Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> S-10 |
View Full Version :
S-10
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
General S-10 rear end question
Upper Control Arms
MAF yes or no answers !!!
RPM Gauge reading high
Drum brakes
Steering Wheel not centered
2000 Chevy s10 surging 2.2l auto
96 S10 breaker blowing
98 s10 pickup. 200mA battery draw. help!
What is a plenum and what are poppet valves?
instrument panel bulbs
93 S10 will not Accellerate HELP
Please help! 91 s10 blazer 4.3 wont start!!
Fuse box
91 S-10 4.3L Parking lights not working
Which sensor is it?
broken steering column HELP
late 90's starter problem
Air injection pump 2000 blazer
98 s10 wheel fitment
rattle/grind coming from rear of tranny
Which tranny is in my truck? Borg or Venture?
HELP! '99 overcooling, 2.2L, 5-speed
2.8L Problem
Dropped Airbag Sensors - Are They Still Good???
Forum Rules! READ ME BEFORE POSTING!
S-10 alternator
1995 S-10 2.2 Starter engage
2002 s10 abs lights always on
86 2.8 V6 S-10 Choke Questions
2003-Shudder when starting from a stop
syclone question
91 s10 ext cab trans help
Radiator Air Bleed ?????
91 s-10 4.3 timing marks
83 2.8L 4x4 carb problems?
HELP - Removing Rear Glass on a '98 S-10
What size connecting rod bearing?
code 15 88 s-10 blazr 4.3L TBI
1986 S-15 Timing issue
dummy lights WTH?
stroker motor
96 S-10 4.3 X Tran removal
Looking For Information on U-Pull its in NJ
2000 S10 Evaporator Drain
transmission crossover
EGR circuit?
what are the best shocks?
97 S-10 A/C Help
Please help I have my truck apart now
Help! Loud Knocking Noise
Transmission problem?
new project
Rattle noise in 4.3L V6 VIN W
carrier bearing replacement
service engine soon
Ignition Switch problem
Transmission Component Slipping
anyone got a vacuum line diagram 4 a S-10
2000 S10 O2 Sensor Failing
91 s10 stalling/sputtering when warm
How do I replace my spark plugs?
1999 s-10 2.2L oil pan gasket replacement
Leaking Hose. Need help identifying hose.
Battery light
1998 S10 Wiper Problem
1997 s10 body allignment
turn signals only with lights off
1988 Chevy S10...Please take the time to read and respond
88 4WD s-10 Blazer vacum lines
fuel filter won't come off
? 92 S-10 wont run right until it warms up?
2001 Blazer Tires & Axle
Running lights on but headlights dead
4.3 to SBC swap
dipstick prob..?
91 s-10 putters on highway
Which sensor
89 S-10 died and won't start
Fuel Pressure
Hard to start 96 4.3
Dual Oil Filter Relocation Kit
91 S10 Code scanner wanted..which 1?
Newbie to Site and need HELP !!!
89 Speedo out
S10 PROBLEM.help
95 s-10 clutch problems
No spark on 91 4.3 Blazer
need an exhaust system
98 S10 Radio
radiator replacement
Chirping Noise
Echeck 98 s10
Exhaust for S-10 (Please reply!!!)
vibration in 92 s-10 blazer 4.3 Tbi
Timing chain...cost of repair
Oil cooler lines 93 S10 Blazer...
help with colors of A and b wire on assembly line datd link
97 to 98 conversion
what is happening
bed swap question
2001 Blazer Oil Drain Plug Gasket???
exhaust on the 4.3 engine
1989 S10 advice
door lock relay
The strangest thing happened to my S10 the other day...
91 S10 need computer for tune up?
S10 power
Reverse Lights
tranny leaking
92 4.3L TBI to CPI?
Hard to start 87
92 S-10 popping the hood - broken cable
How I replaced starter on 92 S-10 4X4 man. trans
Engins Shuts down when I put it in reverse.
1991 S-10 2.8l Vss
91 s10 blazer engine stumble
a/c compressor help
Vibration
1989 Chevy S10 / GMC S15 Modified!
94 passenger power mirror
EGR valve
Grinding in Steering Column
97 S10 won't start
s-10 won't start.
how to hook up stereo
134A Capacity of AC
2002 ZR2 Changing Headlight Bulbs
how would the LED's install for brake/turn signal
1994 s 10 blazer 4.3 cpi
Guage troubles on 1999 S-10
Recall Notice (#06202)
Motor vibration
86 s-10 still cutting out. IM LOST!!
91 2.8l v6 Fuel Pump randomly comes on
dash lights on s-10 blazer
'87 S10 Starting Woes
feeling autocidal...
Need some advice
Where to find a front instrument panel
Tightening Torison Bars
Fluctuating oil pressure
Looking to buy a s-10
S-10 are easy to steal?
My Truck Works Good Then Dies
parking brake cable
86 s-10 cutting out
More Questions on my car.
What's "the rack" exactly?
91 S10 2.5l acceleration problems...
1998 S10 Blazer Engine Control Module
Fuel gauge not accurate
2.2 to 2.8 swap
What do you ride on?
4.3 oxegen sensors...
engine swap
2.8 , 4.3
Battery Draw. Any Ideas?
86 Blazer Missing - only when moving
1999 S10 Dash light problems
code 122
blowing fuses and needing jumpstarts
1998 S10 Issues
Needs new shocks-What would you choose?
88 Chevy S10 2.8L running problems
86 S-10 Blazer A/C problem. Please help!
Digital Dash
2000 2wd knock in front end
1991 s10 blazer no power to fuel pump
Oil leaking problem
Fan clutch removal of 96 s-10
radio auxiliary input
crankshaft position sensor stuck
Lifter Noise?
check engine light
Humming noise from drive train
Replacing knock sensor
No Brake Lights Or Flashers
95 s10 idles up and stalls sometimes
where is the sensors on a 91 S10???
1999 S-10 Fuel Filter Help Please...
86 s-10 idle's low and high
Muffler noises
Another Efan Question
94 s10 window regulator from sash
91 S10 Idle problems
Keepin you updated on everything
Aftermarket Ignition Systems -- Opinions...
Full Recline Bench In a 1st Gen X-Cab???
Vapor Recovery System problem
fuel pump
I want to do away with the efi and put a carburetor in
dual alternators
Need to fix exhuast leak ASAP
Horn relay location...
no rear right turn signal
seat back recline lever breakoff
94 2.2 won't start..any ideas?
Fuel injector
Interior light shut off
Air vents
89 4.3 A/C Question
dtc po155
Abs Light
86 s15 2.8L engine swap to 89 2.8Lmpi any tips
S10 Blazer 2x4 to 4x4 chassis swap
88 S-10 no fluid to rear brakes
My 85' Chevy S-10 Dies on sharp left turns??!!
gas cap pressure/vacuum not sure...
hard start
What's involved in a 350 swap?
Differences between 4.3 HO and Non HO
New Engine Installed !!!
Add to the 2.8?????
Performance Maximization 2.5L TBI
O2 sensor trouble code
From 1st to 2nd gear hard shifting
Help: motor conversion
87 s10 headunit install, Urgent help needed
Window regulator problems
A/C not blowing through vents
87 S10 front speakers
93 Blazer fuel lines and wheel sensor...
"Floppy" steering column on 1989 S-10 Blaser
Plastic door clips
Please help with terrible gas mileage
98 S10 2.2 Transmission Cooler fittings
93 S-10 Blazer 4x4 diagnostics...
Which electric fan?
Vaccuum hoses for a 91 v6 4.3
Electrical Help Please
Need help
95 S-10 (gas smell when I turn it off)
Transfer case shaking
rear end info needed
Key getting stuck in the on position 91 s-10
Adjust Idle 91 s-10 4.3
bad crank sensor
'03 S-dime/3.8 and T-56 conversion?
headlights / speedometer
transmission removal
Passanger side floor borad heat
Trans or transfer case problems
converting 82 suzuki samurai to 4.3L with turbo 350 tranny
Questions with new wheels/tires
u joint replacing
4 wheel drive delay
04 ZR5 Wont engauge 4x4 hi
91 S-10 4.3 4x4 Compression?
Need to know, 2.5 to a 2.8,
Web
AF
