Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24
  1. My S-10 tries to die with the heater on!
  2. What engine options do I have?
  3. 2003 S10 starting problems
  4. Removing Center Console
  5. dual exhaust on 4x4
  6. newbie with milage question
  7. 91 S-10 Oil Pan
  8. 98 chevy s-10 - where is the fuel pump relay?
  9. Four Wheel Drive Problem
  10. 98 Chevy S-10 - won't start - fuel pump?
  11. 86s-10 4x4 2.8 motor problems
  12. major fuel gauge problems
  13. 4x4 S10 or Sonoma!!
  14. s-10 hard tonneau cover
  15. jshort qtr mile times
  16. '97 Blazer random starting
  17. 92 S-10 2.8l 5 SPEED HELP
  18. 1986 blazer w-4.3 4x4 not working help please snow on the way
  19. 86 S10 Fuel Pump Relay Location?
  20. Adding Power locks/Windows?
  21. Changing Transmission Fluid and Filter
  22. 98 s10 no fuel pump
  23. thule fit kit
  24. Newbie Questions
  25. Parting out S-10 87 ext cab
  26. changing O2 sensor on 97 S-10 Blazer
  27. Problem with my S-10
  28. 94 S10 pu auto trans trouble
  29. s-10 alternator replacement now won't start
  30. 2003 s10 Turbo
  31. what heads for my 4.3, 87 TBI
  32. "Service Parts Identification" label
  33. Is it worth restoring?
  34. minor? electrical issues...
  35. S10 ECM RESET/HO2S Problem/Rant
  36. 93 S-10 wiper problem
  37. firing order
  38. 91 S15 Jimmy 4WD 4Sale knocking
  39. S-10 Blazer Squeaky Rear Window
  40. Service Engine Soon Light
  41. oxygen sensor
  42. 2000 S10 Tune Up PCV install
  43. Looking for motor & tranny
  44. Fast idle only when warmed up
  45. Dual Ram Air Hood
  46. a cam and heads
  47. 02 Chevy S-10 hop ups??
  48. S10 runs till it get warm
  49. Choke opens only half way?
  50. Green Wire on fuel pump relay
  51. '93 S10 4WD Hi Won't Engage
  52. blazer top speed 67mph
  53. engine runon
  54. Help lifting a Jimmy 4x4 front
  55. Show off your S-series miles here
  56. Rear Brake Drum S-10 4X4
  57. pictures of my 89 s10
  58. S10 Turn Signal/Flasher unit location
  59. WTB: 82-88 2wd s-10 rear axles....
  60. fair price for complete 4.3 ($300.00)
  61. Random starting problem
  62. help!!! truck vibrates at 180mph
  63. 97 4.3 max power????
  64. 1st post--newbi,need 4.3--KC,MO
  65. How Much Does a Vortec 4.3 Weigh?
  66. No Gas
  67. 95 S10 Starting hard/loading up at Idle
  68. 92 Camaro/S10 16x8 rims 4sale
  69. Help I Am Freezing!!
  70. Please help! 2002 S-10 Shuts off when I put in park
  71. 95' S10 2.2L Issues
  72. Help my 91 4.3 died this morning!!!!!!!!!!!!!!
  73. my S-10
  74. Loss of electrical power, but car still ran
  75. Looking for S-10 Blazer or Extra Cab Pick Up
  76. 96 s-10 dies while driving
  77. Factory CD player
  78. '97 2.2; 4.3 swap a possibility? (tranny related)
  79. '97 Hombre; installing instrument cluster w/tach
  80. some 2002 blazer stuff for sale
  81. 93 S10 will not start
  82. S10 bucking problems
  83. 94 4WD Problems
  84. Fs:3/4 Drop Kit
  85. S10 ZR2 rim size???????????
  86. 85 2.8 tranny swap 5 speed to auto
  87. 93 S10 Will not Start
  88. 88 S-10 Fuel Tank
  89. Back-up lights
  90. ignition
  91. 96 S-10 turn signal flasher
  92. 94 S-10 4.3 Won't Restart When Hot
  93. 93 S-10 engine quits when idle for too long
  94. Understanding Passlock
  95. Klunking Noise
  96. Hot Rod Articles on Building the 4.3
  97. 98 s10 brake lights stuck
  98. fuel Gauge Question on 88 S-10
  99. 4.3 CPI versus TBI. What's the Dif?
  100. S10 2WD lifts?????????
  101. Need S-10 expert
  102. aftermarket tach on 2.2L DIS
  103. Egr Valve Temporarily Stuck Open
  104. Help Identify This 4.3 Motor
  105. bbc s10 headers?
  106. 85 s-10 2.8L help!!!!
  107. Check Gauges light comes on
  108. Fuel Gauge does not work
  109. Throttle Bores
  110. How to Build a Killer 4.3 V-6?
  111. 4x4 Problem
  112. S10/Camaro rims for sale
  113. Small electrical problem
  114. High pitched squeal coming from speakers
  115. 2.2l headers
  116. swap 2.8 for 4.3
  117. Right front wheel clunking
  118. 93 S-10, 2.8L, 5spd WON'T START NOW!! HELP PLEASE!!!!!
  119. 92 4X4 Front Diff. Problems
  120. 1989 S-10 fuel system
  121. 4x4 won't unlock with electronic switch
  122. 94 S10 Blazer heater problem
  123. 2.2l headers
  124. Cold Start Prblm 93 S-10 Blazer 4.3L
  125. Help installing a catalytic converter?
  126. Clutch Problems
  127. Help Please
  128. will it work
  129. 92 s10 blazer cold weather rough idle
  130. brake light flashing
  131. stock vs. zr2
  132. Erratic Temp Readout-SOLVED
  133. clutch noise!
  134. 3.4L Crate-Carb and Cam?
  135. Temp gauge
  136. 89 s10 Blazer Battery Drain
  137. 95 S10 ses lite
  138. Help With 95 Blazers.... ANYONE? PLEASE
  139. Smog issues.
  140. ?'s for v8 swap guys
  141. How do I know...?
  142. Passlock
  143. 1990 digital dash stopped working
  144. starter from 86 s10 blazer fit & work in 88 s10 blazer help pleEASE!!!!
  145. 2.8-3.4 stroker kit+ 3.1 crank pistons
  146. S-10 Oil Pressure
  147. instrument panel lights out
  148. 1985 S-10 chevy
  149. s-10 electrical problems
  150. 4 wheel ABS air bleed
  151. S-10 problems
  152. 99 chevy s-10 blazer
  153. Turn signal problem
  154. ABS problems, could use some helo
  155. the mighty mini
  156. '94 S-10 Blazer tail light plug (where)???
  157. tire size
  158. injector not working
  159. Were are all the performance parts?
  160. what is EGR valve and symptoms of faulty
  161. Replace starter on 4x4 s-10
  162. Engine Is Now Makin Too Much Noise!!!!
  163. Just sayin Hi
  164. 4 wheel drive Doesnt work
  165. Can Someone Help Me? (HEATER CORE)
  166. dropping a s-10
  167. 4wd problem
  168. 93' S-10 Blazer 4.3 No start.
  169. Cannot Get 4wheel Dr To Turn Off!!!!
  170. nasty exhaust noise!
  171. Heater - A/C Fan Control Switch & 4 WD Problem
  172. 4.3 s10
  173. map sensor
  174. best lift kit?
  175. Fuel Pressure Connection '94 s-10 4.3L High output
  176. Why does Chevy not..........
  177. routine maintenance @ 60k miles
  178. Hood Latch on 89 s-10
  179. New Here.....I need help!
  180. No torque on front wheels in 4x4
  181. FS--> Mint S10 in So. California
  182. swaping a 93 vortec into a 92 tbi
  183. Putting a New Rear in the S10... Help needed...
  184. chevy starting
  185. I really need help.
  186. 97 S-10 remote programming instructions
  187. 2002 s-10 SE QUESTION
  188. Cooling fan stays on, kills my power
  189. While Driving all electic shuts off, then back on real fast.
  190. Service Engine Soon Light Came On
  191. 99 S-10 Clutch (won't Go In Gear - Pedal To Floor)
  192. interferance fit engine
  193. single cly misfire
  194. 2001 S10 How Many Bulbs in Instrument Cluster?
  195. 91 s-10 blazer headlights on engine sputters
  196. 2002 Heat Problems
  197. blue and smoked taillights
  198. Problem starting my S-10 truck
  199. 96 4.3 vortec excessive pinging
  200. 2.2L head
  201. Automatic Shift Indicator
  202. 98 S-10 Exit Lighting Question
  203. Lowering Springs for V8 truck
  204. no power at the injectors
  205. Fuel tank help
  206. A/C Heat Problem
  207. 2003 Blazer Xtreme for sale
  208. stalling when coming to stop
  209. s10 air bag light on
  210. s10 dash lights not on and won't start
  211. Back Window Leak
  212. Setting Base Ignition Timing on 4.3L V6
  213. water in oil pan, 1985 S-10
  214. Need S10 V8 4X4 Oil Pan
  215. engine noise
  216. electrical problems on an '85 s-10
  217. '87 Fuel pump problem
  218. 4.3L performance parts any!
  219. (5 S-10 Error Codes
  220. tranny from a 4.3 work work with a 5.7?
  221. Engine vibration
  222. Electric Tranny Problems
  223. S-10 Making Ticking Noise
  224. Erractic Temperature Readout On Dash
  225. s-10 not starting again
  226. Help--Fuse Box Location?
  227. S10 Dash upgrade
  228. EHCU for '95 Chevy S-10
  229. Motor Mount replacement
  230. 94-s-10 acts like it's only on three
  231. More Power For 2.2?????
  232. s-10 2.5L 4-cyl distributor conversion
  233. problems after supercharging 4.3L vortec V6
  234. wanted
  235. electrical problems
  236. More power to my Chevy S10
  237. which muffler?
  238. Full Exhuast System
  239. 98 s-10 header
  240. 94 S-10 Vortec Starting problems
  241. Just replaced the Heater Core in 93 Blazer
  242. 89 S10???
  243. 95 S-10 Clutch
  244. 89 Chev Blazer S-10 Clutch
  245. 91 S-10 upgrades HELP!!!
  246. Shaved Emblems
  247. 2004 4.3 V6 Engine Noise
  248. No heat either! (more details)
  249. 4.3 rough idle
  250. zq8 rims
