View Full Version : S-10
- 86 S10 Fuel Pump Relay Location?
- Adding Power locks/Windows?
- Changing Transmission Fluid and Filter
- 98 s10 no fuel pump
- thule fit kit
- Newbie Questions
- Parting out S-10 87 ext cab
- changing O2 sensor on 97 S-10 Blazer
- Problem with my S-10
- 94 S10 pu auto trans trouble
- s-10 alternator replacement now won't start
- 2003 s10 Turbo
- what heads for my 4.3, 87 TBI
- "Service Parts Identification" label
- Is it worth restoring?
- minor? electrical issues...
- S10 ECM RESET/HO2S Problem/Rant
- 93 S-10 wiper problem
- firing order
- 91 S15 Jimmy 4WD 4Sale knocking
- S-10 Blazer Squeaky Rear Window
- Service Engine Soon Light
- oxygen sensor
- 2000 S10 Tune Up PCV install
- Looking for motor & tranny
- Fast idle only when warmed up
- Dual Ram Air Hood
- a cam and heads
- 02 Chevy S-10 hop ups??
- S10 runs till it get warm
- Choke opens only half way?
- Green Wire on fuel pump relay
- '93 S10 4WD Hi Won't Engage
- blazer top speed 67mph
- engine runon
- Help lifting a Jimmy 4x4 front
- Show off your S-series miles here
- Rear Brake Drum S-10 4X4
- pictures of my 89 s10
- S10 Turn Signal/Flasher unit location
- WTB: 82-88 2wd s-10 rear axles....
- fair price for complete 4.3 ($300.00)
- Random starting problem
- help!!! truck vibrates at 180mph
- 97 4.3 max power????
- 1st post--newbi,need 4.3--KC,MO
- How Much Does a Vortec 4.3 Weigh?
- No Gas
- 95 S10 Starting hard/loading up at Idle
- 92 Camaro/S10 16x8 rims 4sale
- Help I Am Freezing!!
- Please help! 2002 S-10 Shuts off when I put in park
- 95' S10 2.2L Issues
- Help my 91 4.3 died this morning!!!!!!!!!!!!!!
- my S-10
- Loss of electrical power, but car still ran
- Looking for S-10 Blazer or Extra Cab Pick Up
- 96 s-10 dies while driving
- Factory CD player
- '97 2.2; 4.3 swap a possibility? (tranny related)
- '97 Hombre; installing instrument cluster w/tach
- some 2002 blazer stuff for sale
- 93 S10 will not start
- S10 bucking problems
- 94 4WD Problems
- Fs:3/4 Drop Kit
- S10 ZR2 rim size???????????
- 85 2.8 tranny swap 5 speed to auto
- 93 S10 Will not Start
- 88 S-10 Fuel Tank
- Back-up lights
- ignition
- 96 S-10 turn signal flasher
- 94 S-10 4.3 Won't Restart When Hot
- 93 S-10 engine quits when idle for too long
- Understanding Passlock
- Klunking Noise
- Hot Rod Articles on Building the 4.3
- 98 s10 brake lights stuck
- fuel Gauge Question on 88 S-10
- 4.3 CPI versus TBI. What's the Dif?
- S10 2WD lifts?????????
- Need S-10 expert
- aftermarket tach on 2.2L DIS
- Egr Valve Temporarily Stuck Open
- Help Identify This 4.3 Motor
- bbc s10 headers?
- 85 s-10 2.8L help!!!!
- Check Gauges light comes on
- Fuel Gauge does not work
- Throttle Bores
- How to Build a Killer 4.3 V-6?
- 4x4 Problem
- S10/Camaro rims for sale
- Small electrical problem
- High pitched squeal coming from speakers
- 2.2l headers
- swap 2.8 for 4.3
- Right front wheel clunking
- 93 S-10, 2.8L, 5spd WON'T START NOW!! HELP PLEASE!!!!!
- 92 4X4 Front Diff. Problems
- 1989 S-10 fuel system
- 4x4 won't unlock with electronic switch
- 94 S10 Blazer heater problem
- 2.2l headers
- Cold Start Prblm 93 S-10 Blazer 4.3L
- Help installing a catalytic converter?
- Clutch Problems
- Help Please
- will it work
- 92 s10 blazer cold weather rough idle
- brake light flashing
- stock vs. zr2
- Erratic Temp Readout-SOLVED
- clutch noise!
- 3.4L Crate-Carb and Cam?
- Temp gauge
- 89 s10 Blazer Battery Drain
- 95 S10 ses lite
- Help With 95 Blazers.... ANYONE? PLEASE
- Smog issues.
- ?'s for v8 swap guys
- How do I know...?
- Passlock
- 1990 digital dash stopped working
- starter from 86 s10 blazer fit & work in 88 s10 blazer help pleEASE!!!!
- 2.8-3.4 stroker kit+ 3.1 crank pistons
- S-10 Oil Pressure
- instrument panel lights out
- 1985 S-10 chevy
- s-10 electrical problems
- 4 wheel ABS air bleed
- S-10 problems
- 99 chevy s-10 blazer
- Turn signal problem
- ABS problems, could use some helo
- the mighty mini
- '94 S-10 Blazer tail light plug (where)???
- tire size
- injector not working
- Were are all the performance parts?
- what is EGR valve and symptoms of faulty
- Replace starter on 4x4 s-10
- Engine Is Now Makin Too Much Noise!!!!
- Just sayin Hi
- 4 wheel drive Doesnt work
- Can Someone Help Me? (HEATER CORE)
- dropping a s-10
- 4wd problem
- 93' S-10 Blazer 4.3 No start.
- Cannot Get 4wheel Dr To Turn Off!!!!
- nasty exhaust noise!
- Heater - A/C Fan Control Switch & 4 WD Problem
- 4.3 s10
- map sensor
- best lift kit?
- Fuel Pressure Connection '94 s-10 4.3L High output
- Why does Chevy not..........
- routine maintenance @ 60k miles
- Hood Latch on 89 s-10
- New Here.....I need help!
- No torque on front wheels in 4x4
- FS--> Mint S10 in So. California
- swaping a 93 vortec into a 92 tbi
- Putting a New Rear in the S10... Help needed...
- chevy starting
- I really need help.
- 97 S-10 remote programming instructions
- 2002 s-10 SE QUESTION
- Cooling fan stays on, kills my power
- While Driving all electic shuts off, then back on real fast.
- Service Engine Soon Light Came On
- 99 S-10 Clutch (won't Go In Gear - Pedal To Floor)
- interferance fit engine
- single cly misfire
- 2001 S10 How Many Bulbs in Instrument Cluster?
- 91 s-10 blazer headlights on engine sputters
- 2002 Heat Problems
- blue and smoked taillights
- Problem starting my S-10 truck
- 96 4.3 vortec excessive pinging
- 2.2L head
- Automatic Shift Indicator
- 98 S-10 Exit Lighting Question
- Lowering Springs for V8 truck
- no power at the injectors
- Fuel tank help
- A/C Heat Problem
- 2003 Blazer Xtreme for sale
- stalling when coming to stop
- s10 air bag light on
- s10 dash lights not on and won't start
- Back Window Leak
- Setting Base Ignition Timing on 4.3L V6
- water in oil pan, 1985 S-10
- Need S10 V8 4X4 Oil Pan
- engine noise
- electrical problems on an '85 s-10
- '87 Fuel pump problem
- 4.3L performance parts any!
- (5 S-10 Error Codes
- tranny from a 4.3 work work with a 5.7?
- Engine vibration
- Electric Tranny Problems
- S-10 Making Ticking Noise
- Erractic Temperature Readout On Dash
- s-10 not starting again
- Help--Fuse Box Location?
- S10 Dash upgrade
- EHCU for '95 Chevy S-10
- Motor Mount replacement
- 94-s-10 acts like it's only on three
- More Power For 2.2?????
- s-10 2.5L 4-cyl distributor conversion
- problems after supercharging 4.3L vortec V6
- wanted
- More power to my Chevy S10
- which muffler?
- Full Exhuast System
- 98 s-10 header
- 94 S-10 Vortec Starting problems
- Just replaced the Heater Core in 93 Blazer
- 89 S10???
- 95 S-10 Clutch
- 89 Chev Blazer S-10 Clutch
- 91 S-10 upgrades HELP!!!
- Shaved Emblems
- 2004 4.3 V6 Engine Noise
- No heat either! (more details)
- 4.3 rough idle
- zq8 rims
- No Heat in Cab...
- fuel pump
- roadgrater system
- difficulty shifting
- 2000 Xtreme For Sale
- Colored Primer
- what is this?
- Ignition set (by-pass mode) Disconnect Plug
- 1992 GMC Sonoma S-10 Heater Core Replacement
- High Voltage
- CD player install
- '93 S-10 Blazer - Should I dump it?
- 94 4.3 tbi runnin' like a bag of assholes!
- s-10 w/v8 for sale
- Chevrolet Blazer S10 1991 door handle installation
- S-10 Blazer Starter 'Clicks'
- exaust
- IAC (Idle Air Control) is going bad?
