Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Need ECM Wiring Diagram
  2. Temperature Gauge Problem 92 S-10 Blazer
  3. 4.3 to 350 swap
  4. 97 s-10 v6 coolant loss
  5. 1992 S-10 Blazer
  6. C-10 inquiry
  7. My Truck Dosent Want To Stop
  8. Truck won't start when security light is on
  9. 4.3 to Boat
  10. transmission not wanting to shifting
  11. Noise from inside the cab
  12. Flashing Break Light on Dash
  13. electric fan
  14. 1991 S-10 2.5L TBI running too rich when warm
  15. 2002 s10 cruise control
  16. gas tank sending unit
  17. Loosing antifreeze
  18. 91 S-10 4.3 code 24
  19. service engine light on
  20. Bed Cover for S-10 LS 4Dr. Short Box
  21. Is it possible to swap over parts from . . .
  22. 95 S-10 Blazer motor locks
  23. 4 wheel drive not working on 2000 s10 zr2
  24. abs light, problems 98 s-10 zr2
  25. '89 S-10 Water Pump Replacement
  26. 4.3 5pd Blazer?
  27. Dead Speedo and Odometer...wasn't VSS...Please Help
  28. Engine misses after reaching running speed
  29. Building a 4.3 Questions
  30. How to: replacing the 4x4 front differential actuator
  31. Speedometer Problems
  32. 2wd rearends
  33. question regarding ignition switch replacement 1995 blazer
  34. Wont Start
  35. 95 S10 Ran Fine Then Went South
  36. Vacuum Switch.
  37. cd player installation
  38. '89 S10 4x4 2.8 TBI - Sensor Problem?
  39. parking light wiring
  40. 98 s-10 wont run longer than a few seconds
  41. No acceleration?
  42. Big Problem!
  43. Help!
  44. FAQ and How to's Inside! READ ME!!!!!!!!!
  45. fuel pump problem 2000 Chevy S10
  46. 1989 s-10 4x4 2.8L 5sp. with a few issues
  47. Hell of a deal for Dougie
  48. Losing brakes
  49. 2000 S-10 V-6 Valve Lifters
  50. Signal Noise from Tuner
  51. best fuel econ engine for late 80s early 90s S-10?
  52. Choice of Radio Replacement and Speakers
  53. extension cord going to motor
  54. SERVICE ENGINE light coming on
  55. Replace outside door handle 91 s-10
  56. P0101 code
  57. Problems after getting engine wet
  58. '96...weird noise
  59. (94 Chevy SS with CMFI
  60. start no start
  61. 1988 s10 cranking problem
  62. Starter keeps turning, key removed
  63. *How Do I Get Better Gas Mileage???*
  64. obd2 code p0101
  65. do I need to do an underbody coat?
  66. Blower Motor Sometimes runs, sometimes not...
  67. Does running the heater decrease gas mileage?
  68. 4wd Question
  69. 1999 S10 Blazer transfer case engaged
  70. '93 S-10 overheating issues...can of worms!
  71. -10 F carburated 2.8L, no choke
  72. Windshield rust repair
  73. Q about oil and battery gauge
  74. chevy s10 1991 pickup speedometer out
  75. Heater blower motor
  76. 89 s10 heater control valve
  77. p0128 code/Service Engine Soon
  78. abs Brake light on
  79. Vehicle Emission Control Label
  80. brand new S10 owner have alot of questions
  81. how to install flasher
  82. Need Help
  83. clutch problem! Where to start??????
  84. Problems getting worse!
  85. changing a starter
  86. Battery Light/Discharging
  87. 84 S10 SHAKY AT SPEEDS >35 MPH
  88. Just so you guys know
  89. 1994 s-10 blazer won't downshift
  90. Still looking
  91. Yes, I looked first!
  92. Block Drain Leaking? 01 Burb.
  93. 2000 Door panel
  94. 89 S-10 Front end problem
  95. 93 S-10 Blazer 4.3 Vortec Egr Replacement
  96. Holiday card thread
  97. 83 s10 blazer gas smell, vibration, no drips
  98. inside blower
  99. Can High Mileage Vehicles Stay Running?
  100. heater core
  101. Can cold weather make a gas gauge read lower?
  102. What're the symptoms of a dirty transmission filter?
  103. Will coasting in neutral tear up an automatic tranny?
  104. 95 Z Code same as 94 Z Code?
  105. 1994 S-10 blazer 4.3 4 wheel drive interior lights problem
  106. transmission fill
  107. no start 1993 s-10 blazer
  108. Radiator support bolts?
  109. '89 2.8 TBI idles and revs but dies when clutch released
  110. what 4.3 motor has the most h.p
  111. 1993 Chevy S-10 Vin A
  112. Digital Instrument Cluster Whacked!
  113. engine cooling
  114. 91 s10 4.3 starter
  115. CPI Fuel Pressure regulator
  116. 1988 S10 Door Handle Problem
  117. Brake Problems!! Please HELP!!!
  118. Can't find the temperature sensor;-(
  119. 2000 S10 2.2L Computer Question
  120. Starter Changed!!!!
  121. transmission noise i think?
  122. Fun contest that we should try
  123. Front disc problem
  124. HELP HELP Electrical Problems Im 100 percent LOST With my blazer
  125. 84 problems
  126. Truck has no power
  127. Someone Please Help ME!!!!
  128. The Turboed 4.3
  129. 1 fast ride
  130. '98 BCM harness'
  131. Replacement motor in texas for my s-10
  132. Changing starter
  133. billet steering wheel
  134. Intermitant Front driveline grinding/gearclash 01 4x4 ZR-2
  135. tranny problem
  136. HELP Electrical Caos in my 85 S 10
  137. this may be it for my dime :( (for a while anywayse)
  138. rear drive axle/pumpkin
  139. fuel pump not turning on
  140. 91 s10 minus heat brrrr
  141. need to program keyless entry for 95 s10 Blazer
  142. FS: Cincinnati OH - 94 S-10 Blazer 4x4 loaded
  143. Read First - FAQ & how to thread!!
  144. 85 S-10 Blazer Dash Gear Indicator "missing"
  145. 92 Chevy AstroVan
  146. replacing factory stereo
  147. s10 Strange Electric/Guages/lights problem
  148. 4.3 cutting out
  149. Fuel pressure Question
  150. How to park a car
  151. Electrical Problems 87 2.8tbi 4x4 ECMB fuse
  152. 96 s10 won't charge
  153. How to diagnose your fuel system
  154. upgrade suggestions?
  155. 94 to 98 Grill conversion
  156. 1991 s10 2.5 4cyl fuel inj to 350 carb
  157. My S-10 starts, then smokes black, then dies.
  158. Shaved Door Handles ?????
  159. S10 high idle
  160. Switching Fuel Injection to Carb
  161. late 2000 S-10 w/ some 2001 parts idle problems
  162. 1992 Temp Gauge Crazyness
  163. Engine won't crank after intake removal and put back on
  164. 99 S-10 transmission slipping
  165. 4.3 Supercharged or 350 ???
  166. 1993 S-10 Blazer 4dr 4wd
  167. 94 S-10 Blazer Tahoe/Runs but dies...Help
  168. Lifter knocking, will it get worse
  169. HELP!!! Rusty (Leaking) Fuel Lines on 4.3
  170. Fuel Pressure and the filler neck...
  171. Short in wiring harness
  172. Pearl White or Metallic Silver
  173. Chevy S10 Tahoe short/wont start
  174. popularity
  175. Changing Rear End Need Some Info Plz!
  176. 1992 vs. 1993
  177. Fuel pump
  178. interior electrical circuits
  179. How can you tell if your exhaust pipe is clogged or not?
  180. 4.8 Liter?
  181. 98 ZR2 4X4 front end noise,fuse blows
  182. My truck won't start
  183. '94 s-10 WON'T START
  184. S10 spark plugs
  185. 2.8 88 s10 stalls and sputters at idle without brake depressed and dosen't w/brake
  186. need transfercase help
  187. Heater
  188. Idle Problem 1992 s10
  189. 1997-1998 s-10 door panel
  190. Intermittent Valve Tap -- V6
  191. Need parts for my truck...dont know where to find them...
  192. Just did CPI replacement on a 94 s10 blazer
  193. "service engine soon" light on... '98 Blazer
  194. Computer Virus Alert
  195. 1986 s-10 headlight relay
  196. Water Problem
  197. s-10 blazer fuel pump relay
  198. Need a 4'' lift kit for a 94 S-10 Blazer
  199. Big Feet?
  200. 1998 Chevy S-10 heater core removal help/advice
  201. Hoping for some electrical help
  202. 85 s10 loss of power
  203. 1998 s-10 spark plugs
  204. Aftermarket parts/acc
  205. help with remote starter
  206. Rebuild Kits
  207. 305 and 350 block and parts question
  208. Coolant Leak!
  209. Electrical Question
  210. S10 fuel pump problems
  211. Full tune-up questions
  212. Oil filter location: 1995 chevy s10 4.3L vortec
  213. Battery Draining
  214. Any body need a 4.3?
  215. clutch problems, what have I done
  216. major problems: 93 4.3l vortec
  217. A horn fuse blew out, and I dont know which one it is...
  218. Speed Sensor
  219. clutch start switch 2001 s10
  220. EGR valve replacement
  221. temp gauge
  222. Need help withe central electric locks
  223. Must read; Don't buy anything from this guy
  224. HELP! Engine wiring harness diagram ECM to fuse box
  225. 1991 S10 brake bleeder screws
  226. How much is a decent paint job?
  227. 87 s-10 2.8l engine problems NEED SERIOUS HELP!!!
  228. V8 engine swap
  229. crew cab forum
  230. Brake Leak
  231. Transmission Sounds Like A PTO!
  232. 94 s-10 Annoying suspension vibration
  233. Transmission leak?
  234. Heat always partially on.
  235. Few Problems
  236. Squeak sounds like it's coming from....
  237. Differential Oil
  238. parking brake lamp
  239. 95 S-10 Misfiring
  240. alldata
  241. Coolant odor in cab
  242. parking light ?
  243. 87 s10 gas gauge
  244. Buzzing noise when headlights on
  245. speedometer not working
  246. Engine surges at higher rpm when cold
  247. Tsb
  248. Tsb
  249. 84 5 speed blazer s-10 tranny removal?
  250. 94 S10 loss's power
