View Full Version : S-10
- 1992 S-10 Blazer 4X4
- I need a factory cruise control cable for a 1997 S10 w/ a 2.2 4 cyl.
- smoking s10
- '94 S-10 4WD problems, computer module
- 98 s-10 shifting problem, please help!!
- 94 S-10 v-6 CODE 35
- Problem accelerating immediately after start
- Clutch Pedal Problems
- 1994 S10 Blazer Won't Start
- key chime won't shut off
- 2.2L Automatic S-10
- Please Help With Trouble Codes
- S10 Blazer electrical problem
- Brakes, have to pump to stop!
- 87 s-10 swap 2.8 to 4.3 advice
- 96 4.3l V6 engine knock
- A cold dead S10 and On Foot
- S-10 won't always fire up
- 1994 S-10 Blazer
- Getting clunking in 4wd
- 91 s10 Headlights
- How to improve your ride quality
- Hyd clutch/bleeding troubles
- Lubed by the lubed joint?
- 2000 s-10 2.2L oil pan reseal
- Looking for S-10 online stores
- ? for dmbrisket
- Hello Everyone.
- Clutch line.
- my half 350 swap
- Membership
- A question about Manual Transmissions (not directly related to chevie's)
- I'm still here, not ignoring anyone
- clutch problems
- Ignition only fires when key released
- Fuel Or Fire????
- 4.3 S-10 Jerking - Skipping when accelerating
- Would a 2.8 with a bad oil seal around the distrib
- 4x4 doesnt work after changing cv joints
- '90 clutch problem
- 2.5L to 350 V8
- 97 Transmission
- Replacing '89 A-arm bushings
- 92 S10 engine Swap 2.5 to 4.3 ?'s
- Tail Light Issues
- reinstalling lower control arm
- 1989 4.3tbi to 350
- 2003 S-10 Sensor Codes P0155 & P0128
- S10 Prom Ecm Flash?
- Low Temp gauge reading
- 3rd door handle keeps breaking!!!
- how do i diagnose a distributor problem?
- S-10 Baja
- How do I adjust the shift lever on '88 Blazer?
- 2002 s10 knock sensor?
- Belt Squeek problem 1996 S10 CHEVY
- Few Manual-tranny questions
- diagnostic codes
- prob#2 high revving s-10
- problem#1: s-10 input shaft bearing?
- 93 S-10 Starting issue...after dark smoke...
- Need FlyWheel bolts for 1991 S-10
- 2000 zr2 abs light on
- 99 chevy s10, can't disarm alarm
- Fixed vacuum leak, 4x4 still doesn't seem to work
- These Guys are Nuts
- Oil Lines??S10
- blower motor
- Carb/electrical problem..!!
- Strage Starting Problem
- Removing window crank handle
- cyl misfire -- HELP ME PLEASE!!!!!
- Pcv
- Reminder to check your spare tire
- 88 s10 no start
- turbocharged??
- transmission swap
- Heater Control Question
- Torque Convertor Not Staying Locked In
- Looking for info on S10's
- Engine help!
- "91 S-10 Failed Emissions - HIGH HC - help???
- Disable TCC on a 4L60 tranny...
- 2000 S10 2.2 Injector circuit open
- 2003 S-10
- Valve problem?
- Help with 4 Wheel
- engine misfire
- 86 S-10...bring it
- 2000 S10 Xtreme " in process of being show truck "
- silly s10 ac compresser
- '89 S-10 4.3 TBI PU bogs when you step on the gas
- "96 S10 4.3L ZR2 won't start
- can engine oil lines be removed, 94 s10
- 89 S10 Igmition switch replacement
- No heat!
- 96 s10 4.3L Check engine light
- Fuse location for ABS brakes
- how much to pay for a new radiator
- 1989 S-10 Blazer Replace Oil Filter Lines
- freeze plug removal & installation on a 4.3 chevy
- extended cab window seals?
- Front Diff Question
- SS S-10 price
- Timing Chain and 92 S10 Blazer service manual
- 1988 s10 wont start
- horrible gas mileage
- 1997 S10 Cruise control question
- 1998 S-10 LS - 2.2 4 Cylinder Engine
- Finally an independant air fllter test
- s10 parts? buy from dealer or independent auto parts store?
- Trouble starting
- stiff ride
- 97 2.2L P0300 code
- Replace oil lines on S-10
- transfer case-fluid evaporation
- gaps
- 2.2 Head question
- 95 4.3 cpi knock sensor
- broken ground wire to coil. HELP
- Leaking Fuel Lines
- Fuel & Electrical
- HELP locating EGR valve on a 1997 S10 2.2L
- S-10 Problem. Won't start all the time.
- Help with remote starter
- change headlamp 1998 S-10
- Wondering?
- Replacing oil pan gasket-HELP!!
- replacing 4.3, need a suggestion
- Wheel bearings
- 2000 S-10, No power to Fuel pump
- automatic tranny shifting problems
- I fixed the block on my 89 4.3 Liter
- s10 fuel problem.
- It's all hitting the fan...
- 1985 Chevy S10-Tahoe
- 1991 Chevy Blazer Troubles
- 1986 GMC S-15 2.8V6 to a 305 V8
- Any good oil additives recommended?
- stereo install
- gas mileage
- S-10 revs up when in gear. please help
- Not enough voltage
- 1994 S10 Blazer Not running smoothly
- 91 s-10 timing problems
- Very strange happenings
- 2000 S-10 Extreme Sticking Caliper
- S- 10 injector spray prob.....PLZ HELP
- sounds like water
- Right front tire wear
- 84 S10 runs good then quits
- 1994 S10 Blazer Four Wheel Drive Problems
- Door panel and door handles
- 2002 s10 starts hard, runs hard
- '97 4.3L Vortec will not start when cold
- 4wd problem 1992 s-10 Blazer
- 96 s-10 Trans fluid in 4X4 vacuum actuator
- 88 S-10 Blazer Ignition Fault
- Lower Ball Joint Removal
- 01 s-10 xtreme dead
- Tight and responsive steering: Another How-To! YAY
- 1995 s10 4wd 4wd not working properly
- 94 s-10 "W" starts but dies
- 96 s10 wires...
- clutch question
- 92 4.3(Z) running rough in gear
- What part is this?
- 2001 4.3 into 1997 Jimmy
- 95 s10 Blazer Transmission
- 1991 2.5 4cyl with a miss
- ford ranger to s-10
- Suddenly began hesitating, spitting, sputtering
- Brake light problem on 2000 Sonoma
- '97 S10 pickup fuel gauge stuck on full
- How To Adjust Torsion Bars On 4.3l Zr2???
- AC Prob. on 2002 S-10
- 91 s10 brake problems
- 2.2 performance chip
- Need help identifying AC system parts
- Code 43 93 4.3
- trying to find an exhaust system
- s10 speedo recalibration help
- Ignition Accessory Position
- A Wet Winter
- 1988 4.3 s10 backfire
- Sorry about bringing up old posts
- 94 SS running really rough when A/C on
- 92 S-10 Ignition Switch
- lowering
- Out of Ideas!!
- Starting Porblems
- Code P0442 on 98 4.3
- 97 s10 4.3L VIN X p1406 and p0300 codes
- Ride height and leveling kit
- ball joints
- 1999 S-10 Transmission woes
- AC compressor clutch
- 89 s10 front driver wheel sits crooked
- truck dies too much!!
- 1989 S10 Popping Noise
- 1989 S10 Overheating Problem
- 92 S-10 dashboard
- 98 s-10 looking for lower intake r and r schematics
- Sensor question
- 1985 driveshaft carrier help
- 85 s10 blazer 2.8 to small block engine
- Error codes on GMC sonoma 1997
- block test kit
- ? regarding lower ball joints
- Another CPI How-to (focus on regulator)
- How-to change the PITA #3 spark plug
- manual trans noise
- 96 S-10 EGR Valve
- 93 S10 4.3TBI "Z" 5spd ECM/PROM Questions
- 2000 Hydraulic clutch slave cylinder line removal
- 91 S10 TBI 2.5L problems
- I have a 1984 S-10
- 86 S10 2.8 idle problem
- 1994 s-10 engine size please help
- Car amplifier problem
- Cruise ABs not working.
- 2.8 engine for 93 s10 pickup
- 2.8 to 3.4 swap
- 96 s10 2.2 crank no start. no dash lights
- 2.2 cuts out
- Slow to start then runs fine
- '90 S-10 PU Rear side windows leak
- Need ECM Wiring Diagram
- Temperature Gauge Problem 92 S-10 Blazer
- 4.3 to 350 swap
- 97 s-10 v6 coolant loss
- 1992 S-10 Blazer
- C-10 inquiry
- My Truck Dosent Want To Stop
- Truck won't start when security light is on
- 4.3 to Boat
- transmission not wanting to shifting
- Noise from inside the cab
- Flashing Break Light on Dash
- electric fan
- 1991 S-10 2.5L TBI running too rich when warm
- 2002 s10 cruise control
- gas tank sending unit
- Loosing antifreeze
- 91 S-10 4.3 code 24
- service engine light on
- Bed Cover for S-10 LS 4Dr. Short Box
- Is it possible to swap over parts from . . .
- 95 S-10 Blazer motor locks
- 4 wheel drive not working on 2000 s10 zr2
