Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. stalling
  2. type of transmission
  3. Fog Lights
  4. Windshield wiper problems!!!...
  5. 95 S10 surging at low speed/part throttle
  6. rear end info
  7. 2000 Xtended cab seats
  8. 97 hombre 2.2 #3 cyl fills with gas
  9. sittin cockeyed
  10. S-10 intermittent starting problems
  11. Catalytic Converter
  12. No Power mirrors or horn???
  13. hiss noise from ignition key switch or behind dash ?
  14. need help installing
  15. Key less Remote
  16. Spare Tire Hoist
  17. 3rd door handle-Broke again-Can you say cheap?
  18. 95 s10 problem
  19. Multiple misfires 99 2.2
  20. Removing plastic from gauges-How??
  21. fuel injector issue
  22. Will they fit?
  23. 1987 S-10 4X4 Auto. 2.8L V6, Timing? Power?
  24. New lifters...need help
  25. Fuel composition sensor p-0178, p-0179
  26. Want to replace factory radio-Any suggestions?
  27. Debating whether to fix or sell. Need estimates!
  28. 96 s10 Fuse question
  29. S-10 stumbles and stalls
  30. Fuel Pressure Regulator Replace??
  31. 85 Accleration Power Problem
  32. V8 conversion alternator isn't charging battery
  33. Changing spark plugs-When should you?
  34. 01 s-10 stuck in 4hi
  35. Separate key for tailga
  36. Shift Knob
  37. ecm
  38. 2000 s-10 Pick-up, Fuel Pump, I think
  39. 95 S-10 4 X 4 4.3l
  40. S10 Suspension
  41. Vehicle hits over 1 million miles
  42. Stupid Vibrations!!!
  43. 4-wheel drive grind, 2000 S10 4.3 Vortec
  44. camshaft help?
  45. Synthetic (high mileage) oil?
  46. Gauges in and out
  47. starter replacement 94 s10 4x4 6cyl vin Z
  48. starting problems
  49. 93 S-10 rear brakes
  50. Headlight Problem
  51. 1985 chevy s-10 motor swap
  52. swap 2.5 for a 305 h.p
  53. heeelllp 91 s10 problems
  54. Electric Choke light, Electric Windows, A/C stopped working at same time
  55. 2.5L electrical problem
  56. 95 S-10 ABS Question
  57. 3.08 to 3.73 eaton locker swap ???
  58. 4.3 to 5.7 engine swap
  59. S10 Xtreme Whine
  60. Snow Plow
  61. lowering my 91 shortbox
  62. 03 S-10 installing remote starter
  63. Ignition module question
  64. How long will she last?!?!?
  65. 1994 2WD 2.2L auto trans. - what trans's will fit?
  66. s 10 steering column
  67. 00 S-10 2.2l
  68. Air Conditioner
  69. '87 Astro Van 15" Rims on my '98 S-10?
  70. 4L60E trans fluid help
  71. rear end
  72. 94 chev s10 pu 4x4 5sp 4.3l abs LT
  73. Idle Air Control on 99'
  74. 95 dies about half throttle
  75. 89 s10 4.3l auto to a 2.8l standard
  76. '85 S-10 make-over
  77. heating problem plz help
  78. Turn Signals
  79. 85 s-10
  80. 2001 S10 Won't start
  81. E-Brake sticking
  82. 93 2.5 liter grinding third gear
  83. Carb............
  84. why does the fuse keep popping...
  85. Headlight troubles....
  86. Fuel Pump
  87. NEW to American Muscle... please help
  88. 99 2.2 S-10 2WD Brakes, front end
  89. Flickering airbag light!
  90. 2002 Zr2
  91. Air Conditioner Fan
  92. Door Won't Open on my 94 S10
  93. 2.5 to 4.3 swap
  94. 2002 ZR2 4x4 Problems...Stuck in 4-high?
  95. Stupid question >.>
  96. Best size tire for 20x8.5 Rim for DD s-10?
  97. Best size tire for 20x8.5 Rim for DD s-10?
  98. Rear main oil seal
  99. 00 Chevy S-10 2.2L low oil pressure
  100. Rebuild kit
  101. Oil Question
  102. bleeding clutch system
  103. 90 P/U - Head Gasket
  104. Diasabling Auto Headlights
  105. 2001 S10 Chevrolet Pickup
  106. aftermarket air cleaner
  107. Idle speed?
  108. ATF fluid level check-This doesn't make sense!
  109. no spark -96 S10 4.3L 200K miles
  110. 1993 Chevrolet S10 Engine 4.3(V6)
  111. 97 S-10 heater control switch problem
  112. 01 S-10 automatic trans-Should this be changed?
  113. What does your oil pressure run at?
  114. 02 ZR2 transfer case clunk
  115. Wobbly straight steering column-non tilt
  116. 3rd door adjustments
  117. Just need a little direction in removing the alternator from my '99 zr2
  118. Just need a little direction in removing the alternator from my '99 zr2
  119. Why cant I get my PCV out?
  120. 1992 S10-2.5 Tbi / No Spark!!
  121. Running Extremely Rich
  122. wheel bearing or ball joint, maybe???
  123. no spark
  124. Noise Help 95 s-10
  125. 2000 S-10/2.2L/AC Alternator Removal Issues
  126. It Keeps Dieing!!!!
  127. looses power after driving a few miles
  128. 02 S10 oil filter
  129. power steering pump bracket
  130. 1995 Brake failure
  131. 4L60E problems
  132. ABS light comes on the speedometer quits
  133. Headlight Question
  134. 88 s10 electrical issue
  135. starter problems!!!!!!!!
  136. tail lights
  137. Need help BIG Tranny problem!
  138. Where Is The Ecm!!!!
  139. Tranny Swap
  140. '99 2.2 s10 rough and dirty
  141. MY 88 pickup
  142. pics of air filter?
  143. What's the box for?
  144. 4.3l vortec balancer shaft retainer bolts
  145. Stereo Removal in 97 S10
  146. 96 S10 stalls when braking
  147. Engine/trans Change
  148. What to look for when buying an s10
  149. 4.3 vortec balance shaft engine swap
  150. '91 S-10 GVW vs GVRW
  151. Testing a cat. converter
  152. Power Steering Pump Pulley
  153. To Paint or Not to Paint
  154. engine replacement for 2.2
  155. What are these connectors for?
  156. Stalling
  157. 4.3 engine serpinetine belt to regular belt question
  158. Old skool v8 air cleaner wingnut
  159. 4.3 Voortec Fuel Injection Setup
  160. Engine Swap
  161. 96 4.3 no fuel pressure
  162. 95 S10 Ball joints
  163. Co$t of a 400 Small Block swap?
  164. Wide band or Narrow Band?
  165. Erratice Speedometer
  166. Slave/Master Cylinder connection
  167. Tiny Electrical Problem
  168. Fuel Level Sensor issue fixed
  169. Engine swap
  170. 92 long bed with bad u-Joint
  171. Possible heater core trouble ?
  172. 1999 Seats
  173. 1993 S-10 4.3L Starter Problem- ignition switch
  174. clutch problems
  175. 96 s-10 blend door actuator
  176. How to identify a replica Xtreme?
  177. somebody help me out here please with torque specs
  178. Vacuum Hose Routing
  179. 4L60e A/T compatibility
  180. brake rotor(caliper removal?
  181. engine swap
  182. rear diff
  183. automatic transmission problem in 2003 S-10
  184. 95 s-10 problems
  185. Help Quick!!!!!!
  186. 2001 S-10 ABS and BRAKE light problem
  187. i need a certified gm tech's help
  188. Turn Signal Indicator
  189. '86 S10 Body Mount.
  190. 02 S10 Ext Cab Advice
  191. Engine codes
  192. 1988 S-10 Service Engine Soon Light
  193. Something I've always wondered (about tires)
  194. 94 s-10 4.3tbi vortec Posi?
  195. code help
  196. s10 questions
  197. Need help with understanding CA emissions
  198. 1996 S10 Fuel Press. Tester ???
  199. 94 S-10 Will not hold timing
  200. 2003 s-10 emergency brake problem
  201. brake lights
  202. lift
  203. 1989 S10 Fuel Problem
  204. 03 S-10 error P0101 AND P0420
  205. Catalytic Converter Replacement
  206. please help
  207. S-10 Manual transmission capacity?
  208. 94 S-10 SS starting problem
  209. Questions about 4-wheel drive vehicles
  210. Door panel removal
  211. 91 S10 2WD 4.3L 173000mls
  212. Brake Rotors
  213. Squeaking coming from inside the dash?
  214. 1988 Chevrolet S10 Truck 2.5L Firing Order??
  215. Rear End
  216. 2001 S-10 2wd 4.3 V-6 cam specs?
  217. Oil Brands?
  218. 89 S10 4.3 neutral safety switch problem?
  219. gas in oil
  220. 93 Blazer fluid question
  221. quicker potential
  222. WANTED Las Vegas Air Bag Installer
  223. lowering
  224. '88 s10 popping sound front while in place
  225. Automatic floorshift for 97 s-10
  226. Question
  227. Please read!!!!
  228. How many screws on a 1991 s-10 trans
  229. When to replace timing belt
  230. 2000 S-10 ashtray installation
  231. Knocking in the tourque converter or trans
  232. Help with an 89 s10
  233. Where is the ecm on 89 chevy s10
  234. Will they ever recontinue production of the S10?
  235. HELP speedo not working
  236. 2000 S-10 Blower Motor
  237. Do all 2004 S10s have 4WD?
  238. 91 s-10 2.8 to 4.3 swap
  239. The hood won't open on my S10!
  240. Hall Effect Switch
  241. 93 S10 Engine?
  242. 2.2 to 4.3
  243. schreechin noise
  244. How much will a new coil pack cost?
  245. What do you guys think about this???(rollpan questions!)
  246. S10 problems?
  247. How much air do you keep in your tires?
  248. Can't find headlight relay
  249. studdering on accel. only after heating up
  250. S10 2WD lift kit?
