Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 93 S-10 Blazer 4x4 diagnostics...
  2. Which electric fan?
  3. Vaccuum hoses for a 91 v6 4.3
  4. Electrical Help Please
  5. Need help
  6. 95 S-10 (gas smell when I turn it off)
  7. Transfer case shaking
  8. rear end info needed
  9. Key getting stuck in the on position 91 s-10
  10. Adjust Idle 91 s-10 4.3
  11. bad crank sensor
  12. '03 S-dime/3.8 and T-56 conversion?
  13. headlights / speedometer
  14. transmission removal
  15. Passanger side floor borad heat
  16. Trans or transfer case problems
  17. converting 82 suzuki samurai to 4.3L with turbo 350 tranny
  18. Questions with new wheels/tires
  19. u joint replacing
  20. 4 wheel drive delay
  21. 04 ZR5 Wont engauge 4x4 hi
  22. 91 S-10 4.3 4x4 Compression?
  23. Need to know, 2.5 to a 2.8,
  24. 93 trans in 95 4x4
  25. S-10 RANT: conversion problems-700R4
  26. Does anyone know what a 2.8L sounds like dualed out
  27. Does anyone know how to tighten up the torsion bars?
  28. Any Problems with Torsion Keys or Lift Shackles?
  29. Biggest Tires that will fit on a 2002 4X4 Crew Cab?
  30. Any way to make 2002 Crew Cab tires stick out like ZR2?
  31. Problem with 700R4 Tranny
  32. Air condition plug on 1993 s-10 blazer
  33. 2002 4x4 4.3 Liter Overheating????
  34. 92 S-10
  35. 94 s10 will not start
  36. 2.8l Idle Problems Brian's
  37. Speedometer Cluster
  38. 93 S-10 Auto trans, what bolts up?
  39. how to disable fuel pump
  40. blazer engine vibration
  41. Drum Brakes 101
  42. 2000 s-10 Injection Problem
  43. 98 s10 with a 4.3 ecm wiring diagram needed.
  44. 94 Chevy S10 LS not getting gas
  45. coolant leak getting worse!
  46. Ash tray woe's
  47. 98 S10 2.2 runs hot with AC on
  48. '97 4.3l horsepower?
  49. 4.3l turbo?
  50. s10 won't start
  51. 2wd to 4wd
  52. 98 S-10 Arcing Problem
  53. 92 cold start stalling problem
  54. s-10 clutch bleeding problem
  55. 4.3 intechangeability
  56. VIN Decoding
  57. s-10 heater doest work
  58. Need help truck is mis firing
  59. S10 Blazer Fuel Filter????
  60. Floor shift automatic
  61. 2000 s-10 problems please help!!!!
  62. 2000 S10 Trans Problem
  63. Need Help NOW...fan clutch assembly.
  64. 92 s10 blazer egr cleaning
  65. How to change transmission fluid and filter?
  66. Hesitation off the line?
  67. Extreme heat under hood????
  68. 2002 Snorkel???
  69. where is oxygen sensor in bank2
  70. Questions to clear some stuff up...
  71. extended cab windows
  72. 92 Chevy S - 10 Idle Problem
  73. 01 S10
  74. alright, i need help :(
  75. air bag light
  76. s10 1.9 to 2.8 swap
  77. Goin Tothat Big Junkyard In The Sky
  78. Engine codes P0113B, P1404B
  79. 4g63 engine in an s10 P/U?
  80. 97 s-10 throwing P0175 Bank2
  81. 95 S10 Power Mirrors
  82. Does anyone know what other engines
  83. Door won't open
  84. rear view mirror help
  85. has anyone converted from sealed beam to compostie headligth ?
  86. Upgrade 83 Tahoe to Firebird MPFI engine?
  87. Fuel leak
  88. my get up and go has left
  89. K & N Filterchargers..
  90. 5 speed
  91. Need Help!!!
  92. cab mounts
  93. S10 Top Speeds
  94. P0410 trouble code-What seat's will fit?
  95. S10 Gas Mileage
  96. Rough Idle
  97. ?'s about ss s10
  98. Oil Pan Replacement
  99. rear bumper
  100. something is seriously wrong!
  101. a update on the 84` S15 restoration/rebirth
  102. Need help in choosing a new S-10
  103. 89 4.3 TBI Code 45
  104. s10 4x4 problem
  105. 83 S10 ext no power have to floor it to accrelate
  106. 95 4.3TBI ujoint
  107. 84s10 Brake Issue
  108. head bolt tourqe
  109. 97 S-10 transmission bearing?
  110. AC problem Chev. S10 1997
  111. Ticking/Clanking noise in the rear?? 1998 S10 has new problems...
  112. K&N Air filter for 82-86 s10s - $15!
  113. New to the S-10 forum....
  114. my 93 has 4x4 Problems.....
  115. 89 S10 timing
  116. 91 S10 Jerks when you let off the gas.
  117. Rough idle and acceleration till about 30mph...
  118. my latest project
  119. Need Injector Help for 4.3 Chevy
  120. shifter gasket leak
  121. Pressing clutch cuts power for woofers?
  122. A picture of my S10!!
  123. Air Horns- How much do they co$t???
  124. Won't start. Thump fuel tank & it starts
  125. fluctuating gas guage
  126. Instruments out
  127. 1989 S10 Motor
  128. 97 S-10 transmission removal
  129. new plugs and truck runs WORSE! HELP!
  130. need help on chevey s-10
  131. S-10 Codes. No codes from my PCM!
  132. '93 S10 Blazer Fuel Pump ??
  133. Headlamp
  134. Headlamp
  135. S10 Starting Issues
  136. 99 s-10 2.2 will not pass CA. emissions test
  137. s10 pick up
  138. 1995 s-10 lifters????
  139. Temp Gauge
  140. 1997 Dash Trim Piece
  141. 86 S-15 overheating
  142. high pitched squealing coming from rearend?
  143. light weight of 94 s10 4wd pick up ?
  144. 2.5L no start
  145. 93 S-10 4.3L spark plugs
  146. 91 s-10/s-15 fuse location
  147. 89'S-10,2.5 hard to start
  148. posi rear end
  149. spindles or springs
  150. an old ac problem
  151. P0306 and P0300 (Cyl 6 & Random/Multiple Cyl Misfire) HELP A GIRL OUT HERE!
  152. Im Looking For Some Fender Flares!!!
  153. Whats The Biggest Tire That Will Fit???
  154. my 95 s-10 ss, governor
  155. Rear end question
  156. just joined and need help badly
  157. '95 S-10 4x4 transfer case
  158. 1/8 mile and 1/4 mile times
  159. ABS + brake light on simultaneously
  160. '96 vent control problem
  161. 92 S-10 dash wiring harness
  162. s10 tach
  163. cant figure this out
  164. 02 xtreme is pulling one amp with nothing on
  165. lack of parts for '88 s-15..?
  166. How to change the 2 back spark plugs on drivers side
  167. tubular headers for '88 2.8L?
  168. 1998 chevy s-10 wiper motor pulse board
  169. 1993 s-10 2.8 5 speed want start at times
  170. Dual exhaust on a '96 s10 blazer 4.3 Vort.
  171. no fuel, no spark, no guages
  172. no spark
  173. 4.3 question
  174. 92 s10 4.3 wont start
  175. So cool I found one...but...
  176. gas mileage ?
  177. Remove AC Unit on '90 S10
  178. Missing at start-up until warm '94 s-10 W
  179. not holding fuel pressure?????
  180. SES Code P0304
  181. I Need An Exorcist !!!!
  182. 2000 S10 Heater Core Install
  183. 2000 S10 Heater Core Install...
  184. 350 Conversion
  185. How do you fix rough idle on '92 S10?
  186. Air intake heat sensor/diaphram
  187. 4.3 vortec gas mileage
  188. HELP!! fuel leak after
  189. rear differential specs needed.
  190. FUSE BOX for '92 S10 4.3L
  191. blocking egr fixes it but throws code...help
  192. 5.8 Liter in S10?
  193. '92 s-10 blazer electronic 4wd shift motor?
  194. no power to the fuel pump
  195. 4.3 to 350 swap
  196. s-10 rear end
  197. 99 S10 4wd front diff oil
  198. '96 s10 blazer fuel pump not working
  199. '91 S10 4.3 4x4 leaky oil filter re-direct line??
  200. Help: 99' A/c Compressor Freon Fill Tips
  201. 99s-10 blazer 4.3w cyl 2and 3 misfire plague
  202. Looking for a part, help please...
  203. Won't Idle
  204. Looking for a new lift kit...
  205. 1984 GMC S15 re-incarnation time
  206. S-10 Replacing wire speakers. Please Help
  207. changed head gsket 98 VORTEC, no compression on one cylinder
  208. '96 4.3L S-10, misfires or hesitates at constant speed
  209. from a 4.3 to a 2.8 liter
  210. Vmax Street & Performance Manifold Spacer? Got One?
  211. Transmission Problem 1997 S-10
  212. Transmisson Problem 1997 S-10 4+4
  213. Chev s10
  214. S-10 Motors
  215. 1991 tranny install
  216. release bearing
  217. 4.3 tbi conversion to vortec 4.3?
  218. wheel bearings 4wd s-10 1994
  219. '02 S10 Sudden Drop In MPG
  220. Best shock for 89 s10
  221. s- 10
  222. advice on new truck
  223. What Is Tbc Circuit?battery Keeps Going Dead
  224. exhaust ?
  225. S-10 Pickup Timing
  226. 1985 S-10: Need Carburetor Adjustment Specs
  227. cost of adding air-conditioning to 95 S-10
  228. Bad computer? - '89 2.8 TBI
  229. Heater Core Help
  230. Canadians, watch W5 on Saturday
  231. 94 s10 2.2L starting problem
  232. S-10 tire pressures
  233. removing door and front fender 91 s10
  234. How do I make an S-10 trailer?
  235. abs brakes weird..help !
  236. 94 2.2L headgasket replacement
  237. Electronic Spark Control
  238. Will a 91 4 cyl work in an 89 Blazer?
  239. fuel pump stays on
  240. Body Lift
  241. Body Lift
  242. What is involved in removiing a crankshaftin an '88?
  243. electrical problem
  244. 94 S-10 Blazzer
  245. Camshaft position sensor help?????
  246. Idle Air Control Wiring Harness
  247. Timing Chain and Rear Main Seal replacement
  248. Trouble Code #14
  249. tailgate cable help
  250. torsion bar stuck!! help?
