulbs
- headers and exaust
- Only runs with timing advance disconnected
- How much oil do you add when you change your oil and filter?
- horn relay?
- 87 s-10 4 cyclinder 2wd reg cab (standard)
- help runs like s@#%
- tur signal/wiper
- V8 swap and steering column
- 2001 S10 Power Steering Problem
- Gas smell!!! Cant be good, help wntd
- supercharger
- 2.2L HP Tuners- read
- S10 44 Error
- pix of truck b4 paint, will post those later (56k, come back after work)
- 1995 Blazer/timing spout connector location
- E85 Flex fuel
- It will not stay running
- Blinkers and Brake lights are out
- upper, lower bumper, grill, LH & RH fender.....
- Vaccum switch for defrost/vent/heat
- various vacuum problems
- Why Start?
- 98 blazer up and dies
- (Another)lift kit question
- Gas mileage problems
- possible egr stopping up
- help me get the bushing out
- Location of Oxygen Sensor for 1998 S-10
- Sputtering Issue
- '87 S-10 ECM fuse blows instantly??
- electronic instrument panel dims ??
- 93' Chevy S-10 Blazer
- 89 blazer 4.3 vortec swap? will this work?
- ext cab speaker
- 1997 S10 wont start need help fast
- 91 s10 misfires and sputters
- 95 ABS Recall???
- Cat Converter - trouble removing
- Possible Blown Head Gasket
- 93 S-10 Blazer Transfer Case Lubricant?
- Lifting
- **??Custom Lift Kit??**
- Quick question about a cpi replacement!!!
- Gas problem, poor gas mileage
- 64 half ton pick up S10?
- 89 S-10 sucking up my gas. Please help!
- truck not starting without pouring gas in intake
- 85 s-10 4.3 swap
- A Few Questions On A 89 S-10 Pickup
- What are these wires for?
- Anti-lock breaks
- my 1991 s-10
- 1988 radio wiring diagram
- headlight conversion?
- A/c
- 01 s-10 lifts
- 4X4 not working on 84 S10 Some help needed Please
- This ? is for the GM guys out there.
- 1990 S10 Blazer electric problem??
- Air Conditioning
- Help on my decision
- 96 S10 - Stalling out while driving and then the Air Bag/ABS lights come on (cont)
- Simple s10 Question
- Trouble code 45
- Timing check
- 88 s10 problems
- AC issue
- 1990 S-10 Blazer 4X4 5 Speed Manual Tanny
- 99 S-10 takes some time to start
- Egr OR CPI problem. Do you Know?
- Engine oil in Radiator
- Engine Oil in Radiator
- VIN # locationS
- 91 2.5L Engine Problem HELP!
- 87 S10 Blazer Wont Go in Gear
- grease on front end frame
- 93 4x4
- 98 s-10 break lights wont go off
- 1990 S-10 / S-15 Pick up TUNE UP
- Driver's Side Window Problem :-/
Automotive Network, Inc., Copyright ©2013
