View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. S10 also making a grinding noise when I turn
  2. S10 shaking and making a rattling noise when parked
  3. 89 s10 2.8 swap to 2002 4.3l Vortec
  4. Were to buy metal cab mounts
  5. 92 sonoma with v 8
  6. overhead lights won't go out.. all sudden
  7. rusted body mount t-bar crank
  8. clutch problems
  9. Radio Shorting Out
  10. 94 blazer 4.3 4x4 really hard to start??
  11. couple of problems...
  12. AC Odor
  13. Glasspack on a 4.3?
  14. Clear/white replement front signals
  15. 2.5 drive shaft fit 350 trans?
  16. front shocks
  17. cold air intake systems
  18. hood scoops
  19. Over Heating
  20. Oil
  21. 1998 S-10 fan removal to replace water pump.
  22. Dexcool-checking level of protection
  23. 96 S-10 engine wont start
  24. fuel pump????
  25. fuel pump realy
  26. Disable automatic lights at nite
  27. S10 rear bumper
  28. Wiper Problem
  29. Strange misfire
  30. Fuel economy
  31. 2002 ZR2 and the Dexcool nightmare
  32. Rusted cab mounts
  33. 02 Leaking Differential Fluid
  34. gas no go HELP!!!
  35. Chevy S-10 pickup Brake lights fuse blows
  36. A/C leaking
  37. 97' S-10 ZR2 4x4 prob!
  38. '96 Chevy S-10 throttle limiter
  39. mods
  40. Leak in firewall!!
  41. 1997 s-10
  42. 1995 S-10 Head Problems
  43. 1998 s-10 v-6
  44. engine rattle with A/C on
  45. 97 blazer power brake booster ???
  46. S10 Fuel Guage Prob
  47. valve question
  48. A/C heater help
  49. shift timing solenoid
  50. national backorder
  51. 2000 s10 security, starts,then stops in 2 sec
  52. Knock, knock
  53. 1986 S-10 Change Turn Signal Switch?
  54. 87 s-10 help
  55. slipping transmission
  56. 95' S10 2.2 Fuel Pump constantly runs...
  57. intermittant service engine soon light
  58. '94 s-10 starter replacement
  59. o/t need to vent damaged truck tonight
  60. tachometer
  61. tires
  62. 91 s-10 v6
  63. Turn Signal / Wiper Switch
  64. Add on lights blowing fuse
  65. 2000 S10 ticking
  66. 99 s-10 fuel pump bad?
  67. Reverse lights
  68. Turning Signals
  69. Vents are whistleing
  70. 96 s10 2.2 fuel pump relay question need help
  71. plzz help 95 S-10 sluggish acceleration /good midrange/ good full trottle
  72. windshield wiperswitch doesn't work?
  73. Lift Kits 2WD?
  74. Need Help
  75. Upgrades - Suggestions?
  76. Upgrade suggestions
  77. help blazer is dead and wont start
  78. help blazer is dead and wont start
  79. Need help with swap
  80. Oil Pressure
  81. chev s10 horn & elec prob
  82. I have an auto-xray 5000/I need to know where to get list of values
  83. S10 heat problem
  84. wheres the drain for AC condenser
  85. clutch bleed valve
  86. add a ;eaf
  87. 95 S-10 pinging and clattering
  88. 2000 S10 cooling system
  89. Garage put R12 into R134a system
  90. Surging
  91. 2.5L Burning oil - going to remove cylinder head. Help please.
  92. How Low Can I Go With....
  93. Transmission Will Not Shift Right When On Interstate
  94. S-10 Truck won't start when raining
  95. 2.5 to 2.8 or 4.3
  96. rebuilt 2.5 wont stay running
  97. 1991 oil burning s10 blazer, miles 75k
  98. '94 S-10 fuel pump relay
  99. brake booster
  100. 'Nuther day, 'Nuther problem...The Sequel
  101. aftermarket wheels questions
  102. I have the codes - how do I fix???
  103. 1991 S10 Blazer electrical problem??
  104. Low Oil Pressure Fix
  105. about 2 buy a '00 extreme 4.3, please advise!
  106. rear lowing question
  107. 'Nuther day, 'Nuther problem...?
  108. s10 starter re and re
  109. power and exhaust problems
  110. '00 S-10 2.2L 4 cyl - increase power tricks?
  111. 2000 plug socket
  112. 1999 S-10 Problems
  113. 91 2.5L New Engine Won't Run
  114. Help with stereo
  115. egr mods
  116. How do I set timing on 1996 Chvey 2.2L
  117. 2.2 liter a/c compressor change
  118. O2 sensor
  119. S-10 Rear View Mirror Repair
  120. brake is making nose
  121. 03' Sonoma , new here* need help
  122. 94 S10 Blazer A/C relay where is it????
  123. Had to take tent off windows, so now how do I remove the glue?
  124. Signals and Brake Lights?
  125. s10
  126. s-10 blazer running rough
  127. 86 S-15 4x4 Parking Lights
  128. 99 S10 Stalled/Won't crank
  129. trouble code p0171 what do i check out
  130. s10 blazer not running
  131. No fuel no spark
  132. s10 Backfiring
  133. S-10 AC system
  134. Spark from coil
  135. electronic 4 wheel drive enegages itself
  136. anyone opposed?
  137. Awd problem
  138. 1998 S10 Blazer A/C fan
  139. No Spark on an 89 S-10 Blazer
  140. Squeak where driveshaft meets trans.
  141. A/C keeps popping fuse
  142. add-a-leaf...a few questions
  143. sluggish acceleration /good midrange/ good full trottle
  144. Center Console '88 Blazer
  145. 98-present interiors fit older trucks
  146. Engine swap towing
  147. Jet chip Or Hypertech Programmer
  148. extreme body kit
  149. Fuel Pressure Regulator Vacuum
  150. 88 4.3L low oil pressure
  151. **Transmission Codes - What They Mean and What Happens**
  152. S-10 Cat convertor problem
  153. How high will the odometer read?
  154. o/t get truck back today, pic here
  155. S10 wiper stopped working
  156. sparkplug cable replacement
  157. v8 front end drop
  158. 1998 2.2 weird cranking issue
  159. 1994 s10 4.3l tbi z Which Computer
  160. Problem causing alternator to stop working
  161. heater problems
  162. 1998 s10 pickup drivers airbag removal
  163. 4wd console light question
  164. parking brake
  165. 89 Upper Control Arm Bushings
  166. Question About Day Time Running Lights On 03 Extreme S10
  167. 96 s/10 transmission problems
  168. Leak in fuel line
  169. ? about regular cab and extended cab rear beds.
  170. AC recharge ?
  171. S-10 Blower Motor
  172. 1992 vs 1987
  173. DEX-COOL Engine Coolant Information
  174. Blew trans fluid out overflow (vent tube) of trans?
  175. 4.3l tranny swap
  176. 92 s 10
  177. lowering s10 ?s/ and front end ?s
  178. Web Page
  179. New 4.3 in 87 blazer
  180. a few ?'s about my 03 4.3 engine
  181. cluster
  182. Shaving door handles
  183. question about 03 4.3 s10's engine temperature
  184. code p0420
  185. Possible clutch problem
  186. does anyone have stock front coil springs?
  187. 2003 engine acceleration issue
  188. bodies
  189. 92 S10 Blazer Code45
  190. tech 4 ?
  191. 92 blazer 4.3ltr oil pressure
  192. 93 s-10 blazer fuel pump problem
  193. 97 S-10 Engine Stall
  194. b
  195. Rearview Mirror Clip
  196. Help! Starter disabled after battery change due to alarm system?
  197. cracked flex plate (flywheel)
  198. possible fuel pump problem
  199. gauge clusters
  200. 1997 2.2 tach
  201. shaving
  202. 84 S-10 V6 to 2.2 Engine swap
  203. tailgates
  204. Coolant slow leak and a clunking noise
  205. Coolant slow leak and a clunking noise
  206. fog light question
  207. S10 Blazer rear window / hatch squeak fixed
  208. fuel pump in 95 used with eng. from 92?
  209. shifter
  210. v8 s10 owners, I have questions
  211. I think I got the wrong fuel pump 94 s10 tbi
  212. 2000 clutch/transmisson problem?
  213. board, miss the truck, pictures (56k severe warming)
  214. Engine dies when warm - won't restart for 1 hour.
  215. air cond. refridgerant
  216. AC Chuging & kicking
  217. heater core
  218. S-10 Rear Axle
  219. gauge cluter swap
  220. parking lights
  221. Tachometer hook up
  222. Updated my web page, what do you think?
  223. S-10 Parts
  224. 95 S-10 2.2 : Oil Pressure
  225. hypertech powerstat
  226. Which engine gives better performance? 327/350/383/400 small block?
  227. no airconditoning
  228. 98 2.2 runs hot with AC
  229. Water level low
  230. Battery contacts corroded
  231. p0410
  232. s-10 rust repair
  233. 1997 s10 vent doesnt work A/c floor defrost...Info PLEASE
  234. "95" in Texas,and no "AIR"
  235. 95 in Texas,and no "AIR"
  236. brakes
  237. Fuel Pressure
  238. Changing 2000 chevrolet S-10 Pick-up Alternator
  239. 93 S10 Blazer heater core trouble.
  240. 93 S10 Blazer 4x4 problem (4WD problem)
  241. 89 4.3l problems
  242. will it work???
  243. Free hitch n' bumper
  244. Where can I get a Manual for a 2001 Chevy S-10?
  245. stumbled across this
  246. 1997 S10 transmission DTCs
  247. Rims?
  248. 89 S-10 4.3L V6 Problems
  249. Slave cylinder
  250. ABS problem
