Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 1994 s10 fuel delivery reset
  2. 1988 S-10 No Spark
  3. 99 2.2L won't start
  4. 1994 chevy s-10 suddenly shutting off quick bursts
  5. 96 S10 4.3 V6 Vortec engine light on
  6. 87 S10 Blazer Fuel Problem
  7. 91 s-10 problem
  8. How can We help improve this board?
  9. 1998 s10 a/c leaks... help!
  10. 89 s-10 2.5L runs rough, occasional backfire
  11. 1992 S10 pickup I'm comfuse about Gear pl help!!
  12. Engine Swaps wit a side of power
  13. 1989 S 10 Won't Start
  14. 1993 S10 complete motor for sale! $250
  15. Tranny Swap
  16. HELP!! Lifters
  17. Front Roll Pan for 88 S10
  18. 84 S10 Help Help Help!!!
  19. 88 S-10 help
  20. severe power loss under acceleration
  21. Struggling with my baby and NYS emmisions
  22. swap question
  23. 2.2L whirring clicking noise when cold
  24. 1992 S-10 Blazer 4X4
  25. I need a factory cruise control cable for a 1997 S10 w/ a 2.2 4 cyl.
  26. smoking s10
  27. '94 S-10 4WD problems, computer module
  28. 98 s-10 shifting problem, please help!!
  29. 94 S-10 v-6 CODE 35
  30. Problem accelerating immediately after start
  31. Clutch Pedal Problems
  32. 1994 S10 Blazer Won't Start
  33. key chime won't shut off
  34. 2.2L Automatic S-10
  35. Please Help With Trouble Codes
  36. S10 Blazer electrical problem
  37. Brakes, have to pump to stop!
  38. 87 s-10 swap 2.8 to 4.3 advice
  39. 96 4.3l V6 engine knock
  40. A cold dead S10 and On Foot
  41. S-10 won't always fire up
  42. 1994 S-10 Blazer
  43. Getting clunking in 4wd
  44. 91 s10 Headlights
  45. How to improve your ride quality
  46. Hyd clutch/bleeding troubles
  47. Lubed by the lubed joint?
  48. 2000 s-10 2.2L oil pan reseal
  49. Looking for S-10 online stores
  50. ? for dmbrisket
  51. Hello Everyone.
  52. Clutch line.
  53. my half 350 swap
  54. Membership
  55. A question about Manual Transmissions (not directly related to chevie's)
  56. I'm still here, not ignoring anyone
  57. clutch problems
  58. Ignition only fires when key released
  59. Fuel Or Fire????
  60. 4.3 S-10 Jerking - Skipping when accelerating
  61. Would a 2.8 with a bad oil seal around the distrib
  62. 4x4 doesnt work after changing cv joints
  63. '90 clutch problem
  64. 2.5L to 350 V8
  65. 97 Transmission
  66. Replacing '89 A-arm bushings
  67. 92 S10 engine Swap 2.5 to 4.3 ?'s
  68. Tail Light Issues
  69. reinstalling lower control arm
  70. 1989 4.3tbi to 350
  71. 2003 S-10 Sensor Codes P0155 & P0128
  72. S10 Prom Ecm Flash?
  73. Low Temp gauge reading
  74. 3rd door handle keeps breaking!!!
  75. how do i diagnose a distributor problem?
  76. S-10 Baja
  77. How do I adjust the shift lever on '88 Blazer?
  78. 2002 s10 knock sensor?
  79. Belt Squeek problem 1996 S10 CHEVY
  80. Few Manual-tranny questions
  81. diagnostic codes
  82. prob#2 high revving s-10
  83. problem#1: s-10 input shaft bearing?
  84. 93 S-10 Starting issue...after dark smoke...
  85. Need FlyWheel bolts for 1991 S-10
  86. 2000 zr2 abs light on
  87. 99 chevy s10, can't disarm alarm
  88. Fixed vacuum leak, 4x4 still doesn't seem to work
  89. These Guys are Nuts
  90. Oil Lines??S10
  91. blower motor
  92. Carb/electrical problem..!!
  93. Strage Starting Problem
  94. Removing window crank handle
  95. cyl misfire -- HELP ME PLEASE!!!!!
  96. Pcv
  97. Reminder to check your spare tire
  98. 88 s10 no start
  99. turbocharged??
  100. transmission swap
  101. Heater Control Question
  102. Torque Convertor Not Staying Locked In
  103. Looking for info on S10's
  104. Engine help!
  105. "91 S-10 Failed Emissions - HIGH HC - help???
  106. Disable TCC on a 4L60 tranny...
  107. 2000 S10 2.2 Injector circuit open
  108. 2003 S-10
  109. Valve problem?
  110. Help with 4 Wheel
  111. engine misfire
  112. 86 S-10...bring it
  113. 2000 S10 Xtreme " in process of being show truck "
  114. silly s10 ac compresser
  115. '89 S-10 4.3 TBI PU bogs when you step on the gas
  116. "96 S10 4.3L ZR2 won't start
  117. can engine oil lines be removed, 94 s10
  118. 89 S10 Igmition switch replacement
  119. No heat!
  120. 96 s10 4.3L Check engine light
  121. Fuse location for ABS brakes
  122. how much to pay for a new radiator
  123. 1989 S-10 Blazer Replace Oil Filter Lines
  124. freeze plug removal & installation on a 4.3 chevy
  125. extended cab window seals?
  126. Front Diff Question
  127. SS S-10 price
  128. Timing Chain and 92 S10 Blazer service manual
  129. 1988 s10 wont start
  130. horrible gas mileage
  131. 1997 S10 Cruise control question
  132. 1998 S-10 LS - 2.2 4 Cylinder Engine
  133. Finally an independant air fllter test
  134. s10 parts? buy from dealer or independent auto parts store?
  135. Trouble starting
  136. stiff ride
  137. 97 2.2L P0300 code
  138. Replace oil lines on S-10
  139. transfer case-fluid evaporation
  140. gaps
  141. 2.2 Head question
  142. 95 4.3 cpi knock sensor
  143. broken ground wire to coil. HELP
  144. Leaking Fuel Lines
  145. Fuel & Electrical
  146. HELP locating EGR valve on a 1997 S10 2.2L
  147. S-10 Problem. Won't start all the time.
  148. Help with remote starter
  149. change headlamp 1998 S-10
  150. Wondering?
  151. Replacing oil pan gasket-HELP!!
  152. replacing 4.3, need a suggestion
  153. Wheel bearings
  154. 2000 S-10, No power to Fuel pump
  155. automatic tranny shifting problems
  156. I fixed the block on my 89 4.3 Liter
  157. s10 fuel problem.
  158. It's all hitting the fan...
  159. 1985 Chevy S10-Tahoe
  160. 1991 Chevy Blazer Troubles
  161. 1986 GMC S-15 2.8V6 to a 305 V8
  162. Any good oil additives recommended?
  163. stereo install
  164. gas mileage
  165. S-10 revs up when in gear. please help
  166. Not enough voltage
  167. 1994 S10 Blazer Not running smoothly
  168. 91 s-10 timing problems
  169. Very strange happenings
  170. 2000 S-10 Extreme Sticking Caliper
  171. S- 10 injector spray prob.....PLZ HELP
  172. sounds like water
  173. Right front tire wear
  174. 84 S10 runs good then quits
  175. 1994 S10 Blazer Four Wheel Drive Problems
  176. Door panel and door handles
  177. 2002 s10 starts hard, runs hard
  178. '97 4.3L Vortec will not start when cold
  179. 4wd problem 1992 s-10 Blazer
  180. 96 s-10 Trans fluid in 4X4 vacuum actuator
  181. 88 S-10 Blazer Ignition Fault
  182. Lower Ball Joint Removal
  183. 01 s-10 xtreme dead
  184. Tight and responsive steering: Another How-To! YAY
  185. 1995 s10 4wd 4wd not working properly
  186. 94 s-10 "W" starts but dies
  187. 96 s10 wires...
  188. clutch question
  189. 92 4.3(Z) running rough in gear
  190. What part is this?
  191. 2001 4.3 into 1997 Jimmy
  192. 95 s10 Blazer Transmission
  193. 1991 2.5 4cyl with a miss
  194. ford ranger to s-10
  195. Suddenly began hesitating, spitting, sputtering
  196. Brake light problem on 2000 Sonoma
  197. '97 S10 pickup fuel gauge stuck on full
  198. How To Adjust Torsion Bars On 4.3l Zr2???
  199. AC Prob. on 2002 S-10
  200. 91 s10 brake problems
  201. 2.2 performance chip
  202. Need help identifying AC system parts
  203. Code 43 93 4.3
  204. trying to find an exhaust system
  205. s10 speedo recalibration help
  206. Ignition Accessory Position
  207. A Wet Winter
  208. 1988 4.3 s10 backfire
  209. Sorry about bringing up old posts
  210. 94 SS running really rough when A/C on
  211. 92 S-10 Ignition Switch
  212. lowering
  213. Out of Ideas!!
  214. Starting Porblems
  215. Code P0442 on 98 4.3
  216. 97 s10 4.3L VIN X p1406 and p0300 codes
  217. Ride height and leveling kit
  218. ball joints
  219. 1999 S-10 Transmission woes
  220. AC compressor clutch
  221. 89 s10 front driver wheel sits crooked
  222. truck dies too much!!
  223. 1989 S10 Popping Noise
  224. 1989 S10 Overheating Problem
  225. 92 S-10 dashboard
  226. 98 s-10 looking for lower intake r and r schematics
  227. Sensor question
  228. 1985 driveshaft carrier help
  229. 85 s10 blazer 2.8 to small block engine
  230. Error codes on GMC sonoma 1997
  231. block test kit
  232. ? regarding lower ball joints
  233. Another CPI How-to (focus on regulator)
  234. How-to change the PITA #3 spark plug
  235. manual trans noise
  236. 96 S-10 EGR Valve
  237. 93 S10 4.3TBI "Z" 5spd ECM/PROM Questions
  238. 2000 Hydraulic clutch slave cylinder line removal
  239. 91 S10 TBI 2.5L problems
  240. I have a 1984 S-10
  241. 86 S10 2.8 idle problem
  242. 1994 s-10 engine size please help
  243. Car amplifier problem
  244. Cruise ABs not working.
  245. 2.8 engine for 93 s10 pickup
  246. 2.8 to 3.4 swap
  247. 96 s10 2.2 crank no start. no dash lights
  248. 2.2 cuts out
  249. Slow to start then runs fine
  250. '90 S-10 PU Rear side windows leak
