Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24
  1. Cutting out ( shutting down )....
  2. Newborns Nightmear
  3. 1995 S-10 2.2 L Rough Starts
  4. cricket noise
  5. engine noise
  6. Thinking of buying a used S-10
  7. 2.2 vs. 2200 swaping questions
  8. Fault codes
  9. 1994 S10 4.3 Liter Fuel Pump Staying on after ignition turned off
  10. aftrmarkt lighting
  11. Help
  12. wipers broken.
  13. Heater
  14. low fuel indicator light
  15. replacing starter in 92 S-10 p-up 4x2
  16. Fuel Flow Problems
  17. squeek
  18. ZR2 to be or not to be?
  19. 98 2.2L Compatibility
  20. Easy S-10 engine swap
  21. Blazer transfer case questions
  22. 1999 2.2L Loss in Fuel economy
  23. 89 s-10 4.3 no start
  24. Tail lights not working
  25. help 87 2.8 fire order
  26. help 87 2.8 fire order
  27. Speedometer/Tachometer
  28. 94 s-10 trouble starting lopes while idling
  29. Parisienne, 1985 ?
  30. VSS Buffer for Speedometer on 92 Blazer
  31. Replacing stock air filter assy
  32. Misfire, loss of power
  33. 4x4 Transfer case Questions
  34. heat problem...heater core or blend door??
  35. 96 wont start
  36. 4x4 S10 Blazer What Transmission
  37. why the need to do a fluch..when switchin to synthetic?>?
  38. HEATER CORE CHANGE/93 S10 W/ac
  39. vehicle emissions inspections
  40. S10 having trouble passing Smog
  41. 4.3 TBI to Carb.... Possible?
  42. data collecting recorders
  43. stereo installation
  44. subs in a standard cab
  45. 96 S-10 Rear Axel Swa[p
  46. How do i align this door?
  47. 4x4 Problems
  48. fuel gauge problem, help
  49. 1984 S-10 Blazer cutting out.....
  50. questions for a certified gm technicion
  51. '91 usually fast and responsive, but slow today
  52. Rough running S-10 4.3 4x4
  53. 350 S-10 Blazer Dyno Results
  54. new to this and comp dum need help
  55. inst , dome light solution 89 S10 blazer
  56. Firing order
  57. if you have a pre 94 s10..go get sylvania silver star headlights!!!
  58. Top Gun
  59. 94 s-10 engine problems
  60. exterior door handle replacemant
  61. lucas? products......what do u think about them?
  62. air intake duct work
  63. Lifting
  64. subzero temps and 93 s-10 wont start
  65. Fan for heater will only work on level 3??
  66. Rear gate lock inop!
  67. Gauge Panel
  68. High output alternator
  69. Choke Problem...
  70. New rear gasket is leaking
  71. 95 s 10 blazer won't start
  72. I pushed the door latch closed w/ the door open. Now I can't close the door
  73. got bar's?
  74. 1986 s-10 question
  75. 4x4 problem
  76. nothing is safe or secure anymore
  77. 91 S-10 P/U transmission fluid leak
  78. another question
  79. Front Transfere Case Leaking '86 S-10 Blazer
  80. exhaust
  81. s-10 price
  82. 95 s10 zr2 service engine soon light
  83. 4sale/parts needed
  84. custom exhaust?
  85. lift?
  86. numerous problems with my S10
  87. 1999 S-10 2.2L starting problems
  88. 91 S10 blazer 4.3 engine floods out
  89. 99 s10 pu/ speaker questions
  90. oxygen sensors
  91. 92 S-10 Blazer Still Not Starting
  92. Cd stuck in aftermarket receiver
  93. '89 Blazer Heater Hoses
  94. spindles?
  95. question
  96. 2000 Chevy S-10 4x4 High-Pitched Electronic Sound
  97. 94 s-10 blazer hard to start but runs fine once running
  98. Voltage Problem Need Help!!!!!!!!
  99. help.. fuel pump relay location
  100. pic of wiring scamatics for 95 s-10
  101. 87 s10 long bed 56734.4 original fuel problem
  102. ignition switch
  103. How to remove front plastic dash. 1998 S10
  104. V8 Conversion Front Coil Springs Needed
  105. Im an idiot
  106. Power door locks
  107. heater prob.
  108. fuel pump 91 s10
  109. Suspension Lift
  110. 4wheel drive problem, S10
  111. Hello All, a newbe here
  112. door Handle
  113. Vaccume location
  114. odd question
  115. 4X4 problems
  116. need more motor
  117. high pitch grown...then engine light...more....help plzz.
  118. 1991 s10 blazer 4x4 eng. dies in rev/drive
  119. 92 S-10 Blazer Wont Start, Stumbling
  120. Installing Stepside Shaver kit
  121. high flow cat?
  122. Aftermarket parts for the 4.3?
  123. 4WD Problem '99 Blazer - Front not engaging (found reason)
  124. Auto Trans 2002 s 10
  125. 1986 S10 Blazer for sale - $500
  126. S-10 no oil pressure need HELP
  127. 15 inch but want 16 or even 18 inch
  128. 89 4.3 questions
  129. 93 S10 speaker size
  130. 97 Chevy S10 Heater/AC Control panel
  131. whats your winter..warmed up temp on the guage/ summer max temp?
  132. Blower Relay Switch Driving Me Nuts!!!
  133. Engine dianostic key
  134. Help ???
  135. Oil!!!!
  136. lowerig my truck
  137. subs in my truck bed
  138. rearend noise
  139. speakers
  140. body work
  141. dull headlights
  142. vacuum leak at defroster/temp controls cause rough idle?
  143. what's it worth?
  144. engine noise?
  145. Rebuilt motor or replace the rings/pistons
  146. 4.3L vortec
  147. no antifreeze
  148. things you want to know about the 4.3 past and present
  149. temp sensor
  150. Hesitation, stalling Please Help!!!
  151. tilt wheel loose
  152. seats in the bed
  153. saftey issue
  154. posi track Vs. limited slip
  155. digital speedometer
  156. 94 S10 Grill Wanted
  157. 97 Blazer instrument lights. On/Off... NO START
  158. check engine light
  159. Transmission fluid dumping in engind compartment
  160. Brake lights staying on
  161. Blown speakers
  162. power steering
  163. i want to sell how can i make it better?
  164. cranking fine, but occasionally doesn't start??
  165. fuel pump pressure
  166. what clear lense would you guys like to see?
  167. S10 Rear Swap Question
  168. Instrument cluster problems 2000 S 10 2.2 eng. speedometer not working
  169. wheel bearings...at what millage did u replace them?
  170. 1983 parts for sale
  171. removing door panels
  172. Starting Problems
  173. 1992 s10 Blazer speaker short
  174. 1992 s10 Blazer Instrument cluster lights
  175. 1992 s10 Blazer Vaccum leak
  176. 99 Blazer s10 4x4 help
  177. i do not have luck with door handles.
  178. Oil Fill Tube
  179. ecm
  180. rpm meters question
  181. Lifter noise
  182. Vortec turbo charged
  183. will not start!!!
  184. speedometer
  185. need help!!!
  186. fuel pump??
  187. transmission fluid
  188. Amp to factory stero hookup
  189. rear
  190. lowered painted 1985 chevy s-10 pickup for sale
  191. Don't know where to mount subs
  192. Seats
  193. door hinges
  194. S-10 Blazer warms, surges and stalls
  195. Four wheel drive problem
  196. 94 4.6 no start - Experience, please?
  197. Help Please
  198. S10 Cruise Control Blinker Switch Assembly
  199. low oil pressure???
  200. 4wheel drive
  201. a few questions
  202. 99 S10 4x4 problems HELP
  203. my poor truck...
  204. oil sending unit? & lean exhaust code?
  205. No heat!
  206. How interchangeable are 4.3/vortec parts?
  207. Good Shocks????
  208. 98 S-10: Emissions - SES Lamp ON/DTC P0420 Set
  209. 1996 2.2l fuel pump????
  210. brake and blinker problems
  211. drifting
  212. cant switch vent
  213. front end of my s-10 blazer
  214. Front End Generation Swap ???
  215. 91 S10 Heater Core
  216. steering shock absorber
  217. frequent no-start when cold
  218. think outside the box
  219. Engine dies when lights turned on!
  220. speaker problems
  221. Fusible Links to Solenoid?
  222. Drl On 99 Chevy S10 2.2
  223. removal of door panel
  224. clunk/rattle in drivetrain
  225. wiper relay?
  226. Again a nightmare with my S10
  227. dimmer install
  228. Fire order
  229. truck not always starting
  230. 91 s10 stalls at idle
  231. 1989 S-10 Blazer Starting/Electrical Issues
  232. 84 upgrades?
  233. tires and tilting and sorts
  234. odd suspension? brake? differential? problem
  235. installing sun roof
  236. Extreme gets wheel hop
  237. Turn signal assembley switch
  238. Get some bass for your buck
  239. pin out for checking error codes
  240. IAC valve? '97 S-10
  241. Cleaning EGR on 95 4.3L 4x4
  242. bell howsing question
  243. 2.8 stalls after you take your foot off the brake
  244. Want to add a sub what will fit
  245. S10 making a ticking noise.
  246. Can it cut it? 4l60e with a v8?
  247. help please!!!!!!!!!
  248. TCV cable
  249. 4x4 not shifting back to 2hi...
  250. remove wiper from shaft 98 S10
