View Full Version : S-10
- 93 trans in 95 4x4
- S-10 RANT: conversion problems-700R4
- Does anyone know what a 2.8L sounds like dualed out
- Does anyone know how to tighten up the torsion bars?
- Any Problems with Torsion Keys or Lift Shackles?
- Biggest Tires that will fit on a 2002 4X4 Crew Cab?
- Any way to make 2002 Crew Cab tires stick out like ZR2?
- Problem with 700R4 Tranny
- Air condition plug on 1993 s-10 blazer
- 2002 4x4 4.3 Liter Overheating????
- 92 S-10
- 94 s10 will not start
- 2.8l Idle Problems Brian's
- Speedometer Cluster
- 93 S-10 Auto trans, what bolts up?
- how to disable fuel pump
- blazer engine vibration
- Drum Brakes 101
- 2000 s-10 Injection Problem
- 98 s10 with a 4.3 ecm wiring diagram needed.
- 94 Chevy S10 LS not getting gas
- coolant leak getting worse!
- Ash tray woe's
- 98 S10 2.2 runs hot with AC on
- '97 4.3l horsepower?
- 4.3l turbo?
- s10 won't start
- 2wd to 4wd
- 98 S-10 Arcing Problem
- 92 cold start stalling problem
- s-10 clutch bleeding problem
- 4.3 intechangeability
- VIN Decoding
- s-10 heater doest work
- Need help truck is mis firing
- S10 Blazer Fuel Filter????
- Floor shift automatic
- 2000 s-10 problems please help!!!!
- 2000 S10 Trans Problem
- Need Help NOW...fan clutch assembly.
- 92 s10 blazer egr cleaning
- How to change transmission fluid and filter?
- Hesitation off the line?
- Extreme heat under hood????
- 2002 Snorkel???
- where is oxygen sensor in bank2
- Questions to clear some stuff up...
- extended cab windows
- 92 Chevy S - 10 Idle Problem
- 01 S10
- alright, i need help :(
- air bag light
- s10 1.9 to 2.8 swap
- Goin Tothat Big Junkyard In The Sky
- Engine codes P0113B, P1404B
- 4g63 engine in an s10 P/U?
- 97 s-10 throwing P0175 Bank2
- 95 S10 Power Mirrors
- Does anyone know what other engines
- Door won't open
- rear view mirror help
- has anyone converted from sealed beam to compostie headligth ?
- Upgrade 83 Tahoe to Firebird MPFI engine?
- Fuel leak
- my get up and go has left
- K & N Filterchargers..
- 5 speed
- Need Help!!!
- cab mounts
- S10 Top Speeds
- P0410 trouble code-What seat's will fit?
- S10 Gas Mileage
- Rough Idle
- ?'s about ss s10
- Oil Pan Replacement
- rear bumper
- something is seriously wrong!
- a update on the 84` S15 restoration/rebirth
- Need help in choosing a new S-10
- 89 4.3 TBI Code 45
- s10 4x4 problem
- 83 S10 ext no power have to floor it to accrelate
- 95 4.3TBI ujoint
- 84s10 Brake Issue
- head bolt tourqe
- 97 S-10 transmission bearing?
- AC problem Chev. S10 1997
- Ticking/Clanking noise in the rear?? 1998 S10 has new problems...
- K&N Air filter for 82-86 s10s - $15!
- New to the S-10 forum....
- my 93 has 4x4 Problems.....
- 89 S10 timing
- 91 S10 Jerks when you let off the gas.
- Rough idle and acceleration till about 30mph...
- my latest project
- Need Injector Help for 4.3 Chevy
- shifter gasket leak
- Pressing clutch cuts power for woofers?
- A picture of my S10!!
- Air Horns- How much do they co$t???
- Won't start. Thump fuel tank & it starts
- fluctuating gas guage
- Instruments out
- 1989 S10 Motor
- 97 S-10 transmission removal
- new plugs and truck runs WORSE! HELP!
- need help on chevey s-10
- S-10 Codes. No codes from my PCM!
- '93 S10 Blazer Fuel Pump ??
- Headlamp
- Headlamp
- S10 Starting Issues
- 99 s-10 2.2 will not pass CA. emissions test
- s10 pick up
- 1995 s-10 lifters????
- Temp Gauge
- 1997 Dash Trim Piece
- 86 S-15 overheating
- high pitched squealing coming from rearend?
- light weight of 94 s10 4wd pick up ?
- 2.5L no start
- 93 S-10 4.3L spark plugs
- 91 s-10/s-15 fuse location
- 89'S-10,2.5 hard to start
- posi rear end
- spindles or springs
- an old ac problem
- P0306 and P0300 (Cyl 6 & Random/Multiple Cyl Misfire) HELP A GIRL OUT HERE!
- Im Looking For Some Fender Flares!!!
- Whats The Biggest Tire That Will Fit???
- my 95 s-10 ss, governor
- Rear end question
- just joined and need help badly
- '95 S-10 4x4 transfer case
- 1/8 mile and 1/4 mile times
- ABS + brake light on simultaneously
- '96 vent control problem
- 92 S-10 dash wiring harness
- s10 tach
- cant figure this out
- 02 xtreme is pulling one amp with nothing on
- lack of parts for '88 s-15..?
- How to change the 2 back spark plugs on drivers side
- tubular headers for '88 2.8L?
- 1998 chevy s-10 wiper motor pulse board
- 1993 s-10 2.8 5 speed want start at times
- Dual exhaust on a '96 s10 blazer 4.3 Vort.
- no fuel, no spark, no guages
- no spark
- 4.3 question
- 92 s10 4.3 wont start
- So cool I found one...but...
- gas mileage ?
- Remove AC Unit on '90 S10
- Missing at start-up until warm '94 s-10 W
- not holding fuel pressure?????
- SES Code P0304
- I Need An Exorcist !!!!
- 2000 S10 Heater Core Install
- 2000 S10 Heater Core Install...
- 350 Conversion
- How do you fix rough idle on '92 S10?
- Air intake heat sensor/diaphram
- 4.3 vortec gas mileage
- HELP!! fuel leak after
- rear differential specs needed.
- FUSE BOX for '92 S10 4.3L
- blocking egr fixes it but throws code...help
- 5.8 Liter in S10?
- '92 s-10 blazer electronic 4wd shift motor?
- no power to the fuel pump
- 4.3 to 350 swap
- s-10 rear end
- 99 S10 4wd front diff oil
- '96 s10 blazer fuel pump not working
- '91 S10 4.3 4x4 leaky oil filter re-direct line??
- Help: 99' A/c Compressor Freon Fill Tips
- 99s-10 blazer 4.3w cyl 2and 3 misfire plague
- Looking for a part, help please...
- Won't Idle
- Looking for a new lift kit...
- 1984 GMC S15 re-incarnation time
- S-10 Replacing wire speakers. Please Help
- changed head gsket 98 VORTEC, no compression on one cylinder
- '96 4.3L S-10, misfires or hesitates at constant speed
- from a 4.3 to a 2.8 liter
- Vmax Street & Performance Manifold Spacer? Got One?
- Transmission Problem 1997 S-10
- Transmisson Problem 1997 S-10 4+4
- Chev s10
- S-10 Motors
- 1991 tranny install
- release bearing
- 4.3 tbi conversion to vortec 4.3?
- wheel bearings 4wd s-10 1994
- '02 S10 Sudden Drop In MPG
- Best shock for 89 s10
- s- 10
- advice on new truck
- What Is Tbc Circuit?battery Keeps Going Dead
- exhaust ?
- S-10 Pickup Timing
- 1985 S-10: Need Carburetor Adjustment Specs
- cost of adding air-conditioning to 95 S-10
- Bad computer? - '89 2.8 TBI
- Heater Core Help
- Canadians, watch W5 on Saturday
- 94 s10 2.2L starting problem
- S-10 tire pressures
- removing door and front fender 91 s10
- How do I make an S-10 trailer?
- abs brakes weird..help !
- 94 2.2L headgasket replacement
- Electronic Spark Control
- Will a 91 4 cyl work in an 89 Blazer?
- fuel pump stays on
- Body Lift
- Body Lift
- What is involved in removiing a crankshaftin an '88?
- electrical problem
- 94 S-10 Blazzer
- Camshaft position sensor help?????
- Idle Air Control Wiring Harness
- Timing Chain and Rear Main Seal replacement
- Trouble Code #14
- tailgate cable help
- torsion bar stuck!! help?
- 1994 s10 fuel delivery reset
- 1988 S-10 No Spark
- 99 2.2L won't start
- 1994 chevy s-10 suddenly shutting off quick bursts
- 96 S10 4.3 V6 Vortec engine light on
- 87 S10 Blazer Fuel Problem
- 91 s-10 problem
- How can We help improve this board?
- 1998 s10 a/c leaks... help!
- 89 s-10 2.5L runs rough, occasional backfire
- 1992 S10 pickup I'm comfuse about Gear pl help!!
- Engine Swaps wit a side of power
- 1989 S 10 Won't Start
- 1993 S10 complete motor for sale! $250
- Tranny Swap
- HELP!! Lifters
- Front Roll Pan for 88 S10
- 84 S10 Help Help Help!!!
- 88 S-10 help
- severe power loss under acceleration
- Struggling with my baby and NYS emmisions
- swap question
- 2.2L whirring clicking noise when cold
