View Full Version : S-10
- Clock Light Stays On
- 1991 S-10 4x4 4.3 L Fuel Pump Blows Fuse
- mass air flow sensor
- dont know what code this is
- Favorite Spark Plugs
- S10 Rear Axle Spring Seat Spacing
- What size rims can I put on my S-10 without it rubbing?
- Show off Your S-series
- Oil Lines on a 94 S10 Blzr 4.3l
- Fuel Pump interchange
- Air intake systems
- is it siezed?
- Still getting Code 42???
- Governer 99 s-10
- Nissan KA24DE(T) in an S-series?
- manual 96 comes out of 5th gear when slowing down and speeding up again
- Rattaling noises on every bump
- 95 S-10 tranny hangs in second
- 95 4.3L Z code idle
- Other Chevy rims that might fit 98 s10
- S-10 wheel fitment ?
- wiper delay
- governor
- 91 s-10 blazer electrical trouble!!!
- '93 S-10,2.8L, fast idle
- S-10 v8 swap question
- ZR2 or Z71?
- 305 TPI into S-10 Blazer
- firing order
- need help asap
- temperature issues
- should I give them more money??
- Bedliner
- 1995 Chevy S-10 4.3 W motor losing power
- S10 V8 Headers/Brake Lines
- Subs in a s10 extended cab
- 4.3l Throttle body
- 2.2L died,replaced timing chain, now no compression...suggestions?
- WANTED Non running rust free S-10
- 98 s-10 v8 swap?
- 94 S10 Rear Drum Brakes Replc'g?
- Changing exhaust
- EGR Valve Problem
- Dim head lights, turn sigs blink fast 95s-10
- High RPM tran slip, slowly dying front transfer case
- Hinge bushings
- Radio clock reset
- Front driveshaft on a 98 ZR2
- Need wiring (electrical) expert over here!!
- Can I remove all emissions on 85 s10????
- gauges
- V-8 swap in my 93'
- 96 S-10 Thermostat
- V8 headers installation
- 1995 s-10
- Car Does NOt Start - Horn Beeps
- engine swap
- For Sale: 2000 Chevy S10
- rear speakers in 1997 s-10 extended cab
- WHat is CDI?
- EGR Valve ?
- starting problems
- yr 2000...secondary air injection malfunction trouble code??
- S-10 thinks its out of gas at 1/4 tank.
- Trans
- push button to manual swap?
- 1991 Ext. cab S-10 2.8L with a/c-serpentine belt diagram
- Keyless Entry Wires
- 01 S10 5 point wheels
- 1995 trany noise
- strong rear diff.?
- rear end swap
- 96 S-10 Blazer w/ speedometer problems
- wanted s10
- brake lights wont work
- ZR2 torsion bar lift
- 95 S10 Brakes
- Modification
- Steering Column Swap
- body lift kit
- 91 S-10 Blazer died won't start
- suspension?
- '90 s-10 window stuck down
- rough idle ,vibration
- Running Rough! O2 Sensor? Help Anyone!
- s10 SS 1/4 times
- 95 blazer 4.3L fast idle
- 1986 S10 starts doesn't start
- 1986 s10 Starts and doesn't Start
- Irritating Noise S-10
- 91 S10 Transmition problems
- backup lights 1995 chevy S10 pickup
- Backup Lights
- V-8 swaps for 98+?
- need help fast...:(
- uh.. hello
- transmission interchangeability? (new to list)
- 350 Camaro engine fits??
- 97 S-10 Wiper Motor Problem
- 88 s10 wont start when cold
- S10 v8 conversion
- Transmition Problem v8-s10
- Will factory radio from 03 S10 fit in 94 S10?
- Which code reader?
- right turn signal dead
- voltage regulator?
- sorry... oil pressure
- 2002 S-10 Body Lift
- Exaust
- cruise control on 1992 S-10
- S10 brake lights
- 1994 S-10 4.3 Eng. Code W
- Electrical Problem
- left turn signal..dead!!!
- 1989 S10 pickup Instrument Cluster
- horn relay
- Egr Pipe
- Ping and Knock
- Timing Cover
- S-10 Brakes
- 99 S-10 Fuel Pump Problem.....need Help!!!
- 1991 4.3L V6 Stats?
- Has anyone heard of CFM-Tech's High Flow GM Throttle Blade?
- parting out 94 s10 ss
- 98 S10 ZR2 Starting ?
- Adjusting drivers door-Wind noise
- 4.3 sat for a year, where do I start?
- 87 S-10 Blazer pilot bearing problem
- 87 Blazer 2.8L failed smog test - high idle?
- taillights are out/blowing fuses
- Need help fast! Fan removal!!
- Strange noise-What is it?
- Just Bought 1995 S10
- S-10 rear brake rotor removal
- Transmission Cooler-Which coolant line?
- idling problem!
- unable to start on first time
- 92 S-10 Blazer floods when warm
- just purchased a 1994 S-10
- idle air control valve?
- S10 2.2L Cuts off while driving, then won't start
- Airbag light on after plug wire change???
- 94 s10 blazer hesitates after idiling
- Where can i put my Subwoofers
- starter problems, help fast please!!!
- engine backfires help
- seats
- 93 s10 heater problems
- u-joints?
- Passenger Door Panel Removal
- 95 programmer Chips
- 87 s-10 blazer heads
- BBC in an S-10
- Starting Prob's
- strange noise when I turn off my S10
- Wiring from battery to fuse panel
- 1986 v8 s10 straight shift,,
- spark plug burning off
- Put these Camaro rims on ur S-10
- Ball Joints
- 1993 Blazer instrument panel removal???
- 95 S10 turbo 2.2L
- Newer motor for 89
- 1986 Blazer K5 Heater Core Removal
- Help with Fuel Filter
- S10 4.3 performance parts for sale.
- 4.3 motor swap to Vortech 4.3
- What Other Vehicles match S-10 Lug Pattern
- V-6 with the best power?
- 1989 S-10 4X4 front problem(please help)
- 97 Chevy S-10 fuel relay?
- Time's Up!
- 92 S-10 CPI V6, running rich on passenger side
- 2.2L Missing & Fuel Burning (popping) in Catalytic Converter! HELP!
- PS pump noisy
- s10 pickup fuel pump !!AGAIN!!
- need subwoofer help
- 96 s-10 won't start at home, at dealer" starts"
- Q-Form Speaker Kick Panels
- Hypertech Chip
- Bushwacker Fender Flares
- MSD6 Ignition Box
- guage templete
- 83 wipers do not work
- 1983 s-10 door hinge pin removal ?
- Replacing fuel pump/sending unit- 2000, S-10,2.2
- '96 S-10 Turn Signal Switch - HOW TO??
- replacing seat recliner bracket?
- New here.....problem with my door on my S-10
- 98 s-10 INFO
- fuel pump 88 s10
- S10's with V8's
- just bought 85 S10 BLAZER, NEED HELP!!!
- 85 s10 358 v-8
- Starting Problems
- Tilt wheel
- 88 S10 Blazer 4.3L No Fuel
- WTB: s10 under 1500 and in Ohio
- ! Brake Lite Flashing
- burning oil
- 89 s10 blazer with 4.3 burning a lot of gas
- !993 S10- Help with 4WD
- heater only works in 2 positions!! HELP!!
- Hi. S10 offset? Help!!!
- 87 body on 91 Blazer
- 89 S-10 Blazer height
- Tilt Wheel Loose
- Bad HeaterCore Problem
- 96 S-10 Blazer 4X4
- 94 S10 pu auto trans trouble still
- 1997 S10 Door Bushing Replacement
- 95 blazer, OBD-II scantools not reading
- Headlight Wiring Question
- LIFT spindles Help me find
- oxygen sensor
- 2000 S-10 Heater problem
- questions about 84 turbo colt
- people
- help!! i need a new motor!
- 1995 Chevy s10 abs light on
- Diagnostic Code Error
- Dashboard UN-install
- Chevy Extreme Will Z06 Rims Fit
- What's with the children in this place?
- '94 S-10 Blazer Keyless Entry
- s10 blazer shuts down after heating up
- Brake Noise
- Help for replacing a thermostat
- My S-10 tries to die with the heater on!
- What engine options do I have?
- 2003 S10 starting problems
- Removing Center Console
- dual exhaust on 4x4
- newbie with milage question
- 91 S-10 Oil Pan
- 98 chevy s-10 - where is the fuel pump relay?
- Four Wheel Drive Problem
- 98 Chevy S-10 - won't start - fuel pump?
- 86s-10 4x4 2.8 motor problems
- major fuel gauge problems
- 4x4 S10 or Sonoma!!
- s-10 hard tonneau cover
- jshort qtr mile times
- '97 Blazer random starting
- 92 S-10 2.8l 5 SPEED HELP
- 1986 blazer w-4.3 4x4 not working help please snow on the way
- 86 S10 Fuel Pump Relay Location?
- Adding Power locks/Windows?
- Changing Transmission Fluid and Filter
- 98 s10 no fuel pump
