Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24
  1. Does anyone else have this problem?
  2. 327, 350, or 383 in S10?
  3. 2.8 vs a 4.3
  4. K&N Air Filter on my '87 S-10 Blazer
  5. Ticking Noise/Timing Belt
  6. turn signal tempo
  7. clanking noise missing 2.8L
  8. brake fluid leak
  9. '94 ESC Sensor
  10. Fuel issue with 1996 4.3
  11. Light Problem
  12. Thermostat Installation on 91 S-10 w/ 2.8L V6
  13. anyone heard of this before?!
  14. Headlights going CRAZY!!!
  15. Gas Tank
  16. Search Before You Ask Questions!
  17. Turn signal/headlight problem
  18. S-10 & MPG
  19. U Joints
  20. What's the difference between an S10 and an S15?
  21. 3.4 what is it?
  22. Keyless Entry Wiring
  23. 88 s-10 no start
  24. 2003 S-10 Auxilary Audio?
  25. S10 V8 swap Fuel line Mods
  26. Electrical, any ideas?
  27. Here we go again HELP
  28. Wheels and Tires on stock 87 s-10
  29. Gearing and HP
  30. 350 swap
  31. Electric fuel pump for carbed 2.8L
  32. where can find cargo area retractable shade
  33. 1994 S-10 4X4 with Vortec Engine Overheating
  34. 87 s-10 blazer vibration plus fuel smell
  35. My S10 Sob Story...
  36. e-brake light stuck on???
  37. 91 S-10 Heater
  38. Engine Junk - Need Help
  39. 4.3 swap
  40. S10 with no battery power
  41. About body lift 92 S-10 4 x 4
  42. Are older S10s geared lower?
  43. 95-s10 with new problems
  44. what else can be dont to a 93 vortec...internal parts?
  45. Spare tire carrier
  46. Ticking noise in rear
  47. rotten s-10
  48. rotten egg/burning smell
  49. cheap and easy lowering kit
  50. 350 Big-block in S10?
  51. Long Crank?
  52. trying to put a carburetor on 2.2
  53. paint
  54. Relay switch for rear defogger?
  55. vacuum lines?
  56. electrical B.S. Any ideas anyone?
  57. glasspack on a 4cyl
  58. 97 Blazer Alternator/Dash/Running Light Fuse Problem
  59. 2001 S-10 4.3l Rotates, But Wont Start
  60. 93 S10 blazer is crapin out on me
  61. Battery idiot light makin me feel like an idiot
  62. Common problems for a 1993 S-10
  63. front axle????
  64. Engine Blew with only 318k
  65. Remote distance
  66. distributor end play 94 s-10 vortech
  67. is it normal for the fuel pump to make a whinny noise?
  68. No eganging front axel in 4x4
  69. backfire through intake
  70. sanding
  71. Ignition key cylinder problems
  72. How many O2 sensors?
  73. Windshield wiper fluid
  74. 89 s-10 cutting out
  75. electrical problems
  76. stripped windsheild wiper arm
  77. Gas In My Oil!!!
  78. Temp Gauge
  79. 87 2.8 identification
  80. msd6 box on a v6
  81. Disc Brake Conversion
  82. third break light and guage cluster on 98 s 10
  83. lowering kit
  84. speaker ohm settings
  85. side window installation
  86. Front end asselmbly???
  87. power problem with 4.3
  88. 4x4 belltech s10 lowering kit question
  89. the v6 s 10 a few questions
  90. need help ASAP!!
  91. Gauge Panel
  92. New battery for '91
  93. 1990 S10 brake light stays on
  94. how long do the timming chains last..on average?
  95. Carb
  96. 91 S10 rear lighting problem
  97. rocker arm ratio's 98' 60 degree 4.3l csmpfi s-10
  98. passanger window help
  99. Home made lift kit?
  100. s-10 capacities
  101. 60 K maintenance 2001 2.2L
  102. Redoing Interior
  103. Redoing Interior
  104. 2.8l to 4.3l swap question
  105. V-8 into a 95' s-10 blazer 4x4
  106. Steering Collumn Installation Help!!
  107. 1995 jimmy no rear brakes
  108. random vibration in 92 s10 blazer
  109. new exhaust help....
  110. Hey smokey041369 need your help (2.2 to 2.5)
  111. stripped crankshaft
  112. front axle
  113. Explosions thru the exhaust pipe,Help!
  114. 2002 crew cab eletrical problems
  115. Transmission or Clutch plate
  116. In need of a frame
  117. Transmission
  118. oil in intake manifold
  119. 4.3L vortec
  120. gm bucket seat ??
  121. engine swap
  122. getting a loan
  123. -02 Crewcab 4x4 tranny trouble
  124. Repacking Front Axle Bearings on 86 S-10 Blazer
  125. 84' S-10 with a 89' 4.3 motor swap
  126. Flashing Control Gauge Lights, S-10
  127. oil choice
  128. 2.2 S-10 motor swap gone wrong
  129. S10's live forever
  130. 97 S-10 ZR2 Brake and ABS lights flash
  131. tb cpi mpfi
  132. 93 s10 runs fine for a while then dies
  133. Trying to cure 2.2 head problem
  134. excessive idling time cause engine wear ?
  135. mirrors on e bay
  136. i dont know if this is against the rules...but....
  137. tsb 96-6e-101 PROM - Engine Spark Knock, Surge/High Cold Idle Speed
  138. 1996 S10 4.3L Vortec Lifter Question PLEASE!!
  139. Torsion bar mount repalcement 91 4.3L 4x4 Need advice...Thanks guys!!
  140. re&re radiator on 4.3L 4x4
  141. truck feels like it drops into gear
  142. Inspired to lift a little, need advise.
  143. 94 s-10 with cmfi TUNING VALVE
  144. a "weird" smell??
  145. Lopes then dies after starting
  146. disable governer
  147. convertable
  148. Block drain 2.2
  149. 92 Blazer Starting/Fuel Problem Fixed
  150. stripped nut and no bucket seats....please help
  151. 98 S10
  152. Engine Vibration!!!!!!
  153. Yet another "check engine light".What's a good scanner
  154. v-8 powered s-10's & s-15's
  155. basic power
  156. Seat Belt Repair
  157. I require mass amounts of help!!!
  158. 99 How low can I go??
  159. 99 S-10 Power loss
  160. '00 transmission Probs
  161. 4 cylinder to a v6
  162. 85 to 93 grill??
  163. 94 s-10
  164. the all important question
  165. 91 S10 fuel pump problem
  166. oil line leak
  167. s-10 4cyl to v-6 swap
  168. pulley removal
  169. vibration damper removal?
  170. How much HP
  171. 92 S-10 4x4 oil filter housing
  172. 94 s-10 with cmfi
  173. oil pressure sensor
  174. 1st cig lighter then radio died
  175. moter swap questions
  176. s-10 4 cyl to v-6 swap
  177. What is tbc circuit? Battery draw
  178. Instrument Cluster Swap Problem
  179. Chevy S-10 L4 modifications
  180. tranny & engine stopleak known to work ?
  181. '97 Blazer shiftlever brake interlock.
  182. fast idle
  183. blazerLT a question for you
  184. 2.2L s-10 turbo
  185. 94 blazer rubbing
  186. Value of '91 S-10
  187. amp installation
  188. 1991 Chevrolet S-10 loss of power/rough engine idle
  189. vaccum lines
  190. Oil Filters
  191. heater core
  192. How do you take the cat off of an 83 2.8L?
  193. Annoying noise!!
  194. 94 blazer vortech vacuum line diagram
  195. '88 S10 2.8 V6 Sputters and quits often.
  196. Draw on battery
  197. nv1500 in a 2.2 how do i get the top bolts?
  198. Need 83+ S10 Passenger Window
  199. Buying a 1992 S-10
  200. door locks are going crazy
  201. Buying an s-10 which is better for me
  202. 4.3L Motor Swap , rough Idle after heats up
  203. s-10 motor swap
  204. Flipper Door Cowl Induction Hood
  205. rough then fast idle during cold starts
  206. timing chain
  207. S-10 rear axle
  208. Slave Cylinder line - How does it come off?
  209. heater problems 305
  210. 1989 S-10 Keyless entry installation instructions
  211. Need Help Horn won't honk
  212. Secondary Air Injection System Malfunction (code P-0410) PLEASE HELP
  213. s10 4wd not engaging
  214. s10 tbi rough on start
  215. 5speed bell housing bolts?
  216. 1st gen lift
  217. Steering/suspension delima
  218. head lights
  219. Clutch swap
  220. Clutch swap
  221. torsion bar mounts '914x4
  222. 98 2.2L 4cyl noise
  223. pre 94//s10 cargo cover ? any info?
  224. 4.3 vortec 4x4 engine / fuel issue
  225. Gas Tank....
  226. Auto->Man swap
  227. leaking oil
  228. 2.2 to 4.3 need help
  229. 98 S-10 2.2 4cyl Head/egr Question
  230. squeaky
  231. S10 4cyl. Plugs
  232. 1997 S-10 4.3 4X4 Starting Problems
  233. clacking noise
  234. s10 rear brakes not working
  235. 1988 s-10 blazer with 4.3 tbi won't crank
  236. Tach Problems
  237. '88 chev blazer s-10 2.8
  238. Torsion Lift... now needs repairs?!?!
  239. Acceleration Problems
  240. DRL problem - Headlamps
  241. lifter noises
  242. 94 S-10 Hrad to up shift from 2nd to 1st
  243. oil pressure sending unit
  244. wont turn back
  245. saggin
  246. What do you think ? (big pictures)
  247. key will not turn
  248. 89 Chevy S10 torque specs
  249. oxygen sensor
  250. 92 S-10 oil gauge reads low
