View Full Version : S-10
- Tail lights not working
- help 87 2.8 fire order
- Speedometer/Tachometer
- 94 s-10 trouble starting lopes while idling
- Parisienne, 1985 ?
- VSS Buffer for Speedometer on 92 Blazer
- Replacing stock air filter assy
- Misfire, loss of power
- 4x4 Transfer case Questions
- heat problem...heater core or blend door??
- 96 wont start
- 4x4 S10 Blazer What Transmission
- why the need to do a fluch..when switchin to synthetic?>?
- HEATER CORE CHANGE/93 S10 W/ac
- vehicle emissions inspections
- S10 having trouble passing Smog
- 4.3 TBI to Carb.... Possible?
- data collecting recorders
- stereo installation
- subs in a standard cab
- 96 S-10 Rear Axel Swa[p
- How do i align this door?
- 4x4 Problems
- fuel gauge problem, help
- 1984 S-10 Blazer cutting out.....
- questions for a certified gm technicion
- '91 usually fast and responsive, but slow today
- Rough running S-10 4.3 4x4
- 350 S-10 Blazer Dyno Results
- new to this and comp dum need help
- inst , dome light solution 89 S10 blazer
- Firing order
- if you have a pre 94 s10..go get sylvania silver star headlights!!!
- Top Gun
- 94 s-10 engine problems
- exterior door handle replacemant
- lucas? products......what do u think about them?
- air intake duct work
- Lifting
- subzero temps and 93 s-10 wont start
- Fan for heater will only work on level 3??
- Rear gate lock inop!
- Gauge Panel
- High output alternator
- Choke Problem...
- New rear gasket is leaking
- 95 s 10 blazer won't start
- I pushed the door latch closed w/ the door open. Now I can't close the door
- got bar's?
- 1986 s-10 question
- 4x4 problem
- nothing is safe or secure anymore
- 91 S-10 P/U transmission fluid leak
- another question
- Front Transfere Case Leaking '86 S-10 Blazer
- exhaust
- s-10 price
- 95 s10 zr2 service engine soon light
- 4sale/parts needed
- custom exhaust?
- lift?
- numerous problems with my S10
- 1999 S-10 2.2L starting problems
- 91 S10 blazer 4.3 engine floods out
- 99 s10 pu/ speaker questions
- oxygen sensors
- 92 S-10 Blazer Still Not Starting
- Cd stuck in aftermarket receiver
- '89 Blazer Heater Hoses
- spindles?
- question
- 2000 Chevy S-10 4x4 High-Pitched Electronic Sound
- 94 s-10 blazer hard to start but runs fine once running
- Voltage Problem Need Help!!!!!!!!
- help.. fuel pump relay location
- pic of wiring scamatics for 95 s-10
- 87 s10 long bed 56734.4 original fuel problem
- ignition switch
- How to remove front plastic dash. 1998 S10
- V8 Conversion Front Coil Springs Needed
- Im an idiot
- Power door locks
- heater prob.
- fuel pump 91 s10
- Suspension Lift
- 4wheel drive problem, S10
- Hello All, a newbe here
- door Handle
- Vaccume location
- odd question
- 4X4 problems
- need more motor
- high pitch grown...then engine light...more....help plzz.
- 1991 s10 blazer 4x4 eng. dies in rev/drive
- 92 S-10 Blazer Wont Start, Stumbling
- Installing Stepside Shaver kit
- high flow cat?
- Aftermarket parts for the 4.3?
- 4WD Problem '99 Blazer - Front not engaging (found reason)
- Auto Trans 2002 s 10
- 1986 S10 Blazer for sale - $500
- S-10 no oil pressure need HELP
- 15 inch but want 16 or even 18 inch
- 89 4.3 questions
- 93 S10 speaker size
- 97 Chevy S10 Heater/AC Control panel
- whats your winter..warmed up temp on the guage/ summer max temp?
- Blower Relay Switch Driving Me Nuts!!!
- Engine dianostic key
- Help ???
- Oil!!!!
- lowerig my truck
- subs in my truck bed
- rearend noise
- speakers
- body work
- dull headlights
- vacuum leak at defroster/temp controls cause rough idle?
- what's it worth?
- engine noise?
- Rebuilt motor or replace the rings/pistons
- 4.3L vortec
- no antifreeze
- things you want to know about the 4.3 past and present
- temp sensor
- Hesitation, stalling Please Help!!!
- tilt wheel loose
- seats in the bed
- saftey issue
- posi track Vs. limited slip
- digital speedometer
- 94 S10 Grill Wanted
- 97 Blazer instrument lights. On/Off... NO START
- check engine light
- Transmission fluid dumping in engind compartment
- Brake lights staying on
- Blown speakers
- power steering
- i want to sell how can i make it better?
- cranking fine, but occasionally doesn't start??
- fuel pump pressure
- what clear lense would you guys like to see?
- S10 Rear Swap Question
- Instrument cluster problems 2000 S 10 2.2 eng. speedometer not working
- wheel bearings...at what millage did u replace them?
- 1983 parts for sale
- removing door panels
- Starting Problems
- 1992 s10 Blazer speaker short
- 1992 s10 Blazer Instrument cluster lights
- 1992 s10 Blazer Vaccum leak
- 99 Blazer s10 4x4 help
- i do not have luck with door handles.
- Oil Fill Tube
- ecm
- rpm meters question
- Lifter noise
- Vortec turbo charged
- will not start!!!
- speedometer
- need help!!!
- fuel pump??
- transmission fluid
- Amp to factory stero hookup
- rear
- lowered painted 1985 chevy s-10 pickup for sale
- Don't know where to mount subs
- Seats
- door hinges
- S-10 Blazer warms, surges and stalls
- Four wheel drive problem
- 94 4.6 no start - Experience, please?
- Help Please
- S10 Cruise Control Blinker Switch Assembly
- low oil pressure???
- 4wheel drive
- a few questions
- 99 S10 4x4 problems HELP
- my poor truck...
- oil sending unit? & lean exhaust code?
- No heat!
- How interchangeable are 4.3/vortec parts?
- Good Shocks????
- 98 S-10: Emissions - SES Lamp ON/DTC P0420 Set
- 1996 2.2l fuel pump????
- brake and blinker problems
- drifting
- cant switch vent
- front end of my s-10 blazer
- Front End Generation Swap ???
- 91 S10 Heater Core
- steering shock absorber
- frequent no-start when cold
- think outside the box
- Engine dies when lights turned on!
- speaker problems
- Fusible Links to Solenoid?
- Drl On 99 Chevy S10 2.2
- removal of door panel
- clunk/rattle in drivetrain
- wiper relay?
- Again a nightmare with my S10
- dimmer install
- Fire order
- truck not always starting
- 91 s10 stalls at idle
- 1989 S-10 Blazer Starting/Electrical Issues
- 84 upgrades?
- tires and tilting and sorts
- odd suspension? brake? differential? problem
- installing sun roof
- Extreme gets wheel hop
- Turn signal assembley switch
- Get some bass for your buck
- pin out for checking error codes
- IAC valve? '97 S-10
- Cleaning EGR on 95 4.3L 4x4
- bell howsing question
- 2.8 stalls after you take your foot off the brake
- Want to add a sub what will fit
- S10 making a ticking noise.
- Can it cut it? 4l60e with a v8?
- help please!!!!!!!!!
- TCV cable
- 4x4 not shifting back to 2hi...
- remove wiper from shaft 98 S10
- 92 s-10 no fuel at injector
- hinge noise
- what tires should i get
- Idiot lights on dash....
- Got Electric Supercharger?
- Positive cable grnding to engine
- fuel pump not pumping93 s10 blazer
- Idiot Lights On Dash
- not getting any power to the new cd player
- chassis ground wire on harness
- Surge and ping
- Idling problems on '95 S10 4.3 Z
- 2001 s-10 dtc p1153 anyone have this problem?
- 93 S-10 Blzr the 4x4 wont work
- supercharged s-10 extreme
- removing radio and installing new one...few questions
- 86 S-10 dash lights
- Pictures of 1995 S-10 Engine
- Brake problems...
- engine problems 89 s-10 blazer
- Would like to motor swap
- Black Smoke...
- big problem need help really quick.
