View Full Version : S-10
- abs light, problems 98 s-10 zr2
- '89 S-10 Water Pump Replacement
- 4.3 5pd Blazer?
- Dead Speedo and Odometer...wasn't VSS...Please Help
- Engine misses after reaching running speed
- Building a 4.3 Questions
- How to: replacing the 4x4 front differential actuator
- Speedometer Problems
- 2wd rearends
- question regarding ignition switch replacement 1995 blazer
- Wont Start
- 95 S10 Ran Fine Then Went South
- Vacuum Switch.
- cd player installation
- '89 S10 4x4 2.8 TBI - Sensor Problem?
- parking light wiring
- 98 s-10 wont run longer than a few seconds
- No acceleration?
- Big Problem!
- Help!
- FAQ and How to's Inside! READ ME!!!!!!!!!
- fuel pump problem 2000 Chevy S10
- 1989 s-10 4x4 2.8L 5sp. with a few issues
- Hell of a deal for Dougie
- Losing brakes
- 2000 S-10 V-6 Valve Lifters
- Signal Noise from Tuner
- best fuel econ engine for late 80s early 90s S-10?
- Choice of Radio Replacement and Speakers
- extension cord going to motor
- SERVICE ENGINE light coming on
- Replace outside door handle 91 s-10
- P0101 code
- Problems after getting engine wet
- '96...weird noise
- (94 Chevy SS with CMFI
- start no start
- 1988 s10 cranking problem
- Starter keeps turning, key removed
- *How Do I Get Better Gas Mileage???*
- obd2 code p0101
- do I need to do an underbody coat?
- Blower Motor Sometimes runs, sometimes not...
- Does running the heater decrease gas mileage?
- 4wd Question
- 1999 S10 Blazer transfer case engaged
- '93 S-10 overheating issues...can of worms!
- -10 F carburated 2.8L, no choke
- Windshield rust repair
- Q about oil and battery gauge
- chevy s10 1991 pickup speedometer out
- Heater blower motor
- 89 s10 heater control valve
- p0128 code/Service Engine Soon
- abs Brake light on
- Vehicle Emission Control Label
- brand new S10 owner have alot of questions
- how to install flasher
- Need Help
- clutch problem! Where to start??????
- Problems getting worse!
- changing a starter
- Battery Light/Discharging
- 84 S10 SHAKY AT SPEEDS >35 MPH
- Just so you guys know
- 1994 s-10 blazer won't downshift
- Still looking
- Yes, I looked first!
- Block Drain Leaking? 01 Burb.
- 2000 Door panel
- 89 S-10 Front end problem
- 93 S-10 Blazer 4.3 Vortec Egr Replacement
- Holiday card thread
- 83 s10 blazer gas smell, vibration, no drips
- inside blower
- Can High Mileage Vehicles Stay Running?
- heater core
- Can cold weather make a gas gauge read lower?
- What're the symptoms of a dirty transmission filter?
- Will coasting in neutral tear up an automatic tranny?
- 95 Z Code same as 94 Z Code?
- 1994 S-10 blazer 4.3 4 wheel drive interior lights problem
- transmission fill
- no start 1993 s-10 blazer
- Radiator support bolts?
- '89 2.8 TBI idles and revs but dies when clutch released
- what 4.3 motor has the most h.p
- 1993 Chevy S-10 Vin A
- Digital Instrument Cluster Whacked!
- engine cooling
- 91 s10 4.3 starter
- CPI Fuel Pressure regulator
- 1988 S10 Door Handle Problem
- Brake Problems!! Please HELP!!!
- Can't find the temperature sensor;-(
- 2000 S10 2.2L Computer Question
- Starter Changed!!!!
- transmission noise i think?
- Fun contest that we should try
- Front disc problem
- HELP HELP Electrical Problems Im 100 percent LOST With my blazer
- 84 problems
- Truck has no power
- Someone Please Help ME!!!!
- The Turboed 4.3
- 1 fast ride
- '98 BCM harness'
- Replacement motor in texas for my s-10
- Changing starter
- billet steering wheel
- Intermitant Front driveline grinding/gearclash 01 4x4 ZR-2
- tranny problem
- HELP Electrical Caos in my 85 S 10
- this may be it for my dime :( (for a while anywayse)
- rear drive axle/pumpkin
- fuel pump not turning on
- 91 s10 minus heat brrrr
- need to program keyless entry for 95 s10 Blazer
- FS: Cincinnati OH - 94 S-10 Blazer 4x4 loaded
- Read First - FAQ & how to thread!!
- 85 S-10 Blazer Dash Gear Indicator "missing"
- 92 Chevy AstroVan
- replacing factory stereo
- s10 Strange Electric/Guages/lights problem
- 4.3 cutting out
- Fuel pressure Question
- How to park a car
- Electrical Problems 87 2.8tbi 4x4 ECMB fuse
- 96 s10 won't charge
- How to diagnose your fuel system
- upgrade suggestions?
- 94 to 98 Grill conversion
- 1991 s10 2.5 4cyl fuel inj to 350 carb
- My S-10 starts, then smokes black, then dies.
- Shaved Door Handles ?????
- S10 high idle
- Switching Fuel Injection to Carb
- late 2000 S-10 w/ some 2001 parts idle problems
- 1992 Temp Gauge Crazyness
- Engine won't crank after intake removal and put back on
- 99 S-10 transmission slipping
- 4.3 Supercharged or 350 ???
- 1993 S-10 Blazer 4dr 4wd
- 94 S-10 Blazer Tahoe/Runs but dies...Help
- Lifter knocking, will it get worse
- HELP!!! Rusty (Leaking) Fuel Lines on 4.3
- Fuel Pressure and the filler neck...
- Short in wiring harness
- Pearl White or Metallic Silver
- Chevy S10 Tahoe short/wont start
- popularity
- Changing Rear End Need Some Info Plz!
- 1992 vs. 1993
- Fuel pump
- interior electrical circuits
- How can you tell if your exhaust pipe is clogged or not?
- 4.8 Liter?
- 98 ZR2 4X4 front end noise,fuse blows
- My truck won't start
- '94 s-10 WON'T START
- S10 spark plugs
- 2.8 88 s10 stalls and sputters at idle without brake depressed and dosen't w/brake
- need transfercase help
- Heater
- Idle Problem 1992 s10
- 1997-1998 s-10 door panel
- Intermittent Valve Tap -- V6
- Need parts for my truck...dont know where to find them...
- Just did CPI replacement on a 94 s10 blazer
- "service engine soon" light on... '98 Blazer
- Computer Virus Alert
- 1986 s-10 headlight relay
- Water Problem
- s-10 blazer fuel pump relay
- Need a 4'' lift kit for a 94 S-10 Blazer
- Big Feet?
- 1998 Chevy S-10 heater core removal help/advice
- Hoping for some electrical help
- 85 s10 loss of power
- 1998 s-10 spark plugs
- Aftermarket parts/acc
- help with remote starter
- Rebuild Kits
- 305 and 350 block and parts question
- Coolant Leak!
- Electrical Question
- S10 fuel pump problems
- Full tune-up questions
- Oil filter location: 1995 chevy s10 4.3L vortec
- Battery Draining
- Any body need a 4.3?
- clutch problems, what have I done
- major problems: 93 4.3l vortec
- A horn fuse blew out, and I dont know which one it is...
- Speed Sensor
- clutch start switch 2001 s10
- EGR valve replacement
- temp gauge
- Need help withe central electric locks
- Must read; Don't buy anything from this guy
- HELP! Engine wiring harness diagram ECM to fuse box
- 1991 S10 brake bleeder screws
- How much is a decent paint job?
- 87 s-10 2.8l engine problems NEED SERIOUS HELP!!!
- V8 engine swap
- crew cab forum
- Brake Leak
- Transmission Sounds Like A PTO!
- 94 s-10 Annoying suspension vibration
- Transmission leak?
- Heat always partially on.
- Few Problems
- Squeak sounds like it's coming from....
- Differential Oil
- parking brake lamp
- 95 S-10 Misfiring
- alldata
- Coolant odor in cab
- parking light ?
- 87 s10 gas gauge
- Buzzing noise when headlights on
- speedometer not working
- Engine surges at higher rpm when cold
- Tsb
- Tsb
- 84 5 speed blazer s-10 tranny removal?
- 94 S10 loss's power
- 93 S10 Tailgate
- Heat always on after heater core replaced
- no start condition
- safty first guys... seriously...
- 1985 S-10 Durango not starting...
- PO122 code
- Distributor Problems
- 94 s-10
- Does anyone have a really hooked up s10?
- No Power Locks...heater fan...
- starting problems
- Weird Electonic Happenings
- truck pics
- ecm problems
- Where to find good online info for free
- Obscure problem or do Duralast parts suck?
- engine 'roar'
- turn signal antics
- any1 know a good place on the web for custom s10 parts?
- Has there ever been a diesel S10?
- 1991 blazer won't accelerate
- Need Help Replacing upper hinge
- did Midas make a mistake?
