View Full Version : S-10
- Has there ever been a diesel S10?
- 1991 blazer won't accelerate
- Need Help Replacing upper hinge
- did Midas make a mistake?
- *** 96 S10 4.3 Fuel pump prbl ***
- Aak! There's SMOKE coming from my dashboard!
- how many miles does your chevy have?
- umm what happens when you drive without brakepads for a while?
- Crap i think i messde up my a/c =(
- Timing Problem? '89 S-10
- a problem with an '89 idling engine
- Need help on where to place sound system
- At what speed does your S10 change into 4th gear?
- Lifter replacement 97 S-10 4CYL
- Transmission Removal
- replace waterpump yes or no
- 4.3 Starts but stalls
- 383 swap
- 2.8L engine mounts on frame
- PO442 small leak evap system?
- Transmission Weight
- It won't start at all
- Transmission
- 1987 chevy s-10 tahoe?
- how to remove center support bearing?
- Blowing ECM 1 fuse maybe a short?
- Speedo Woes-Need answers.
- Heater motor issues....
- 94 4.3 Vortec skipping under load
- windshield wiper grill
- truck pics
- 95 blazer - random misfiring
- How To Drain Fuel Tank
- cant find fuel pump relay
- Stuck Distibutor
- Looking for: Stock Stero Wiring Diagram.
- Custom Lifts 98 ZR2
- electrical troubles
- 1997 s-10 wont start
- 99-s-10 v6 won't start
- what do u think?
- Coolant leak, but where?
- Automotive Forum Member Praise
- got my Ravin exhaust
- Door pin and bushing repair How-To!
- Clutch Problems 91 5 speed
- WRECKED my S-10!!! Help!
- 95 2.2 sonoma 107k miles
- Valve stem seals, anyone in the know?
- '87 S10 location of fuse for fuel pump
- 99 Blazer Hesitation
- Does code P420 mean I need a new cat. converter??
- 1993 S-10 Blazer PROBLEMS!!!
- 2.8L serpentine belt diagram
- throttle body spacers, worth it or not?
- 1999 s-10 clutch problem
- The elusive door sping tool
- hop ups for 92 s-10 (4.3)
- Tire Topic
- 94 S-10 V6 monster
- Brakes making a squeaking noise
- 89 S-10 Runs short time then dies
- Aftermarket wiring harness
- 94 Silverado
- 1998 Chevy S-10 headlight problem:
- oh shit
- 92 s-10 performance
- Pulling Motor
- Front Signal Light Problem
- swapping in engine from a newer S-10
- 91 s-10 truble
- electrical problems with ING/GAUG fuse and Good alternator not charging battier
- 98 s10 2.2 coolant system
- help!! 4.3 drivability problems
- No first gear
- dash/parking lights
- 2000 chevy s10 w/2.2L
- dash /parking lights
- 1996 S-10 Won't Start
- 4x4 help
- Broken Mounts
- 4x4 suggestions
- 88 s10
- swaping out 4.3 vortec motor
- Manual Transmission Fluid Type
- Clutch fluid problem... slave cylinder leaking??
- 87 S10 Will Not Start
- Clutch or Slave Cylinder??
- engine swap
- 1993 s-10 ECM support
- Shifting 3rd to 4th
- ghostly, banned car commercial
- how to post pics
- 84 S-10 connected battery terms. wrong
- please help me stop clutch/transmission noise!
- Wont go into self-diagnostic mode.
- '02 S-10 cuts-out accelerating...Egn Light On
- bench seat to bucket seats conversion
- S10 - Sonoma Window Electrical Problem
- 98 S10 Throttle Body
- 4.3L to 2.2L Transmision Compatibility
- possible clutch problem
- 83 S-10 2.8 several issues..
- My personal web space is updated!
- Got some questions on a 4.3 to 4.3 swap
- Axle locked-up
- Will not start 2000 S-10 p/u
- 1996 S10 Starting Problem
- rear brake/turn signals
- Driveability-surges-hard brake pedal(new booster) misses-generaly runs like crap have
- vapor lock
- fuel injector question
- booster to pedal HELP
- NOOB - Looking to do a 350
- What does code p1222 fuel pump circuit voltage low mean
- newbee brake problem
- 1984 s-10 motor
- broken release cable
- transmission downshifts at top speed
- Please Help Stumped On This One
- 1993 s10 p/u *STARTER*
- No heat coming out at all
- heater fan switch does not work on high
- rough riding when between 35 - 50 mph
- Over Heating 2
- Clutch assembly
- Broken motor mounts
- What would you do?
- 87 s-10 rear transmission seal
- 1995 s-10 blazer, engine code W
- hard starting
- AC Orifice Tube
- 95 tranny
- shocks bouncing
- clutch
- 92 4.3 CPI s10 4x4 rough idle
- knocking on acceleration
- wheels and tires
- 95 Chevy Won't Start, No spark
- S10 Overheating HELP)))
- replacement brake rotors
- radiator drain cock
- '91 4.3L Coolant leak
- Trans oil in torque converter
- 1992 4.3l Problem- Need Help To Diagnose
- Oil Check Valve Fell Out
- 96 S10Blazer Starting Problem
- electric problem?
- transmission issues in 1988 s-10
- Question about turbochargers
- 1997 fule pump
- cat back help
- selling my truck
- 98 sonoma manual trans problems
- How to remove '93 door panel???
- '93 S10 Wiper Problem!!!!
- Cranks but won't Start!
- 1989 S-Blazer Bellhousing Bolts
- Dash Lights
- help!!!!!!!!!!!!
- vin x, vin w
- just a "clicking" sound ???
- I'm still here
- 86 S-10 stalling. WHY?
- Door Panels
- 1994 S-10 Steering Wheel Removal
- ABS removal on 94 2WD
- Alternator belt squeek
- ok fella's here's a new one for you all.
- Tilt column repair help
- Bracing cab mount on Blazer with spare tire carrier
- Need assistance with Turn Signal Issue, '95 LS 4x4 "w" vin
- okay fellas need some more help!
- Bleeding brakes?????
- Bleeding brakes on 91 s-10
- White Smoke Under Hood?
- Funny picture
- Depressed brake leaks air.Help
- S-10 setting a while - What maintenance is needed???
- 02 sensor wiring
- 1996 S-10
- Fuel Composition Sensor need some help
- 1996 S10 chevy p/u
- running lights
- 1991 Brakes continue to drag
- Gas problems, not sure if it's a problem or normal?
- What Might Be Knocking?
- Aftermarket Tachometer Hookup
- Poor heat
- PCM troubles
- 87 S-10 tailgate removal
- how to ground ALDL connector
- 84 S10 Electrical problem
- downshift switch malfunction?
- Cab Corner And Paint Repair ???$$$
- in need of some help before i go mad
- disable air conditioner
- EGR Valve Info
- EGR Valve / fuel system HELP
- procedures required before timming adjustment
- cpi unit
- s10 zr2 slipping transmission
- OBD II Code PO410
- engine temp sensor (gauge)
- hey
- 01 S-10 tranny or U-joint making bad loud noise at 50mph?
- Gas Guage Not Working
- front end noise
- Engine cutting out
- Electrical Issues
- slight knock in 93 4.3 vortec, missin in cyl 2
- alot of moisture
- 1987 s-10 2.5L vacum diagram
- 1987 s-10 2.5L
- quick ? on hdlght removal 2000 s10
- 89 s10 blazer not starting
- Lowering my S-10
- Moderator Suggestions
- front end alignment
- 1998 s10 blazer
- Blowin pcv valve?
- My 1992 s-10 blazer keeps blowing fuses after a new fuel pump
- Side mirror replacement
- 96 S10 Door Panels
- Where is the PCV Valve on 93 4.3 -Not Vortec
- 95 S-10 no power. NO lights, nothing HELP!!
- S-10 pick up 1990
- S10 Wheels bolt pattern
- tbi
- Best tires for s-10
- Cassette Wire
- 1996 S-10 Charging/Cranking Problem
- 2000 4x4 S-10 std cab body lift kit
- tbi injector problem
- Clutch Problems - 93 4.3L TBI
- digital dashboard-93 s-10 blazer
- Bedliner
- 1.6 Ratio Rockers on a 4.3
- Remote and RCA wire install?
- Idle problems
- electrical problem's interrior please help
- Used $.75 inch wheels for sale with tires
- Transmission slips occasionally
- 98 S-10 Break lights don't work
- Noid vs. Test Lights
- 1983 s-10 electrical woes
- 85 S-10 Racecar questions
- Chevy s10 2.2l...hp gains
