View Full Version : S-10
- cold start problems
- S-10 transmission interchangeability?
- s-10 frame question....
- Need help with plug order on 4.3 cap
- Jammed access door
- 96 s-10 not starting - clicking noise
- 89 4.3L S10 Blazer performance
- V8 S-10
- Power window motor change on 2dr S10 '94
- a good lowering kit...
- ecotech????
- 2.8 s-10 stalling out
- Carb swap question on '85 2.8 V6
- slave cylinder?
- 94ss w please tell me how to adjust timing
- Fuel Pump Connected to brakes!?
- ECM B Fuse keeps blowing, engine won't run.
- 95 S10 Transmission removal
- 91 s10 body lift
- Replacing Bumper With Roll Pan...question
- 5-speed help
- Help!! 97 S-10 Not starting!!!
- always finding problems
- 95 s 10 complete front for sale
- Tune-up and upgrade info
- ZR2 tach
- Oil filter conversion question
- Cold Air Intake
- more advice needed...
- 95 s10..what shud i do first?
- can a cpi cause my truck not to start?
- door locks
- 2.2 intake and mileage
- 2003 keyless elect door locks
- 1999 Chev. S-10 Pickup 2.2 Liter
- Chevy Cyclone Picture
- 96 S-10 Ext cab back-up lights
- I sat there at a home depot for 22minutes
- ABS light @ high speeds
- towing S-10
- no power to ignition switch... HELP!!
- just purchased a 95 s10
- Compatibility?
- New Motor Wont Start
- Truck acts like it is starving for fuel
- High Idle
- tailgate stuck
- 2000 S-10 Flex-Fuel Fuel Pump
- Won't start...
- truck will not start
- 4.3 L Granatelli MAF Sensor
- A/c Squeals!
- 93 s-10 header dual exhaust problem
- Need Help
- Just Got 20's Now What??
- HELP- how to remove dist. rotor on 91 4-cyl
- engine stalling when turning right
- 350 swap
- Cat Converter
- 2.2L to 4.3L NEED INFO PLEASE!
- 2000 s-10 2.2L
- Rear End Pricing?
- xtreme fog lights
- Switching from 15" to 14" Rims
- 95 S10 with 65K miles for sale
- 88 s-10 2.8L bog down with map sensor plugged in
- bogging down
- Swap 96 S10 Ext. cab 2.2 a/t to 2000 4.3
- Need help
- Brake Pad Mount Bolts..
- 91' 2.5L- 40K miles- maintenance questions
- Bogging down on acceleration
- Pitman And Idler Arm Question
- 86 dash conversion
- leaking anti-freeze.. !! HELP !!
- Clutch and Pitman and Idler Arm
- ZR2 tach problem
- 91 S-10 Blazer Sport Troublecode 24...
- Crank Case Pressure High
- 91 S-10 No Fuel & No Spark
- Disc Brake Dragging
- Studdering at takeoff
- 97 zr2 manual tranmissions
- gas mixed eith my oil, egr
- 4x4 switch problem
- anti theft cd player code?
- Need to find the Oxygen Sensor wire
- truck making noises
- PS help needed!!
- 2003 s10 noise when on gas pedal
- Where is my diagnostic port??? help!!!
- battery draining out on s10
- 1986 s-10 erratic starting
- 2.2 head bolt sequence
- Adding an Air Conditioner unit
- want to swap motors
- S-10 Stalls when hot
- ZR2 aftermarket wheels?
- short throw shifter for 02 s10 v6
- s-10 quirks
- '86 Rims on a '98 S-10? Problems? 14" and 15"
- towing capacities
- Rewiring S-10
- two ?'s tach, and fuel system fault codes
- Bad signal to EGR Valve?
- 91 S-10 4.3 oil leak
- erratic fuel gauge
- 1989 Jimmy 4wd tranny swap
- Windshield Wiper Help
- key stuck in ignition
- rear end (camaro 2 blazer
- Vortec V6 heads
- '01 removing window crank (manual)
- S-10 tail light fuse
- tail gate malfunction
- 94 s-10 doesnt go past half tank gas
- instument panel illumination
- rear end
- carb - injection
- 89 high pedal on clutch 2.8L
- replacing leaking oil cooler lines
- 1995 S10 For Sale
- Wiper Motor Help
- a/c help
- swap of injection to carb need help
- Engine temp on 02 s-10
- 97 s10 clutch
- 1999 s-10 keyless install not originally equipped
- stuck in 4WD LO
- Weird clunk and humming
- 1985 S-10 Blazer
- engine block heater
- are all gm 93 4.3 liter the same?
- Sunroof on 93 s-10 stock?
- For Sale 98 Red S10 SS
- Need help please!!
- 2.8 Intake & Cam Mods
- my erratic startin S-10, is this a breed problem ya'll?
- shifting problems
- thinking fuel pump - Help
- quits when warm then won't start
- rear hatch on 95 s 10 blazer
- Ravens or Flowmasters?
- are these heads the same
- 91 motor?
- 2.2 head question
- window fuse keeps blowing
- cold starting problems
- Horn not working
- 2002 abs light comes on and off
- Weird Clunking Sounds
- 91 s10 headlights problems
- Chevy S-10 Multiple Personality Disorder
- 2003 extreme; towing limit
- 2.8 v6 to 2.5 4cyl swap
- A little help please...
- speedometer
- turn signal staying on and not blinking
- Looking for a computer
- 92 S10 truck bed, door & engine 4 sale
- '97 Chevy 2X2 S10 ABS and A/C Problem
- changing front end in '88 S10 Blazer 4x4
- S-10 V-8 Engine Swap HELP!!
- I need an ext. cab for 96 s-10
- ZQ8 Suspension
- 2000 Jimmy/Blazer/S10/Sonoma Supercharger
- 92 s/15 jimmy problem
- 350 or 4.3l??
- help with a bagged four link
- S-10 Rattle Noise
- 93 S-10 2.8 engine quits when idle for too long
- 4l60e auto trans wiring? what is it?
- ac problem
- cool s-10 for my son
- LT1 Conversion
- F/S 2000 2.2L w/ 25k miles
- '90 s10 wont start unless primed, already replaced fuel pump
- Which one is the fuel relay fuel?
- 1994 S10 wiring Digram
- Wiring harness differences?
- Rims too wide and rub against frame NEED HELP!!
- 94 s10 blazer 4.3cpi won't start
- 1998 S-10 Starter not engaging...HELP!!!!
- z28 wheels on s-10
- S-10 Xtreme Rims Wanted, Any other parts
- 31 inch tires on a 89 s10 blazer
- '97 s-10 2.2 alternator replacement
- s10 dash lights not on and won't start
- emergency brake wont stay engaged
- Vent lo-hi does not blow
- S10 Maint
- Oxygen Sensors and Transmissions - Please Help
- Need hoods for S-10's
- s-10 in north carolina
- Instructions For 94 S10 Keyless Entry
- '94 2.2 & '00 2.2 same?
- 95 s 10 wiring diagram????
- 95 s 10 dash pieces.....
- Seat Belts for 1971 S-10 Blazer
- Autometer Gauges
- Brakes, Groaning Noise
- engine swap
- throttle body spacer
- Starting
- 2001 S-10 What factory radios will fit?
- 1991 S-10 4.3L Fuel Injectors not working
- 1988 No power, harder to figure out then rubix cube
- Shifter Question
- 96 s-10, brake and tranny noise, turning radius question
- 95 S-10 Vortec basics needed
- New to the Domestics
- Will 15x8 rims fit on 1985 S10 4x4??
- How do I install a door with PW and PL?
- Flowmaster Dual Corner exits
- ZR2 mud flaps
- C5 rims on S10
- 95 S10 has fuel in oil
- 1989 4.3 s10 blazer forsale in CT
- TBI 2.8 won't start
- Rear window latch, 2000 S-10
- 98 4.3 Cranks but wont start
- Gmc Jimmy help
- Hydo's or Bags?
- S10 rear disc brake conversion
- Wipers
- Electric Speedometer Problems!!!
- 97 chevy blazer whinning noise from fuel tank area
- I'm still getting code 42
- lift and tires?
- Air filter/intake
- Tire Size???
- 92 S10 for sale $400
- firing order for 2.8 v6
- 1991 S-10 4.3L - Oil Problems?
- 95 dash upgrade will a 98+ Fit?
- 1991 2.5L 4 Cyl, eng prob
- IAT sensor
- no spark on 1997 4.3 s10
- Left signal faster than right
- need electrical help
- S-10 Warmup and Stall
- S10 2.2L BACK to the Drawing Board
- Would it be easy to make an S-10run a 11sec 1/4
- Rear Posi Stuck
- Sway Bar Urethane Bushings
- Having a little trouble with my s10, what to do?
- general car audio info
- 97 s10 4.3l x (won't start)
- '93 S-10 Blazer stalling:Need Help
- S-10 Xtreme Rims (Wanted to Buy)
