View Full Version : S-10
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. New lifters...need help
  2. Fuel composition sensor p-0178, p-0179
  3. Want to replace factory radio-Any suggestions?
  4. Debating whether to fix or sell. Need estimates!
  5. 96 s10 Fuse question
  6. S-10 stumbles and stalls
  7. Fuel Pressure Regulator Replace??
  8. 85 Accleration Power Problem
  9. V8 conversion alternator isn't charging battery
  10. Changing spark plugs-When should you?
  11. 01 s-10 stuck in 4hi
  12. Separate key for tailga
  13. Shift Knob
  14. ecm
  15. 2000 s-10 Pick-up, Fuel Pump, I think
  16. 95 S-10 4 X 4 4.3l
  17. S10 Suspension
  18. Vehicle hits over 1 million miles
  19. Stupid Vibrations!!!
  20. 4-wheel drive grind, 2000 S10 4.3 Vortec
  21. camshaft help?
  22. Synthetic (high mileage) oil?
  23. Gauges in and out
  24. starter replacement 94 s10 4x4 6cyl vin Z
  25. starting problems
  26. 93 S-10 rear brakes
  27. Headlight Problem
  28. 1985 chevy s-10 motor swap
  29. swap 2.5 for a 305 h.p
  30. heeelllp 91 s10 problems
  31. Electric Choke light, Electric Windows, A/C stopped working at same time
  32. 2.5L electrical problem
  33. 95 S-10 ABS Question
  34. 3.08 to 3.73 eaton locker swap ???
  35. 4.3 to 5.7 engine swap
  36. S10 Xtreme Whine
  37. Snow Plow
  38. lowering my 91 shortbox
  39. 03 S-10 installing remote starter
  40. Ignition module question
  41. How long will she last?!?!?
  42. 1994 2WD 2.2L auto trans. - what trans's will fit?
  43. s 10 steering column
  44. 00 S-10 2.2l
  45. Air Conditioner
  46. '87 Astro Van 15" Rims on my '98 S-10?
  47. 4L60E trans fluid help
  48. rear end
  49. 94 chev s10 pu 4x4 5sp 4.3l abs LT
  50. Idle Air Control on 99'
  51. 95 dies about half throttle
  52. 89 s10 4.3l auto to a 2.8l standard
  53. '85 S-10 make-over
  54. heating problem plz help
  55. Turn Signals
  56. 85 s-10
  57. 2001 S10 Won't start
  58. E-Brake sticking
  59. 93 2.5 liter grinding third gear
  60. Carb............
  61. why does the fuse keep popping...
  62. Headlight troubles....
  63. Fuel Pump
  64. NEW to American Muscle... please help
  65. 99 2.2 S-10 2WD Brakes, front end
  66. Flickering airbag light!
  67. 2002 Zr2
  68. Air Conditioner Fan
  69. Door Won't Open on my 94 S10
  70. 2.5 to 4.3 swap
  71. 2002 ZR2 4x4 Problems...Stuck in 4-high?
  72. Stupid question >.>
  73. Best size tire for 20x8.5 Rim for DD s-10?
  74. Best size tire for 20x8.5 Rim for DD s-10?
  75. Rear main oil seal
  76. 00 Chevy S-10 2.2L low oil pressure
  77. Rebuild kit
  78. Oil Question
  79. bleeding clutch system
  80. 90 P/U - Head Gasket
  81. Diasabling Auto Headlights
  82. 2001 S10 Chevrolet Pickup
  83. aftermarket air cleaner
  84. Idle speed?
  85. ATF fluid level check-This doesn't make sense!
  86. no spark -96 S10 4.3L 200K miles
  87. 1993 Chevrolet S10 Engine 4.3(V6)
  88. 97 S-10 heater control switch problem
  89. 01 S-10 automatic trans-Should this be changed?
  90. What does your oil pressure run at?
  91. 02 ZR2 transfer case clunk
  92. Wobbly straight steering column-non tilt
  93. 3rd door adjustments
  94. Just need a little direction in removing the alternator from my '99 zr2
  95. Just need a little direction in removing the alternator from my '99 zr2
  96. Why cant I get my PCV out?
  97. 1992 S10-2.5 Tbi / No Spark!!
  98. Running Extremely Rich
  99. wheel bearing or ball joint, maybe???
  100. no spark
  101. Noise Help 95 s-10
  102. 2000 S-10/2.2L/AC Alternator Removal Issues
  103. It Keeps Dieing!!!!
  104. looses power after driving a few miles
  105. 02 S10 oil filter
  106. power steering pump bracket
  107. 1995 Brake failure
  108. 4L60E problems
  109. ABS light comes on the speedometer quits
  110. Headlight Question
  111. 88 s10 electrical issue
  112. starter problems!!!!!!!!
  113. tail lights
  114. Need help BIG Tranny problem!
  115. Where Is The Ecm!!!!
  116. Tranny Swap
  117. '99 2.2 s10 rough and dirty
  118. MY 88 pickup
  119. pics of air filter?
  120. What's the box for?
  121. 4.3l vortec balancer shaft retainer bolts
  122. Stereo Removal in 97 S10
  123. 96 S10 stalls when braking
  124. Engine/trans Change
  125. What to look for when buying an s10
  126. 4.3 vortec balance shaft engine swap
  127. '91 S-10 GVW vs GVRW
  128. Testing a cat. converter
  129. Power Steering Pump Pulley
  130. To Paint or Not to Paint
  131. engine replacement for 2.2
  132. What are these connectors for?
  133. Stalling
  134. 4.3 engine serpinetine belt to regular belt question
  135. Old skool v8 air cleaner wingnut
  136. 4.3 Voortec Fuel Injection Setup
  137. Engine Swap
  138. 96 4.3 no fuel pressure
  139. 95 S10 Ball joints
  140. Co$t of a 400 Small Block swap?
  141. Wide band or Narrow Band?
  142. Erratice Speedometer
  143. Slave/Master Cylinder connection
  144. Tiny Electrical Problem
  145. Fuel Level Sensor issue fixed
  146. Engine swap
  147. 92 long bed with bad u-Joint
  148. Possible heater core trouble ?
  149. 1999 Seats
  150. 1993 S-10 4.3L Starter Problem- ignition switch
  151. clutch problems
  152. 96 s-10 blend door actuator
  153. How to identify a replica Xtreme?
  154. somebody help me out here please with torque specs
  155. Vacuum Hose Routing
  156. 4L60e A/T compatibility
  157. brake rotor(caliper removal?
  158. engine swap
  159. rear diff
  160. automatic transmission problem in 2003 S-10
  161. 95 s-10 problems
  162. Help Quick!!!!!!
  163. 2001 S-10 ABS and BRAKE light problem
  164. i need a certified gm tech's help
  165. Turn Signal Indicator
  166. '86 S10 Body Mount.
  167. 02 S10 Ext Cab Advice
  168. Engine codes
  169. 1988 S-10 Service Engine Soon Light
  170. Something I've always wondered (about tires)
  171. 94 s-10 4.3tbi vortec Posi?
  172. code help
  173. s10 questions
  174. Need help with understanding CA emissions
  175. 1996 S10 Fuel Press. Tester ???
  176. 94 S-10 Will not hold timing
  177. 2003 s-10 emergency brake problem
  178. brake lights
  179. lift
  180. 1989 S10 Fuel Problem
  181. 03 S-10 error P0101 AND P0420
  182. Catalytic Converter Replacement
  183. please help
  184. S-10 Manual transmission capacity?
  185. 94 S-10 SS starting problem
  186. Questions about 4-wheel drive vehicles
  187. Door panel removal
  188. 91 S10 2WD 4.3L 173000mls
  189. Brake Rotors
  190. Squeaking coming from inside the dash?
  191. 1988 Chevrolet S10 Truck 2.5L Firing Order??
  192. Rear End
  193. 2001 S-10 2wd 4.3 V-6 cam specs?
  194. Oil Brands?
  195. 89 S10 4.3 neutral safety switch problem?
  196. gas in oil
  197. 93 Blazer fluid question
  198. quicker potential
  199. WANTED Las Vegas Air Bag Installer
  200. lowering
  201. '88 s10 popping sound front while in place
  202. Automatic floorshift for 97 s-10
  203. Question
  204. Please read!!!!
  205. How many screws on a 1991 s-10 trans
  206. When to replace timing belt
  207. 2000 S-10 ashtray installation
  208. Knocking in the tourque converter or trans
  209. Help with an 89 s10
  210. Where is the ecm on 89 chevy s10
  211. Will they ever recontinue production of the S10?
  212. HELP speedo not working
  213. 2000 S-10 Blower Motor
  214. Do all 2004 S10s have 4WD?
  215. 91 s-10 2.8 to 4.3 swap
  216. The hood won't open on my S10!
  217. Hall Effect Switch
  218. 93 S10 Engine?
  219. 2.2 to 4.3
  220. schreechin noise
  221. How much will a new coil pack cost?
  222. What do you guys think about this???(rollpan questions!)
  223. S10 problems?
  224. How much air do you keep in your tires?
  225. Can't find headlight relay
  226. studdering on accel. only after heating up
  227. S10 2WD lift kit?
  228. 96 s-10 headlights
  229. Tire Change
  230. replacing roller on a window regulator...
  231. What do you call the new S10's now?
  232. Question about the Quad Cab S10
  233. Can't relase spare tire, '91 S-10
  234. 98 S10 Location of ABS Control Modules and Sensors
  235. Throttle body gurus needed
  236. s10 frames
  237. 89 s10 blazer 4x4 engine trouble help
  238. 1991 S10 2.5 liter - Unkown Sensor
  239. What would you buy?
  240. How to move tensioner
  241. non replacable instrment cluster bulb??
  242. 1996 4.3 engine swap
  243. Radiator drain?
  244. Rocker Panel Kit
  245. 22's on a 2wd
  246. oils
  247. 1988 Chevrolet S10 Truck 2.8L Firing Order?? PLEASE HELP
  248. Not Sure
  249. need a new alternator
  250. What is a Pulse module and where does it go?
