Our Community is 705,000 Strong. Join Us.
View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 98 2.2 runs hot with AC
  2. Water level low
  3. Battery contacts corroded
  4. p0410
  5. s-10 rust repair
  6. 1997 s10 vent doesnt work A/c floor defrost...Info PLEASE
  7. "95" in Texas,and no "AIR"
  8. 95 in Texas,and no "AIR"
  9. brakes
  10. Fuel Pressure
  11. Changing 2000 chevrolet S-10 Pick-up Alternator
  12. 93 S10 Blazer heater core trouble.
  13. 93 S10 Blazer 4x4 problem (4WD problem)
  14. 89 4.3l problems
  15. will it work???
  16. Free hitch n' bumper
  17. Where can I get a Manual for a 2001 Chevy S-10?
  18. stumbled across this
  19. 1997 S10 transmission DTCs
  20. Rims?
  21. 89 S-10 4.3L V6 Problems
  22. Slave cylinder
  23. ABS problem
  24. Where does the O2 Sensor go
  25. 4.3 engine miss ??
  26. 1996 si stepside f/s
  27. 2003 S10 4.3 V6 Idle speed
  28. 3rd Brake light Melted
  29. 7.2 Liter in S10?
  30. How do you compare 'liters' with regular engine sizes?
  31. Will bigger tires cause your speedo meter to read differently?
  32. 2001 S10 Autotrans downspout washer leak
  33. engine cuts out under a load or when accellerating
  34. passengers air bag removal
  35. 92 s10 4wd ABS light on
  36. hot weather non starts
  37. Door Panel Removal on '86S-10 Blazer
  38. '88 S-10 Blazer, 2.8l Idler pully
  39. Need help removing drivers side airbag
  40. driveshaft
  41. motor swap question
  42. My s-10 just went up in flames!!! HELP!!!!
  43. stalling
  44. need some advice
  45. S-10 Idle
  46. '94 4 Cyl. Very slow, need speed
  47. fuel injector??
  48. machined Cam on a 99 s-10
  49. 96 S10 Reminder Tone Module
  50. should i make the purchase?
  51. engine troubles
  52. 95 S-10 suddenly running rough
  53. 1997 S10 weird Problem
  54. fuel capacity
  55. question for body worken guys
  56. transmission question about switching 91 transmission with an 88
  57. Can newer grill bolt in my '86 S10?
  58. 88 S-10 cranks/will not fire/has fuel & spark
  59. 90 s-10 Blazer Brakes
  60. 1992 s-10 blazer squeaky front axel
  61. Installing a 3/4 drop kit
  62. lifting an s-10
  63. Clutch issue
  64. 01 ext cab rear speaker ideas plus speaker box ideas
  65. 89 4.3L Throttle Body...Leeking by Injectors????
  66. s10 fan problems
  67. Locate PCV 2000 S 10 pick up 4 cycl
  68. What parts should I keep?
  69. Some More engine questions on my 94
  70. Question
  71. Another Quick Q... Gas gauge
  72. Been Meaning to ask... what's your MPG?
  73. ABS problem
  74. Instrument Panel Lights
  75. lifting a 00 2WD S10
  76. 1995 S-10 Speakers
  77. 4.3l questions
  78. rear axle squeeking
  79. 1988 s-10 blazer 2.8l 4wd, no fuel prime,no check engine lite
  80. Electrical driveability nightmare
  81. Know nothing...need help...94 s10....
  82. duel exhaust
  83. Pictures
  84. Wont Start
  85. need to replace fuel injector on 97 S10 2.2L
  86. cat converter 2.2 4.3 swap
  87. Surging w/No Check engine light
  88. Low Pressure Switch
  89. Question About Special Tools for Idler Arm Installation
  90. MAP And O2 Sensor
  91. 1996 Chevy S-10 4.3L
  92. rear disks ever stock?
  93. 2001 S-10 Security Light
  94. 95 S-10, manual trans. 5-speed
  95. whiney tranny
  96. 1998 s10 wiring diagram
  97. 355 swap with goodies..
  98. can i bake the drums??
  99. '94 S-10 Blazer Smokes from Defrost & Floor Vents
  100. Connecting a Laptop to my truck
  101. S-10 350 swap
  102. 85 S-10. Headlights, tail lights, horn, instrument lights and radio out.
  103. How do you tell if a fuel filter needs replacing?
  104. wont start
  105. 96 5-speed tranny locked between gears
  106. 94 s10 4.3l tbi black smoke
  107. truck bed seems loose?
  108. Excessive cranking
  109. Emissions Problems with my 94 ZR2
  110. Emissions Problems with my 94 ZR2
  111. No downlow power
  112. Open Diff. to Posi rear end
  113. IAC Vavle, how much should it move?
  114. hows the zr2 lifted
  115. '91 S10 Blazer - Alarm install questions
  116. Neon Light law
  117. speakers
  118. 98+ High beams and Lows, both on
  119. 1998 S-10 Heat doesn't turn off....and A/C doesn't work no more
  120. Strange starting problem
  121. 95 S10 in 4yrs 12-15 starters
  122. newbie here with some s10 questions
  123. 1986 S-10 GM Shop Manual
  124. '95 S10 Vortec v6 4.3 and '91 GMC v6 4.3 engine swap
  125. code p0140
  126. For Sale
  127. 2002 S-10 Performance Upgrade
  128. still wont start
  129. Question about the emergency lights
  130. Sub enclosure for ext cab(down firing) yeah or neah?
  131. CPI Parts
  132. Hey guys, can you help with an S10 that stalls out going down the road?
  133. fuel pump?
  134. reclining seat lever
  135. S10 Cranking problems-please help.
  136. How to get codes?
  137. help is nice let me know what you think
  138. 93 s10 blazer tranny problems
  139. do i need a new driveshaft??
  140. 2.2 overheating fan maybe?
  141. '93 S-10 Problems
  142. should i remove the bed
  143. Is valve tap bad?
  144. Engine swap
  145. Do I really need this fuel pump?
  146. S-15 check engine light
  147. s10 found
  148. s-10 back brakes lock up when get wet
  149. Fuel injector problem --HELP
  150. Coolant leak around 2nd left manifold bolt.
  151. fuel pump removal
  152. S10 making a quiet grinding noise
  153. 94 s10 blazer 4.3 vortec vin W
  154. 94 s10 blazer tranny shift adjustments?
  155. radio clock stays on, battery drains????
  156. transfer case?
  157. Do Anyone Know The Dimensions of....
  158. electric brake controller
  159. Gauge Lights
  160. tps question
  161. thermostat gauge
  162. Frozen Fuel Pump replacement
  163. i need a opinion on a motor
  164. leaning S-10
  165. Idiot Lites to Factory Gauges
  166. starter pinion sticking
  167. EGR Valve
  168. Where to check fuel pressure 94 s-10 tbi
  169. S-10 Blazer wiring problem
  170. Flexplate To Torque Converter
  171. 95ZR-2 fuel injection
  172. MAP Circuit low input.
  173. 1987 door panel removal
  174. Oil drain plug spins around but doesn't come off
  175. Question for the 4cyl owners
  176. power loss under acceleration
  177. what do i have?
  178. swap questions
  179. I does anyone have one?
  180. 98 with very strange problem
  181. Rattle noise in exhaust under load 98 S-10
  182. truck wont start
  183. Storing engines
  184. Check for broken timing chain
  185. '99 S-10, No Spark
  186. How to Set timming
  187. Missing wires at ECM. Help!!!
  188. Hissing Noise From Heater/AC Controls
  189. fusibile link
  190. New moter
  191. 91 2.5lt FPR
  192. full-size rearend on an s-10
  193. only getting 11mpg out of my 94 s-10 4.3tbi need help
  194. Odd problems.. Could use some advice quick
  195. Cant get carb off
  196. Sand blasting a rusty old 38 ...
  197. what to look for
  198. 94 s10 blazer alternator belt
  199. window problems!
  200. clutch proglems
  201. S-10 TBI Removal On The Fly
  202. sellin 94 s-10 blazer
  203. the new guy
  204. something squeeks
  205. Passenger Side Plugs Fouled
  206. my truck hesitates
  207. HELP! I Cant get the starter out of my 95' S-10
  208. water cylinder decarbonizing.. how much?
  209. s-10 xxtreme
  210. flywheel problems
  211. shift knob
  212. ignition
  213. Subs In Standard Cab Question
  214. s10 2.2 to 4.3 engine swap
  215. clear coat on black plastic....
  216. Center Console & Bucket Seats
  217. Won't start!
  218. is it egr valve???
  219. Grind Noise in Rear end when I accellerate
  220. S-15 4x4 stalling
  221. Code?
  222. Oil pressure gauge flipping out
  223. cam shaft
  224. 94 4.3 fuel problem??? HELP
  225. Exhaust smell in coolant
  226. Losing power
  227. vss to cable driven speedo
  228. 95 S-10 "Wierd" starting problem
  229. Any RWAL ABS brake gurus out there? (Long)
  230. Stuck in 4Lo
  231. 94 4cyl. auto no up shift
  232. grinding noise on acceleration
  233. Intermittent rough Idle below 1500 RPM HELP!
  234. 1993 S10 Radio Problem - Help
  235. tire question
  236. More Power! 4.3L
  237. Air Conditioner
  238. One of my many questions
  239. damage report
  240. all cylinders misfiring only a p0300 code !!help me!!
  241. Electrical issue - signals, hazards, brake lights, buzzer
  242. How do you take the overdrive off in an S10?
  243. Pontiac 350 and turbo 350 tranny
  244. 50-55 fuel pressure good or bad?
  245. Cab Corner Panels 1993 S10
  246. fuel pressure??
  247. 2000 S10 clutch fluid
  248. Replacement Of Oil Cooler Lines?
  249. clutch linkage
  250. 4.3 tbi to 4.3 cpi swap won't start
