Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24
  1. 91 headlight switch problems
  2. Exhaust leak..AIR tube
  3. cap and rotor
  4. 1999 s10 auto trans wont shift unless let of the gas
  5. 1999-2004 S10 Automatic Transmission Fix
  6. Intake /exhaust systems
  7. 1/4 Mile for a 88' S-10 with a 350?
  8. vacuum lines
  9. 95 2.2L problem
  10. How many GM Techs are on here?
  11. jet computer chip
  12. third door
  13. Checking starter ring gear clearance on 99s10
  14. Major Water Leak S10 Blazer
  15. desperate for electrical help
  16. Spark Plug Gap!
  17. 86 s-10 parts
  18. Electrical Problems I Need Help With 92 S10
  19. 1992 s10 - 2.8 V6 - Wiper Motor ?
  20. 2002 S-10 Crew Cab nothing but trouble
  21. 1999 S10, 4.3 Fan Clutch Removal!! Help Please
  22. 4 barrel throttle body or should i just keep my 2 barrel
  23. posting pics
  24. 2000 S-10 rear axle seals
  25. Fuel Gauge
  26. Service Engine Light
  27. Why wont my s 10 Shift in 3rd gear
  28. Please read Thanks
  29. help with 99 s10
  30. Starting
  31. wheel fit question
  32. Why is my car revving high in 3rd gear
  33. heater blower
  34. Need Help, I'm out of Ideas....
  35. dim headlight
  36. S-10 ignition switch
  37. 97 s10 timing
  38. lifted 89 s10 blazer
  39. TBI problem on my 92 S10 Blazer?
  40. Pinion shims
  41. engine swap info needed
  42. 4.3 Rev's high when started
  43. 92 s10 starter problems
  44. Air intakes & power chips on ebay??
  45. Halp !!
  46. Blowing fuse/no dash lights
  47. 1994 S10 Heater
  48. 4.3 TBI to 4.3Vortech Swap?
  49. 1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!!
  50. 96 S-10 coolant leak...
  51. buzzing noise coming from fuel pump
  52. 95 S-10, Brake Master Cylinder Failure or Not?
  53. Wiring for brake light on cap for '98 S-10
  54. fuel milelage
  55. is it worth it?
  56. 2000 S-10 stuck on "vent"
  57. anyone here of this sim turbo???
  58. its cheaper question
  59. How do I replace the belt tensioner
  60. 2000 S10 Wiring for Alarm System
  61. 2000 S10 Cigarette Lighter
  62. timing
  63. Stereo/Lighter Fuse?
  64. 83 S10 4x4 4Sale
  65. 94 losing oil pressure at idle
  66. diagram
  67. Chirping sound from engine or tranny.
  68. Temp Gauge?
  69. 4x4 won't work!!
  70. Coolant leak into passenger seat
  71. Oxygen sensor wiring
  72. wierd sound
  73. Wiper problems
  74. body panels
  75. 91 s-10 won't start
  76. turbo's
  77. Coolant leaks
  78. 89 S-10 Blazer 4.3 Rough Acceleration
  79. Riding the "bucking bronco"
  80. 2000 S10 - advice
  81. new steering column
  82. 98 2.2 auto transmission error code
  83. Air in brakes
  84. 91 S10 Blazer: mystery wire under center console?
  85. 95 2.2L Service Engine Soon
  86. Intake and Valve Covers
  87. Electrical
  88. corvette wheels?
  89. torque converter?
  90. 89 to 93 4.3 Swap HELP
  91. Rough starting...
  92. 1985 S-10 questions
  93. 01 ZR2 Problems
  94. 1992 Chevy S-10 A/C Problem
  95. xtreme s10 specs
  96. C6 Corvette Wheels
  97. 1995 Blazer idling
  98. lift kits
  99. Sagging rear springs
  100. Low rpm surge, then drop, then surge...
  101. O2 Sensor
  102. Online parts
  103. 1994 s-10 fuel odors
  104. for you v6 guys
  105. 89 s 10 blazer instrument cluster
  106. I thought i had seen it all "Until"
  107. mystery wire on 89 s 10 blazer
  108. 98 2.2 egr valve trans problem
  109. heatercore clogged how to
  110. water temp
  111. RPMs
  112. 97 S10 Pickup hard start during damp weather
  113. Disappearing Anit-Freeze
  114. New Clutch Install ????
  115. Reprograming 4.3 ecm chip
  116. rattling under dash
  117. 2.2 to 4.3 swap?
  118. how to get "service engine" codes
  119. want to trade for s 10 truck
  120. doors
  121. overhead console malfunctioning
  122. Check engine light stops cranking only when cold
  123. No Brakes
  124. 3 question
  125. 96 s10 heat not working
  126. Electrical problem affects tran (safety mode)
  127. AL's header for sale
  128. 700r4 auto tran.
  129. 1994 S-10 Lift Kits?
  130. 1989 S-10 Power Widow Relay Location ??
  131. '95 S-10 Dash Removal
  132. bucket seats
  133. 85 S-10 dies after shifting
  134. 89 4.3L Auto trans Timing
  135. 1988 s-10 2.8l oil leak
  136. dash convertions?
  137. 4.3 Wanted
  138. Engine Swap: 2.8L to 4.3L
  139. 91 s10 hesitation and jerking
  140. suspension clicks
  141. Electric Superchargers
  142. 1998 S-10 Blazer won't start
  143. tires!!
  144. Hot (temp) front wheels
  145. not enough power
  146. Spoiler?
  147. knocking noise on cold start-up 99 4cyl.
  148. headlight relay?
  149. 91 s10 blazer 4.3 tbi hard to start and more....
  150. Clutch
  151. transmission questions (94 not 92 S10 SS 2.2L)
  152. 2002 S-10 service engine soon light on
  153. 1992 S 10 runs like crap !!!
  154. 92 Ss 2.2l
  155. Cat Converter
  156. 95 S-10 Buzzer Alarm
  157. '92 Sonoma GT - Rough idle, running rich, 32, 43, 45 codes
  158. Oil Pressure? 95 S-10, 2.2, 5spd ~125k
  159. solid t-bar mounts
  160. 94 S-10 Blazer
  161. 91 s10 blazer suspension lift kits?
  162. Replacing Ball joints 98 2WD
  163. Heavy Vibration
  164. Oil Pressure? 95 S-10, 2.2, 5spd ~125k
  165. 2000 Chevy S-10 Extreme!!!!!!!!!For Sale
  166. Changing the tire size might screw up the computer on my '98 S-10?
  167. hydraulic clutch HELP?
  168. Muffler
  169. 4.3 CMFI or CPI or VOrtec
  170. Need your help 91 s10
  171. engine power loss - intermittent hesitation
  172. This one hose....
  173. S-10 horsepower
  174. Steering Column
  175. oil fuel pump switch
  176. 1st gen u-joint replacement
  177. 85 s-10 lift
  178. 95 S10 Air Bag Light / Fixed??
  179. turbo kit for 2.2 s-10
  180. no power to fuel pump
  181. 92 s-15 4x4 wheel bearings
  182. 1998 S-10 Reverse Lights Not Working
  183. s10 for sale
  184. v8 swap
  185. Need advice
  186. Disabling Theft-deterrent on stereo
  187. 3 inch body lift
  188. 91 s10 wont shift into 4 hi or low
  189. New Fogs ????
  190. 1995 Blazer S10 - Fuel Problem
  191. 98 S10 windshield wiper trouble
  192. runnin rich
  193. doors
  194. egr valve gasket w/screen!
  195. ProCharger P1SC will she fit?
  196. Need help installing aftermarket air dam
  197. Fuel Managment.. NEED HELP!!!!!
  198. what octane are you guys using? pollinput goin
  199. subs
  200. Oil
  201. 85 s10 starter repair
  202. Speedometer swap in a '92?
  203. Help!! '98 2.2L S10
  204. S-10 2.2 four cyl. same as Buick 2.2?
  205. Headlights?
  206. Serpentine Belt
  207. Added Hp on 4cylinder..
  208. headers
  209. 4.3l swap, performance??
  210. i need a good part site
  211. 96 S10 LS Headlight Problem
  212. Solid axel 2wd-4wd coversion & 350 swap
  213. S-10 not starting after long storage
  214. 92 4.3 rough running gas smell
  215. Chirping noise from rear
  216. S-10/Sonoma Body Kits??
  217. 90 S10. Clutch Bleeding Problems.
  218. ABS and Emergency Brake Light
  219. 2.5 to 2.8 swap
  220. cant get cable out need help!
  221. i need help with my 94 s10 4speed
  222. 1985 S10 Pickup Brakes
  223. whining noise
  224. can someone help me
  225. 1989 s10 4 cyclinder - motor not running smoothly
  226. changing motors
  227. 4.3 Vortec for sale. and many more parts if interested
  228. How do you get a pic on here?
  229. Synthetic Oil????
  230. Looking to sell or trade my 2001 s-dime for.....
  231. need a part...
  232. chevy s-10
  233. maintance
  234. Vibration
  235. 4.3 motor problems
  236. Tires rubbing
  237. 1993 S-10 Blazer 4X4 Will Be Missed But Need To Sell ASAP
  238. Hard Starting 4.3L Vortec 1993 S10 Blazer.
  239. Reliability Of 1999- 4cyl
  240. wierd vibe
  241. Choke will not set
  242. where is the fuel filter
  243. Dash LEDs don't work.
  244. fuel filter
  245. Have you replaced your PCV Valve Lately?
  246. how good is the s10
  247. Bar's Radiator Stop Leak... would you suggest?
  248. 96 exhaust
  249. Valvoline blew out my heater core!!!
  250. anyone have 0-60 and 1/4 mile times for the s10?
